TG-CJ-LI-20-20-6-PF
TG-CJ-LI-20-20-6-PF
    T-GLOBAL
    HEATSINKCER20X20X6MMW/TAPE
TG-CJ-LI-20-20-6-PF 数据手册
TG-CJ-Li-20-20-6-PF Ceramic Heatsink Version 1.220917 Ceramic Heatsink TG-CJ-Li-20-20-6-PF is a ceramic heatsink which is designed from a propriety grade of technical engineering ceramic to give the ultimate combination of manufacturability and thermal performance. TG-CJ-Li-20-20-6-PF offers a high electrical breakdown voltage, high thermal conductivity and will not cause EMI issues like some metal heatsinks. The inherent stability of the ceramic formulation gives high corrosion and chemical resistance which provides a long service life. TG-CJ-Li-20-20-6-PF is supplied with a high-performance thermal tape which can be used to easily and permenantly attach the heatsink to a variety of surfaces. Features Large contact area Low weight High breakdown voltage Excellent heat spreader Custom shapes possible Applications LED, M/B, P/S, LCD, TV, Notebook, PC, PC Telecom Device, Wireless Hub, Power transistor, Power module, CPU, Chip IC Properties REACH Compliant ROHS Compliant Main Component Property Property Unit Density g/cm3 3.66 Water Absorption % 0.002 Sinter Temperature °C 1700 Acid Resistance mg/cm3 Alkali mg/cm3 ≦0.2 Mohs Hardness HV 9 Bend Strength Mpa Compression Intensity Mpa ≧ 610 Maximum Working Temperature °C ≧ 620 1400 Thermal Expansion Coefficient (1x10 ) mm/°C 7.8~8.3 Thermal Shock Resistance T (°C) 200 Thermal Conductivity W/m.k. 40~51 Physical Property Mechanical Property Thermal Property Electrical Property Technical Ceramic ≦0.2 -6 Resisting Rate of Volume Ω °C 1016 DC Breakdown Strength KV/mm 15.2~16.7 Insulation Breakdown Intensity KV/mm 18 Dielectric Constant (1MHz) (E) 10 Dielectric Dissipation (tg o) 0.4*10-3 Part Number Information TG-CJ-Li-20-20-6-PF Product Length Width Depth Adhesive TG-CJ-Li-20-20-6-PF 20 20 6 1 Sided Tape * All measurements in mm T-Global Technology Limited 1 & 2 Cosford Business Park, Central Park, Lutterworth, Leicestershire LE17 4QU U.K. Tel: +44 (0)1455 553 510 Email: sales@tglobaltechnology.com Web: www.tglobaltechnology.com Skype: tglobal.technology VAT #: GB 116 662 714 NOTICE: The information contained herein is to the best of our knowledge true and accurate. However, since the varied conditions of potential use are beyond our control, all recommendations or suggestions are presented without guarantee or responsibility on our part and users should make their own test to determine the suitability of our products in any specific situation. This product is sold without warranty either expressed or implied, of fitness for a particular purpose or otherwise, except that this product shall be of standard quality, and except to the extent otherwise stated T-Global Technology Europe and North America’s invoice, quotation, or order acknowledgment. We disclaim any and liability incurred in connection with the use of information contained herein, or otherwise. All risks of such are assumed by the user. Furthermore, nothing contained herein shall be construed as a recommendation to use any process or to manufacture or to use any product in conflict with existing future patents covering any product or material or its use. Li98 Thermal Tape Version 1.200917 Thermal Tape Li98 thermal tapes are double-sided thermal interface tapes and provide exceptional bonding properties between electronic components and heat sinks, eliminating the need for mechanical fasteners. Li98 can be offered in various formats such as sheets, rolls and die cut parts depending on the applications and have proven reliability under various mechanical, thermal, and environmental stresses. Features Good adhesion (Acrylic PSA) Great reliability Cost effective with great performance Easy to assemble Applications Electronic components: IC, CPU, MOS LED, M/B, P/S, Heat Sink LCD, TV, Notebook PC, PC Telecom Device, Wireless Hub, etc. DDR II Module, DVD Applications, Hand-set applications, etc. Properties REACH Compliant ROHS Compliant Property Colour Thickness Thermal