DA-038-12-02-00-00
DA-038-12-02-00-00
    LAIRD(莱尔德)
    THERMOELECT ASSY DIRECT AIR 3.6A
DA-038-12-02-00-00 数据手册
Thermoelectric Assemblies About Laird Laird is a global technology company focused on providing systems, components and solutions that protect electronics from electromagnetic interference and heat, and that enable connectivity in mission-critical wireless applications and antenna systems. Introduction We are a global leader in the field of radio frequency (RF) engineering and in the design, development and supply of innovative technology that allows people, organisations and applications to connect efficiently. Thermoelectric Assemblies (TEAs) are compact units that control the temperature of a wide variety of applications, such as laser diode packages in active optics, lasers in medical and industrial instrumentation, electronic enclosures, sample storage chambers in medical diagnostics and analytical instruments and batteries in various automotive and telecom applications. TEAs serve a cooling capacity spectrum from approximately 10 to 400 Watts, and can cool by removing heat from control sources through convection, conduction, or liquid means. Our aim is to be a trusted partner to our customers by delivering problem-solving solutions through Innovation, Reliable Fulfilment, and Speed. Advantages Laird partners with its customers to design custom thermal solutions for applications in many industries including: • Medical Diagnostics • Analytical Instrumentation • Medical Imaging • Semiconductor Fabrication • Battery Cooling • Aerospace Defense • Industrial Laser Systems • Food & Beverage • Optoelectronics • Automotive As an industry leader in high-performance Engineered Thermal Systems that demand high system uptime, Laird provides the knowledge, innovation, and resources to ensure exceptional thermal performance and customer satisfaction for applications in the medical, analytical, telecom, industrial, and consumer markets. TEAs offer several advantages over other cooling technologies. For example, conventional fan trays do not cool to below ambient and require an air exchange with the outside environment. On the other hand, TEAs can cool to well below ambient and protect electronics inside enclosures from outside contaminants, and also limit moisture exposure from the outside environment. TEAs also offer precise temperature control and accuracies to within 0.01˚C are achievable under steady-state conditions. • TEAs have several advantages over conventional compressor-based systems: • Compact size and lower weight than conventional compressor-based systems • Mountable in any orientation and have lower noise and vibration • Environmentally friendly, as TEAs do not use CFCs and are RoHS compliant • Low to no field maintenance requirement, which lowers the total cost of ownership. Engineers must now consider thermal management early in the product design process. Simple thermal management solutions, such as adding a fan or heat sink, are no longer typically viable to meet required performance and reliability specifications. A standard TEA allows the designer to start with a basic set of building blocks that mate fans and TEMs to heat exchangers. Laird has conducted two decades worth of design and validation testing on various combinations of thermal components to optimize cooling power and efficiency at various heat loads. This results in engineers saving time with redesign and validation testing a TEA that has already been perfected by Laird. Below is a summary of inherent benefits of initiating a thermal design with a standard TEA versus a custom solution: 1. Reduce product development time by initiated product at TEA level vs TEM level. 2. Reduce costs by utilizing components that are already established in the supply chain. 3. Long term history of products in field provide reliable field data of robustness of products in operation. 