TG-CJ-Li-32-32-6-PF
Ceramic Heatsink
Version 1.220917
Ceramic Heatsink
T-Global’s range of ceramic heatsinks have been designed from a proprietary
blend of engineering ceramics to offer superior thermal management for the most
demanding of applications. Compared to aluminium, ceramics confer additional
benefits such as electrically isolating, resistant to corrosion, low weight and does not
act like an antenna. The addition of a pre-applied thermal tape further reduces the
manufacturing complexity when compared to aluminum heatsinks.
Features
Large contact area
Low weight
High breakdown voltage
Excellent heat spreader
Custom shapes possible
Applications
LED, M/B, P/S, LCD, TV, Notebook, PC, PC Telecom Device, Wireless Hub,
Power transistor, Power module, CPU, Chip IC
Properties
REACH Compliant
ROHS Compliant
Main Component
Property
Thermal Property
Electrical Property
Property
Unit
Density
g/cm3
3.66
0.002
Water Absorption
Sinter Temperature
°C
Acid Resistance
mg/cm
3
Alkali
mg/cm
3
Mohs Hardness
HV
Bend Strength
Mpa
Compression Intensity
Mpa
Physical Property
Mechanical
Property
Technical Ceramic
1700
≦0.2
≦0.2
9
≧ 610
Maximum Working Temperature
°C
≧ 620
Thermal Expansion Coefficient
(1x10-6) mm/°C
7.8~8.3
Thermal Shock Resistance
T (°C)
200
1400
Thermal Conductivity
W/m.k.
40~51
Resisting Rate of Volume
Ω °C
1016
DC Breakdown Strength
KV/mm
15.2~16.7
Insulation Breakdown Intensity
KV/mm
18
Dielectric Constant (1MHz)
(E)
10
Dielectric Dissipation
(tg o)
0.4*10-3
Part Number Information
TG-CJ-Li-32-32-6-PF
Product
Length
Width
Depth
Adhesive
TG-CJ-Li-32-32-6-PF
32
32
6
1 Sided Tape
* All measurements in mm
T-Global Technology Limited
1 & 2 Cosford Business Park, Central Park,
Lutterworth, Leicestershire LE17 4QU U.K.
Tel: +44 (0)1455 553 510
Email: sales@tglobaltechnology.com
Web: www.tglobaltechnology.com
Skype: tglobal.technology
VAT #: GB 116 662 714
NOTICE: The information contained herein is to the best of our knowledge true and accurate. However, since the varied conditions of potential use are beyond our control, all recommendations or
suggestions are presented without guarantee or responsibility on our part and users should make
their own test to determine the suitability of our products in any specific situation. This product is
sold without warranty either expressed or implied, of fitness for a particular purpose or otherwise,
except that this product shall be of standard quality, and except to the extent otherwise stated
T-Global Technology Europe and North America’s invoice, quotation, or order acknowledgment. We
disclaim any and liability incurred in connection with the use of information contained herein, or
otherwise. All risks of such are assumed by the user. Furthermore, nothing contained herein shall
be construed as a recommendation to use any process or to manufacture or to use any product in
conflict with existing future patents covering any product or material or its use.
Li98
Thermal Tape
Version 1.200917
Thermal Tape
Li98 thermal tapes are double-sided thermal interface tapes and provide exceptional
bonding properties between electronic components and heat sinks, eliminating the
need for mechanical fasteners. Li98 can be offered in various formats such as sheets,
rolls and die cut parts depending on the applications and have proven reliability
under various mechanical, thermal, and environmental stresses.
Features
Good adhesion (Acrylic PSA)
Great reliability
Cost effective with great performance
Easy to assemble
Applications
Electronic components: IC, CPU, MOS
LED, M/B, P/S, Heat Sink
LCD, TV, Notebook PC, PC Telecom Device, Wireless Hub, etc.
DDR II Module, DVD Applications, Hand-set applications, etc.
