DL‐210‐24‐00‐00‐00
Direct‐to‐Liquid Thermoelectric Assembly
Thermoelectric cooling unit for medical and industrial
applications
The Direct-to-Liquid Series thermoelectric assembly (TEA) offers dependable,
compact performance by cooling objects via liquid to transfer heat. Heat is
absorbed through a cold block and dissipated thru a second liquid heat
exchanger. The thermoelectric modules are custom designed to achieve a
high coefficient of performance (COP) to minimize power consumption. This
product series is available in a wide range of cooling capacities and voltages.
Custom configurations are available, however, MOQ applies.
The liquid heat exchanger is designed to accommodate distilled water with
glycol. Corrosion resistant turbulators are enclosed inside channels to
increase heat transfer. Mating port adaptors are sold separately.
Americas: +1.919.597.7300
Europe: +46.31.420530
Asia: +86.755.2714.1166
ets.sales@lairdtech.com
www.lairdtech.com
FEATURES
APPLICATIONS
Compact form factor
Reliable solid-state operation
Precise temperature control
Bi-metal thermostat for overheat
protection
RoHS compliant
Medical Diagnostics
Industrial Lasers
Medical Lasers
Analytical Instrumentation
DL‐210‐24‐00‐00‐00
SPECIFICATIONS
TECHNICAL
Technology
Thermoelectric modules, liquid cooling, closed
loop (non‐mixing), filterless, non‐refrigerant
Cooling at ΔT = 0°C
265W (904 Btu/h)
1
Voltage (nominal / maximum)
24/28 VDC
COP (Coefficient of Performance)
71%
Grounding (all voltages)
Positive or negative
Current draw, ±10% (nominal / startup)
7.8/8.5 A
Weight
1.3 kg (2.9 lbs)
Connector type (on unit / mating side)
TEM: Leads, 18 AWG, Red/Black
OHT: Leads
ENVIRONMENTAL
Temperature range
Hi‐Pot Test
‐40°C to +62°C (‐40°F to +143°F)
750 VDC
Over temp Thermostat
75°C±5°C (167°F±41°F) on hot side heat sink
1) Max ripple 5%
DL‐210‐24‐00‐00‐00
MECHANICAL DRAWING
For overheating protection, the cooler is equipped with a bimetal thermostat. The maximum rating
for the thermostat is 8 A dc. For systems with 8 A or less, the thermostat can be connected directly
in series with the thermoelectric modules (TEMs). Otherwise, connect the TEMs to the power
source through a relay of suitable rating which state is controlled with the bimetal thermostat.
Note: Cold block requires insulation to minimize moisture buildup under dew point conditions.
THR‐DS‐DL‐210‐24‐00‐00‐00_083115
Any information furnished by Laird and its agents is believed to be accurate and reliable. All specifications are subject to change without notice. Responsibility for the use
and application of Laird materials rests with the end user, since Laird and its agents cannot be aware of all potential uses. Laird makes no warranties as to the fitness,
merchantability or suitability of any Laird materials or products for any specific or general uses. Laird, Laird Technologies, Inc or any of its affiliates or agents shall not be
liable for incidental or consequential damages of any kind. All Laird products are sold pursuant to the Laird Technologies’ Terms and Conditions of sale in effect from time
to time, a copy of which will be furnished upon request. © Copyright 2014 Laird Technologies, Inc. All Rights Reserved. Laird, Laird Technologies, the Laird Logo, and other
marks are trademarks or registered trademarks of Laird Technologies, Inc. or an affiliate company thereof. Other product or service names may be the property of third
parties. Nothing herein provides a license under any Laird or any third party intellectual property rights.
很抱歉,暂时无法提供与“DL-210-24-00-00-00”相匹配的价格&库存,您可以联系我们找货
