BOARD LEVEL
HEAT SINKS
BOARD LEVEL
HEAT SINKS
BOARD LEVEL POWER SEMICONDUCTOR HEAT SINKS
601 & 603 SERIES
UNIVERSAL 678 SERIES VERTICAL HEAT SINK FOR POWER DEVICES
678-39-S & 678-39-C
LOW-HEIGHT HEAT SINKS
DO-4/DO-5 Diodes
MECHANICAL DIMENSIONS
NATURAL AND FORCED
CONVECTION CHARACTERISTICS
Wakefield-Vette introduces Universal 678 series, high performance, low cost and versatile heat sink
with screw or clip for all kinds of standard packages. This type of heat sink provides both vertical and
horizontal mounting options on PCB to accommodate natural and forced convection cooling method.
SPECIFICATIONS
603 SERIES
(EXTRUSION PROFILE 1284)
601 SERIES
SEMICONDUCTOR MOUNTING HOLES
K
E
F
Heat Sink: Aluminum Alloy 6063-T5 or Equivalent with
either degreased or black anodized finish
Spring Clip: Music Wire, Per ASTM A228 with bright
nickel plating
Solder Foot: Cold-rolled Steel, Per ASTM A-366 with
pure tin over copper strike. RoHS compliant.
Insulator (Optional): t-Global H48-1, L37-3F and
H48-6S. The thickness of the insulating material not to
exceed 10 mil (0.01”).
678-39-C
Dimensions: in. (mm)
TO-3
Minimum assembly cost and labor - Spring Clips make
the mounting holes and fasteners obsolete in assembly
operations & reduce costs.
Design Flexibility - Universal mountable and “one fits all”
give designers total freedom to fit their packaging designs
with ideal device pack style and to orient the heat sink to
meet their power dissipations with optimized cooling method.
(see page 7 of data sheet).
Thermal Resistance
Part Number Description Length Width @ Forced Air Flow
678-39-S
MAXIMUM PERFORMANCE NATURAL CONVECTION HEAT
SINK FOR ALL METAL-CASE SEMICONDUCTORS
FEATURES AND BENEFITS
Universal Heat Sink for TO Devices w/Screw Hole,
1.520"
Black Anodize
(38.61mm)
Universal Heat Sink for TO Devices w/ Clip,
Black Anodize
1.520"
(38.61mm)
2.362"
(60.00mm)
0.6°C/W @ 600 LFM
2.362"
(60.00mm)
0.6°C/W @ 600 LFM
THERMAL PERFORMANCE
641 SERIES
Available with a standard TO-3 mounting hole pattern predrilled for cost-effective mounting in limited-height
applications, the 641 Series provides maximum performance in natural convection with an optimized heat sink
surface area. The 641K type with an open channel area of 1.300 in. (33.0) and no predrilled mounting holes can
be adapted to meet mounting requirements for most metal case power semiconductor types.
Standard
P/N
641A
641K
Outline
Dimensions
in. (mm)
4.125 (104.8) x 3.000 (76.2)
Height
in. (mm)
1.000 (25.4)
1.000 (25.4)
Thermal Performance at Typical Load
Mounting
Hole
Pattern
Natural
Convection
(1) TO-3
None
36°C @ 15W
36°C @ 15W
Forced
Convection
0.9°C/W @ 250 LFM
0.9°C/W @ 250 LFM
Weight
lbs. (grams)
0.2900 (131.54)
0.2900 (131.54)
Material: Aluminum Alloy, Black Anodized.
NATURAL AND FORCED
641 SERIES
(EXTRUSION PROFILE 1371)
A
K
76
77
很抱歉,暂时无法提供与“678-39-S”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+47.465071+6.13853
- 10+42.0304310+5.43568
- 25+40.0405125+5.17833
- 50+38.5936250+4.99121
- 216+35.70534216+4.61768
- 432+34.41176432+4.45038
- 648+33.67655648+4.35530
- 1080+32.771581080+4.23826
