662-15AGT5
662-15AGT5
    WAKEFIELD-VETTE
    HEATSINK EXTRUSION 45MM
662-15AGT5 数据手册
THERMAL MANAGEMENT SOLUTIONS & THERMAL INTERFACE Thermal Management Solutions for BGAs............. 7 Thermal Interface ........................................... 8 THERMAL MANAGEMENT SOLUTIONS FOR BGAs BGA THERMAL SOLUTIONS MATRIX The following table represents Wakefield-Vette’s recommendations for a variety of standard BGA sizes. However, this is by no means a complete list of components that can be used with these heat sinks. To determine suitability for your particular component, request a BGA heat sink evaluation kit. BGA Sizes (mm) 17 19 21 21 23 23 25 27 29 31 31 33 35 35 35 37.5 37.5 45.7 x 35.5 40 37.5 40 40 42.5 45 45 47.5 50 50 50 50 50 up to 45 up to 45 Heat Sink Footprint (mm) Heat Sink Height (inches) Recommended Series # Attachment Method 17 x 17 19 x 19 21 x 21 21 x 21 22 x 22 22 x 22 25 x 25 28 x 28 30 x 30 31 x 28 31 x 31 32 x 32 35 x 35 35 x 35 35 x 35 37 x 37 37 x 37 37 x 47 38 x 38 38 x 38 40 x 28 40 x 40 41 x 41 43 x 43 43 x 43 47 x 47 50 x 50 51 x 51 52 x 51 53 x 47 64 x 51 73 x 50 73 x 50 .40 1.00 .40 .25 .35 .45 .60 .40 .60 .75 .25 .35 .45 .60 .25 .35 .45 .60 .77 .65 .80 .35 .40 .65 .25 .35 .45 .60 .25 .35 .45 .60 .50 .65 .80 .30 .50 1.00 .29 .35 .26 .53 .41 .20 .25 .35 .45 .60 .15 .80 .40 .65 .80 1.00 .20 1.00 .80 .40 .65 .80 1.00 .24 .50 1.00 .95 D10650 602 D10850 624 604 605 625 658 606 607 611 610 612 642 630 613 659 617 614 660 643 655 615 628 662 616 698 618 622 798 620 609 619 Adhesive Adhesive Adhesive Adhesive Adhesive Adhesive Adhesive Adhesive Adhesive Adhesive Adhesive Adhesive Adhesive Adhesive Adhesive Adhesive Adhesive Adhesive Adhesive Adhesive Clip Adhesive Adhesive Adhesive Adhesive Adhesive Adhesive Adhesive Adhesive Adhesive Adhesive Clip Clip RoHS COMPLIANCE Please note that Wakefield-Vette part numbers designated with an “E” in this catalog denote new parts in compliance with the RoHS initiative, with the exception of our Precision Clamps. Wakefield-Vette will still continue to offer nonRoHS compliant versions of these parts. Please be aware that many Wakefield-Vette Standard parts have always been compliant since their design inception and therefore will not carry the “E” designation. Wakefield-Vette requests that you refer to the RoHS compliance tool on our website at www.wakefield-vette.com to verify RoHS compliance. If you require further clarification or information regarding RoHS, please contact the factory. Contact us: (603) 635-2800 7 THERMAL INTERFACE THERMAL INTERFACE MATERIAL PART NUMBER GUIDE All of the heat sinks shown in this catalog are available with any of the following thermal tape and interface materials, pre-applied at the factory. Use the “T” series, thermally enhanced, pressure sensitive adhesives to attach the heat sink to the electronic package and provide a good thermal link to the heat sink. Specify these materials in applications where the heat sink will be fixed to the electronic package by some mechanical means other than a tape. Please note that none of these materials are for use in applications requiring electrical isolation from the electronic device. All options other than -T1 and -T4 are RoHS compliant. Note: To obtain the estimated thermal resistance of the interface material in your application, divide the thermal impedance value by the area of the pad in square inches. For example, a 2” x 2” piece of T4 has a resistance of 1.10 C-in^2/W v­ 4 in^2=0.275 C/W “T” Series Thermally Enhanced Pressure Sensitive Adhesives Manufacturer Thermal Impedance Thickness, Suffix Product C-in^2/W Inches -T1 Chomerics, T405 0.47 0.006 -T1E Chomerics, T405R 0.47 0.006 -T3 Chomerics, T412 0.25 0.009 -T4 Chomerics, T410 1.10 0.007 -T4E Chomerics, T410R 1.10 0.007 -T5 Chomerics, T411 1.00 0.011 -T6 3M, 8810 0.88 0.010 -T7 Bergquist, BP 108 1.28 0.008 Package Surface, Comments Metal/ceramic; aluminum carrier RoHS-compliant version of -T1 Metal/ceramic; very good performance and conformity Plastic RoHS-compliant version of -T4 Plastic; conforms to out-of-flat packages Metal/ceramic; very good adhesion and conformity Metal/ceramic; electrically insulating ORDERING INFORMATION Once you have chosen heat sink and thermal interface material that meets your thermal & mechanical requirements it is easy to designate the part number. Simply add the interface material suffix referenced on the chart above to the base part number for the heat sink. The base part number already includes information regarding its size and finish. Example: To order the 658 Series heat sink at .350” tall with the T5 thermal interface material, specify part number: 8 658-35AB - T5 From Catalog Page XX From Table on Page XX wakefield-vette.com INTEGRATED CIRCUIT COOLING TITLE HEAT SINKS Heat Sinks For BGAs, Super BGAs, & FPBGAs .................... 12–27 Deltem™ Composite Heat Sinks For BGAs ........................ 18 Heat Sinks For Microprocessors & ASICs .......................... 28–30 Pin Fin Heat Sinks ....................................................... 31 Elliptical Fin Heat Sinks ................................................ 32 Pin Fin & Elliptical Fin Heat Sinks .................................. 33 Ceramic Heat Sink For To Devices w/ OmniKlip ................ 34–35 Wave Series Heat Sink With Integrated Clip Assembly ....... 