BOARD LEVEL
HEAT SINKS
BOARD LEVEL
HEAT SINKS
BOARD LEVEL POWER SEMICONDUCTOR HEAT SINKS
TO-92
Power semiconductors packaged in a TO-92 style plastic case can be cooled effectively at little additional cost with
the addition of the 292-AB heat sink. The 292-AB is effective over the typical power range of such devices.
0.225°C/W @ 0.250 W
Black Anodized
0.00049 (0.22)
Thermal Performance at Typical Load
Height Above
Maximum
PC Board “A”
Footprint
Natural
Forced
in. (mm) in. (mm) Convection Convection
Standard P/N
Standoff Pin Plain Pin
667-10ABESP
667-15ABESP
667-20ABESP
667-25ABESP
Material: Aluminum, Black Anodized
MECHANICAL DIMENSIONS
667-10ABPP
667-15ABPP
667-20ABPP
667-25ABPP
1.000 (25.4)
1.500 (38.1)
2.000 (50.8)
2.500 (63.5)
52
-7
TO-220
61
21
8
4
637 SERIES
Wave-solderable pins on 1 in. centers for vertical mounting on printed circuit boards. Maximum semiconductor
package width 0.625 in. (15.9). Use this heat sink where weight and board space occupied must be minimized.
Refer to the Accessory products section for thermal interface materials, thermal compounds, and other
accessories products.
Standard
P/N
637-10ABEP
637-15ABEP
637-20ABEP
637-25ABEP
Height Above
PC Board “A”
in. (mm)
Maximum Footprint
in. (mm)
1.000 (25.4)
1.500 (38.1)
2.000 (50.8)
2.500 (63.5)
1.375 (34.9) x 0.500 (12.7)
Natural
Forced
Convection
Convection
Weight
lbs. (grams)
76°C @ 6W
65°C @ 6W
55°C @ 6W
48°C @ 6W
0.023 (10.43)
0.035 (15.88)
0.050 (22.68)
0.062 (28.12)
5
.8°C/W @ 200 LFM
5
.5°C/W @ 200 LFM
4
.7°C/W @ 200 LFM
4
.2°C/W @ 200 LFM
04
6
1
06
ERUTAREPMET KNIS TAEH
)Cϒ( TNEIBMA EVOBA ESIR
2
001
08
P
-766
PBA01
766
PBA52-
6
1-7
A0
PB
66
3
)STTAW( NOITAPISSID REWOP
HIGH-EFFICIENCY HEAT SINKS FOR VERTICAL
BOARD MOUNTING
BA
ECNATSISER LAMREHT
)TTAW/Cϒ( TNEIBMA OT KNIS
Dimensions: in. (mm)
)MPF( YTICOLEV RIA
006
004
002
5.8°C/W @ 200 LFM
5.5°C/W @ 200 LFM
4.7°C/W @ 200 LFM
4.2°C/W @ 200 LFM
0.0240 (11.0)
0.0340 (15.6)
0.0460 (21.0)
0.0580 (26.2)
Wave-solderable pins. Material: Aluminum, Black Anodized
008
76°C @ 6W
66°C @ 6W
58°C @ 6W
48°C @ 6W
Order 330 SC or 285 SC SpeedClip™ separately.
