BOARD LEVEL
HEAT SINKS
BOARD LEVEL
HEAT SINKS
BOARD LEVEL POWER SEMICONDUCTOR HEAT SINKS
ALUMINUM AND COPPER LOW-COST WAVE-SOLDERABLE
HEAT SINKS
286 SERIES
Efficient heat removal at low cost can be achieved by inserting the 286 Series directly into pre-drilled circuit boards;
scored mounting tabs may be bent after insertion to provide added stability. The 286 Series can be wave-soldered
directly to the board. See also 286DB Series on page 55.
Standard
P/N
286-AB
286-CBTE
286-CTE
Height Above
PC Board
Maximum Footprint
in. (mm)
in. (mm)
Material
1.190 (30.2)
1.190 (30.2)
1.190 (30.2)
1.000 (25.4) x 0.500 (12.7)
Thermal Performance at Typical Load
Natural
Forced
Convection
Convection
Aluminum, Anodized
Copper, Black
Copper, Tinned
58°C @ 4W
58°C @ 4W
58°C @ 4W
7.4°CW @ 200 LFM
7.4°CW @ 200 LFM
7.4°CW @ 200 LFM
Weight
lbs. (grams)
0.0085 (3.86)
0.0250 (11.34)
0.0250 (11.34)
Material: 286-AB style (aluminum, black anodized), 286-CBT style (copper, black paint tin tabs), and 286-CT style (copper, tinned).
MECHANICAL DIMENSIONS
285 SC AND 330 SC SPEEDCLIPS™
TO-220
285 & 330 SERIES
SpeedClips™ employ a locking safety tab for mounting. Must be ordered separately for these heat sink series. Use
these SpeedClips™ with our 237, 240, and 252 Series heat sinks for the lowest production assembly time and cost.
Order one SpeedClip™ for each heat sink purchased. Must be purchased with heat sinks.
Standard
P/N
Nominal Installed
Loading Force
285 SC
330 SC
10 lbs
4 lbs
For Use
With Series
Material
Weight
lbs. (grams)
232, 237, 240, 252, 667
Carbon Steel
Stainless Steel
0.00053 (0.24)
0.00074 (0.34)
NATURAL AND FORCED
CONVECTION CHARACTERISTICS
Speed
Clip
330 SC
Speed
Clip
285 SC
4 lb (17.8N)
Nominal Force
Installed
10 lb (44.5N)
Nominal Force
Installed
Dimensions: in. (mm)
WAVE-SOLDERABLE LOW-COST HEAT SINKS
TO-220
695 SERIES
287 SERIES
287-1ABE 287-1ABH
287-2ABE 287-2ABH
1.180 (30.0)
1.180 (30.0)
Natural
Forced
Convection
Convection
Maximum
Footprint “A”
in. (mm)
1.000 (25.4) x 1.000 (25.4)
65°C @ 4W
55°C @ 4W
7.8°CW @ 200 LFM
6.4°CW @ 200 LFM
Stud-Mount
Mount and effectively heat sink small stud-mounted diodes with the 695 Series space-saving heat sink type. Each
unit is black anodized aluminum with an 0.200 in. (5.1) dia. mounting hole centered in the base. The folded fin
design provides good heat dissipation for use where height is limited above the printed circuit board or base plate.
Mount these cost-effective TO-220 heat sinks vertically into pre-drilled printed circuit boards. Soldered, pre-tinned
tabs can be wavesoldered directly to the board. A 0.375 in. (9.5 mm) mounting slot allows for correct positioning
of TO-220 and similar semiconductor packages.
Height Above
Standard P/N
PC Board
Mounting Slot Mounting Hole
in. (mm)
SPACE-SAVING HEAT SINKS FOR SMALL
STUD-MOUNTED DIODES
Weight
lbs. (grams)
Standard
P/N
Maximum
Width
in. (mm)
0.0090 (4.08)
0.0140 (6.35)
695-1B
1.330 (33.8)
Height
in. (mm)
0.530 (13.7)
Natural
Forced
Convection
Convection
72°C @ 4.0W
5
.2°C/W @ 400 LFM
Weight
lbs. (grams)
0.008 (4.0)
Material: Aluminum, Black Anodized
NATURAL AND FORCED
NATURAL AND FORCED
Standard P/N Dim. “A”
287-1AB
0.500 (12.7)
287-2AB
1.000 (25.4)
287-1ABH
0.500 (12.7)
287-2ABH
1.000 (25.4)
66
wakefield-vette.com
Contact us: (603) 635-2800
67
很抱歉,暂时无法提供与“286-AB”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+4.827101+0.62400
- 10+4.7433010+0.61320
- 25+4.6954025+0.60700
- 50+4.2043050+0.54350
- 100+4.18030100+0.54040
- 250+4.16830250+0.53880
- 500+3.62930500+0.46920
- 1000+3.605401000+0.46610
- 5000+3.593405000+0.46450
- 国内价格 香港价格
- 100+5.89008100+0.76136
- 500+4.39868500+0.56858
- 1000+4.280081000+0.55325
- 2500+4.153362500+0.53687