36–43 With the increase in heat dissipation from microelectronics devices and the reduction in overall form factors, thermal management becomes a more important element of electronic product design. Both the performance reliability and life expectancy of electronic equipment are inversely related to the component temperature of the equipment. The relationship between the reliability and the operating temperature of a typical silicon semi-conductor device shows that a reduction in the temperature corresponds to an exponential increase in the a component may be achieved by effectively controlling the device operating temperature within the limits set by the device design engineers. Heat sinks are devices that enhance heat dissipation from a hot surface,usually the case of a heat generating component, to a cooler ambient, usually air. For the following discussions, air is assumed to be the cooling fluid. In most situations, heat transfer across the interface between the solid surface and the coolant air is the least efficient within the system, and the solid-air interface represents the greatest barrier for heat dissipation. A heat sink lowers this barrier mainly by increasing the surface area that is in direct contact with the coolant. This allows more heat to be dissipated and/or lowers the device operating temperature. The primary purpose of a heat sink is to maintain the device temperature below the maximum allowable temperature specified by the device manufacturers. INTEGRATED CIRCUIT COOLING HEAT SINKS reliability and life expectancy of the device. Therefore, long life and reliable performance of 11 INTEGRATED CIRCUIT COOLING HEAT SINKS INTEGRATED CIRCUIT COOLING HEAT SINKS HEAT SINKS FOR BGAs, SUPER BGAs, PBGAs, & FPBGAs 659 SERIES 624 SERIES OMNIDIRECTIONAL PIN FIN HEAT SINK FOR BGAs The 624 Series is an omnidirectional pin fin heat sink for both natural and forced-convection applications. PRODUCT FEATURES Applications include network routers and switches, high-resolution printers, digital cameras, consumer video games, digital video disks (DVD) and global positioning systems (GPS). • Available in four standard heights, .25 inch, .35 inch, .45 inch, and .60 inch. Standard P/N 624-25AB 624-35AB 624-45AB 624-60AB UNIDIRECTIONAL FIN HEAT SINK FOR BGAs Base Dimensions in. Sq. .827 (21) .827 (21) .827 (21) .827 (21) Fin Height “A” Typical in. (mm) Applications .250 (6.4) 21mm BGA .350 (8.9) 21mm BGA .450 (11.4) 21mm BGA .600 (15.2) 21mm BGA • Weight lbs. (grams) .009 (4.09) .011 (4.99) .015 (6.81) .026 (11.80) Standard P/N Base Dimensions in. (mm) Height in. (mm) Typical Application 659-65AB 1.45 (36.8) sq 0 .650 (16.5) 37mm BGA Heat Sink Finish Weight lbs. (grams) Black Anodized 0.050 (22.68) Notes: 1. Optional factory pre-applied pressure-sensitive adhesive. See Page 8. NATURAL AND FORCED CONVECTION CHARACTERISTICS MECHANICAL DIMENSIONS Available with pressure sensitive adhesives for quick and easy mounting. See Page 8. Dimensions: in. (mm) Case-to-Ambient Thermal Resistance, C/W Material: Aluminum, Black Anodized MECHANICAL DIMENSIONS 624 624 THERMAL PERFORMANCE Series Heat Sink Thermal Performance 655 SERIES 30 624-25-T4 624-35-T4 25 624-45-T4 624-60-T4 20 Standard Base Dimensions Dimension “A” Dimension “B” Typical P/N in. (mm) in. (mm) in. (mm) Applications 15 655-26AB 655-53AB 10 5 200 300 400 500 0.260 (6.6) 0.525 (13.3) 0.125 (3.2) 0.145 (3.7) 40mm BGA 40mm BGA Black Anodized Black Anodized Weight lbs. (grams) 0.038 (17.01) 0.050 (22.68) PRODUCT FEATURES • Available in four standard heights, .25 inch, .35 inch, .45 inch, and .60 inch. MECHANICAL DIMENSIONS 625 SERIES Applications include network routers and switches, high-resolution printers, digital cameras, consumer video games, digital video disks (DVD) and global positioning systems (GPS). Standard P/N Base Dimensions in. Sq. 625-25AB 625-35AB 625-45AB 625-60AB .984 (25) .984 (25) .984 (25) .984 (25) Fin Height “A” Typical Weight in. (mm) Applications lbs. (grams) 0.250 (6.4) 0.350 (8.9) 0.450 (11.4) 0.600 (15.2) 25 mm BGA 25 mm BGA 25 mm BGA 25 mm BGA .012 (5.45) .014 (6.36) .018 (8.17) .030 (13.62) Material: Aluminum, Black Anodized Case-to-Ambient Thermal Resistance, C/W Dimensions: in. (mm) The 625 Series is an omnidirectional pin fin heat sink for both natural and forced-convection applications. Available with pressure sensitive adhesives for quick and easy mounting. See Page 8. NATURAL AND FORCED CONVECTION CHARACTERISTICS Dimensions: in. 600 Approach Velocity, LFM OMNIDIRECTIONAL PIN FIN HEAT SINK FOR BGAs 12 1.600 (40.6) sq 1.600 (40.6) sq Heat Sink Finish Notes: 1. Optional factory pre-applied pressure-sensitive adhesive. See Page 8. 0 Performance shown is with T4 thermal adhesive applied. • OMNIDIRECTIONAL PIN FIN HEAT SINK FOR BGAs AND POWERPC™ 16 625-45-T4 658-25AB 658-35AB 658-45AB 658-60AB Base Dimensions Dimension “A” in. (mm) in. (mm) 1.100 (27.9) sq 1.100 (27.9) sq 1.100 (27.9) sq 1.100 (27.9) sq 0.250 (6.4) 0.350 (8.9) 0.450 (11.4) 0.600 (15.2) Typical Applications 27mm BGA 27mm BGA 27mm BGA 27mm BGA MECHANICAL DIMENSIONS 20 625-25-T4 Standard P/N 658 SERIES Heat Sink Finish Weight lbs. (grams) Black Anodized Black Anodized Black Anodized Black Anodized 0.013 (5.67) 0.015 (6.70) 0.019 (8.50) 0.031 (14.17) Notes: 1. Optional factory pre-applied pressure-sensitive adhesive. See Page 8. 