4. Product enhancements are captured through market evolution. TEA Portfolio There are five distinct TEA product families that were designed for a specific cooling capacity range, temperature differential range or tight space constraint. The diagram to the right is a perceptual map of a cooling spectrum that can be used to guide designers to a particular product family that will have the desired attributes that the application requires. Thermoelectric Applications Cascade Series 35 – 60 Watts Temperature Differential (ΔT) Laird offers the widest selection of TEAs on the market. Products are designed and manufactured to strict process control standards and pass/ fail criteria, assuring that our customers receive the best possible TEAs. Our standard product portfolio includes an extensive array of thermal management solutions that cover a wide range of cooling capacities with compact form factors and high coefficient of performance. Standard operating voltages are 12 and 24 VDC, and on some models 48 VDC. The standard product offering includes heat transfer mechanisms designed to absorb and dissipate heat by convection, conduction, or through liquid heat exchangers. All products are manufactured in an ISO 9001:2008 certified facility and are designed to meet the cooling needs of many thermal management applications in the medical, analytical, industrial and telecom markets. PowerCool Series 19 – 195 Watts Tunnel Series 11 – 39 W MRC Chiller Series 150, 300 Watts 0 • High Powered Projectors Telecommunications • Industrial Laser Systems Cooling below ambient is necessary to extend life of batteries in wireless base stations. Temperature stabilization is required to maintain peak performance of laser diodes. Food & Beverage • High Powered Laser Diodes Medical Temperature stabilization is required to obtain a high image resolution. Cooling reagent chambers below ambient is critical to extend life of reagents and keep replacement costs down. Rapid thermal cycling is crucial to speed up DNA amplification. • Medical Imaging • Clinical Diagnostics • Medical Lasers • Analytical Instrumentation • PCR 480 Temperature stabilization is critical to maintain industrial lasers at peak performance and allows high end printing systems to produce high quality prints at high run rates. • Kiosks • Battery Backup Systems Cooling Capacity (W) Industrial & Instrumentation Thermoelectric Assemblies are used in a wide range of applications to stabilize the temperature of sensitive electronic components or to cool devices and compartments below ambient. • Telecom Enclosures Outdoor Cooler Series 102 – 480 Watts • Metrology Instrumentation • Digital Color Printing Systems Temperature control is crucial to keep food fresh and beverages cold. • Beverage Coolers • Small Refrigerators • Portable Food Containers • Coffee Makers • Juice Dispensers • Vending Machines Power Cool Series The Power Cool Series offers the widest selection of cooling capacities ranging from 20 to 193 Watts. The TEAs use impingement flow to dissipate heat on the hot side. The cold side heat transfer mechanism can absorb heat using convection (heat sink and fan), conduction (cold plate), or liquid (heat exchanger) means. This product series is offered in 12 or 24 VDC configurations. For 100 Watt systems and higher, 48 VDC is available. The Power Cool Series is designed for indoor use in the medical, analytical, and industrial markets. Air-to-Air Systems (AA) • AA-150 • AA-100 Air-to-Air Assemblies offer dependable, compact performance by cooling objects via convection. Heat is absorbed and dissipated by heat exchangers equipped with fans and ducted shrouds. Specifications apply to ambient temperature of 32°C and nominal voltage with tolerances ±10%. Lw • AA-034 Ww • AA-200 • AA-024 Hw Hc • AA-060 • AA-019 Lc PART NO. AA-019-12-22-00-00 AA-024-12-22-00-00 