Cascade Series DAC-060-24-02
MFG Part Number: DAC060-24-02-00-00
Cascade Series Thermoelectric Cooler Assembly
Features
The DAC-060-24-02 is a thermoelectric cooler assembly that offers
dependable, compact performance by cooling objects via convection or
conduction. Heat is absorbed and dissipated thru high density heat
exchangers equipped with air ducted shrouds and brand name fans. The
heat pumping action is created by thermoelectric modules that are custom
designed multistage cascades to achieve a high temperature differential.
Custom configurations are available, however MOQ applies. This product
can produce up to 40% more cooling capacity at cold temperatures,
surpassing standard product offerings with similar form factors.
Applications
High heat pumping capacity at cold
temperatures
Precise temperature control
Reliable solid-state operation
Compact design
Thermoelectric Cooling for CMOS Sensors
Heads-Up Displays, Imaging Sensors
ELECTRICAL AND THERMAL PERFORMANCE
Heat Pumped at Cold Side (Qc)
Tambient = 35°C | Tcontrol = 20°C
80.00
80.00
70.00
70.00
60.00
60.00
50.00
ΔT=0°C
ΔT=10°C
ΔT=20°C
ΔT=30°C
40.00
30.00
Qc (Watts)
Qc (Watts)
50.00
30.00
20.00
20.00
10.00
10.00
0.00
0.00
0.50
1.00
1.50
2.00
2.50
3.00
3.50
Operating Current (Amps)
4.00
4.50
ΔT=0°C
ΔT=10°C
ΔT=20°C
ΔT=30°C
40.00
0.00
0.00
5.00
10.00
15.00
20.00
25.00
Operating Voltage (Volts)
30.00
35.00
Coefficient of Performance (COP = Qc/Pin)
6.00
6.00
5.00
5.00
4.00
ΔT=0°C
ΔT=10°C
ΔT=20°C
ΔT=30°C
3.00
COP
COP
4.00
2.00
2.00
1.00
1.00
0.00
0.00
0.50
1.00
1.50
2.00
2.50
3.00
3.50
4.00
0.00
0.00
4.50
ΔT=0°C
ΔT=10°C
ΔT=20°C
ΔT=30°C
3.00
5.00
20.00
25.00
30.00
35.00
Total Heat Dissipated at Hot Side (Qh=Qc+Pin)
250.00
250.00
200.00
200.00
ΔT=0°C
ΔT=10°C
ΔT=20°C
ΔT=30°C
150.00
100.00
Qh (Watts)
Qh (Watts)
15.00
50.00
0.00
0.00
10.00
ΔT=0°C
ΔT=10°C
ΔT=20°C
ΔT=30°C
150.00
100.00
50.00
0.50
1.00
1.50
2.00
2.50
3.00
3.50
4.00
0.00
0.00
4.50
5.00
10.00
15.00
20.00
25.00
30.00
35.00
Voperating = 24.02 Volts | Ioperating = 3.35 Amps
80.00
1.00
70.00
0.80
50.00
0.60
COP
Qc (Watts)
60.00
40.00
0.40
30.00
20.00
0.20
10.00
0.00
0.0
10.0
20.0
30.0
40.0
ΔT (°C)
50.0
60.0
70.0
80.0
0.00
0.0
10.0
20.0
30.0
40.0
ΔT (°C)
50.0
60.0
70.0
80.0
SPECIFICATIONS
Heat Transfer Mechanism, Cold Side
Heat Transfer Mechanism, Hot Side
Operating Temperature Range
Supply Voltage
Direct - Conduction
Air - Forced Convection
-10°C to 48°C
24.0 VDC nominal / 28.0 VDC maximum
Current Draw
4.6 A running / 5.5 A startup
Power Supply
110.0 Watts
Performance Tolerance
Hi-Pot Testing
Fan MTBF
Over-Temp Thermostat (Hot and Cold Side Heat Sink)
Weight
Panel Mounting
10%
No Testing
50,000 hours
75°C ±5°C (hot side heat sink)
1.80 kg
Flush Mount
MOUNTING HOLE LOCATION
WIRING SCHEMATIC
NOTES
1
For indoor use only
2
Units are generally maintenance free, however occasionally it is recommended to clean the heat sinks and fans of debris. This is best
done with compressed air.
Any information furnished by Laird and its agents, whether in specifications, data sheets, product catalogues or otherwise, is believed to be (but is not warranted as being)
accurate and reliable, is provided for information only and does not form part of any contract with Laird. All specifications are subject to change without notice. Laird assumes
no responsibility and disclaims all liability for losses or damages resulting from use of or reliance on this information. All Laird products are sold subject to the Laird Terms and
Conditions of sale (including Laird’s limited warranty) in effect from time to time, a copy of which will be furnished upon request.
© Copyright 2019-2022 Laird Thermal Systems, Inc. All rights reserved. Laird™, the Laird Ring Logo, and Laird Thermal Systems™ are trademarks or registered trademarks
of Laird Limited or its subsidiaries.
Revision: 00 Date: 06-01-2022
Print Date: 06-15-2022
很抱歉,暂时无法提供与“DAC060-24-02-00-00”相匹配的价格&库存,您可以联系我们找货