625 THERMAL PERFORMANCE 625 Series Heat Sink Thermal Performance 18 OMNIDIRECTIONAL PIN FIN HEAT SINK FOR BGAs AND POWERPC™ MECHANICAL DIMENSIONS 625-25-T4 NATURAL AND FORCED CONVECTION CHARACTERISTICS 625-60-T4 14 12 10 KEY: 658-25AB + 658-35AB 658-45AB o 658-60AB 8 6 4 2 0 200 300 400 Approach Velocity, LFM Performance shown is with T4 thermal adhesive applied. 500 600 Dimensions: in. Dimensions: in. (mm) 13 INTEGRATED CIRCUIT COOLING HEAT SINKS INTEGRATED CIRCUIT COOLING HEAT SINKS HEAT SINKS FOR BGAs, SUPER BGAs, PBGAs, & FPBGAs 662 SERIES OMNIDIRECTIONAL PIN FIN HEAT SINK FOR LIMITED HEIGHT BGAs 660 SERIES UNIDIRECTIONAL FIN HEAT SINK FOR BGAs Standard P/N Base Dimensions in. (mm) Height in. (mm) Typical Application Heat Sink Finish Weight lbs. (grams) 660-29AB 1.530SQ. (38.9)SQ. 0.285 (7.2) 37mm BGA Black Anodized 0.031 (14.17) Standard P/N Base Dimensions in. (mm) 662-15AG 1.713 (43.5) sq 662-15AB 1.713 (43.5) sq Height in. (mm) 0.150 (3.8) 0.150 (3.8) T ypical Applications 4 5mm BGA 45mm BGA Heat Sink Finish Weight lbs. (grams) Gold Iridite 0.019 (8.50) Black Anodized 0 .019 (8.50) Notes: 1. Optional factory pre-applied pressure-sensitive adhesive. See Page 8. Notes: 1. Optional factory pre-applied pressure-sensitive adhesive. See Page 8. MECHANICAL DIMENSIONS NATURAL AND FORCED CONVECTION CHARACTERISTICS NATURAL AND FORCED CONVECTION CHARACTERISTICS MECHANICAL DIMENSIONS Dimensions: in. (mm) Dimensions: in. (mm) 628 SERIES UNIDIRECTIONAL FIN HEAT SINK FOR BGAs 642 SERIES PRODUCT FEATURES The 642 Series is an unidirectional pin fin heat sink for both natural and forced-convection applications. • Available in four standard heights, .25 inch, .35 inch, .45 inch, and .60 inch. Applications include network routers and switches, high-resolution printers, digital cameras, consumer video games, digital video disks (DVD) and global positioning systems (GPS). • Available with pressure sensitive adhesives for quick and easy mounting. See Page 8. Standard P/N 642-25AB 642-35AB 642-45AB 642-60AB Base Dimensions Fin Height “A” in. Sq. in. (mm) 1.378 (35) .250 (6.4) 1.378 (35) .350 (8.9) 1.378 (35) .450 (11.4) 1.378 (35) .600 (15.2) Standard P/N Typical Applications 35 mm BGA 35 mm BGA 35 mm BGA 35 mm BGA 628-20AB 628-25AB 628-35AB 628-40AB 628-65AB OMNIDIRECTIONAL PIN FIN HEAT SINK FOR BGAs Base Dimensions in. (mm) 1.750 (44.5) x 1.700 (43.2) 1.750 (44.5) x 1.700 (43.2) 1.750 (44.5) x 1.700 (43.2) 1.750 (44.5) x 1.700 (43.2) 1.750 (44.5) x 1.700 (43.2) Dimensions “A” Typical in. (mm) Applications 0.200 (5.1) 0.250 (6.4) 0.350 (8.9) 0.400 (10.2) 0.650 (16.5) 45mm BGA 45mm BGA 45mm BGA 45mm BGA 45mm BGA Heat Sink Finish Black Anodized Black Anodized Black Anodized B lack Anodized Black Anodized Weight lbs. (grams) 0.031 (14.17) 0.038 (17.01) 0.044 (19.84) 0.050 (22.68) 0.056 (25.51) Notes: 1. Optional factory pre-applied pressure-sensitive adhesive. See Page 8. NATURAL CONVECTION CHARACTERISTICS MECHANICAL DIMENSIONS Weight lbs. (grams) .022 (9.99) .027 (12.26) .031 (14.07) .039 (17.71) Material: Aluminum, Black Anodized Dimensions: in. (mm) 642 THERMAL PERFORMANCE 642 Series Heat Sink Thermal Performance Case-to-Ambient Thermal Resistance, C/W MECHANICAL DIMENSIONS 14 642-25-T4 642-35-T4 12 642-45-T4 8 6 4 Dimensions: in. (mm) 2 0 200 300 400 500 Approach Velocity, LFM Performance shown is with T4 thermal adhesive applied. 14 FORCED CONVECTION CHARACTERISTICS 642-60-T4 10 600 KEY: 628-20AB 628-25AB 628-35AB 628-40AB 628-65AB 15 INTEGRATED CIRCUIT COOLING HEAT SINKS INTEGRATED CIRCUIT COOLING HEAT SINKS HEAT SINKS FOR BGAs, SUPER BGAs, PBGAs, & FPBGAs 798 SERIES PIN FIN HEAT SINK FOR BGAs 630 SERIES OMNIDIRECTIONAL PIN FIN HEAT SINK FOR BGAs The 630 Series is an omnidirectional pin fin heat sink for both natural and forced-convection applications. PRODUCT FEATURES Applications include network routers and switches, highresolution printers, digital cameras, consumer video games, digital video disks (DVD) and global positioning systems (GPS). • Available in four standard heights, .25 inch, .35 inch, .45 inch, and .60 inch. Standard P/N Base Dimensions in. Sq. 630-25AB 630-35AB 630-45AB 630-60AB 1.378 (35) 1.378 (35) 1.378 (35) 1.378 (35) Fin Height “A” Typical Weight in. (mm) Applications lbs. (grams) .250 (6.4) . 350 (8.9) .450 (11.4) .600 (15.2) 35mm BGA 35mm BGA 35mm BGA 35mm BGA .009 (4.09) .011 (4.99) .015 (6.81) .026 (11.80) • Standard P/N Base Dimensions in. (mm) 798-40AB 798-65AB 798-80AB 798-100AB Dimensions “A” in. (mm) 2.100 (53.3) x 1.860 (47.2) 2.100 (53.3) x 1.860 (47.2) 2.100 (53.3) x 1.860 (47.2) 2.100 (53.3) x 1.860 (47.2) 0 .400 (10.2) 0 .650 (16.5) 0.800 (20.3) 1.000 (25.4) Typical Applications 45mm BGA 45mm BGA 45mm BGA 45mm BGA Heat Sink Finish Black Anodized Black Anodized Black Anodized Black Anodized 0.063 (28.35) 0.106 (48.19) 0.113 (51.03) 0.131 (59.53) FORCED CONVECTION THERMAL PERFORMANCE DATA (FLOW PARALLEL TO EXTRUSION DIRECTION) MECHANICAL DIMENSIONS Available with pressure sensitive adhesives for quick and easy mounting. See Page 8. Weight lbs. (grams) Material: Aluminum, Black Anodized Dimensions: in. (mm) MECHANICAL DIMENSIONS 630 THERMAL PERFORMANCE NOTES: KEY: 798-40AB 1 . Heat sink mounting surface flatness: 0.004” TIR 798-65AB 798-80AB 798-100AB 2. Optional factory pre-applied pressure-sensitive adhesive. See Page 8. 