Additional Resources:
Product Page
3D Model
date
08/05/2022
page 1 of 10
SERIES: CP35 | DESCRIPTION: PELTIER MODULE
FEATURES
• arcTEC™ structure on select models
• solid state device
• precise temperature control
• quiet operation
MODEL
input
voltage1
input
current2
internal
resistance3
max
(Vdc)
max
(A)
typ
(Ω±10%)
Th=27°C
(W)
Th=50°C
(W)
Th=27°C
(°C)
Th=50°C
(°C)
CP35147
2.1
3.5
0.44
3.9
4.3
68
75
CP35247
3.8
3.5
0.80
7.0
7.7
68
75
CP35301547
4.2
3.5
0.90
7.9
8.7
68
75
CP353476
8.6
3.5
1.93
16.0
17.8
70
77
CP353047
11.8
3.5
2.52
24.0
26.0
70
77
CP354476
15.4
3.5
3.3
29.0
32.0
70
77
24.1
3.5
5.17
49.0
53.0
70
77
6
CP354047
6
Notes:
1. Maximum voltage at ΔT max and Th=27°C
2. Maximum current to achieve ΔT max
3. Measured by AC 4-terminal method at 25°C
4. Maximum heat absorbed at cold side occurs at Imax, Vmax, and ∆T=0°C
5. Maximum temperature difference occurs at Imax, Vmax, and Q=0W (ΔT max measured in a vacuum at 1.3 Pa)
6. Designed with arcTEC™ structure.
cuidevices.com
output
Qmax4
output
∆Tmax5
Product Page
3D Model
CUI DEVICES | SERIES: CP35 | DESCRIPTION: PELTIER MODULE
date 08/05/2022 | page 2 of 10
SPECIFICATIONS
parameter
conditions/description
min
solder melting temperature
connection between thermoelectric pairs
CP35347, CP353047, CP35447, CP354047
all other models
235
138
typ
max
°C
°C
assembly compression
1
RoHS
units
MPa
yes
MECHANICAL DRAWING
units: mm
MATERIAL
HOT SIDE
0.05
THICKNESS
COLD SIDE
0.05
ceramic plate
96% AL2O3
wire leads
20 AWG
sealer
silicon rubber 703 RTV (between cold and
hot side plates)
joint cover
marking
P/N & S/N printed on cold side surface
7 3.0
Red (+)
WIDTH
COLD SIDE
Black (-)
LENGTH
100.0 5.0
MODEL NO.
LENGTH
(mm)
WIDTH
(mm)
THICKNESS
(mm)
CP35147
15 ±0.3
15 ±0.3
4.7 ±0.1
CP35247
20 ±0.3
20 ±0.3
4.7 ±0.1
CP35301547
30 ±0.3
15 ±0.3
4.7 ±0.1
CP353471
30 ±0.3
30 ±0.3
4.7 ±0.1
CP353047
30 ±0.3
30 ±0.3
4.7 ±0.1
CP35447
40 ±0.3
40 ±0.3
4.65 ±0.025
CP354047
40 ±0.3
40 ±0.3
4.7 ±0.1
Notes: 1. Wire lead strip length on model CP35347 is 10 ±3.0 mm.
cuidevices.com
PLATING
tin
Product Page
3D Model
date 08/05/2022 | page 3 of 10
Input Voltage (V)
CP35147 PERFORMANCE (Th=27°C)
3.5 A
2.0
2.8 A
2.1 A
1.5
1.4 A
1.0
0.7 A
0.5
Heat Pumped, Q (W)
3.5 A
2.8 A
A
2.1
1.4 A
3.0
2.0
0.7 A
1.0
60
50
40
30
ΔT=Th-Tc (°C)
CP35147 PERFORMANCE (Th=50°C)
Input Voltage (V)
3.5 A
2.8 A
2.0
2.1 A
1.5
1.4 A
1.0
0.7 A
0.5
Heat Pumped, Q (W)
3.5 A
2.8 A
A
2.1
4.0
3.0
1.4 A
2.0
0.7 A
1.0
60
50
40
ΔT=Th-Tc (°C)
cuidevices.com
30
Product Page
3D Model
date 08/05/2022 | page 4 of 10
Input Voltage (V)
CP35247 PERFORMANCE (Th=27°C)
3.5 A
4.0
2.8 A
2.1 A
1.4 A
2.0
0.7 A
Heat Pumped, Q (W)
6.0
A
2.8
2.1
1.4
4.0
A
A
A
0.7 A
2.0
60
50
40
30
ΔT=Th-Tc (°C)
Input Voltage (V)
CP35247 PERFORMANCE (Th=50°C)
4.0
3.5 A
2.8 A
2.1 A
1.4 A
2.0
0.7 A
Heat Pumped, Q (W)
A
2.8
6.0
A
2.1
1.4
4.0
A
A
0.7 A
2.0
60
50
40
ΔT=Th-Tc (°C)
cuidevices.com
30
Product Page
3D Model
date 08/05/2022 | page 5 of 10
Input Voltage (V)
CP35301547 PERFORMANCE (Th=27°C)
8.0
6.0
3.5 A
4.0
2.8 A
2.1 A
1.4 A
2.0
0.7 A
Heat Pumped, Q (W)
3.5 A 2.8 A
