TG-CJ-30.5-30.5-6-PF 数据手册
Ceramic Heatsink
Version 1.220917
Ceramic Heatsink
T-Global’s range of ceramic heatsinks have been designed from a proprietary
blend of engineering ceramics to offer superior thermal management for the most
demanding of applications. Compared to aluminium, ceramics confer additional
benefits such as electrically isolating, resistant to corrosion, low weight and does not
act like an antenna. The addition of a pre-applied thermal tape further reduces the
manufacturing complexity when compared to aluminum heatsinks.
Features
Large contact area
Low weight
High breakdown voltage
Excellent heat spreader
Custom shapes possible
Applications
LED, M/B, P/S, LCD, TV, Notebook, PC, PC Telecom Device, Wireless Hub,
Power transistor, Power module, CPU, Chip IC
Properties
REACH Compliant
ROHS Compliant
Main Component
Property
Physical Property
Mechanical Property
Thermal Property
Electrical Property
Technical Ceramic
Property
Unit
Density
g/cm3
3.66
Water Absorption
0.002
Sinter Temperature
°C
Acid Resistance
mg/cm
Alkali
mg/cm
1700
3
Mohs Hardness
HV
Bend Strength
Mpa
3
≦0.2
≦0.2
9
Compression Intensity
Mpa
≧ 610
Maximum Working Temperature
°C
1400
Thermal Expansion Coefficient
(1x10 )
mm/°C
7.8~8.3
Thermal Shock Resistance
T (°C)
200
Thermal Conductivity
W/m.k.
40~51
≧ 620
-6
Resisting Rate of Volume
Ω °C
1016
DC Breakdown Strength
KV/mm
15.2~16.7
Insulation Breakdown Intensity
KV/mm
18
Dielectric Constant (1MHz)
(E)
10
Dielectric Dissipation
(tg o)
0.4*10-3
Part Number Information
Product
Length
Width
Depth
Adhesive
30.5
30.5
6
* All measurements in mm
T-Global Technology Limited
1 & 2 Cosford Business Park, Central Park,
Lutterworth, Leicestershire LE17 4QU U.K.
Tel: +44 (0)1455 553 510
Email: sales@tglobaltechnology.com
Web: www.tglobaltechnology.com
Skype: tglobal.technology
VAT #: GB 116 662 714
NOTICE: The information contained herein is to the best of our knowledge true and accurate. However, since the varied conditions of potential use are beyond our control, all recommendations or
suggestions are presented without guarantee or responsibility on our part and users should make
their own test to determine the suitability of our products in any specific situation. This product is
sold without warranty either expressed or implied, of fitness for a particular purpose or otherwise,
except that this product shall be of standard quality, and except to the extent otherwise stated
T-Global Technology Europe and North America’s invoice, quotation, or order acknowledgment. We
disclaim any and liability incurred in connection with the use of information contained herein, or
otherwise. All risks of such are assumed by the user. Furthermore, nothing contained herein shall
be construed as a recommendation to use any process or to manufacture or to use any product in
conflict with existing future patents covering any product or material or its use.
TG-CJ-30.5-30.5-6-PF 价格&库存
很抱歉,暂时无法提供与“TG-CJ-30.5-30.5-6-PF”相匹配的价格&库存,您可以联系我们找货