643 SERIES OMNIDIRECTIONAL PIN FIN HEAT SINK FOR BGAs The Series 643-35AP is an omnidirectional pin fin heat sink for both natural and forced-convection applications designed to fit a 40 mm BGA. • Applications include network routers and switches, high-resolution printers, digital cameras, consumer video games, digital video disks (DVD) and global positioning systems (GPS). Dimensions: in. OMNIDIRECTIONAL PIN FIN HEAT SINK FOR BGAs 698 SERIES Standard P/N 643-35AP Standard P/N Base Dimensions in. (mm) Dimensions “A” in. (mm) Typical Applications 698-40AB 698-65AB 698-80AB 698-100AB 2.100 (53.3) sq. 2.100 (53.3) sq. 2.100 (53.3) sq. 2.100 (53.3) sq. 0.400 (10.2) sq. 0.650 (16.5) sq. 0.800 (20.3) sq. 1.000 (25.4) sq. 45mm BGA 45mm BGA 45mm BGA 45mm BGA Heat Sink Finish Black Anodized Black Anodized Black Anodized Black Anodized Weight lbs. (grams) Base Dimensions in. (mm) 1.60 (40.64) x 1.10 (27.94) Fin Height in. (mm) 0.350 (8.89) Typical Applications Weight lbs. (grams) 40 mm BGA .070 (31.78) 0.075 (34.02) 0.119 (53.86) 0.125 (56.70) 0.144 (65.20) 643 THERMAL PERFORMANCE 919541 Series Heat Sink Thermal Performance FORCED CONVECTION THERMAL PERFORMANCE DATA (FLOW PARALLEL TO EXTRUSION DIRECTION) KEY: 698-40AB 698-65AB 698-80AB 698-100AB Dimensions: in. (mm) be purchased without heat sink) MECHANICAL DIMENSIONS Case-to-Ambient Thermal Resistance, C/W MECHANICAL DIMENSIONS Available with pressure sensitive adhesives to ensure good thermal performance. See page 8. • Can be ordered with the 829SC clip. Order clip separately. (Clip cannot Material: Aluminum, Plain Finish Notes: 1. Optional factory preapplied pressure-sensitive adhesive. See Page 8. 16 PRODUCT FEATURES 10 9 8 7 6 5 4 3 2 1 0 0 Dimensions: in. 100 200 300 400 500 600 700 Approach Air Velocity, LFM Performance shown is with S5 interface material applied. 17 INTEGRATED CIRCUIT COOLING HEAT SINKS INTEGRATED CIRCUIT COOLING HEAT SINKS DELTEM™ COMPOSITE HEAT SINKS FOR BGAs DELTEM™ D10650-40 HEAT SINKS FOR BGAs, SUPER BGAs, PBGAs, & FPBGAs PIN FIN HEAT SINK FOR BGAs HEAT SINK/CLIP ASSEMBLY FOR BGAs AND POWERPC™ PACKAGES PIN FIN HEAT SINK Standard Base Dimensions Height P/N in. (mm) in. (mm) Weight lbs. (grams) D10650-40 0.004 (1.91) 0.650 (16.5) sq 0.400 (10.2) Standard P/N 609-50AB 609-100AB Base Dimensions in. (mm) Dimensions “A” in. (mm) Typical Applications 0 .500 (12.7) 1.00 (25.4) 40&45mm BGA 40&45mm BGA 2.895 (73.5) x 2.000 (50.8) 2.808 (71.32) x 1.700 (43.2) Heat Sink Finish Black Anodized Black Anodized Height in. (mm) Typical Applications Weight lbs. (grams) 0.850 (21.6) sq 0.400 (10.2) 21mm BGA 0.006 (3.9) THERMAL RESISTANCE SINK TO AMBIENT (ϒC/WATT) D10850-40 DELTEM™ D10850-40 Base Dimensions in. (mm) 2.808 Notes: Available with pressure sensitive adhesives for quick and easy mounting. See Page 8. 5 4 609-50AB * 609-100AB 3 2 1 0 100 200 300 AIR VELOCITY (LFM) 400 500 *Performance is for shrouded conditions. 609-100 will perform better than 609-50 in cases with bypass. “A” DIM. (609-50AB) MECHANICAL DIMENSIONS DELTEM™ D10650-40 PIN FIN HEAT SINK 0.094 (42.5) 0.130 (59.0) FORCED CONVECTION THERMAL PERFORMANCE DATA (FLOW PARALLEL TO EXTRUSION DIRECTION) MECHANICAL DIMENSIONS Standard P/N Weight lbs. (grams) Note: Optional factory pre-applied thermal interface material. S3 (Bergquist Q-Pad 3, 0.14 °C in2/w) S4 (Bergquist Softface, 0.07 °C in2/w) Notes: Available with pressure sensitive adhesives for quick and easy mounting. See Page 8. PIN FIN HEAT SINK 609 SERIES (609-100AB) DELTEM™ D10850-40 PIN FIN HEAT SINK 609-50AB HEAT SINK AND CLIP ASSEMBLY Designed to fit a .063” thick PCB electronic package thickness of .110” Dimensions: in. (mm) 619 SERIES Standard P/N Dimensions: in. (mm) Base Dimensions in. (mm) Height in. (mm) Typical Applications Heat Sink Finish 61995AB124D1 2.871 (72.92) x 1.98 (50.29) 0.953 (24.21) 40&45mm BGA Black Anodized 61995AB054D1 2.871 (72.92) x 1.98 (50.29) 0.953 (24.21) 40&45mm BGA Black Anodized Dimensions: in. (mm) NATURAL AND FORCED CONVECTION CHARACTERISTICS FAN HEAT SINK FOR BGA AND POWERPC™ PACKAGES NATURAL AND FORCED CONVECTION CHARACTERISTICS Thermal Performance Weight lbs.(grams) 1.2° C/W 1.2° C/W .150 (68.10) .150 (68.10) Note: O  ptional factory pre-applied thermal interface material. See 609 series. MECHANICAL DIMENSIONS AIR VELOCITY (LFM) 600 800 1000 0 30 80 25 20 60 15 40 10 20 5 0 0 0 0.25 0.50 0.75 HEAT DISSIPATED (WATTS) 1.00 1.25 200 400 600 800 FEATURES AND BENEFITS 1000 16 100 14 80 12 10 60 8 40 6 4 20 2 0 THERMAL RESISTANCE SINK TO AMBIENT (C) 400 HEAT SINK TEMPERATURE RISE ABOVE AMBIENT AIR (C) 200 100 THERMAL RESISTANCE SINK TO AMBIENT (C) HEAT SINK TEMPERATURE RISE ABOVE AMBIENT AIR (C) 0 AIR VELOCITY (LFM) • Captivated clips for ease of assembly. • Low acoustic noise. • Impingement air flow. • Accommodates BGA packages up to 45 mm in size. 0 0 0.25 0.50 0.75 1.00 1.25 HEAT DISSIPATED (WATTS) See 609 Series for PCB hole layout for clip attachment 18 Dimensions: in. 19 Thermal Interface Material Option Blank None S3 Bergquist Qpad 3 S4 Bergquist Softface INTEGRATED CIRCUIT COOLING HEAT SINKS INTEGRATED CIRCUIT COOLING HEAT SINKS Height in. (mm) Heat Sink Finish Weight lbs. (grams) Standard P/N Base Dimensions in. (mm) Height in. (mm) .750 (19.1) sq 1.000 (25.4) Plain .021 (9.59) 605-75AB .880 (22.4) sq .750 (19.1) 2 1 300 400 500 600 700 8 6 4 604-60AB 2 0 100 200 300 THERMAL RESISTANCE SINK TO AMBIENT (C) 6 604 SERIES 4 3 2 Weight lbs. (grams) 200 300 400 500 .012 (5.60) AIR VELOCITY (LFM) .016 (7.47) 600 700 7 6 5 4 2 3 4 2 3 1 2 12 604-40AB 10 8 