6.0
2.1
4.0
A
1.4 A
0.7 A
2.0
60
50
40
30
ΔT=Th-Tc (°C)
Input Voltage (V)
CP35301547 PERFORMANCE (Th=50°C)
8.0
6.0
3.5 A
2.8 A
4.0
2.1 A
1.4 A
2.0
0.7 A
Heat Pumped, Q (W)
3.5 A
8.0
2.8 A A
2.1
6.0
1.4 A
4.0
0.7 A
2.0
60
50
40
ΔT=Th-Tc (°C)
cuidevices.com
30
Product Page
3D Model
date 08/05/2022 | page 6 of 10
Input Voltage (V)
CP35347 PERFORMANCE (Th=27°C)
3.5 A
8.0
2.8 A
2.1 A
1.4 A
4.0
0.7 A
Heat Pumped, Q (W)
16
3.5
A
A
2.8
2.1
12
1.4
8.0
A
A
0.7 A
4.0
60
50
40
30
ΔT=Th-Tc (°C)
Heat Pumped, Q (W)
Input Voltage (V)
CP35347 PERFORMANCE (Th=50°C)
8.0
3.5 A
2.8 A
2.1 A
1.4 A
4.0
0.7 A
16
2.8
A
2.1
12
A
A
1.4
A
8.0
0.7 A
4.0
60
50
40
ΔT=Th-Tc (°C)
cuidevices.com
30
Product Page
3D Model
date 08/05/2022 | page 7 of 10
Input Voltage (V)
CP353047 PERFORMANCE (Th=27°C)
3.5 A
12
2.8 A
9.0
2.1 A
6.0
1.4 A
0.7 A
3.0
Heat Pumped, Q (W)
2.8 A
3.5 A
18
2.1
12
A
1.4 A
0.7 A
6.0
60
50
40
30
ΔT=Th-Tc (°C)
Input Voltage (V)
CP353047 PERFORMANCE (Th=50°C)
12
3.5 A
2.8 A
2.1 A
9.0
1.4 A
6.0
0.7 A
3.0
Heat Pumped, Q (W)
3.5 A
2.8 A
A
2.1
24
18
1.4 A
12
0.7 A
6.0
60
50
40
ΔT=Th-Tc (°C)
cuidevices.com
30
Product Page
3D Model
date 08/05/2022 | page 8 of 10
Input Voltage (V)
CP35447 PERFORMANCE (Th=27°C)
3.5 A
16
2.8 A
2.1 A
1.4 A
8.0
0.7 A
Heat Pumped, Q (W)
A
3.5
A
2.8
24
2.1
A
1.4
16
A
0.7 A
8.0
60
50
40
30
ΔT=Th-Tc (°C)
Input Voltage (V)
CP35447 PERFORMANCE (Th=50°C)
3.5 A
16
2.8 A
2.1 A
1.4 A
8.0
0.7 A
Heat Pumped, Q (W)
24
A
2.8
A
2.1
A
1.4
16
A
0.7 A
8.0
60
50
40
ΔT=Th-Tc (°C)
cuidevices.com
30
Product Page
3D Model
date 08/05/2022 | page 9 of 10
Input Voltage (V)
CP354047 PERFORMANCE (Th=27°C)
3.5 A
24
2.8 A
18
2.1 A
1.4 A
12
0.7 A
6.0
Heat Pumped, Q (W)
60
2.8 A
3.5 A
40
2.1 A
1.4 A
0.7 A
60
50
40
30
ΔT=Th-Tc (°C)
Input Voltage (V)
CP354047 PERFORMANCE (Th=50°C)
3.5 A
24
2.8 A
2.1 A
18
1.4 A
12
0.7 A
6.0
Heat Pumped, Q (W)
2.8 A
60
3.5 A
40
2.1 A
1.4 A
0.7 A
70
60
50
40
30
ΔT=Th-Tc (°C)
cuidevices.com
Product Page
3D Model
date 08/05/2022 | page 10 of 10
REVISION HISTORY
rev.
description
date
1.0
initial release
09/08/2016
1.01
changed models CP35347 & CP35447 to arcTEC™ structure
12/01/2017
1.02
added models CP353047 & CP354047, brand update
10/18/2019
logo, datasheet style update
08/05/2022
1.03
The revision history provided is for informational purposes only and is believed to be accurate.
CUI Devices offers a one (1) year limited warranty. Complete warranty information is listed on our website.
CUI Devices reserves the right to make changes to the product at any time without notice. Information provided by CUI Devices is believed to be accurate
and reliable. However, no responsibility is assumed by CUI Devices for its use, nor for any infringements of patents or other rights of third parties which may
result from its use.
CUI Devices products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A
critical component is any component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life
support device or system, or to affect its safety or effectiveness.
cuidevices.com
很抱歉,暂时无法提供与“CP35447”相匹配的价格&库存,您可以联系我们找货
