LL‐120‐24‐00‐00‐00
Liquid‐to‐Liquid Thermoelectric Assembly
Thermoelectric cooling unit for medical and industrial laser applications
The Liquid-to-Liquid Series thermoelectric assembly (TEA) offers dependable,
compact performance by cooling objects via liquid to transfer heat. Heat is
absorbed through one liquid heat exchanger and dissipated thru a second
liquid heat exchanger. The thermoelectric modules are custom designed to
achieve a high coefficient of performance (COP) to minimize power
consumption. This product series is available in a wide range of cooling
capacities and voltages. Custom configurations are available, however, MOQ
applies.
Heat exchangers are designed to accommodate distilled water with glycol.
Corrosion resistant turbulators are enclosed inside channels to increase heat
transfer. Mating port adaptors are sold separately.
FEATURES
APPLICATIONS
Compact form factor
Reliable solid-state operation
Precise temperature control
Bi-metal thermostat for overheat
protection
RoHS compliant
Americas: +1.919.597.7300
Europe: +46.31.420530
Asia: +86.755.2714.1166
ets.sales@lairdtech.com
www.lairdtech.com
Medical Diagnostics
Industrial Lasers
Medical Lasers
Analytical Instrumentation
LL‐120‐24‐00‐00‐00
SPECIFICATIONS
TECHNICAL
Technology
Thermoelectric modules, liquid cooling, closed
loop (non‐mixing), filterless, non‐refrigerant
Cooling at ΔT = 0°C
136 W ( 464 Btu/h)
1
Voltage (nominal / maximum)
24/28 VDC
COP (Coefficient of Performance)
74%
Grounding (all voltages)
Positive or negative
Current draw, ±10% (nominal / startup)
4.2/4.7 A
Weight
0.8 kg (1.8 lbs)
Connector type (on unit / mating side)
TEM: Leads, 18 AWG, Red/Black
OHT: Leads
ENVIRONMENTAL
Temperature range
‐40°C to +62°C (‐40°F to +143°F)
Hi‐Pot Testing
750 VDC
75°C±5°C (167°F±41°F) on hot side heat sink
Over temp Thermostat
1)
Max ripple 5%
LL‐120‐24‐00‐00‐00
MECHANICAL DRAWING
For overheating protection, the cooler is equipped with a bimetal thermostat. The maximum rating
for the thermostat is 8 A. For systems with 8 A or less, the thermostat can be connected directly in
series with the thermoelectric modules (TEMs). Otherwise, connect the TEMs to the power source
through a relay of suitable rating which state is controlled with the bimetal thermostat.
Note: Cold side heat exchanger requires insulation to minimize moisture buildup under dew point
conditions.
THR‐DS‐LL‐120‐24‐00‐00‐00_082115
Any information furnished by Laird and its agents is believed to be accurate and reliable. All specifications are subject to change without notice. Responsibility for the use
and application of Laird materials rests with the end user, since Laird and its agents cannot be aware of all potential uses. Laird makes no warranties as to the fitness,
merchantability or suitability of any Laird materials or products for any specific or general uses. Laird, Laird Technologies, Inc or any of its affiliates or agents shall not be
liable for incidental or consequential damages of any kind. All Laird products are sold pursuant to the Laird Technologies’ Terms and Conditions of sale in effect from time
to time, a copy of which will be furnished upon request. © Copyright 2014 Laird Technologies, Inc. All Rights Reserved. Laird, Laird Technologies, the Laird Logo, and other
marks are trademarks or registered trademarks of Laird Technologies, Inc. or an affiliate company thereof. Other product or service names may be the property of third
parties. Nothing herein provides a license under any Laird or any third party intellectual property rights.
很抱歉,暂时无法提供与“LL-120-24-00-00-00”相匹配的价格&库存,您可以联系我们找货