6 4 604-60AB 0 2 100 1 700 200 0 100 300 400 500 600 700 AIR VELOCITY (LFM) 200 300 400 500 600 700 3 606 SERIES 2 200 400 7 6 5 4 7 6 5 8 7 6 4 3 2 1 200 300 400 500 600 700 7 6 5 4 3 2 1 0 100 300 400 Standard 500 600 P/N 500 600 700 Base Dimensions in. (mm) 1.185 (30.1) sq 700 604-40AB 10 7 8 6 6 5 4 4 2 3 0 2 100 Height 200 1 .767 (19.5) 0 100 Heat Sink 400 500 300 in. (mm) 200 600 Finish AIR VELOCITY (LFM) Weight 700 lbs. (grams) Black Anodized 300 400 500 .041 (18.7) 600 700 AIR VELOCITY (LFM) MECHANICAL DIMENSIONS 606 THERMAL PERFORMANCE 10 9 8 7 6 5 4 3 2 1 0 100 8 7 7 6 6 5 4 3 5 4 7 610-35AB 3 6 2 1 2 5 610-40AB 1 4 0 100 200 300 400 500 AIR VELOCITY (LFM) 200 5 UNIDIRECTIONAL FIN HEAT604-60AB SINK FOR BGAs 1 300 400 500 AIR VELOCITY (LFM) NCE SINK TO (C) 5 4 300 AIR VELOCITY (LFM) ANCE SINK TO CE SINK TO T (C) C) TANCE SINK TO NT (C) 6 5 Material: Aluminum, Black Anodized 10 9 8 7 6 5 4 3 2 1 0 100 6 12 0 100 200 7 14 6 606-77AB wakefield-vette.com 7 0 100 AIR VELOCITY (LFM) 1 L RESISTANCE SINK TO AMBIENT (C) 5 600 700 2 8 0 100 700 AIR VELOCITY (LFM) THERMAL RESISTANCE SINK TO AMBIENT (C) 4 14 THERMAL RESISTANCE SINK TO AMBIENT (C) THERMAL RESISTANCE SINK TO THERMAL RESISTANCE SINK(C) TO AMBIENT AMBIENT (C) THERMAL RESISTANCE SINK TO AMBIENT (C) 5 6 8 600 7 0 100 3 604 THERMAL PERFORMANCE 7 AIR VELOCITY (LFM) 20 500 AIR VELOCITY (LFM) 7 5 400 THERMAL RESISTANCE SINK TO THERMAL RESISTANCE SINK TO AMBIENT (C) AMBIENT (C) 200 10 8 6 500 .030 (13.5) AIR VELOCITY (LFM) 600 4 605 THERMAL PERFORMANCE 604-40AB AIR VELOCITY (LFM) 400 500 6 600 700 600 700 0 3 100 2 300 400 500 600 700 AIR VELOCITY (LFM) 200 300 400 500 600 700 8 7 6 5 4 3 2 100 AIR VELOCITY (LFM) 6 Contact us: (603) 635-2800 5 3 200 1 0 100 7 4 THERMAL RESISTANCE SINK TO AMBIENT (C) 3 Black Anodized Black Anodized 7 300 400 8 614-30AB 10 9 8 7 66 21 610-35AB K TO 4 Heat Sink 1 Finish 0 100 MECHANICAL DIMENSIONS 200 300 10 THERMAL RESISTANCE SINK TO AMBIENT (C) 5 12 Material: Aluminum, Black Anodized 0 100 Black Anodized 200 Weight lbs. (grams) 12 THERMAL RESISTANCE SINK TO AMBIENT (C) 6 THERMAL RESISTANCE SINK TO AMBIENT (C) THERMAL RESISTANCE SINK TO AMBIENT (C) OMNIDIRECTIONAL PIN FIN HEAT SINK FOR BGAs .400 (10.2) .600 (15.2) 1 100 14 AIR VELOCITY (LFM) .850 (21.6) sq .850 (21.6) sq 2 Heat Sink 0 Finish THERMAL RESISTANCE SINK TO AMBIENT (C) THERMAL RESISTANCE SINK TO AMBIENT (C) THERMAL RESISTANCE SINK TO AMBIENT (C) 7 0 100 604-40AB 604-60AB 605 SERIES 3 MECHANICAL DIMENSIONS 602 THERMAL PERFORMANCE Height in. (mm) 4 THERMAL RESISTANCE SINK TO THERMAL RESISTANCE SINK TO (C) AMBIENT AMBIENT (C) MECHANICAL DIMENSIONS Base Dimensions in. (mm) 5 14 Material: Aluminum, Black Anodized Material: Aluminum, Plain Finish Standard P/N THERMAL RESISTANCE SINK TO AMBIENT (C) Base Dimensions in. (mm) 602-100AP 6 UNIDIRECTIONAL FIN HEAT SINK FOR BGAs UNIDIRECTIONAL FIN HEAT SINK FOR BGAs Standard P/N 7 ANCE SINK TO O (C) T 602 SERIES THERMAL RESISTANCE SINK TO AMBIENT (C) HEAT SINKS FOR BGAs, SUPER BGAs, PBGAs, & FPBGAs 8 1 0 100 INTEGRATED CIRCUIT COOLING HEAT SINKS 200 300 400 500 600 700 604-60AB 0 100 2 0 100 200 300 400 500 600 6 5 607-65AB 1.200 (30.5) x 1.105 (28.1) 3 2 Height 1 in. (mm) 0 Heat Sink Finish .650 (16.5) 100 Weight lbs. (grams) Anodized 200 Black 300 400 500.041 (18.7) 600 700 600 700 0 100 INTEGRATED CIRCUIT COOLING HEAT SINKS 7 6 5 7 6 5 4 3 2 611 SERIES 1 UNIDIRECTIONAL FIN HEAT SINK FOR BGAs 4 0 100 3 2 1 0 100 AIR VELOCITY (LFM) Material: Aluminum, Black Anodized 500 700 THERMAL RESISTANCE SINK TO AMBIENT (C) THERMAL RESISTANCE SINK TO AMBIENT (C) THERMAL RESISTANCE SINK TO AMBIENT (C) 7 4 UNIDIRECTIONAL FIN HEAT SINK FOR BGAs Base Dimensions in. (mm) 400 AIR VELOCITY (LFM) HEAT SINKS FOR BGAs, SUPER BGAs, PBGAs, & FPBGAs 8 Standard P/N 300 AIR VELOCITY (LFM) AIR VELOCITY (LFM) 607 SERIES 200 T 4 Standard P/N Base Dimensions in. (mm) 611-80AB 1.200 (30.5) sq 200 Material: 300 Aluminum, 400 500Anodized 600 Black THERMAL RESISTANCE SINK TO AMBIENT (C) THERMA THERM 2 200 300 400 500 Height in. (mm) Heat Sink Finish AIR VELOCITY Weight (LFM) .800 (20.3) Black Anodized .036 (16.3) 600 700 lbs. (grams) 10 9 8 7 6 5 4 3 2 1 0 100 700 AIR VELOCITY (LFM) 3 2 1 0 100 200 300 400 500 600 700 10 8 7 604-40AB 6 5 6 4 4 3 2 2 1 0 100 604-60AB 200 300 0 100 AIR VELOCITY (LFM) 611 THERMAL PERFORMANCE THERMAL RESISTANCE SINK TO AMBIENT (C) 4 12 MECHANICAL DIMENSIONS THERMAL RESISTANCE SINK TO AMBIENT (C) 5 THERMAL RESISTANCE SINK TO AMBIENT (C) 6 14 200 400 500 AIR VELOCITY (LFM) 300 400 600 700 500 600 700 AIR VELOCITY (LFM) 10 9 8 7 6 5 4 3 2 1 0 100 610-35AB 610-40AB 7 6 5 4 3 2 1 0 100 200 300 400 500 600 THERMAL RESISTANCE SINK TO AMBIENT (C) 607 THERMAL PERFORMANCE 7 THERMAL RESISTANCE SINK TO AMBIENT (C) THERMAL RESISTANCE SINK TO AMBIENT (C) MECHANICAL DIMENSIONS 200 300 400 500 600 700 8 7 6 5 4 3 2 100 AIR VELOCITY (LFM) 700 8 2 1 Standard 0 P/N 100 610-35AB 610-40AB Base Dimensions in. (mm) 200 300 400 500 1.240 (31.5) sq AIR VELOCITY (LFM) 1.240 (31.5) sq Height in. (mm) 600 .350 (8.9) .400 (10.2) 700 Heat Sink Finish 4 3 2 1 610 6 SERIES 0 100 Black Anodized Black Anodized Material: Aluminum, Black Anodized 5 4 Weight 3lbs. (grams) (10.0) 2.022 200 300 .024 (10.8) 1 MECHANICAL DIMENSIONS 5 4 3 2 1 0 100 200 300 400 500 AIR VELOCITY (LFM) 600 700 10 9 8 7 6 5 4 3 2 1 0 100 TANCE SINK TO NT (C) 6 5 4 ANCE SINK TO T (C) wakefield-vette.com 7 600 700 200 300 400 500 600 700 614-30AB 6 610-40AB 5 4 3 2 200 300 400 500 600 AIR VELOCITY (LFM) 300 400 500 AIR VELOCITY (LFM) 8 7 6 700 1 200 614-30AB 612 SERIES 6 5 614-100AB (dashed) 4 614-50AB 3 2 100 200 300 6 5 UNIDIRECTIONAL FIN HEAT SINK FOR BGAs 4 3 Standard P/N Base Dimensions 2 in. (mm) 612-65AB 1.390 (35.3) sq 1 Material: Aluminum, Black Anodized 0 100 Height in. (mm) Heat Sink Finish Weight lbs. (grams) .650 (16.5) Black Anodized .054 (24.5) 200 300 400 500 600 700 AIR VELOCITY (LFM) 612 THERMAL PERFORMANCE 400 500 600 700 MECHANICAL DIMENSIONS AIR VELOCITY (LFM) 610-35AB 0 100 22 500 7 AIR VELOCITY (LFM) 610 THERMAL PERFORMANCE 6 THERMAL RESISTANCE SINK TO AMBIENT (C) 7 THERMAL RESISTANCE SINK TO AMBIENT (C) THERMAL RESISTANCE SINK TO AMBIENT (C) 0 100 400 AIR VELOCITY (LFM) 8 THERMAL RESISTANCE SINK TO AMBIENT (C) OMNIDIRECTIONAL PIN FIN HEAT SINK FOR BGAs 7 THERMAL RESISTANCE SINK TO AMBIENT (C) 3 5 THERMAL RESISTANCE SINK TO AMBIENT (C) 4 6 600 700 THERMAL RESISTANCE SINK TO AMBIENT (C) 5 7 THERMAL RESISTANCE SINK TO AMBIENT (C) 6 THERMAL RESISTANCE SINK TO AMBIENT (C) 7 THERMAL RESISTANCE SINK TO AMBIENT (C) THERMAL RESISTANCE SINK TO AMBIENT (C) AIR VELOCITY (LFM) 8 7 614-30AB 6 5 2 1 200 200 300 400 300 400 500 600 700 AIR VELOCITY (LFM) 614-50AB 3 2 100 3 0 100 614-100AP (dashed) 4 4 500 600 700 AIR VELOCITY (LFM) Contact us: (603) 635-2800 23 8 7 6 5 4 3 2 100 2 200 300 400 500 600 0 0 100 200 300 400 500 600 700 100 200 300 400 500 600 700 700 AIR VELOCITY (LFM) THERMA 0 100 AIR VELOCITY (LFM) AIR VELOCITY (LFM) 300 400 500 600 700 INTEGRATED CIRCUIT COOLING HEAT SINKS 8 7 7 5 4 3 613 SERIES 2 1 200 300 400 500 Standard AIR VELOCITY (LFM) 600 P/N 613-50AB 6 5 5 4 4 3 THERMAL RESISTANCE SINK TO AMBIENT (C) HEAT SINKS FOR BGAs, SUPER BGAs, PBGAs, & FPBGAs 6 7 6 0 100 UNIDIRECTIONAL 2 FIN HEAT SINK FOR BGAs 3 700 Base Dimensions in. (mm) 1.450 (36.8) sq 2 1 1 0 Height 100 0in. (mm) 100 200 200 .500 (12.7) 300 Heat Sink 300 400 Finish Weight 600 700 lbs. (grams) 500 AIR VELOCITY (LFM) 400 500 600 Black Anodized 700 .046 (20.8) AIR VELOCITY (LFM) Material: Aluminum, Black Anodized 8 7 614-30AB 6 5 614-50AB 3 2 100 UNIDIRECTIONAL FIN HEAT SINK FOR BGAs 614-100AB (dashed) 4 200 300 Standard P/N 400 500 615-41AB Base Dimensions in. (mm) 600 AIR VELOCITY (LFM) 700 1.600 (40.6) sq 615 SERIES Height in. (mm) Heat Sink Finish Weight lbs. (grams) .410 (10.4) Black Anodized .046 (21.0) Material: Aluminum, Black Anodized 7 6 4 5 3 4 2 3 1 0 100 200 300 400 500 600 700 AIR VELOCITY (LFM) 2 1 10 613 THERMAL PERFORMANCE 9 8 610-35AB 7 6 5 610-40AB 4 3 2 1 0 100 200 300 400 500 0 100 200 300 AIR VELOCITY (LFM) 400 500 600 600 700 MECHANICAL DIMENSIONS 8 7 615 THERMAL PERFORMANCE THERMAL RESISTANCE SINK TO AMBIENT (C) MECHANICAL DIMENSIONS 5 THERMAL RESISTANCE SINK TO AMBIENT (C) 6 THERMAL RESISTANCE SINK TO AMBIENT (C) THERMAL RESISTANCE SINK TO AMBIENT (C) THERMAL RESISTANCE SINK TO AMBIENT (C) 200 AIR VELOCITY (LFM) THERMAL RESISTANCE SINK TO AMBIENT (C) THERMAL RESISTANCE SINK TO AMBIENT (C) THERMAL RESISTANCE SINK TO AMBIENT (C) INTEGRATED CIRCUIT COOLING HEAT SINKS 3 2 1 0 100 614-30AB 6 5 614-100AP (dashed) 4 614-50AB 3 2 100 200 300 400 500 600 700 5 UNIDIRECTIONAL FIN HEAT SINK FOR BGAs 4 3 2 Standard P/N 1 614-30AB 0 614-50AB 100 614-100AP Base Dimensions in. (mm) 200 1.500 (38.1) sq 1.500 (38.1) sq 300 1.500 (38.1)400 sq Height in. (mm) 500 AIR VELOCITY (LFM) Heat Sink Finish .300  (7.6) .500 (12.7) 600 1.000 (25.4) 700 Black Anodized Black Anodized Plain 6 5 4 3 2 1 200 300 400 500 600 700 AIR VELOCITY (LFM) 8 7 614-30AB 614 SERIES 6 5 4 3 616 SERIES 614-100AB (dashed) Weight lbs. (grams) 614-50AB .030 (13.8) 2 .048 (21.8) 100 200 .046 (20.9) Material: Aluminum, Black Anodized or Plain 300 400 500 600 THERMAL RESISTANCE SINK TO AMBIENT (C) 6 THERMAL RESISTANCE SINK TO AMBIENT (C) THERMAL RESISTANCE SINK TO AMBIENT (C) AIR VELOCITY (LFM) 7 7 0 100 AIR VELOCITY (LFM) 700 8 UNIDIRECTIONAL FIN HEAT SINK FOR BGAs 2 Standard P/N Base Dimensions 1 in. (mm) Height in. (mm) Heat Sink Finish Weight lbs. (grams) 616-80AB 1.85 (47.0) sq .800 (20.3) Black Anodized .054 (24.5) Material: Aluminum, Black Anodized 700 3 AIR VELOCITY (LFM) 0 100 200 300 400 500 600 700 AIR VELOCITY (LFM) 3 2 1 0 100 200 300 400 500 600 614-30AB 6 5 614-100AP (dashed) 4 614-50AB 3 2 100 200 300 400 7 6 5 4 3 2 1 0 100 500 600 AIR VELOCITY (LFM) 700 AIR VELOCITY (LFM) 300 400 500 600 700 4 3 2 wakefield-vette.com 3 2 3 2 1 0 100 200 300 400 500 600 700 AIR VELOCITY (LFM) 1 0 100 STANCE SINK TO ENT (C) 24 200 AIR VELOCITY (LFM) 700 5 THERMAL RESISTANCE SINK TO AMBIENT (C) 4 7 616 THERMAL PERFORMANCE 200 Contact us: (603) 635-2800 NCE SINK TO (C) 5 8 MECHANICAL DIMENSIONS 8 THERMAL RESISTANCE SINK TO AMBIENT (C) 6 THERMAL RESISTANCE SINK TO AMBIENT (C) 614 THERMAL PERFORMANCE THERMAL RESISTANCE SINK TO AMBIENT (C) THERMAL RESISTANCE SINK TO AMBIENT (C) MECHANICAL DIMENSIONS 300 400 500 AIR VELOCITY (LFM) 7 6 5 618-20AB 600 700 25 THERMAL RE AM 5 4 UNIDIRECTIONAL FIN HEAT SINK FOR BGAs 3 2 100 1.450 (36.8) x 1.850 (47.0) Heat Sink Finish 200(20.3) 300 .800 Weight lbs. (grams) 400 500 600 Black Anodized 700 (37.2) .082 2 200 300 400 500 600 1 0 100 Height in. (mm) 2.00 (50.8) sq 2.00 (80.8) sq .200  (5.1) 1.000 (25.4) Material: Aluminum, Black Anodized or Plain 200 300 400 500 600 700 AIR VELOCITY (LFM) Heat3Sink