MTN-264-55
MTN-264-55
    WAKEFIELD-VETTE
    HEATSINKTO-247/TO-264W/CLIP
MTN-264-55 数据手册
Mountain Series Heat Sinks for TO-264, TO-247 Devices MTN-264-55 Part Number Description Type Package Cooled HEATSINK w/ Two Clips for TO-247 TO-247 and MTN-264-55 TO-264 Top Mount TO-264 Attachment Method Clip and PC Pin Length Width Height Off Base (Height of Fin) 2.17" 1.740" 1.56" (55.11mm) (44.3mm) (39.5mm) Thermal Resistance @ Forced Air Flow 3.7°C/W @ 18 Watts Material Material Finish Black Aluminum Anodized Wakefield-Vette's Mountain Series Heat Sinks are high performance, low cost, configurable, scalable and compact with a matrix clip system for TO220, TO-247, TO-264 and other standard packages. This type powerful heat sink provides easiest assembly, largest surface areas, smallest space occupation and all-in-one solution. The power dissipations can be easily increased simply by extending the fin height on each side of the heat sink, while keeping the heat sink height and PCB layout the same. It is the ideal type of heat sink for high power density and small size (1U or 2U) electronic packaging with forced convention cooling. FEATURES AND BENIFITS ● Minimum assembly cost and labor Spring Clips make the mounting holes and fasteners obsolete in assembly operations & reduce costs. ● Maximum Thermal Transfer Maximum surface area per unit volume, efficient cooling fins & consistent mounting force reduces thermal resistance ● Maximum Repeatability Constant spring force over repeated assembly/disassembly ● Maximum Reliability Resilient spring action locks electronic component in place. Fewer parts in assembly and no fasteners and washers required. Prevent short circuit by eliminating metal particles generated from hardware or thread tapping Thermal Resistance www.wakefield-vette.com
MTN-264-55 价格&库存
很抱歉,暂时无法提供与“MTN-264-55”相匹配的价格&库存,您可以联系我们找货
MTN-264-55
  • 2460+89.991972460+11.64287