AA-024-24-22-00-00 AA-034-12-22-00-00 AA-040-12-22-00-00 AA-040-24-22-00-00 AA-060-12-22-00-00 AA-060-24-22-00-00 AA-070-24-22-00-00 AA-100-24-22-00-00 AA-150-24-22-00-00 AA-200-24-22-00-00 AA-200-48-22-00-00 COOLING POWER (W) NOMINAL VOLTAGE (V) CURRENT (A) WEIGHT (kg) 20 24 24 33 41 39 58 58 71 102 143 195 195 12 12 24 12 12 24 12 24 24 24 24 24 48 2.3 2.4 1.5 3.5 6.3 2.6 6.2 3.1 3.8 5.6 7.9 11.3 5.7 0.3 0.6 0.6 0.9 1.8 1.8 2.5 2.5 2.5 4.0 4.1 7.0 7.0 Direct-to-Air Systems (DA) DIMENSIONS (mm) Ww Wc 60 80 80 100 120 120 180 180 180 230 250 350 350 62 82 82 102 122 122 122 122 122 152 153 153 153 40 62 62 82 102 102 102 102 102 122 152 152 152 Hw 57 60 60 60 68 68 68 68 68 75 80 85 85 Hc 48 62 62 64 79 78 78 78 84 86 86 93 93 • DA-160 • DA-044 • DA-034 WwWw • DA-024 • DA-014 • DAC035 • DA-045 HcHc Wc Wc LcLc THERELECTRIC ASSEMBLIES 80 100 100 120 160 160 230 230 230 300 300 400 400 Lc • DA-135 HwHw DA-014-12-02-00-00 DA-024-12-02-00-00 DA-024-24-02-00-00 DA-034-12-02-00-00 DA-034-24-02-00-00 DA-044-12-02-00-00 DA-044-24-02-00-00 DA-045-12-02-00-00 DA-045-24-02-00-00 DA-075-12-02-00-00 DA-075-24-02-00-00 DA-115-24-02-00-00 DA-135-24-02-00-00 DA-160-24-02-00-00 Lw • DA-115 Direct-to-Air Assemblies offer dependable, compact performance by cooling objects via conduction. Heat is absorbed through a cold plate, pumping the heat through the TEM and dissipating it into the air through a heat sink equipped with fan and shroud. Specifications apply to an ambient temperature of 32°C and nominal voltage with tolerances ±10%. PART NO. • AA-070 Wc LwLw • AA-040 COOLING POWER (W) NOMINAL VOLTAGE (V) CURRENT (A) WEIGHT (kg) 12 24 24 34 34 42 44 48 45 71 71 113 135 160 12 12 24 12 24 12 24 12 24 12 24 24 24 24 1.8 2.4 2.4 2.6 1.9 3.8 2.2 6.1 2.5 7.2 3.7 5.8 6.9 7.4 0.2 0.3 0.3 0.5 0.5 0.6 0.6 1.2 1.2 1.7 1.7 2.9 2.9 3.5 DIMENSIONS (mm) Lw 60 80 80 100 100 120 120 160 160 230 230 300 300 300 Lc 50 60 60 60 60 60 60 60 60 120 120 220 220 180 Ww 40 60 60 80 80 100 100 122 122 122 122 152 152 152 Wc 30 40 40 40 40 40 40 60 60 60 60 60 60 130 Hw 44 56 56 59 59 60 60 71 71 71 71 78 78 84 Hc 11 14 14 14 14 14 14 15 15 15 15 16 16 16 Power Cool Series Liquid-to-Air Systems (LA) Liquid-to-Air Assemblies cool or heat liquids that flow through a heat exchanger. The liquid heat exchanger is designed for a re-circulating system, absorbs heat and pumps it through the TEM, where it dissipates into the outside environment through an air heat exchanger. Specifications apply to an ambient temperature of 32°C and nominal voltage with tolerances ±10%. Ww Lw Hw Hc Lc PART NO. LA-024-12-02-00-00 LA-024-24-02-00-00 LA-045-12-02-00-00 LA-045-24-02-00-00 LA-075-24-02-00-00 LA-115-24-02-00-00 LA-160-24-02-00-00 30 Wc 2xRP ⅛“x10 COOLING POWER (W) NOMINAL VOLTAGE (V) CURRENT (A) WEIGHT (kg) 24 24 43 47 71 113 160 12 24 12 24 24 24 24 2.4 2.0 4.1 2.8 3.7 5.8 7.4 0.4 0.4 1.3 1.3 1.8 3.0 3.5 Lw 80 80 160 160 230 300 300 Lc DIMENSIONS (mm) Ww Wc 80 80 100 100 140 240 200 60 60 122 122 122 152 152 60 60 60 60 60 60 136 Hw 64 64 71 71 71 78 84 Tunnel Series The Tunnel Series TEAs are designed with a patented, high-performance cross flow technology that maximizes heat transfer when pulling air through a heat exchanger. The number of airflow paths required to operate is reduced when compared to traditional impingement flow TEAs. This product series is offered in 12 or 24 volt configurations and can cool by either convection or conduction means. Air-to-Air PART NO. DA-011-05-02-00-00 DA-033-12-02-00-00 ATT-027-12-22-00-00 AAT-032-12-22-00-00 AAT-055-12-22-00-00 ATT-055-24-22-00-00 AAT-085-12-22-00-00 AAT-085-24-22-00-00 DAT-029-12-02-00-00 DAT-040-12-02-00-00 DAT-065-12-02-00-00 DAT-065-24-02-00-00 DAT-105-12-02-00-00 DAT-105-24-02-00-00 Direct-to-Air COOLING POWER (W) NOMINAL VOLTAGE (V) CURRENT (A) 11 32 27 33 56 55 82 85 29 40 65 64 103 106 5 12 12 12 12 24 12 24 12 12 12 24 12 24 