BOARD LEVEL
HEAT SINKS
BOARD LEVEL
HEAT SINKS
BOARD LEVEL POWER SEMICONDUCTOR HEAT SINKS
288 SERIES
COMPACT WAVE-SOLDERABLE LOW-COST
HEAT SINKS
TO-220 and TO-202
Mounting tabs are pre-tinned to ensure excellent wave-solder bond and good electrical connections for
vertical mounting of TO-220 and TO-202 semiconductor packages. These heat sinks are designed for use
where minimum PC board space is available. The 288-1AB is a stamped aluminum heat sink, black anodized,
designed for applications requiring good heat dissipation from a heat sink occupying minimum space,
available at minimum cost.
TOP-MOUNT BOOSTER HEAT SINKS FOR USE WITH
270/272/280 SERIES
TO-220
271 SERIES
NATURAL AND FORCED
CONVECTION CHARACTERISTICS
MECHANICAL DIMENSIONS
Thermal Performance at Typical Load
Standard
P/N
Height Above
PC Board
in. (mm)
Maximum
Footprint
in. (mm)
288-1ABE
1.250 (31.8)
0.875 (22.2) x 0.215 (5.5)
Natural
Convection
85°C @ 4W
Forced
Convection
Weight
lbs. (grams)
12°C/W @ 200 LFM
0.0057 (2.59)
NATURAL AND FORCED
Dimensions: in. (mm)
270, 272, &
280 SERIES
SMALL FOOTPRINT LOW-COST HEAT SINKS
TO-220 and TO-202
These exceptionally low-cost heat sinks can be mounted horizontally under a TO-220 or TO-202 case style
with a maximum height of only 0.375 in. (9.4). For added performance, a 271 Series heat sink can also be used
for double-sided heat dissipation. The 270-AB and 280-AB accept one power semiconductor; the 272-AB is
designed for two power semiconductors. Specify solderable tab options for the 272 Series by the addition of
suffix “O1” or “02” to the standard part number (i.e. 272-AB01 or 272-AB02).
Standard
P/N
270-AB
272-AB
280-AB
Height Above
PC Board
in. (mm)
0.375 (9.4)
0.375 (9.4)
0.375 (9.4)
Horizontal Mounting
Maximum Footing
Solderable
in. (mm)
Tab Options
1.750 (44.5) x 0.700 (17.8)
1.750 (44.5) x 1.450 (36.8)
01,02
Natural
Convection
Forced
Convection
70°C @ 4W 6.0°C/W @ 400 LFM
42°C @ 4W
3.6°C/W @ 400 LFM
70°C @ 4W
6.0°C/W @ 400 LFM
Weight
lbs. (grams)
0.0052 (2.36)
0.0105 (5.72)
0.0048 (2.18)
Material: Aluminum, Black Anodized
270/272/280 SERIES
TO-220
271 SERIES
NATURAL AND FORCED
This top-hat style booster heat sink can be added to any of the 270, 272, or 280 Series for improved performance.
NOTE A: Thermal resistance with one 271-AB. NOTE B: Thermal resistance (total) as shown with (2) 271-AB types
added to (1) 272-AB type.
Standard
P/N
Height Above
Semiconductor Case
in. (mm)
Horizontal
Mounting Footprint
Dimensions
in. (mm)
271-AB
0.500 (12.7)
Natural
Convection
62°C @ 4W (NOTE A)
31 °C @ 4W (NOTE B)
Forced
Convection
5.1°C/W @ 400 LFM
1.8°C/W 400 LFM (NOTE B)
Weight
lbs. (grams)
270 SERIES
280 SERIES
0.0052 (2.36)
272 SERIES
62
272AB01
272AB02
63
很抱歉,暂时无法提供与“288-1ABE”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 50+15.2431150+1.97452
- 250+8.46583250+1.09662
- 500+8.00784500+1.03730
- 1000+7.603361000+0.98490
- 2500+7.440432500+0.96380
- 国内价格 香港价格
- 1+11.724341+1.51872
- 10+10.3483310+1.34047
- 25+9.8612425+1.27738
- 50+9.5052450+1.23127
- 100+9.16140100+1.18673
- 250+8.72671250+1.13042
- 500+8.41134500+1.08957
- 1000+8.106891000+1.05013
- 5000+7.440885000+0.96386
