BOARD LEVEL
HEAT SINKS
BOARD LEVEL
HEAT SINKS
BOARD LEVEL POWER SEMICONDUCTOR HEAT SINKS
289 & 290 SERIES
LOW-COST SINGLE OR DUAL PACKAGE
HEAT SINKS
TO-218; TO-202; TO-220
HIGH-PERFORMANCE, HIGH-POWER VERTICAL
MOUNT HEAT SINKS
TO-220
237 & 252 SERIES
Low in cost and compact in overall dimensions, one 289 Series heat sink can accommodate one semiconductor;
the 289 Series is available with a black anodized finish (289-AB) or with no finish (289-AP). Two semiconductors
can be mounted to the 290-2AB style.
Standard
P/N
Height Above
PC Board
in. (mm)
Horizontal Mounting
Maximum Footing
in. (mm)
289-AB
289-AP
290-1AB
290-2AB
0.500 (12.7)
0.500 (12.7)
0.500 (12.7)
0.500 (12.7)
1.000 (25.4) x 0.710 (18.1)
1.000 (25.4) x 1.180 (30.0)
Thermal Performance at Typical Load
Natural
Convection
Forced
Convection
50°C @ 2W
50°C @ 2W
44°C @ 2W
44°C @ 2W
9.0 C/W @ 400 LFM
9.0 C/W @ 400 LFM
7.0 C/W @ 400 LFM
7.0 C/W @ 400 LFM
Weight
lbs. (grams)
0.0055 (2.49)
0.0055 (2.49)
0.0082 (3.72)
0.0081 (3.67)
Material: Aluminum, Black Anodized
Standard
P/N
Height Above
Footprint
PC Board
Dimensions
Mounting
Solderable Mounting
Natural
Forced
in. (mm) in. (mm)
Configuration Tab Options Style Convection
Convection
237-167AB2
237-167AB3
237-167ABE2-24
252-167AB2
252-167AB3
252-167ABE2-24
1.675 (42.5)
1.675 (42.5)
1.675 (42.5)
1.675 (42.5)
1.675 (42.5)
1.675 (42.5)
1.000 (25-4) x 1.000 (25.4)
1.000 (25.4) x 1.000 (25.4)
Vertical
Vertical
Vertical
Vertical
Vertical
Vertical
2, Twisted
3, Twisted
2, Solderable
2, Twisted
3, Twisted
2, Solderable
Clip/Mtg
Clip/Mtg
Clip/Mtg
Clip/Mtg
Clip/Mtg
Clip/Mtg
Slot 46°C @ 4W 4.5°C/W @ 200 LFM
Slot 40°C @ 4W 4.5°C/W @ 200 LFM
Order SpeedClips™ 285SC or 330SC separately for rapid component installation, lowering manufacturing costs.
289 SERIES
MECHANICAL DIMENSIONS
NATURAL AND FORCED
CONVECTION CHARACTERISTICS
290 SERIES
227-167
237-167AB2
252-167AB2
252-167
NATURAL AND FORCED
237-167AB2-24
252-167AB2-24
237 AND 252 SERIES
237-167AB3
252-167AB3
237 AND 252 SERIES
Dimensions: in. (mm)
237-167AB3
252-167AB3
HIGH-PERFORMANCE SLIM PROFILE HEAT SINKS
WITH INTEGRAL CLIPS
Multiwatt
Standard
P/N
250-122AB
250-122ABE-09
250-122ABE-25
250 SERIES
Height Above
Footprint
PC Board
Dimensions
Mounting
Solderable Mounting
Natural
Forced
in. (mm) in. (mm) Configuration Tab Options Style Convection Convection
1.220 (31.0)
1.220 (31.0)
1.380 (35.1)
1.000 (25.4) x .500 (12.7)
Vert./Horiz.
Vertical
Vertical
No Tab
09
25
Clip
Clip
Clip
50°C @ 4W
50°C @ 4W
50°C @ 4W
3.7°C/W @ 400 LFM
3.7°C/W @ 400 LFM
3.7°C/W @ 400 LFM
250 SERIES
250-122AB-09
250-122AB-25
NATURAL AND FORCED
291 SERIES
LABOR-SAVING CLIP-ON HEAT SINKS
TO-220
Designed for mounting horizontally or vertically on a circuit board, 291 Series heat sinks employ a unique clip for
attachment of TO-220 case styles. One type is available with a locking clip and one with a 0.140 in. (3.6) diameter
mounting hole only.
Vertical
Height Above
Standard
PC Board
P/N
in. (mm)
291-C236AB
291-H36AB
0.860 (21.9)
0.860 (21.9)
Mounting Footprint
Dimensions
Mounting
in. (mm)
Style
1.100 (27.0) x 0.360 (9.1)
TO-220 (Clip)
TO-220 (Mtg. Hole)
Natural
Forced
Convection
Convection
80°C @ 2W
68°C @ 2W
24°C/W @ 600 LFM
16°C/W @ 600 LFM
Weight
lbs. (grams)
0.0026 (1.18)
0.0026 (1.18))
291 SERIES
NATURAL AND FORCED
250-122AB
64
Contact us: (603) 635-2800
291-H
291-C2
65
很抱歉,暂时无法提供与“290-1AB”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+5.40208
- 10+4.64866
- 100+4.35760
- 500+4.10845
- 国内价格 香港价格
- 1+4.859921+0.62953
- 10+4.3012910+0.55717
- 25+4.0985725+0.53091
- 50+3.9501050+0.51168
- 100+3.80697100+0.49314
- 250+3.62637250+0.46975
- 500+3.49532500+0.45277
- 1000+3.369001000+0.43641
- 5000+3.092615000+0.40060
