Additional Resources:
Product Page
date
08/05/2022
page 1 of 8
SERIES: CP70 | DESCRIPTION: PELTIER MODULE
FEATURES
• arcTEC™ structure on select models
• solid state device
• precise temperature control
• quiet operation
MODEL
input
voltage1
input
current2
internal
resistance3
max
(Vdc)
max
(A)
typ
(Ω±10%)
CP70137
2.1
7.0
0.24
CP70237
3.8
7.0
0.42
CP70301537
4.2
7.0
0.48
CP703376
8.6
7.0
1.0
CP70437
15.4
7.0
1.75
55.0
6
Notes:
1. Maximum voltage at ΔT max and Th=27°C
2. Maximum current to achieve ΔT max
3. Measured by AC 4-terminal method at 25°C
4. Maximum heat absorbed at cold side occurs at Imax, Vmax, and ∆T=0°C
5. Maximum temperature difference occurs at Imax, Vmax, and Q=0W (ΔT max measured in a vacuum at 1.3 Pa)
6. Designed with arcTEC™ structure
cuidevices.com
output
Qmax4
Th=27°C
(W)
output
∆Tmax5
Th=50°C
(W)
Th=27°C
(°C)
Th=50°C
(°C)
7.5
8.3
68
75
13.6
15.1
68
75
15.4
17.1
68
75
31.0
34.6
70
77
60.5
70
77
Product Page
CUI DEVICES | SERIES: CP70 | DESCRIPTION: PELTIER MODULE
date 08/05/2022 | page 2 of 8
SPECIFICATIONS
parameter
conditions/description
min
solder melting temperature
connection between thermoelectric pairs
235
typ
units
°C
assembly compression
hot side plate
RoHS
max
1
MPa
80
°C
yes
MECHANICAL DRAWING
units: mm
MATERIAL
HOT SIDE
0.05
THICKNESS
COLD SIDE
0.05
96% AL2O3
wire leads
20 AWG
sealer
silicon rubber 703 RTV (between cold and
hot side plates)
joint cover
marking
P/N & S/N printed on cold side surface
7 3.0
Red (+)
WIDTH
COLD SIDE
Black (-)
LENGTH
100.0 5.0
MODEL NO.
LENGTH
(mm)
WIDTH
(mm)
THICKNESS
(mm)
CP70137
15 ±0.3
15 ±0.3
3.7 ±0.1
CP70237
20 ±0.3
20 ±0.3
3.7 ±0.1
CP70301537
30 ±0.3
15 ±0.3
3.7 ±0.1
1
CP70337
30 ±0.3
30 ±0.3
3.7 ±0.1
CP704371
40 ±0.3
40 ±0.3
3.7 ±0.1
Notes: 1. Wire lead strip length on models CP70337 & CP70437 is 10 ±3.0 mm.
cuidevices.com
PLATING
ceramic plate
tin
Product Page
date 08/05/2022 | page 3 of 8
CP70137 PERFORMANCE (Th=27°C)
Input Voltage (V)
7A
2.0
5.6 A
4.2 A
1.5
2.8 A
1.0
1.4 A
0.5
Heat Pumped, Q (W)
7A
5.6 A
6.0
4.2
4.0
A
2.8 A
1.4 A
2.0
60
50
40
30
ΔT=Th-Tc (°C)
CP70137 PERFORMANCE (Th=50°C)
Input Voltage (V)
7A
5.6 A
2.0
4.2 A
1.5
2.8 A
1.0
1.4 A
0.5
Heat Pumped, Q (W)
7A
8.0
5.6 A
A
4.2
6.0
2.8 A
4.0
1.4 A
2.0
60
50
40
ΔT=Th-Tc (°C)
cuidevices.com
30
Product Page
date 08/05/2022 | page 4 of 8
Input Voltage (V)
CP70237 PERFORMANCE (Th=27°C)
7A
4.0
5.6 A
3.0
4.2 A
2.8 A
2.0
1.4 A
1.0
Heat Pumped, Q (W)
7A
12
4.2
8.0
5.6 A
A
2.8 A
1.4 A
4.0
60
50
40
30
ΔT=Th-Tc (°C)
Input Voltage (V)
CP70237 PERFORMANCE (Th=50°C)