Finish Black Anodized 2 Plain 1 0 100 THERMAL RESISTANCE SINK TO AMBIENT (C) 3 Weight lbs. (grams) 200 300 400 500 600 300 400 500 600 700 618 THERMAL PERFORMANCE 1 300 400 500 600 700 7 6 618-20AB 5 4 3 2 1 0 100 200 300 400 500 600 700 6 618-20AB 5 300 4 3 400 500 600 700 AIR VELOCITY (LFM) 2 1 wakefield-vette.com TANCE SINK TO T (C) SISTANCE SINK TO BIENT (C) 3 3 2 300 400 .063 (28.6) 500 600 700 AIR VELOCITY (LFM) 200 300 400 3 300 400 500 600 AIR VELOCITY (LFM) 2 3 02 100 1 200 300 400 500 600 700 AIR VELOCITY (LFM) 200 300 400 500 600 700 AIR VELOCITY (LFM) 500 600 700 Standard 700 P/N 622-80AB 7 6 618-20AB 5 4 UNIDIRECTIONAL FIN HEAT SINK FOR BGAs 3 Base Dimensions in. (mm) 2.050 (52.1) x 2.000 (50.8) 2 1 Height in. (mm) 618-100AB Heat Sink Weight lbs. (grams) Finish 0 .800 (20.3) 100 200 300 Material: Aluminum, Black Anodized Black 400Anodized 500 600 .123 (56.0) 700 AIR VELOCITY (LFM) 1 MECHANICAL DIMENSIONS 0 100 200 300 400 500 AIR VELOCITY (LFM) 3 2 1 200 4 0 100 622 SERIES 200 1 5 300 400 500 AIR VELOCITY (LFM) 600 700 600 622 THERMAL PERFORMANCE 700 3 2 1 0 100 200 300 400 500 600 700 AIR VELOCITY (LFM) Contact us: (603) 635-2800 5 200 620 THERMAL PERFORMANCE 2 618-100AB 0 100 4 0 100 618-100AB 7 1 5 Weight lbs. (grams) 3 AIR VELOCITY (LFM) 4 INTEGRATED CIRCUIT 700 COOLING HEAT SINKS 600 620 SERIES 100 Black Anodized 2 700 AIR VELOCITY (LFM) AIR VELOCITY (LFM) 26 500 1 .235 (6.0) 700 AIR VELOCITY (LFM) AIR VELOCITY (LFM) 200 200 3 (21.0) .122 (55.5) 0 100 2 200 1 1 .046 3 0 100 2 0 100 2 THERMAL RESISTANCE SINK TO AMBIENT (C) THERMAL RESISTANCE SINK TO AMBIENT (C) MECHANICAL DIMENSIONS 4 THERMAL RESISTANCE SINK TO AMBIENT (C) 2 Base Dimensions in. (mm) 3 2 Heat Sink Finish 0 4 700 618 SERIES THERMAL RESISTANCE SINK TO AMBIENT (C) 5 THERMAL RESISTANCE SINK TO AMBIENT (C) THERMAL RESISTANCE SINK TO AMBIENT (C) 5 UNIDIRECTIONAL FIN HEAT SINK FOR BGAs 6 618-20AB 618-100AP 400 3 Height in. (mm) MECHANICAL DIMENSIONS 5 1 AIR VELOCITY (LFM) 3 300 AIR VELOCITY (LFM) 6 0 100 0 100 Base Dimensions in. (mm) 7 THERMAL RESISTANCE SINK TO AMBIENT (C) 3 8 THERMAL RESISTANCE SINK TO AMBIENT (C) THERMAL RESISTANCE SINK TO AMBIENT (C) THERMAL RESISTANCE SINK TO AMBIENT (C) 617 THERMAL PERFORMANCE Standard P/N 0 620-24AB 2.500 (63.5) x 2.000 (50.8) 100 Material: 200 Aluminum, 300 Black 400Anodized 500 600 AIR VELOCITY (LFM) MECHANICAL DIMENSIONS 1 THERMAL RESISTANCE SINK TO 617-80AB Height in. (mm) Material: Aluminum, Black Anodized 4 200 UNIDIRECTIONAL FIN HEAT SINK FOR BGAs THERMAL RESISTANCEAMBIENT SINK TO (C) AMBIENT (C) Base Dimensions 1 in. (mm) 0 2 THERMAL RESISTANCE SINK TO AMBIENT (C) Standard P/N 3 THERMAL RESISTANCE SINK TO AMBIENT (C) 6 THERMAL RESISTANCE SINK TO AMBIENT (C) 7 THERMAL RESISTANCE SINK TO AMBIENT (C) THERMAL RESISTANCE SINK TO AMBIENT (C) 617 SERIES Standard P/N 1 AIR VELOCITY (LFM) HEAT SINKS FOR BGAs, SUPER8 BGAs, PBGAs, & FPBGAs 7 2 0 100 INTEGRATED CIRCUIT COOLING HEAT SINKS 8 3 27 INTEGRATED CIRCUIT COOLING HEAT SINKS INTEGRATED CIRCUIT COOLING HEAT SINKS HEAT SINKS FOR MICROPROCESSORS & ASICs 569, 579, 589, 599 SERIES HEAT SINKS & CLIP FOR INTEL’S PENTIUM, PENTIUM MMX, AMD’S K6 & K62, CYRIX’S 6X86 & MEDIA GX, CENTAUR/IDT’S WINCHIP C6 PRODUCT FEATURES • Compact design heat sinks can comfortably fit a variety of Robust Socket 7-based PC boxes. Standard Base Dimensions P/N in. (mm) • Robust clip attachments. 569-100AK 579-150AK 589-150AK 599X-100AB • Clips are not captive to sink. Material: Aluminum, Black Anodized To order heat sink with optional interface material pre-applied at the factory, add S4 or S5 suffix to the part number. (See Product Designation) Thermal Resistance at 200 LFM (°C/W) Interface Material Options 1.00 (25.4) 1.50 (38.10) 1.50 (38.10) 1.00 (25.4) 1.7 1.6 1.5 1.9 Pages 74–76 Pages 74–76 Pages 74–76 Pages 74–76 18 x 18 PGA Standard P/N Base Dimensions in. (mm) 649-33AB 649-51AB 1.70 (43.2) sq 1.86 (47.2) sq Height in. (mm) Base Thickness in. (mm) 0.315 (8.0) 0.510 (13.0) 0.090 (2.3) 0.090 (2.3) Clip Color Gray Gray 649 SERIES Heat Sink Finish Weight lbs. (grams) Black Anodized Black Anodized 0.044 (19.84) 0.056 (25.51) MECHANICAL DIMENSIONS MECHANICAL DIMENSIONS 2.34 .42 1.00 1.50 .23 5x9SC RC01-1 • 2.34 (59.44) x 2.68 (67.95) 2.15 (54.71) x 1.95 (49.53) 2.15 (54.71) x 3.10 (78.74) 1.96 (49.78) x 2.67 (67.95) Fin Height in. (mm) SPIDERCLIP™ HEAT SINK ASSEMBLY FOR MOTOROLA MC68040™, MC68060 1.50 Wakefield 2.68 PRODUCT DESIGNATION 569 - 100 XX - XX OPTIONAL THERMAL INTERFACE PAD (SEE PRODUCT DES.) 569-100AK SERIES ROCKER CLIP OPTION (SEE PRODUCT DES.) THERMAL INTERFACE HEIGHT S4 = DELTALINK IV BLANK = NO THERMAL PAD 100 = 1.00" Dimensions: in. CLIP SPRING CLIP OPTION (SEE PRODUCT DES.) AK = SPRING CLIP LOW-COST HEAT SINKS FOR DIPs AND SRAMs 14-16 Pin DIPs MODEL NUMBER Dimensions: in. (mm) Dimensions: in. (mm) 649-51AB SPIDERCLIP™ ASSEMBLY 649-33AB SPIDERCLIP™ ASSEMBLY NATURAL AND FORCED CONVECTION CHARACTERISTICS 650 & 651 SERIES These extruded heat sinks serve as low-cost heat dissipation solutions for DIPs with pin counts from 14 to 16. Use an epoxy such as Wakefield-Vette Engineering DeltaBond™ 152 or 155, or use Wakefield-Vette 2-part DeltaBond™ 156 modified acrylic adhesive. The 650 and 651 are also available in natural aluminum finish. They can be ordered as 650P or 651P. Standard Length Width P/N in. (mm) in. (mm) 650B 651B 0.250 (6.4) 0.750 (19.1) MECHANICAL DIMENSIONS 0.740 (18.9) 0.415 (10.5) Height Typical Weight in. (mm) Applications lbs. (grams) 0.240 (6.1) 0.240 (6.1) 14-Pin, 16-Pin DIP 14-Pin, 16-Pin DIP 0.003 (1.36) 0.005 (2.27) NATURAL AND FORCED CONVECTION CHARACTERISTICS NOTES: 1. Finish: black anodize 650B Dimensions: in. (mm) 28 651B 2. TIR: Total Indicator Reading. This is a measure of flatness across the greatest dimension of a surface. 