PH3-300-300-0.21-1A
PH3-300-300-0.21-1A
    T-GLOBAL
    IR HEAT SPREADER/EMITTER W/ADH
PH3-300-300-0.21-1A 数据手册
Polyester: Part Number Our standard part numbers are built as follows: NAME OF THE PRODUCT – LENGTH – WIDTH – THICKNESS – ADHESIVE *All measurements in mm E.g: PH3 – 150 – 150 – 0.06 – 1A PH3 Product with a length of 150 mm a width of 150 mm, thickness of 0.06 mm and 1 side adhesive PH3 – 150 – 150 – 0.06 PH3 Product with a length of 150 mm a width of 150 mm, thickness of 0.06 mm and NO ADHESIVE Common Weights Thickness Size 100x100 150x150 300x300 320x320 0.06 17.08 38.64 155.08 176.47 0.11 17.14 38.70 155.14 176.53 0.21 17.25 38.81 155.25 176.64 * All weights are in gr ** All sizes are in mm Application Guide Without thermal interface material, the heat flow go through joint face slowly, and the thermal conductive performance is bad (Thermal conductivity of air is 0.026 W/m K). Using T-Global Thermal Interface Material to link two joint faces, the heat flow go through equally, and the thermal conductive performance is good. Digi-Key PAR T NUMBERS NOTICE: The information contained herein is to the best of our knowledge true and accurate. However, since the varied conditions of potential use are beyond our control, all recommendations or suggestions are presented without guarantee or responsibility on our part and users should make their own test to determine the suitability of our products in any specific situation. This product is sold without warranty either expressed or implied, of fitness for a particular purpose or otherwise, except that this product shall be of standard quality, and except to the extent otherwise stated T-Global Technology Europe and North America’s invoice, quotation, or order acknowledgment. We disclaim any and liability incurred in connection with the use of information contained herein, or otherwise. All risks of such are assumed by the user. Furthermore, nothing contained herein shall be construed as a recommendation to use any process or to manufacture or to use any product in conflict with existing future patents covering any product or material or its use. Tel: +44 (0) 1455 553 510 Email: sales@tglobaltechnology.com Web: www.tglobaltechnology.com Skype: tglobal.technology
PH3-300-300-0.21-1A 价格&库存
很抱歉,暂时无法提供与“PH3-300-300-0.21-1A”相匹配的价格&库存,您可以联系我们找货
