DAC035-12-02-00-00
DAC035-12-02-00-00
    LAIRD(莱尔德)
    THERMOELECT ASSY DIRECT AIR 4.8A
DAC035-12-02-00-00 数据手册
Cascade Series DAC-035-12-02 MFG Part Number: DAC035-12-02-00-00 Cascade Series Thermoelectric Cooler Assembly Features The DAC-035-12-02 is a thermoelectric cooler assembly that offers dependable, compact performance by cooling objects via convection or conduction. Heat is absorbed and dissipated thru high density heat exchangers equipped with air ducted shrouds and brand name fans. The heat pumping action is created by thermoelectric modules that are custom designed multistage cascades to achieve a high temperature differential. Custom configurations are available, however MOQ applies. This product can produce up to 40% more cooling capacity at cold temperatures, surpassing standard product offerings with similar form factors. ● ● ● ● Applications High heat pumping capacity at cold temperatures Precise temperature control Reliable solid-state operation Compact design ● ● Thermoelectric Cooling for CMOS Sensors Heads-Up Displays, Imaging Sensors ELECTRICAL AND THERMAL PERFORMANCE Heat Pumped at Cold Side (Qc) Tambient = 35°C | Tcontrol = 20°C 50.00 50.00 40.00 40.00 ΔT=0°C ΔT=10°C ΔT=20°C ΔT=30°C 30.00 20.00 10.00 0.00 0.00 Qc (Watts) Qc (Watts) Heat Pumped at Cold Side (Qc) Tambient = 35°C | Tcontrol = 20°C ΔT=0°C ΔT=10°C ΔT=20°C ΔT=30°C 30.00 20.00 10.00 0.50 1.00 1.50 2.00 2.50 3.00 3.50 Operating Current (Amps) 4.00 4.50 0.00 0.00 2.00 4.00 6.00 8.00 10.00 12.00 14.00 16.00 18.00 Operating Voltage (Volts) Cascade Series DAC-035-12-02 MFG Part Number: DAC035-12-02-00-00 Coefficient of Performance (COP = Qc/Pin) Tambient = 35°C | Tcontrol = 20°C Coefficient of Performance (COP = Qc/Pin) Tambient = 35°C | Tcontrol = 20°C 6.00 6.00 5.00 5.00 4.00 ΔT=0°C ΔT=10°C ΔT=20°C ΔT=30°C 3.00 COP COP 4.00 2.00 2.00 1.00 1.00 0.00 0.00 0.50 1.00 1.50 2.00 2.50 3.00 3.50 4.00 0.00 0.00 4.50 ΔT=0°C ΔT=10°C ΔT=20°C ΔT=30°C 3.00 2.00 4.00 Operating Current (Amps) 120.00 120.00 100.00 100.00 80.00 ΔT=0°C ΔT=10°C ΔT=20°C ΔT=30°C 60.00 20.00 20.00 1.50 2.00 2.50 3.00 3.50 4.00 0.00 0.00 4.50 ΔT=0°C ΔT=10°C ΔT=20°C ΔT=30°C 60.00 40.00 1.00 2.00 Operating Current (Amps) 4.00 6.00 8.00 10.00 12.00 14.00 16.00 18.00 Operating Voltage (Volts) Heat Pumped at Cold Side (Qc) Voperating = 12 Volts | Ioperating = 3.46 Amps Coefficient of Performance (COP = Qc/Pin) Voperating = 12 Volts | Ioperating = 3.46 Amps 50.00 1.00 40.00 0.80 30.00 0.60 COP Qc (Watts) 10.00 12.00 14.00 16.00 18.00 80.00 40.00 0.50 8.00 Total Heat Dissipated at Hot Side (Qh=Qc+Pin) Tambient = 35°C | Tcontrol = 20°C Qh (Watts) Qh (Watts) Total Heat Dissipated at Hot Side (Qh=Qc+Pin) Tambient = 35°C | Tcontrol = 20°C 0.00 0.00 6.00 Operating Voltage (Volts) 20.00 0.40 10.00 0.20 0.00 0.0 10.0 20.0 30.0 40.0 ΔT (°C) 50.0 60.0 70.0 80.0 0.00 0.0 10.0 20.0 30.0 40.0 ΔT (°C) 50.0 60.0 70.0 80.0 Cascade Series DAC-035-12-02 MFG Part Number: DAC035-12-02-00-00 SPECIFICATIONS Heat Transfer Mechanism, Cold Side Heat Transfer Mechanism, Hot Side Operating Temperature Range Supply Voltage Direct - Conduction Air - Forced Convection -10°C to 54°C 12.0 VDC nominal / 14.0 VDC maximum Current Draw 4.8 A running / 5.5 A startup Power Supply 58.0 Watts Performance Tolerance Hi-Pot Testing Fan MTBF Over-Temp Thermostat (Hot and Cold Side Heat Sink) Weight Panel Mounting 10% No Testing 50,000 hours 75°C ±5°C (hot side heat sink) 1.20 kg Flush Mount Cascade Series DAC-035-12-02 MFG Part Number: DAC035-12-02-00-00 MOUNTING HOLE LOCATION WIRING SCHEMATIC NOTES 1 For indoor use only 2 Units are generally maintenance free, however occasionally it is recommended to clean the heat sinks and fans of debris. This is best done with compressed air. Any information furnished by Laird and its agents, whether in specifications, data sheets, product catalogues or otherwise, is believed to be (but is not warranted as being) accurate and reliable, is provided for information only and does not form part of any contract with Laird. All specifications are subject to change without notice. Laird assumes no responsibility and disclaims all liability for losses or damages resulting from use of or reliance on this information. All Laird products are sold subject to the Laird Terms and Conditions of sale (including Laird’s limited warranty) in effect from time to time, a copy of which will be furnished upon request. © Copyright 2019-2022 Laird Thermal Systems, Inc. All rights reserved. Laird™, the Laird Ring Logo, and Laird Thermal Systems™ are trademarks or registered trademarks of Laird Limited or its subsidiaries. Revision: 00 Date: 06-01-2022 Print Date: 06-15-2022
DAC035-12-02-00-00 价格&库存
很抱歉,暂时无法提供与“DAC035-12-02-00-00”相匹配的价格&库存,您可以联系我们找货