4.0
7A
5.6 A
4.2 A
3.0
2.8 A
2.0
1.4 A
1.0
Heat Pumped, Q (W)
5.6 A
16
7A
12
4.2
8.0
A
2.8 A
1.4 A
4.0
60
50
40
ΔT=Th-Tc (°C)
cuidevices.com
30
Product Page
date 08/05/2022 | page 5 of 8
Input Voltage (V)
CP70301537 PERFORMANCE (Th=27°C)
8.0
6.0
7A
4.0
5.6 A
4.2 A
2.8 A
2.0
1.4 A
Heat Pumped, Q (W)
5.6 A
16
7A
12
4.2
8.0
A
2.8 A
1.4 A
4.0
60
50
40
30
ΔT=Th-Tc (°C)
Input Voltage (V)
CP70301537 PERFORMANCE (Th=50°C)
8.0
6.0
7A
4.0
5.6 A
4.2 A
2.8 A
2.0
1.4 A
Heat Pumped, Q (W)
7A
16
5.6 A
A
4.2
12
2.8 A
8.0
1.4 A
4.0
60
50
40
ΔT=Th-Tc (°C)
cuidevices.com
30
Product Page
date 08/05/2022 | page 6 of 8
CP70337 PERFORMANCE (Th=27°C)
Input Voltage (V)
7A
8.0
5.6 A
4.2 A
6.0
2.8 A
4.0
1.4 A
2.0
Heat Pumped, Q (W)
7A
5.6 A
24
4.2 A
16
2.8 A
1.4 A
8.0
60
50
40
30
ΔT=Th-Tc (°C)
CP70337 PERFORMANCE (Th=50°C)
Input Voltage (V)
7A
5.6 A
8.0
4.2 A
6.0
2.8 A
4.0
1.4 A
2.0
Heat Pumped, Q (W)
7A
32
5.6 A
24
4.2 A
2.8 A
16
1.4 A
8.0
60
50
40
ΔT=Th-Tc (°C)
cuidevices.com
30
Product Page
date 08/05/2022 | page 7 of 8
Input Voltage (V)
CP70437 PERFORMANCE (Th=27°C)
7A
16
5.6 A
12
4.2 A
8.0
2.8 A
1.4 A
4.0
Heat Pumped, Q (W)
7A
5.6 A
4.2 A
2.8 A
40
1.4 A
60
50
40
30
ΔT=Th-Tc (°C)
CP70437 PERFORMANCE (Th=50°C)
Input Voltage (V)
7A
16
5.6 A
4.2 A
12
2.8 A
8.0
1.4 A
4.0
Heat Pumped, Q (W)
7A
60
5.6 A
4.2 A
40
2.8 A
1.4 A
60
50
40
ΔT=Th-Tc (°C)
cuidevices.com
30
Product Page
date 08/05/2022 | page 8 of 8
REVISION HISTORY
rev.
description
date
1.0
initial release
09/08/2016
1.01
changed models CP70337 & CP70437 to arcTEC™ structure
12/01/2017
1.02
changed thickness of CP70137, CP70237, CP70301537 models
09/19/2018
1.03
brand update
10/30/2019
1.04
logo, datasheet style update
08/05/2022
The revision history provided is for informational purposes only and is believed to be accurate.
CUI Devices offers a one (1) year limited warranty. Complete warranty information is listed on our website.
CUI Devices reserves the right to make changes to the product at any time without notice. Information provided by CUI Devices is believed to be accurate
and reliable. However, no responsibility is assumed by CUI Devices for its use, nor for any infringements of patents or other rights of third parties which may
result from its use.
CUI Devices products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A
critical component is any component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life
support device or system, or to affect its safety or effectiveness.
cuidevices.com
很抱歉,暂时无法提供与“CP70301537”相匹配的价格&库存,您可以联系我们找货
