LL-210-24-00-00-00
LL-210-24-00-00-00
    LAIRD(莱尔德)
    Liquid to Liquid Thermoelectric Assembly 208W 24V
LL-210-24-00-00-00 数据手册
LL‐210‐24‐00‐00‐00  Liquid‐to‐Liquid Thermoelectric Assembly        Thermoelectric cooling unit for medical and industrial laser applications The Liquid-to-Liquid Series thermoelectric assembly (TEA) offers dependable, compact performance by cooling objects via liquid to transfer heat. Heat is absorbed through one liquid heat exchanger and dissipated thru a second liquid heat exchanger. The thermoelectric modules are custom designed to achieve a high coefficient of performance (COP) to minimize power consumption. This product series is available in a wide range of cooling capacities and voltages. Custom configurations are available, however, MOQ applies.   Heat exchangers are designed to accommodate distilled water with glycol. Corrosion resistant turbulators are enclosed inside channels to increase heat transfer. Mating port adaptors are sold separately.   FEATURES APPLICATIONS         Compact form factor Reliable solid-state operation Precise temperature control Bi-metal thermostat for overheat protection  RoHS compliant       Americas: +1.919.597.7300   Europe: +46.31.420530   Asia: +86.755.2714.1166  ets.sales@lairdtech.com  www.lairdtech.com    Medical Diagnostics Industrial Lasers Medical Lasers Analytical Instrumentation  LL‐210‐24‐00‐00‐00  Liquid‐to‐Liquid Thermoelectric Assembly                  SPECIFICATIONS  TECHNICAL    Technology  Thermoelectric modules, liquid cooling, closed  loop (non‐mixing), filterless, non‐refrigerant  Cooling at ΔT = 0°C  266W (907 Btu/h)   1 Voltage (nominal / maximum)    24/28 VDC   COP (Coefficient of Performance)  71%  Grounding (all voltages)  Positive or negative   Current draw, ±10% (nominal / startup)  7.9/8.5 A  Weight  1.4 kg (3.1 lbs)  Connector type (on unit / mating side)   TEM: Leads, 18 AWG, Red/Black  OHT: Leads,   ENVIRONMENTAL    Temperature range  Hi‐pot testing  ‐40°C to +62°C (‐40°F to +143°F)   750 VDC   Over temp Thermostat  75°C±5°C (167°F±41°F) on hot side heat sink    1) Max ripple 5%     LL‐210‐24‐00‐00‐00  Liquid‐to‐Liquid Thermoelectric Assembly          MECHANICAL DRAWING      For overheating protection, the cooler is equipped with a bimetal thermostat. The maximum rating for the thermostat is 8 A. For systems with 8 A or less, the thermostat can be connected directly in series with the thermoelectric modules (TEMs). Otherwise, connect the TEMs to the power source through a relay of suitable rating which state is controlled with the bimetal thermostat. Note: Cold side heat exchanger requires insulation to minimize moisture buildup under dew point conditions.                           THR‐DS‐LL‐210‐24‐00‐00‐00_082015  Any information furnished by Laird and its agents is believed to be accurate and reliable. All specifications are subject to change without notice. Responsibility for the use  and application of Laird materials rests with the end user, since Laird and its agents cannot be aware of all potential uses.  Laird makes no warranties as to the fitness,  merchantability or suitability of any Laird materials or products for any specific or general uses.  Laird, Laird Technologies, Inc or any of its affiliates or agents shall not be  liable for incidental or consequential damages of any kind.  All Laird products are sold pursuant to the Laird Technologies’ Terms and Conditions of sale in effect from time  to time, a copy of which will be furnished upon request.  © Copyright 2014 Laird Technologies, Inc.  All Rights Reserved.  Laird, Laird Technologies, the Laird Logo, and other  marks are trademarks or registered trademarks of Laird Technologies, Inc. or an affiliate company thereof.  Other product or service names may be the property of third  parties.  Nothing herein provides a license under any Laird or any third party intellectual property rights.     LL‐210‐24‐00‐00‐00  Liquid‐to‐Liquid Thermoelectric Assembly                THR‐DS‐LL‐210‐24‐00‐00‐00_082015  Any information furnished by Laird and its agents is believed to be accurate and reliable. All specifications are subject to change without notice. Responsibility for the use  and application of Laird materials rests with the end user, since Laird and its agents cannot be aware of all potential uses.  Laird makes no warranties as to the fitness,  merchantability or suitability of any Laird materials or products for any specific or general uses.  Laird, Laird Technologies, Inc or any of its affiliates or agents shall not be  liable for incidental or consequential damages of any kind.  All Laird products are sold pursuant to the Laird Technologies’ Terms and Conditions of sale in effect from time  to time, a copy of which will be furnished upon request.  © Copyright 2014 Laird Technologies, Inc.  All Rights Reserved.  Laird, Laird Technologies, the Laird Logo, and other  marks are trademarks or registered trademarks of Laird Technologies, Inc. or an affiliate company thereof.  Other product or service names may be the property of third  parties.  Nothing herein provides a license under any Laird or any third party intellectual property rights.
LL-210-24-00-00-00
物料型号:LL-210-24-00-00-00
器件简介:Laird的液体对液体热电制冷组件(TEA)通过液体传热来冷却物体,提供可靠、紧凑的性能。热电模块是为实现高系数性能(COP)定制设计的,以最小化功耗。
引脚分配:TEM(热电模块):18 AWG红/黑线;OHT(热交换器):接线端子。
参数特性: - 技术:热电模块、液体冷却、闭环(不混合)、无过滤、无制冷剂。 - 0°C时的冷却能力:266W(907 Btu/h)。 - 额定/最大电压:24/28 VDC。 - 性能系数(COP):71%。 - 接地:正或负。 - 电流消耗:7.9/8.5A(额定/启动)。 - 重量:1.4 kg(3.1 lbs)。 - 环境温度范围:-40°C至+62°C(-40°F至+143°F)。
功能详解:该组件通过一个液体热交换器吸收热量,并通过第二个液体热交换器散发热量。它具有紧凑的外形、可靠的固态操作、精确的温度控制和双金属热保护器。
应用信息:适用于医疗诊断、工业激光、分析仪器等。
封装信息:热交换器设计用于蒸馏水和乙二醇,耐腐蚀扰流器内置于通道中以增加热传递。适配器端口单独出售。
LL-210-24-00-00-00 价格&库存
很抱歉,暂时无法提供与“LL-210-24-00-00-00”相匹配的价格&库存,您可以联系我们找货
