LA-045-12-02-00-00
LA-045-12-02-00-00
    LAIRD(莱尔德)
    THERMOELECT ASSY LIQUID-AIR 4.1A
LA-045-12-02-00-00 数据手册
LA‐045‐12‐02‐00‐00  Liquid‐to‐Air Thermoelectric Assembly        Thermoelectric cooling unit for medical and industrial  applications         The Liquid‐to‐Air Series thermoelectric assembly (TEA) offers  dependable, compact performance by cooling objects via liquid to  transfer heat. Heat is absorbed through a liquid heat exchanger and  dissipated thru a high density heat sink equipped with an air ducted  shroud and brand name fan. The thermoelectric modules are custom  designed to achieve a high coefficient of performance (COP) to minimize  power consumption. This product series is available in a wide range of  cooling capacities and voltages. Custom configurations are available,  however, MOQ applies.                    Americas: +1.919.597.7300   Europe: +46.31.420530   Asia: +86.755.2714.1166  ets.sales@lairdtech.com  www.lairdtech.com    FEATURES    APPLICATIONS           Compact form factor  Precise temperature control  Reliable solid‐state operation  DC operation  RoHS compliant  Medical Diagnostics  Industrial Lasers  Medical Lasers  Analytical Instrumentation   LA‐045‐12‐02‐00‐00  Liquid‐to‐Liquid Thermoelectric Assembly          SPECIFICATIONS  TECHNICAL  Technology  Cooling at ΔT = 0°C  Voltage (nominal / maximum) 1  Grounding (all voltages)  Current draw, ±10%   (nominal / startup)  Weight   MTBF (fans)  ENVIRONMENTAL  Temperature range  Over temp Thermostat    Thermoelectric based  43 W   12/15 VDC   Positive or negative   3.7/4.3 A  1.5 kg  50,000 hours    ‐10°C to +52°C   75°C±5°C  (hot side heat sink)       LA‐045‐12‐02‐00‐00  Liquid‐to‐Liquid Thermoelectric Assembly      MECHANICAL DRAWING                Note:     For overheating protection, the cooler is equipped with a bimetal  thermostat. The maximum rating for the thermostat is 8 A dc. For  systems with 8 A or less, the thermostat can be connected directly  in series with the thermoelectric modules (TEMs). Otherwise,  connect the TEMs to the power source through a relay of suitable  rating which state is controlled with the bimetal thermostat.  Turbulators are mounted inside liquid channels to turbulate flow  Cold block requires insulation to minimize moisture buildup under  dew point conditions.  THR‐DS‐LA‐045‐12‐00‐00_121715  Any information furnished by Laird and its agents is believed to be accurate and reliable. All specifications are subject to change without notice. Responsibility for the use  and application of Laird materials rests with the end user, since Laird and its agents cannot be aware of all potential uses.  Laird makes no warranties as to the fitness,  merchantability or suitability of any Laird materials or products for any specific or general uses.  Laird, Laird Technologies, Inc or any of its affiliates or agents shall not be  liable for incidental or consequential damages of any kind.  All Laird products are sold pursuant to the Laird Technologies’ Terms and Conditions of sale in effect from time  to time, a copy of which will be furnished upon request.  © Copyright 2014 Laird Technologies, Inc.  All Rights Reserved.  Laird, Laird Technologies, the Laird Logo, and other  marks are trademarks or registered trademarks of Laird Technologies, Inc. or an affiliate company thereof.  Other product or service names may be the property of third  parties.  Nothing herein provides a license under any Laird or any third party intellectual property rights.
LA-045-12-02-00-00 价格&库存
很抱歉,暂时无法提供与“LA-045-12-02-00-00”相匹配的价格&库存,您可以联系我们找货
