1
2
3
4
5
A
6
7
Specification: (Ta=32°C)
Code: Description:
Heat transfer, cold side:
Heat transfer, warm side:
Cascade:
Cooling power: [W]
Voltage, nominal: [VDC]
A
A
033
24
Fan(s), cold side:
Fan(s), warm side:
Temperature controller, sensor:
Temperature control settings, trim options:
Additional controller information:
2
2
Temperature control position:
Options:
Weight:
Overheating thermostat:
Operating temperature:
TE-Module(s) temperature specification:
Enclosed:
Packing:
C
Air
Air
28 W at dT=0°C. Tolerance: ±10%.
24 VDC.
Nominal: 24 VDC, Max: 28 VDC.
Nominal: 2,3 A, Initial: 2,7 A. All at dT=0°C. Tolerance: ±10%.
MTBF: 52,000 hrs. L10 at 25°C. Nominal current: 0.15 A. Voltage: 24 VDC ±10%.
MTBF: 50,000 hrs. L10 at 25°C. Nominal current: 0.25 A. Voltage: 24 VDC ±10%.
None.
TEM Voltage: [VDC]
TEM Current: [A]
B
8
A
B
1,4
None.
-10°C to +48°C at nominal voltage.
Max. surface temperature: 80°C.
Individual cardboard box.
C
Mounting hole print: 99 x 67
97
D
65
74
D
E
E
120
4x O 4.5
Comments / deviations:
General tolerances:
Heat sinks and, if applicable, D-plates and shrouds in anodised aluminium.
Designed by:
F
Approved by:
Release date: Customer:
Henrik Höjer Pavel Cech
Supercool AB
2
3
Project:
20050128 Supercool AB
Box 27, S-40120 Göteborg, Sweden
tfn: +46 31 420530, fax: +46 31 247909
e-mail: info@supercool.se
Web: www.supercool.se
1
SS-ISO 2768-1 c
Title:
Part nr:
T60
TE ASSEMBLY 24 VDC AIR - AIR
AA-033-24-22-00-00
Rev. nr. Status: Scale: Size, sheet
- A3, 1(3)
6 This drawing is the property of Supercool
7 AB. Protected in accordance with prevailing
8 law.
F
1
2
3
4
5
6
8
65
180
A
7
A
63
Warm side air flow
B
9
138
B
C
C
Cold side air flow
65
97
84
D
D
4xO 4.5
Electrical connections:
"TEM+": + TEM
"TEM-": - TEM
"F+": + Fan(s)
"F-": - Fan(s)
74
E
General tolerances:
Designed by:
F
Approved by:
1
2
Project:
Supercool AB
3
SS-ISO 2768-1 c
120
E
Title:
Part nr:
T60
AA-033-24-22-00-00
- A3, 2(3)
8 law.
F
很抱歉,暂时无法提供与“AA-033-24-22-00-00”相匹配的价格&库存,您可以联系我们找货
