QB0603A25WCATD
QB0603A25WCATD
    ATC
    Heat Sink Aluminum Nitride Ceramic Heat Spreader
QB0603A25WCATD 数据手册
ATC Q-BRIDGE THERMAL CONDUCTOR ATC Q-Bridge Thermal Conductor ATC’s new Q-Bridge Thermal Conductor is manufactured with the highest quality materials for reliable and repeatable performance providing a cost effective thermal management solution. These devices are constructed with Aluminum Nitride (AlN) or Beryllium Oxide (BeO) and are available in standard EIA form factors. Q-Bridge provides the designer with the ability to manage thermal conditions by directing heat to a thermal ground plane, heat sink or any other specific thermal point of interest. The inherently low capacitance makes this device virtually transparent at RF / microwave frequencies. This device has the added benefit of offering additional layers of protection to adjacent components from hot spot thermal loads. Q-Bridge provides the benefit of increased overall circuit reliability. ATC’s Q-Bridge is manufactured using one-piece construction, providing a RoHS compliant SMT package that is fully compatible with high speed automated pick-and-place processing. It is available in 0402, 0603 and 0805 EIA case sizes. Custom configurations are also available. Applications: • GaN Power Amplifiers • High RF Power Amplifiers • Filters • Synthesizers • Industrial Computers • Switch Mode Power Supplies • Pin & Laser Diodes Features: Functional Applications: • High Thermal Conductivity • Between active device and adjacent ground planes • Low Thermal Resistance • Specific contact pad to case • Low Capacitance • Contact pad to contact pad • Increases Circuit Reliability • Direct component contact to via pad or trace • RoHS Compliant • Edges fully metalized • More efficient thermal management Termination Materials ATC Termination Code Non-Magnetic Termination Materials TN Tin over Non-Magnetic Barrier Termination CA Gold over Non-Magnetic Barrier Termination WN Tin/Lead, Solder over Non-Magnetic Nickel Barrier Termination ATC # 001-1143 Rev B, 3/15 ATC Q-BRIDGE THERMAL CONDUCTOR Dimensions Size (EIA) Mechanical Configurations Length (L) 0402 0.040 ±.002 (1.02 ±0.051) 0.020 ±.002 (0.51 ±0.051) 20 15 0.010 ±.002 (0.25 ±0.051) 0603 0.060 ±.002 (1.52 ±0.051) 0.030 ±.002 (0.76 ±0.051) 25 20 0.015 ±.002 (0.38 ±0.051) 0805 0.080 ±.002 (2.03 ±0.051) 0.050 ±.002 (1.27 ±0.051) 40 25 0.020 ±.002 (0.51 ±0.051) t Standard Thickness (T, mils) Termination (t) A B Width (W) W L T inches (mm) Specifications AlN Case Size 0402 0603 0805 BeO Case Size Thermal Resistance (ºC/W) Thickness A 25 20 10 Thickness B 32 25 16 Thermal Resistance (ºC/W) Thickness A 16 13 7 Thickness B 21 16 11 Thermal Conductivity (mW/ºC)* Thickness A 40 50 100 Capacitance Value (pF) Thickness B 30 40 60 Thickness A .06 .08 .13 Thermal Conductivity (mW/ºC) Thickness A 61 76 153 Thickness B .05 .06 .08 Capacitance Value (pF) Thickness B 46 61 92 Thickness A .05 .06 .10 Thickness B 0402 .04 0603 .05 0805 .07 * Note: Thermal conductivity is normalized to chip size. All values are approximate. Consult factory for extended thermal conductivity options. ATC Part Number Code QB 0603 A 25 W TN T Packaging T = Tape and Reel, std. 1000 pc., 7” Reel 5000 pc., 7” Reel C = ATC Matrix Tray Q-Bridge Case Size Substrate A = AlN; B = BeO Termination TN, CA, WN Thickness (mils) Style W = Edge Wrap E = No Wrap The above part number refers to a Q-Bridge, Thickness 25 mils., (EIA case size 0603), Aluminum Nitride (AlN) substrate, Style W, T Termination, with Tape and Reel Packaging. ATC accepts orders for our parts using designations with or without the “ATC” prefix. Both methods of defining the part number are equivalent, i.e., part numbers referenced with the “ATC” prefix are interchangeable to parts referenced without the “ATC” prefix. Customers are free to use either in specifying or procuring parts from American Technical Ceramics. For additional information and catalogs contact your ATC representative or call direct at +1-631-622-4700. Consult factory for additional performance data. Sales of ATC products are subject to the terms and conditions contained in American Technical Ceramics Corp. Terms and Conditions of Sale (ATC document #001-992 Rev. A 10/03). Copies of these terms and conditions will be provided upon request. They may also be viewed on ATC’s website at www.atceramics.com/productfinder/default.asp. Click on the link for Terms and Conditions of Sale. ATC has made every effort to have this information as accurate as possible. However, no responsibility is assumed by ATC for its use, nor for any infringements of rights of third parties which may result from its use. ATC reserves the right to revise the content or modify its product line without prior notice. © 2015 American Technical Ceramics Corp. All Rights Reserved. ATC # 001-1143, Rev B, 3/15
QB0603A25WCATD 价格&库存
很抱歉,暂时无法提供与“QB0603A25WCATD”相匹配的价格&库存,您可以联系我们找货
