Aluminum Heat Sink for Raspberry Pi 3 - 14 x 14 x 8mm
PRODUCT ID: 3083
Description
Looking for a nice way to cool down your Raspberry Pi 3? Check out this 14x14x8 Heat Sink!
This heat sink is made from high quality aluminum and will work perfectly with any Raspberry
Pi but is best paired with a Raspberry Pi 3 since it can run a little hot. It comes with thermal
adhesive already applied to the back making installation super easy. Clean the surface of the
chip of any dust or grease then peel off the protective film and press the heat sink firmly onto
the chip. You can use this heatsink with any of our injection molded Adafruit Pi Enclosures,
but it may not work with other enclosures and most HATs will not fit on top with the heat sink
installed.
We don't have formal specs for this heat sink, but when we ran 'stress -c 4' on the Pi 3 to run
all 4 CPUs, a heat-sink-less Pi quickly dropped down to 0.96 GHz to maintain thermal
equilibrium. With this heat sink installed, it could run at 1.1 GHz (so, approx 14% higher
performance)
Note that you do not need a heatsink for the Pi 3, it will automatically adjust its speed to
avoid overheating! It can also, of course, be used for other processors and chips
Technical Details
Product Dimensions: 14.0mm x 13.8mm x 8.2mm / 0.6" x 0.5" x 0.3"
Product Weight: 1.8g/0.1oz
Engineered in NYC Adafruit ®
很抱歉,暂时无法提供与“3083”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+13.095161+1.64380
