BOARD LEVEL
HEAT SINKS
BOARD LEVEL
HEAT SINKS
BOARD LEVEL POWER SEMICONDUCTOR HEAT SINKS
HIGH-PERFORMANCE, HIGH-POWER HEAT
SINKS FOR VERTICAL BOARD MOUNTING
677 SERIES
Standard
P/N
Height Above
PC Board “A”
in. (mm)
677-10ABEP
677-15ABEP
677-20ABEP
677-25ABEP
Thermal Performance at Typical Load
Maximum
Footprint
in. (mm)
1.000 (25.4)
1.500 (38.1)
2.000 (50.8)
2.500 (63.5)
TO-218; TO-220; TO-247;
15-Lead Multiwatt
Natural
Convection
1.650 (41.9) x 1.000 (25.4)
52°C @ 6W
46°C @ 6W
40°C @ 6W
35°C @ 6W
Forced
Convection
3.1°C/W @ 200 LFM
2.8°C/W @ 200 LFM
2.5°C/W @ 200 LFM
2.2°C/W @ 200 LFM
Wave-solderable pins. Material: Aluminum, Black Anodized
MECHANICAL DIMENSIONS
NATURAL AND FORCED
CONVECTION CHARACTERISTICS
677 SERIES
(EXTRUSION
PROFILE 8719)
MAXIMUM EFFICIENCY OMNIDIRECTIONAL
HEAT SINKS
TO-3; TO-220
680 SERIES
Achieve optimum natural convection cooling per unit volume occupied above the printed circuit board for TO-3
(one semiconductor package per heat sink) or for two TO-220 style cases, when this low-cost heat sink is used. Any
mounting attitude will provide free circulation of air in natural convection applications. These 680 Series heat sinks
can also be specified without any semiconductor mounting hole pattern by specifying suffix “K” (Example: 680-5K).
Standard
P/N
680-5A
680-75A
680-10A
680-125A
680-5220
680-75220
680-10220
680-125220
Height Above
PC Board “A”
in. (mm)
Horizontal Mounting
Footprint Dimensions
in. (mm)
0.500 (12.7)
0.750 (19.1)
1.000 (25.4)
1.250 (31.8)
0.500 (12.7)
0.750 (19.1)
1.000 (25.4)
1.250 (31.8)
1.810 (46.0)-sq
1.810 (46.0)-sq
1.810 (46.0)-sq
1.810 (46.0)-sq
1.810 (46.0)-sq
1.810 (46.0)-sq
1.810 (46.0)-sq
1.810 (46.0)-sq
Natural
Convection
70°C @ 7.5W
58°C @ 7.5W
52°C @ 7.5W
45°C @ 7.5W
70°C @ 7.5W
58°C @ 7.5W
52°C @ 7.5W
45°C @ 7.5W
Forced
Convection
3.0°C/W @ 400 LFM
2.4°C/W @ 400 LFM
2.0°C/W @ 400 LFM
1.5°C/W @ 400 LFM
3.0°C/W @ 400 LFM
2.4°C/W @ 400 LFM
2.0°C/W @ 400 LFM
1.5°C/W @ 400 LFM
Semiconductor
Mounting
Hole Pattern
Weight
lbs. (grams)
(1) TO-3
(1) TO-3
(1) TO-3
(1) TO-3
(2) TO-220
(2) TO-220
(2) TO-220
(2) TO-220
0.0700 (31.75)
0.0900 (40.82)
0.0980 (44.45)
0.1100 (49.90)
0.0700 (31.75)
0.0900 (40.82)
0.0980 (44.45)
0.1100 (49.90)
NATURAL AND FORCED
Dimensions: in. (mm)
HIGHEST EFFICIENCY/LOWEST UNIT COST
HEAT SINKS
TO-3; TO-66; TO-220
690 SERIES
These low-cost heat sinks provide the most power dissipation at the lowest unit cost and are available in three
standard types to mount and cool one TO-3 or TO-66 metal power semiconductor type or two plastic package
TO-220 power semiconductor types. For higher power semiconductors, the 690 Series can dissipate up to 20
watts while maintaining a mounting surface temperature rise above ambient air temperature of no more
than 91°C.
Standard
P/N
Height Above
PC Board
in. (mm)
Outline Dimensions
in. (mm)
690-3B
690-66B
690-220B
1.310 (33.3)
1.310 (33.3)
1.310 (33.3)
1.860 (47.2)-sq
1.860 (47.2)-sq
1.860 (47.2)-sq
Thermal
Natural
Forced
Convection
Convection
44°C @ 7.5W
44°C @ 7.5W
44°C @ 7.5W
Semiconductor
Mounting
Hole Pattern
2.0°C/W @ 400 LFM
2.0°C/W @ 400 LFM
2.0°C/W @ 400 LFM
(1) TO-3
(1) TO-66
(2) TO-220
0.0700 (31.75)
0.0700 (31.75)
0.0700 (31.75)
NATURAL AND FORCED
TO-3
601 & 603 SERIES
74
TO-66
*TWO TO-220’S
*TWO TO-220’S
LOW-HEIGHT HEAT SINKS
DO-4/DO-5 Diodes
Use these low-height heat sinks on printed circuit board applications for TO-66 power semiconductors and DO-4
and DO-5 diodes, where close board-to-board spacing and efficient heat dissipation are required. The 601 and
603 Series may also be attached to enclosure panels or brackets using isolation hardware where necessary.
601E
601F
601K
603K
TO-3
K
Standard
P/N
220
A
Weight
lbs. (grams)
SEMICONDUCTOR MOUNTING HOLES
Footprint
Dimensions
in. (mm)
Height
in. (mm)
2.000 (50.8) x 1.250 (31.8)
2.000 (50.8) x 2.000 (50.8)
0.562 (14.3)
0.562 (14.3)
0.562 (14.3)
0.562 (14.3)
Mounting
Hole Dia.
Natural
Forced
in. (mm)
Convection
Convection
0.200 (5.1)
0.270 (6.9)
None
None
52°C @ 5.0W
52°C @ 5.0W
52°C @ 5.0W
41°C @ 5.0W
4.5°C/W @ 175 LFM
4.5°C/W @ 175 LFM
4.5°C/W @ 175 LFM
4.0°C/W @ 175 LFM
Weight
lbs. (grams)
0.0500 (22.68)
0.0500 (22.68)
0.0500 (22.68)
0.0810 (36.74)
Material: Aluminum Alloy, Black Anodized
75
很抱歉,暂时无法提供与“677-20ABPE”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 30+32.4513230+4.19808
- 50+30.9396550+4.00252
- 150+21.81730150+2.82240