Properties
REACH Compliant
ROHS Compliant
Property
Colour
Thickness
Li98
Unit
Tolerance
Green
Red
Visual
0.15
0.25
mm
ASTM D374
0.0059
0.00984
inch
ASTM D374
0.95
0.95
W/mK
±0.10%
ASTM
D5470
°C
Continuous Working Temperature
-30 to 120
Short Time Using Temperature
200
°C
Density
1.85
g/cm3
±1.3
ASTM D792
400
psi
ASTM D412
Tensile Strength
200
Glass Transition Temperature
°C
Initial Tack
10
8
cm
PSTC-6
Lap Shear Strength
61
55
N/cm2
ASTM
D1002
Die Shear Strength 25 °C
120
109
N/cm2
±0.2
Die Shear Strength 80 °C
69
68
N/cm
-30
2
Holding Power 1000g 25 °C
>10000
min
PSTC-7
Holding Power 1000g 80 °C
>10000
min
PSTC-7
ASTM
D3330
90° Peeling Strength
>10
>12
N/in
Dielectric Breakdown Voltage
(AC)
2
3
kV/mm
±0.10%
ASTM D149
(DC)
3
4
kV/mm
±0.10%
ASTM D149
Reinforcement Carrier
Fiberglass Mesh
Thermal Impedance vs Pressure vs Deflection
Test Method
Li98
Thermal Tape
Li98
Product
Length
Width
Thickness
Adhesive
Li98
50mm
Standard Weights & Dimensional Tolerance
Size
Thickness (mm)
0.15 Weight (gr)
0.25 Weight (gr)
100x100
2.78
4.63
150x150
6.24
10.41
300x300
24.98
41.63
320x320
28.42
* All measurements in weights are in gr
** All sizes are in mm
47.36
Die-Cut
Thickness
Tolerances
Data
Digi-Key Part
T-Global Part
1168-1715-ND
LP0001/01-Li98-0.15
1168-1908-ND
LP0007/01-Li98-0.25
1168-1867-ND
LP0003/01-Li98-0.25
1168-1845-ND
TG-CPCB1-Li98-0.15
1168-1843-ND
TG-CPCB2-Li98-0.15
1168-1841-ND
TG-CPCB3-Li98-0.15
1168-1847-ND
LP0001/01-Li98-0.25
1168-1857-ND
LP0002/01-Li98-0.25
1168-1907-ND
LP0007/01-Li98-0.15
1168-1763-ND
LP0003/01-Li98-0.15
1168-1718-ND
LP0002/01-Li98-0.15
1168-1766-ND
LP0004/01-Li98-0.15
1168-1769-ND
LP0005/01-Li98-0.15
1168-1877-ND
LP0004/01-Li98-0.25
1168-1772-ND
LP0006/01-Li98-0.15
1168-1887-ND
LP0005/01-Li98-0.25
1168-1897-ND
LP0006/01-Li98-0.25
Digi-Key Part
T-Global Part
1168-1715-ND
LP0001/01-Li98-0.15
1168-1908-ND
LP0007/01-Li98-0.25
1168-1867-ND
LP0003/01-Li98-0.25
1168-1845-ND
TG-CPCB1-Li98-0.15
1168-1843-ND
TG-CPCB2-Li98-0.15
1168-1841-ND
TG-CPCB3-Li98-0.15
Thickness
Material
0.0007”
Acrylic
(0.178mm) Elastomer
Thickness (mm)
Tolerance (mm)
0.3
±0.03
0.5
±0.05
0.8
±0.08
1.0
±0.1
1.2
±0.12
1.5
±0.15
2.0
±0.2
2.5 - 3.5
±0.25
4.0 - 4.5
±0.3
5.0
±0.35
6.0 - 8.0
±0.4
9.0
±0.45
10.0
±0.5
>10.0
±0.5
Adhesive
Backing
Carrier
Thermal
Conductivity
Both
sides
Fiberglass
2.0 W/m-K
* Data for design engineer guidance
only. Observed performance varies in
application. Engineers are reminded
to test the material in application.
control, all recommendations or suggestions are presented without guarantee or responsibility on our part and users should make their own test to determine the
suitability of our products in any specific situation. This product is sold without warranty either expressed or implied, of fitness for a particular purpose or otherwise,
except that this product shall be of standard quality, and except to the extent otherwise stated T-Global Technology Europe and North America’s invoice, quotation, or
order acknowledgment. We disclaim any and liability incurred in connection with the use of information contained herein, or otherwise. All risks of such are assumed
by the user. Furthermore, nothing contained herein shall be construed as a recommendation to use any process or to manufacture or to use any product in conflict
Tel: +44 (0)1455 553 510 Email: sales@tglobaltechnology.com Web: www.tglobaltechnology.com Skype: tglobal.technology