Conductivity Li98 Unit Tolerance Green Red - - Visual 0.15 0.25 mm - ASTM D374 0.0059 0.00984 inch - ASTM D374 0.95 0.95 W/mK ±0.10% ASTM D5470 °C - - Continuous Working Temperature -30 to 120 Short Time Using Temperature 200 °C - - Density 1.85 g/cm3 ±1.3 ASTM D792 400 psi - ASTM D412 Tensile Strength 200 Glass Transition Temperature °C - - Initial Tack 10 8 cm - PSTC-6 Lap Shear Strength 61 55 N/cm2 - ASTM D1002 Die Shear Strength 25 °C 120 109 N/cm2 ±0.2 - Die Shear Strength 80 °C 69 68 N/cm - -30 2 Holding Power 1000g 25 °C >10000 min PSTC-7 Holding Power 1000g 80 °C >10000 min PSTC-7 ASTM D3330 90° Peeling Strength >10 >12 N/in Dielectric Breakdown Voltage (AC) 2 3 kV/mm ±0.10% ASTM D149 Dielectric Breakdown Voltage (DC) 3 4 kV/mm ±0.10% ASTM D149 - - - Reinforcement Carrier Fiberglass Mesh Thermal Impedance vs Pressure vs Deflection T-Global Technology Limited 1 & 2 Cosford Business Park, Central Park, Lutterworth, Leicestershire LE17 4QU U.K. Tel: +44 (0)1455 553 510 Email: sales@tglobaltechnology.com Web: www.tglobaltechnology.com Skype: tglobal.technology VAT #: GB 116 662 714 Test Method Li98 Thermal Tape Part Number Information Li98 Product Length Width Thickness Adhesive Li98 50mm 20 0.15 - * All measurements in mm Standard Weights & Dimensional Tolerance Size Thickness (mm) 0.15 Weight (gr) 0.25 Weight (gr) 100x100 2.78 4.63 150x150 6.24 10.41 300x300 24.98 41.63 320x320 28.42 * All measurements in weights are in gr ** All sizes are in mm 47.36 Die-Cut Thickness Tolerances Data Digi-Key Part T-Global Part 1168-1715-ND LP0001/01-Li98-0.15 1168-1908-ND LP0007/01-Li98-0.25 1168-1867-ND LP0003/01-Li98-0.25 1168-1845-ND TG-CPCB1-Li98-0.15 1168-1843-ND TG-CPCB2-Li98-0.15 1168-1841-ND TG-CPCB3-Li98-0.15 1168-1847-ND LP0001/01-Li98-0.25 1168-1857-ND LP0002/01-Li98-0.25 1168-1907-ND LP0007/01-Li98-0.15 1168-1763-ND LP0003/01-Li98-0.15 1168-1718-ND LP0002/01-Li98-0.15 1168-1766-ND LP0004/01-Li98-0.15 1168-1769-ND LP0005/01-Li98-0.15 1168-1877-ND LP0004/01-Li98-0.25 1168-1772-ND LP0006/01-Li98-0.15 1168-1887-ND LP0005/01-Li98-0.25 1168-1897-ND LP0006/01-Li98-0.25 Digi-Key Part T-Global Part 1168-1715-ND LP0001/01-Li98-0.15 1168-1908-ND LP0007/01-Li98-0.25 1168-1867-ND LP0003/01-Li98-0.25 1168-1845-ND TG-CPCB1-Li98-0.15 1168-1843-ND TG-CPCB2-Li98-0.15 1168-1841-ND TG-CPCB3-Li98-0.15 Thickness Material 0.0007” Acrylic (0.178mm) Elastomer Thickness (mm) Tolerance (mm) 0.3 ±0.03 0.5 ±0.05 0.8 ±0.08 1.0 ±0.1 1.2 ±0.12 1.5 ±0.15 2.0 ±0.2 2.5 - 3.5 ±0.25 4.0 - 4.5 ±0.3 5.0 ±0.35 6.0 - 8.0 ±0.4 9.0 ±0.45 10.0 ±0.5 >10.0 ±0.5 Adhesive Backing Carrier Thermal Conductivity Both sides Fiberglass 2.0 W/m-K * Data for design engineer guidance only. Observed performance varies in application. Engineers are reminded to test the material in application. NOTICE: The information contained herein is to the best of our knowledge true and accurate. However, since the varied conditions of potential use are beyond our control, all recommendations or suggestions are presented without guarantee or responsibility on our part and users should make their own test to determine the suitability of our products in any specific situation. This product is sold without warranty either expressed or implied, of fitness for a particular purpose or otherwise, except that this product shall be of standard quality, and except to the extent otherwise stated T-Global Technology Europe and North America’s invoice, quotation, or order acknowledgment. We disclaim any and liability incurred in connection with the use of information contained herein, or otherwise. All risks of such are assumed by the user. Furthermore, nothing contained herein shall be construed as a recommendation to use any process or to manufacture or to use any product in conflict with existing future patents covering any product or material or its use. Tel: +44 (0)1455 553 510 Email: sales@tglobaltechnology.com Web: www.tglobaltechnology.com Skype: tglobal.technology
TG-CJ-LI-20-20-6-PF 价格&库存
很抱歉,暂时无法提供与“TG-CJ-LI-20-20-6-PF”相匹配的价格&库存,您可以联系我们找货
