Additional Resources:
Product Page
date
08/05/2022
page 1 of 4
SERIES: CP28-2 | DESCRIPTION: PELTIER MODULE
FEATURES
• solid state device
• 2-stage cooler
• precise temperature control
• quiet operation
MODEL
CP28372-2
Notes:
input
voltage1
input
current2
output
Qmax3
max
(Vdc)
max
(A)
Th=27°C
(W)
Th=50°C
(W)
Th=27°C
(°C)
Th=50°C
(°C)
15.7
2.8
8.7
9.6
95
105
1. Maximum voltage at ΔT max and Th=27°C
2. Maximum current to achieve ΔT max
3. Maximum heat absorbed at cold side occurs at Imax, Vmax, and ∆T=0°C
4. Maximum temperature difference occurs at Imax, Vmax, and Q=0W (ΔT max measured in a vacuum at 1.3 Pa)
PART NUMBER KEY
CP28 X 72-2
Base Number
Length x Width:
3 = 30 x 30 mm
cuidevices.com
output
∆Tmax4
Product Page
CUI DEVICES | SERIES: CP28-2 | DESCRIPTION: PELTIER MODULE
date 08/05/2022 | page 2 of 4
SPECIFICATIONS
parameter
conditions/description
internal resistance1
solder melting temperature
connection between thermoelectric pairs
min
typ
max
units
4.5
5.0
5.5
Ω
1
MPa
80
°C
138
°C
assembly compression
hot side plate
RoHS
Note:
yes
1. Measured by AC 4-terminal method at 25°C
MECHANICAL DRAWING
units: mm
MATERIAL
0.05
COLD SIDE
0.05
HOT SIDE
PLATING
ceramic plate
96% AL2O3
wire leads
22 AWG
sealer
no sealer
marking
P/N & S/N printed on cold side surface
tin
7.2 0.2
100 5.0
Red (+)
10 3.0
15 0.3
30 0.3
COLD SIDE
Black (-)
30 3.0
cuidevices.com
Product Page
date 08/05/2022 | page 3 of 4
Input Voltage (V)
PERFORMANCE (Th=27°C)
2.8 A
16
2.24 A
1.68 A
1.12 A
8.0
0.56 A
Heat Pumped, Q (W)
2.24 A
8.0
A
2.8
A
1.68
2A
1.1
4.0
0.56
A
100
90
80
70
60
50
40
30
ΔT=Th-Tc (°C)
Input Voltage (V)
PERFORMANCE (Th=50°C)
2.8 A
16
2.24 A
1.68 A
1.12 A
8.0
0.56 A
Heat Pumped, Q (W)
8.0
2.24 A
A
1.68
A
2A
1.1
0.56
4.0
A
100
90
80
70
60
50
ΔT=Th-Tc (°C)
cuidevices.com
40
30
Product Page
date 08/05/2022 | page 4 of 4
REVISION HISTORY
1.0
initial release
09/12/2016
1.01
brand update
10/30/2019
logo, datasheet style update
08/05/2022
1.02
The revision history provided is for informational purposes only and is believed to be accurate.
CUI Devices offers a one (1) year limited warranty. Complete warranty information is listed on our website.
CUI Devices reserves the right to make changes to the product at any time without notice. Information provided by CUI Devices is believed to be accurate
and reliable. However, no responsibility is assumed by CUI Devices for its use, nor for any infringements of patents or other rights of third parties which may
result from its use.
CUI Devices products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A
critical component is any component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life
support device or system, or to affect its safety or effectiveness.
cuidevices.com
很抱歉,暂时无法提供与“CP28372-2”相匹配的价格&库存,您可以联系我们找货
