LA‐075‐24‐02‐00‐00
Liquid‐to‐Air Thermoelectric Assembly
Thermoelectric cooling unit for medical and industrial
applications
The Liquid‐to‐Air Series thermoelectric assembly (TEA) offers
dependable, compact performance by cooling objects via liquid to
transfer heat. Heat is absorbed through a liquid heat exchanger and
dissipated thru a high density heat sink equipped with an air ducted
shroud and brand name fan. The thermoelectric modules are custom
designed to achieve a high coefficient of performance (COP) to
minimize power consumption. This product series is available in a
wide range of cooling capacities and voltages. Custom configurations
are available, however, MOQ applies.
Americas: +1.919.597.7300
Europe: +46.31.420530
Asia: +86.755.2714.1166
ets.sales@lairdtech.com
www.lairdtech.com
FEATURES
APPLICATIONS
Compact form factor
Precise temperature control
Reliable solid‐state operation
DC operation
RoHS compliant
Medical Diagnostics
Industrial Lasers
Medical Lasers
Analytical Instrumentation
LA‐075‐24‐02‐00‐00
SPECIFICATIONS
TECHNICAL
Technology
Cooling at ΔT = 0°C
Voltage (nominal/maximum)
Current draw, ±10% (nominal/startup)
Weight
MTBF (fans)
ENVIRONMENTAL
Temperature range
Over temp Thermostat
Thermoelectric based
71 W
24/30 VDC
3.4/4.3 A
2 kg
50,000 hours
‐10°C to +49°C (‐40°F to +143°F)
75°C±5°C on hot side heat sink
surface
LA‐075‐24‐02‐00‐00
MECHANICAL DRAWING
Note:
For overheating protection, the cooler is equipped with a bimetal
thermostat. The maximum rating for the thermostat is 8 A dc. For systems
with 8 A or less, the thermostat can be connected directly in series with
the thermoelectric modules (TEMs). Otherwise, connect the TEMs to the
power source through a relay of suitable rating which state is controlled
with the bimetal thermostat.
Turbulators are mounted inside liquid channels to turbulate flow
Cold block requires insulation to minimize moisture buildup under dew
point conditions.
THR‐DS‐LA‐075‐24‐02‐00‐00_121715
Any information furnished by Laird and its agents is believed to be accurate and reliable. All specifications are subject to change without notice. Responsibility for the use
and application of Laird materials rests with the end user, since Laird and its agents cannot be aware of all potential uses. Laird makes no warranties as to the fitness,
merchantability or suitability of any Laird materials or products for any specific or general uses. Laird, Laird Technologies, Inc or any of its affiliates or agents shall not be
liable for incidental or consequential damages of any kind. All Laird products are sold pursuant to the Laird Technologies’ Terms and Conditions of sale in effect from time
to time, a copy of which will be furnished upon request. © Copyright 2014 Laird Technologies, Inc. All Rights Reserved. Laird, Laird Technologies, the Laird Logo, and other
marks are trademarks or registered trademarks of Laird Technologies, Inc. or an affiliate company thereof. Other product or service names may be the property of third
parties. Nothing herein provides a license under any Laird or any third party intellectual property rights.
很抱歉,暂时无法提供与“LA-075-24-02-00-00”相匹配的价格&库存,您可以联系我们找货
