DL-060-12-00-00-00
DL-060-12-00-00-00
    LAIRD(莱尔德)
    Direct to Liquid Thermoelectric Assembly 59W 12V
DL-060-12-00-00-00 数据手册
DL‐060‐12‐00‐00‐00  Direct‐to‐Liquid Thermoelectric Assembly      Thermoelectric cooling unit for medical and industrial applications     The Direct-to-Liquid Series thermoelectric assembly (TEA) offers dependable, compact performance by cooling objects via liquid to transfer heat. Heat is absorbed through a cold block and dissipated thru a second liquid heat exchanger. The thermoelectric modules are custom designed to achieve a high coefficient of performance (COP) to minimize power consumption. This product series is available in a wide range of cooling capacities and voltages. Custom configurations are available, however, MOQ applies. The liquid heat exchanger is designed to accommodate distilled water with glycol. Corrosion resistant turbulators are enclosed inside channels to increase heat transfer. Mating port adaptors are sold separately.             FEATURES APPLICATIONS  Compact form factor  Medical Diagnostics  Industrial Lasers  Medical Lasers  Analytical Instrumentation     Reliable solid-state operation  Precise temperature control  Bi-metal thermostat for overheat protection  RoHS compliant        Americas: +1.919.597.7300   Europe: +46.31.420530   Asia: +86.755.2714.1166  ets.sales@lairdtech.com  www.lairdtech.com     DL‐060‐12‐00‐00‐00  Direct‐to‐Liquid Thermoelectric Assembly                  SPECIFICATIONS  TECHNICAL    Technology  Thermoelectric modules, liquid cooling, closed  loop (non‐mixing), filter less, non‐refrigerant  Cooling at ΔT = 0°C  65 W (222 Btu/h)   1 Voltage (nominal / maximum)    12/15 VDC   COP (Coefficient of Performance)  72%  Grounding (all voltages)  Positive or negative   Current draw, ±10% (nominal / startup)  3.9/4.3 A  Weight  0.4 kg (0.9 lbs)  Connector type (on unit / mating side)   TEM: Leads, 20 AWG, Red/Black  OHT: Leads  ENVIRONMENTAL    Temperature range  Hi‐Pot Test  ‐40°C to +62°C (‐40°F to +143°F)   750 VDC   Over temp Thermostat  75°C±5°C (167°F±41°F) on hot side heat sink    1) Max ripple 5%     DL‐060‐12‐00‐00‐00  Direct‐to‐Liquid Thermoelectric Assembly          MECHANICAL DRAWING      For overheating protection, the cooler is equipped with a bimetal thermostat. The maximum rating for the thermostat is 8 A dc. For systems with 8 A or less, the thermostat can be connected directly in series with the thermoelectric modules (TEMs). Otherwise, connect the TEMs to the power source through a relay of suitable rating which state is controlled with the bimetal thermostat. Note: Cold block requires insulation to minimize moisture buildup under dew point conditions.                              THR‐DS‐DL‐060‐12‐00‐00‐00_083115  Any information furnished by Laird and its agents is believed to be accurate and reliable. All specifications are subject to change without notice. Responsibility for the use  and application of Laird materials rests with the end user, since Laird and its agents cannot be aware of all potential uses.  Laird makes no warranties as to the fitness,   merchantability or suitability of any Laird materials or products for any specific or general uses.  Laird, Laird Technologies, Inc or any of its affiliates or agents shall not be  liable for incidental or consequential damages of any kind.  All Laird products are sold pursuant to the Laird Technologies’ Terms and Conditions of sale in effect from time  to time, a copy of which will be furnished upon request.  © Copyright 2014 Laird Technologies, Inc.  All Rights Reserved.  Laird, Laird Technologies, the Laird Logo, and other  marks are trademarks or registered trademarks of Laird Technologies, Inc. or an affiliate company thereof.  Other product or service names may be the property of third  parties.  Nothing herein provides a license under any Laird or any third party intellectual property rights.     DL‐060‐12‐00‐00‐00  Direct‐to‐Liquid Thermoelectric Assembly              THR‐DS‐DL‐060‐12‐00‐00‐00_083115  Any information furnished by Laird and its agents is believed to be accurate and reliable. All specifications are subject to change without notice. Responsibility for the use  and application of Laird materials rests with the end user, since Laird and its agents cannot be aware of all potential uses.  Laird makes no warranties as to the fitness,  merchantability or suitability of any Laird materials or products for any specific or general uses.  Laird, Laird Technologies, Inc or any of its affiliates or agents shall not be  liable for incidental or consequential damages of any kind.  All Laird products are sold pursuant to the Laird Technologies’ Terms and Conditions of sale in effect from time  to time, a copy of which will be furnished upon request.  © Copyright 2014 Laird Technologies, Inc.  All Rights Reserved.  Laird, Laird Technologies, the Laird Logo, and other  marks are trademarks or registered trademarks of Laird Technologies, Inc. or an affiliate company thereof.  Other product or service names may be the property of third  parties.  Nothing herein provides a license under any Laird or any third party intellectual property rights.
DL-060-12-00-00-00 价格&库存
很抱歉,暂时无法提供与“DL-060-12-00-00-00”相匹配的价格&库存,您可以联系我们找货
