BOARD LEVEL
HEAT SINKS
BOARD LEVEL
HEAT SINKS
BOARD LEVEL POWER SEMICONDUCTOR HEAT SINKS
217 SERIES
SURFACE MOUNT HEAT SINKS
D2PAK; TO-220; SOT-223; SOL-20
Compatible with surface mount technology (SMT) automated production techniques for ease of assembly
and a variety of soldering methods, these heat sinks allow greater packaging densities and reduction in
PC-board area, increasing the power dissipation of surface mount devices (SMDs) while maintaining and
improving manufacturers’ component thermal specifications.
217 SERIES
D2PAK; TO-220; SOL-20
MECHANICAL DIMENSIONS
BOARD LAYOUT RECOMMENDATIONS
TUBE DETAILS
FEATURES AND BENEFITS
• No interface material is needed
• Copper with matte tin plating for improved solderability and assembly
• Both the component and the heat sink are installed on the PC-board utilizing
standard SMT assembly equipment for ”Tape & Reel” and “Tube” formats
• EIA standards and ESD protection are specified
• Can be used with water soluble or no clean SMT solder creams or other pastes
Package
Quantity
1
Thermal Performance at Typical Load
Natural
Forced
Convection
Convection
55°C @ 1W
16.0°C/W @ 200 LFM
55°C @ 1W
16.0°C/W @ 200 LFM
55°C @ 1W
16.0°C/W @ 200 LFM
Material: Copper, Matte Tin Plated
Tube: 16.25 Inches Long,
Min. esd Material with
Nail Stops
20 Pieces per Tube
217-36CTT6
THERMAL PERFORMANCE
6 LAYER BOARD, D’ PAK
125°C LEAD, 40°C AMBIENT
SOL 20
REF: JEDEC TO-263 (DD PAK)
REF: JEDEC MO-169 (DD PAK)
Dimensions: in.
Device Tab dT, C
218 SERIES
Standard
P/N
Height Above
PC Board
in. (mm)
Maximum
Footprint
in. (mm)
.40 (10.2)
.40 (10.2)
.90 (22.9) x .315 (8.0)
1.03 (26.2) x .50 (12.7)
218-40CTE3
218-40CTE5
Device Power Dissipation. W
62°C rise @ 2W
62°C rise @ 2W
Device + HS, NC Device + HS, 100 lfm
Device + HS, 200 lfm Device + HS, 300 lfm
AIR VELOCITY (LFM)
200
400
600
AIR VELOCITY (LFM)
800
100
1000
25
80
15
40
10
0.5
400
1.0
600
1.5
800
2.0
2.5
HEAT SINK TEMPERATURE RISE
ABOVE AMBIENT AIR (C)
NOTES
1. Material to be “ESD”
2. Approximately 6 Meters per Reel
3. 250 Pieces per Reel.
200
100
1000
25
80
15
40
10
218-40CT3
200
0.5
wakefield-vette.com
OVE AMBIENT AIR (C)
60
40
400
600
400
1.0
Solid line = 218-40CT5
218-40CT5
800
600
1.5
800
2.0
2.5
800
Dashed Line = 218-40CT3
AIR VELOCITY (LFM)
AIR VELOCITY (LFM)
100
600
HEAT DISSIPATED (WATTS)
1000
16
14
12
10
8
6
4
TAPE DETAILS
400
217-36CTR6
REEL DETAILS
21°C/W @ 200LFM
21°C/W @ 200LFM
NATURAL AND FORCED
CONVECTION CHARACTERISTICS
Device only, NC
Dimensions: in.
46
Thermal
Natural Convection
Forced Convection
THERMAL RESISTANCE SINK TO
AMBIENT (C)
KEY:
SMT Devices
SECTION A-A
217-36CT6
217-36CT6
AMBIENT (C)
Package
Format
Bulk
Tube
Tape & Reel
Contact us: (603) 635-2800
100
200
400
600
800
1000
10
80
8
60
6
40
4
AMBIENT (C)
Height Above
PC Board
Dimensions
in. (mm)
in. (mm)
.360 (9.1)
.600 (15.2) x .740 (18.8)
.360 (9.1)
.360 (9.1)
AMBIENT (C)
Footprint
Standard
P/N
217-36CTE6
217-36CTTE6
217-36CTRE6
47
很抱歉,暂时无法提供与“218-40CTE3”相匹配的价格&库存,您可以联系我们找货