2.2 3.1 2.3 2.8 5.3 2.6 8.1 4.2 2.6 2.7 5.1 2.6 8.5 4.4 Height 56 82 142 141 142 142 154 154 87 85 85 85 98 98 DIMENSIONS (mm) Length 60 99 115 155 180 180 248 248 96 155 180 180 248 248 Width 44 66 84 84 84 84 83 83 65 65 65 65 83 83 Hc 15 15 20 20 20 20 20 Outdoor Cooler Series The Outdoor Cooler Series is designed for outdoor use to control the temperature of electronic cabinets. The product series has been designed to pass harsh environmental demands such as earthquake resistance, salt fog, wind-driven rain, high temperature exposure and dust. The cooling capacity ranges from 100 to 250 Watts. This product series is offered in 24 and 48 VDC configurations and is designed for outdoor use in the telecom and industrial markets. As a standard option products are also sold with bi-polar thermostatic control to heat and cool to specific temperature set points. PART NO. AA-100-24-44-00-XX AA-100-48-44-00-XX AA-150-24-44-00-XX AA-150-48-44-00-XX AA-200-24-44-00-XX AA-200-48-44-00-XX AA-230-24-D44-00-XX AA-230-48-D44-00-XX AA-250-24-44-00-XX AA-250-48-44-00-XX AA-480-24-44-00-XX AA-480-48-44-00-XX COOLING POWER (W) NOMINAL VOLTAGE (VDC) CURRENT (A) 102 102 143 143 193 193 230 230 244 244 480 480 24 48 24 48 24 48 24 48 24 48 24 48 5.6 2.8 7.9 3.9 11.3 5.6 12.1 6.1 12.1 6.1 19.3 6.1 TEMPERATURE REGULATION Open Loop Open Loop Open Loop Open Loop Open Loop Open Loop Open Loop Open Loop Height 180 180 180 180 183 183 105 105 204 204 122 122 DIMENSIONS (mm) Length Width 300 300 300 300 400 400 400 400 400 400 330 330 122 122 152 152 153 153 180 180 153 153 303 303 Cascade Series The Cascade Series is a TEA that is specifically designed to reach colder temperatures than standard TEA product offerings. The TEMs are custom designed multistage cascades that achieve a high cooling capacity (Qc) at high temperature differentials (ΔT). The cold side mechanism can transfer heat using convective (sink and fan) or conductive (cold plate) means. This product series is offered in 12 or 24 volt configurations and is designed for indoor use in lab instruments. Air-to-Air PART NO. AAC-050-24-22-00-00 DAC-035-12-02-00-00 DAC-060-24-02-00-00 Direct-to-Air COOLING POWER NOMINAL VOLTAGE (V) CURRENT (A) 49 31 58 24 12 24 4.7 4.8 4.6 Height 152 91 91 DIMENSIONS (mm) Length 230 160 230 Width 122 122 122 Direct-to-Liquid Systems (DL) Direct-to-Liquid Assemblies cool or heat objects attached directly to the cold plate. Heat is dissipated into a liquid heat exchanger on the hot side. The liquid circuit is normally a re-circulating type that requires a pump and additional liquid heat exchanger that dissipates heat into the ambient environment. Specifications apply to the warm side liquid temperature of 32°C and nominal voltage with tolerances ±10%. Lw Ww 30 2xRP ⅛“x10 Hw Hc Lc PART NO. DL-060-12-00-00 DL-060-24-00-00 DL-120-24-00-00 DL-210-24-00-00 Wc COOLING POWER (W) NOMINAL VOLTAGE (V) CURRENT (A) WEIGHT (kg) 59 59 122 207 12 24 24 24 4.2 2.1 4.2 8.1 0.4 0.4 0.7 1.3 Lw 100 100 140 240 Lc DIMENSIONS (mm) Ww Wc 60 60 120 120 60 60 60 60 Hw 60 60 60 60 Hc 15 15 15 15 24 24 24 24 Temperature Controllers Laird offers three types of controllers to drive TEAs. The Q Series is designed for single directional thermostatic control. The PR Series is designed for PID control and comes with GUI to make adjustments on the fly. Bi-polar thermostatic controllers are available, but sold with Outdoor Cooler Series units only. DESCRIPTION REGULATION TYPE TEMP RANGE (°C) ACCURACY (°C) INPUT VOLTAGE MAX OUTPUT CURRENT ALARM OUTPUTS SR-54 Microcontroller based device ON/OFF or PID -20 to 100°C ±0.13°C 16 to 60 VDC 20 Amps, 28 VDC 12 Amps, 60 VDC Yes PR-59 Programmable PID Controller PWM Sensor Dependent Sensor Dependent 11-30VDC < 15A Yes QC-50 Single Directional Thermostatic ON/OFF Cool >5ºC Off 35ºC Off
DA-038-12-02-00-00 价格&库存
很抱歉,暂时无法提供与“DA-038-12-02-00-00”相匹配的价格&库存,您可以联系我们找货
