LL-060-12-00-00-00
LL-060-12-00-00-00
    LAIRD(莱尔德)
    Liquid to Liquid Thermoelectric Assembly 61W 12V
LL-060-12-00-00-00 数据手册
Liquid Series LL-060-12-00 MFG Part Number: LL-060-12-00-00-00 Liquid Series Thermoelectric Cooler Assembly Features The LL-060-12-00 thermoelectric cooler assembly offers dependable, compact performance by cooling objects via liquid to transfer heat. Heat is absorbed through one liquid heat exchanger and dissipated thru a second liquid heat exchanger. The thermoelectric modules are custom designed to achieve a high coefficient of performance (COP) to minimize power consumption. It has a maximum Qc of 61 Watts when ΔT = 0 and a maximum ΔT of 42 °C at Qc = 0. Heat exchangers are designed to accommodate distilled water with glycol. Corrosion resistant turbulators are enclosed inside channels to increase heat transfer. Mating port adaptors are sold separately. ● ● ● ● ● Applications Compact design Precise temperature control Reliable solid-state operation DC operation RoHS-compliant ● ● ● ● Medical Diagnostics Industrial Lasers Medical Lasers Analytical Instrumentation ELECTRICAL AND THERMAL PERFORMANCE Heat Pumped at Cold Side (Qc) Tambient = 35°C | Tcontrol = 20°C 80.00 80.00 70.00 70.00 60.00 60.00 50.00 ΔT=0°C ΔT=10°C ΔT=20°C ΔT=30°C 40.00 30.00 Qc (Watts) Qc (Watts) Heat Pumped at Cold Side (Qc) Tambient = 35°C | Tcontrol = 20°C 50.00 40.00 30.00 20.00 20.00 10.00 10.00 0.00 0.00 1.00 2.00 3.00 4.00 5.00 6.00 7.00 Operating Current (Amps) 8.00 9.00 ΔT=0°C ΔT=10°C ΔT=20°C ΔT=30°C 0.00 0.00 5.00 10.00 15.00 20.00 Operating Voltage (Volts) 25.00 Liquid Series LL-060-12-00 MFG Part Number: LL-060-12-00-00-00 Coefficient of Performance (COP = Qc/Pin) Tambient = 35°C | Tcontrol = 20°C Coefficient of Performance (COP = Qc/Pin) Tambient = 35°C | Tcontrol = 20°C 6.00 6.00 5.00 5.00 4.00 ΔT=0°C ΔT=10°C ΔT=20°C ΔT=30°C 3.00 COP COP 4.00 2.00 2.00 1.00 1.00 0.00 0.00 1.00 2.00 3.00 4.00 5.00 6.00 7.00 8.00 ΔT=0°C ΔT=10°C ΔT=20°C ΔT=30°C 3.00 0.00 0.00 9.00 5.00 10.00 Operating Current (Amps) 20.00 25.00 Total Heat Dissipated at Hot Side (Qh=Qc+Pin) Tambient = 35°C | Tcontrol = 20°C 250.00 250.00 200.00 200.00 ΔT=0°C ΔT=10°C ΔT=20°C ΔT=30°C 150.00 100.00 Qh (Watts) Qh (Watts) Total Heat Dissipated at Hot Side (Qh=Qc+Pin) Tambient = 35°C | Tcontrol = 20°C 50.00 0.00 0.00 15.00 Operating Voltage (Volts) ΔT=0°C ΔT=10°C ΔT=20°C ΔT=30°C 150.00 100.00 50.00 1.00 2.00 3.00 4.00 5.00 6.00 7.00 8.00 0.00 0.00 9.00 5.00 Operating Current (Amps) 10.00 15.00 20.00 25.00 Operating Voltage (Volts) Heat Pumped at Cold Side (Qc) Voperating = 12.02 Volts | Ioperating = 5.19 Amps Coefficient of Performance (COP = Qc/Pin) Voperating = 12.02 Volts | Ioperating = 5.19 Amps 70.00 1.20 60.00 1.00 0.80 40.00 COP Qc (Watts) 50.00 30.00 0.60 0.40 20.00 0.20 10.00 0.00 0.0 5.0 10.0 15.0 20.0 25.0 ΔT (°C) 30.0 35.0 40.0 45.0 0.00 0.0 5.0 10.0 15.0 20.0 25.0 ΔT (°C) 30.0 35.0 40.0 45.0 Liquid Series LL-060-12-00 MFG Part Number: LL-060-12-00-00-00 System Resistance Curve 0.60 Pressure Drop (Bar) 0.50 0.40 0.30 0.20 0.10 0.00 0.0 0.5 1.0 1.5 2.0 2.5 3.0 3.5 Flow Rate (L/min) SPECIFICATIONS Heat Transfer Mechanism, Cold Side Liquid - Forced Convection Heat Transfer Mechanism, Hot Side Liquid - Forced Convection Operating Temperature Range Supply Voltage -40°C to 62°C 12.0 VDC nominal / 15.0 VDC maximum Current Draw 3.9 A running / 4.3 A startup Power Supply 56.0 Watts Performance Tolerance Hi-Pot Testing Over-Temp Thermostat (Hot and Cold Side Heat Sink) Weight 10% 750 VDC 75°C ±5°C (hot side heat sink) 0.50 kg Liquid Series LL-060-12-00 MFG Part Number: LL-060-12-00-00-00 MOUNTING HOLE LOCATION ELECTRICAL CONNECTIONS NOTES 1 For indoor use only 2 Turbulators are mounted inside liquid channels to create turbulent flow 3 Cold block requires insulation to minimize moisture buildup under dew point conditions. Any information furnished by Laird and its agents, whether in specifications, data sheets, product catalogues or otherwise, is believed to be (but is not warranted as being) accurate and reliable, is provided for information only and does not form part of any contract with Laird. All specifications are subject to change without notice. Laird assumes no responsibility and disclaims all liability for losses or damages resulting from use of or reliance on this information. All Laird products are sold subject to the Laird Terms and Conditions of sale (including Laird’s limited warranty) in effect from time to time, a copy of which will be furnished upon request. © Copyright 2019-2022 Laird Thermal Systems, Inc. All rights reserved. Laird™, the Laird Ring Logo, and Laird Thermal Systems™ are trademarks or registered trademarks of Laird Limited or its subsidiaries. Revision: 00 Date: 06-01-2022 Print Date: 06-15-2022
LL-060-12-00-00-00 价格&库存
很抱歉,暂时无法提供与“LL-060-12-00-00-00”相匹配的价格&库存,您可以联系我们找货