NATURAL AND FORCED
CONVECTION CHARACTERISTICS
0001
5
Weight
lbs. (grams)
0.500
0.500REF
(12.7)
REF
(12.7)
deepS
pilC
CS033
bl 4
lanimoN
ecroF
dellatsnI
deepS
pilC
CS582
bl 01
lanimoN
ecroF
dellatsnI
0.093
0.093
DIA
(2.4) DIA
(2.4)
NOMINAL)
(NOMINAL)
390.0
AID )4.2(
)LANIMON(
1.375
1.375
REF
REF
390.(34.9)
AID (34.9)
)4.2(
651.0
)0.4(
0.062
0.062REF
REF
(1.6)
(1.6)
0.730
0.730
(18.5)
(18.5)
FER )7.21(
STANDOFF
PINS
“SP”
0.180 DIA
0.180
(4.6) DIA 1.000
(4.6)
1.000
(25.4)
(25.4)
AID 081.0
)6.4(
000.1
)4.52(
037.0
)5.81(
PLAIN
PINS
“PP”
NATURAL AND FORCED
Speed
Clip
Speed
330SC
Clip
330SC
4lb
Nominal
4 lb
Force
Nominal
Force
Installed
573.1
FER )9.430.093
( 0.093 DIA
(2.4)
(2.4) DIA
Installed
Speed
0.044(1.1)
(1.1)(STANDOFF)
(STANDOFF)
0.044
076.0
)0.71(
A
0.130
(3.3)
0.130
(3.3)
)FFODNATS( )1.1( 440.0.670
(17.0)
(17.0)
)3.3( 031A.0
0.125
(3.2)
DIA
0.125
(3.2)
DIA
RAISED
x 0.030
(0.8)
HIGH
RAISEDBOSS
BOSS
x 0.030
(0.8)
HIGH
005.0
667 SERIES
(EXTRUSION PROFILE 8073)
AID )2.3( 521.0
HGIH )8.0( 030.0 x SSOB DESIAR Dimensions:
626 & 627 SERIES
Standard
P/N
Standard
P/N
626-10ABEP
626-15ABEP
626-20ABEP
626-25ABEP
627-10ABP
627-15ABP
627-20ABP
627-25ABP
0.156 (4.0)
0.156
260.0
FER )6.1(
(4.0)
in. (mm)
Speed
Clip
Clip
285SC
285SC
10
10lblb
Nominal
Nominal
Force
Force
Installed
Installed
100
AIR
VELOCITY
(FPM)
AIR
VELOCITY
(FPM)
400
600
800
80
4
60
40
7-
P
1.000 (25.4)
1.500 (38.1)
2.000 (50.8)
2.500 (63-5)
Maximum
Footprint
in. (mm)
1.375 (34.9) x .500 (12.7)
3
66710ABP
667-2
5ABP
2
4
8
12
16
POWER
DISSIPATION
(WATTS)
POWER
DISSIPATION
(WATTS)
BOARD MOUNTING
Height Above
PC Board “A”
in. (mm)
1000
5
THERMAL
RESISTANCE
THERMAL
RESISTANCE
SINK TO
(ϒC/WATT)
SINK
TOAMBIENT
AMBIENT
(°C/WATT)
0. 600 (15.3)
Finish
Weight
lbs. (grams)
AB
0.750 (19.1)
Thermal Performance
Natural Convection
0A
BP
292-AB
Overall
Fin Width
in. (mm)
Excellent performance, choice of wave-solderable plain pins (PP-Type) or wave-solderable hex-shaped standoff
pins (SP-Type), and reduced assembly cost.
66
Height Above
PC Board
in. (mm)
667 SERIES
7-1
Standard
P/N
LABOR-SAVING SPEEDCLIP™ HEAT SINKS FOR
VERTICAL BOARD MOUNTING
TO-220
66
HEAT SINK FOR SINGLE TO-92
HEATSINK
SINKTEMPERATURE
TEMPERATURE
HEAT
RISEABOVE
ABOVEAMBIENT
AMBIENT
RISE
(ϒC)(°C)
292 SERIES
TO-220 and TO-218
Natural
Forced
Convection
Convection
76°C @ 6W
65°C @ 6W
55°C @ 6W
48°C @ 6W
5.8°C/W @ 200 LFM
5.5°C/W @ 200 LFM
4.7°C/W @ 200 LFM
4.2°C/M @ 200 LFM
626 AND 627 SERIES
NATURAL AND FORCED
637 SERIES
(EXTRUSION PROFILE 5183)
NATURAL AND FORCED
70
wakefield-vette.com
Contact us: (603) 635-2800
71
很抱歉,暂时无法提供与“627-10ABPE”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1400+13.051181400+1.68810