29 INTEGRATED CIRCUIT COOLING HEAT SINKS INTEGRATED CIRCUIT COOLING HEAT SINKS HEAT SINKS FOR MICROPROCESSORS & ASICs 669 SERIES SPIDERCLIP™ HEAT SINK ASSEMBLY FOR INTELDX4™, AMD AM486DX2, AND AM486DX4 661 SERIES HEAT SINK WITHOUT CLIP Wakefield-Vette’s 900 Series Heat Sinks for Chipset can match up to devices from Intel, Xilinx, TI, Motorola, ATI, AMD, Nvidia, Vishay, Powerex, Infineon, Microsemi, and many more. 669 Series SpiderClip™ Heat Sink Assemblies may be applied to the following: These heat sinks are designed for air flow applications in the Telecom, Data Center, Networking, Cloud Computing, and many more Industries. • Intel 80486DX and 80486DX2™ (168 PGA) • Intel DX4™ (168 PGA) • Intel 80486SX (168 PGA) and I860XR (208 PGA) • AMD Am 486 Microprocessors AM486DX2, AM486DX4 Standard Base Dimensions P/N in. (mm) 669-32AG 669-33AB 669-40AB 669-52AB 661-32AG 661-33AB 661-40AB 661-52AB PIN FIN HEAT SINK 1.70 (43.2) sq 1.70 (43.2) sq 1.70 (43.2) sq 1.70 (43.2) sq 1.70 (43.2) sq 1.70 (43.2) sq 1.70 (43.2) sq 1.70 (43.2) sq • Intel 82495 Cache Controller • AMD Am 29000 Microcontrollers • Intel I960CA, I960CF Enbedded Controllers Forced Convection Base Thickness in. (mm) Clip Color Standard Finish Weight lbs. (grams) 0.315 (8.0) 0.315 (8.0) 0.400 (10.2) 0.520 (13.2) 0.315 (8.0) 0.315 (8.0) 0.400 (10.2) 0.520 (13.2) 0.090 (2.3) 0.090 (2.3) 0.090 (2.3) 0.090 (2.3) 0.090 (2.3) 0.090 (2.3) 0.090 (2.3) 0.090 (2.3) Black Black Black Black N/A N/A N/A N/A Gold Iridite Black Anodized Black Anodized Black Anodized Gold Iridite Black Anodized Black Anodized Black Anodized 0.044 (19.84) 0.044 (19.84) 0.044 (19.84) 0.050 (22.68) 0.044 (19.84) 0.044 (19.84) 0.044 (19.84) 0.050 (22.68) Natural Convection 200 LFM 400 LFM 600 LFM 12 15 18 21 23 28 33 12 15 18 21 23 28 33 19mm 19mm 19mm 19mm 19mm 19mm 19mm 21mm 21mm 21mm 21mm 21mm 21mm 21mm 12.74 C/W 12.05 C/W 11.35 C/W 10.66 C/W 10.55 C/W 10.27 C/W 9.99 C/W 12.4 C/W 11.73 C/W 11.06 C/W 10.38 C/W 10.27 C/W 9.98 C/W 9.7 C/W 6.6 C/W 6.3 C/W 5.97 C/W 5.66 C/W 5.36 C/W 4.91 C/W 4.52 C/W 6.61 C/W 5.84 C/W 5.51 C/W 5.20 C/W 4.9 C/W 4.55 C/W 4.18 C/W 4.79 C/W 4.51 C/W 4.16 C/W 3.89 C/W 3.64 C/W 3.36 C/W 3.07 C/W 4.37 C/W 4.09 C/W 3.76 C/W 3.49 C/W 3.26 C/W 2.98 C/W 2.73 C/W 4.16 C/W 3.86 C/W 3.47 C/W 3.21 C/W 2.99 C/W 2.71 C/W 2.49 C/W 3.7 C/W 3.42 C/W 3.07 C/W 2.84 C/W 2.62 C/W 2.42 C/W 2.21 C/W 903 12 15 18 21 23 28 33 23mm 23mm 23mm 23mm 23mm 23mm 23mm 12.06 C/W 5.72 C/W 11.41 C/W 5.39 C/W 10.76 C/W 5.05 C/W 10.11 C/W 4.74 C/W 9.99 C/W 4.44 C/W 9.70 C/W 4.09 C/W 9.41 C/W 3.83 C/W 3.95 C/W 3.67 C/W 3.35 C/W 3.1 C/W 2.87 C/W 2.62 C/W 2.43 C/W 3.24 C/W 2.99 C/W 2.67 C/W 2.46 C/W 2.31 C/W 2.12 C/W 1.96 C/W 904 12 15 18 21 23 28 33 27mm 27mm 27mm 27mm 27mm 27mm 27mm 11.38 C/W 10.78 C/W 10.17 C/W 9.56 C/W 9.44 C/W 9.13 C/W 8.82 C/W 4.84 C/W 4.48 C/W 4.13 C/W 3.82 C/W 3.51 C/W 3.26 C/W 3.07 C/W 3.11 C/W 2.84 C/W 2.56 C/W 2.32 C/W 2.11 C/W 1.97 C/W 1.82 C/W 2.32 C/W 2.12 C/W 1.88 C/W 1.72 C/W 1.6 C/W 1.49 C/W 1.39 C/W 905 12 15 18 21 23 28 33 29mm 29mm 29mm 29mm 29mm 29mm 29mm 11.04 C/W 10.46 C/W 9.87 C/W 9.28 C/W 9.16 C/W 8.84 C/W 8.53 C/W 4.08 C/W 2.55 C/W 1.98 C/W 3.82 C/W 2.32 C/W 1.78 C/W 3.58 C/W 2.14 C/W 1.58 C/W 3.33 C/W 1.96 C/W 1.44 C/W 3.13 C/W 1.82 C/W 1.34 C/W 2.82 C/W 1.64 C/W 1.2 C/W 2.59 C/W 1.47 C/W 1.07 C/W 901 902 669-33AB, 669-40AB, 669-52AB 669-32AG SPIDERCLIP™ ASSEMBLY 669-52AB SPIDERCLIP™ ASSEMBLY Dimensions: in. (mm) Chip Size Series Height Dimensions “A” Height in. (mm) MECHANICAL DIMENSIONS 669-32AG 900 SERIES 17 x 17 SPGA Dielectric Breakdown (Nylon Clip Coating) Dielectric Strength: 100 VDC/mil Breakdown Voltage: 200 VDC (minimum) NATURAL AND FORCED CONVECTION CHARACTERISTICS Forced Convection Natural Convection 200 LFM 400 LFM 600 LFM Chip Size Series Height 12 15 18 21 23 28 33 12 15 18 21 23 28 33 31mm 31mm 31mm 31mm 31mm 31mm 31mm 33mm 33mm 33mm 33mm 33mm 33mm 33mm 10.71 C/W 10.14 C/W 9.57 C/W 9.01 C/W 8.88 C/W 8.56 C/W 8.24 C/W 10.37 C/W 9.82 C/W 9.28 C/W 8.73 C/W 8.60 C/W 8.27 C/W 7.94 C/W 3.49 C/W 3.18 C/W 2.93 C/W 2.72 C/W 2.5 C/W 2.26 C/W 2.09 C/W 3.32 C/W 3.14 C/W 2.89 C/W 2.67 C/W 2.45 C/W 2.24 C/W 2.03 C/W 2.28 C/W 2.03 C/W 1.86 C/W 1.69 C/W 1.54 C/W 1.38 C/W 1.27 C/W 2.18 C/W 1.99 C/W 1.78 C/W 1.60 C/W 1.43 C/W 1.28 C/W 1.15 C/W 1.69 C/W 1.5 C/W 1.33 C/W 1.2 C/W 1.07 C/W .96 C/W .88 C/W 1.62 C/W 1.45 C/W 1.3 C/W 1.13 C/W .99 C/W .87 C/W .77 C/W 908 12 15 18 21 23 28 33 35mm 35mm 35mm 35mm 35mm 35mm 35mm 10.03 C/W 9.5 C/W 8.98 C/W 8.46 C/W 8.32 C/W 7.99 C/W 7.65 C/W 3.06 C/W 1.97 C/W 2.85 C/W 1.81 C/W 2.6 C/W 1.64 C/W 2.4 C/W 1.5 C/W 2.19 C/W 1.34 C/W 1.97 C/W 1.19 C/W 1.82 C/W 1.06 C/W 1.49 C/W 1.34 C/W 1.19 C/W 1.07 C/W .97 C/W .83 C/W .7 C/W 909 12 15 18 21 23 28 33 37.5mm 37.5mm 37.5mm 37.5mm 37.5mm 37.5mm 37.5mm 9.60 C/W 9.11 C/W 8.61 C/W 8.11 C/W 7.98 C/W 7.63 C/W 7.29 C/W 2.93 C/W 2.71 C/W 2.52 C/W 2.25 C/W 2.04 C/W 1.82 C/W 1.6 C/W 1.90 C/W 1.36 C/W 1.72 C/W 1.19 C/W 1.53 C/W 1.05 C/W 1.36 C/W .88 C/W 1.2 C/W .75 C/W 1.01 C/W .63 C/W .87 C/W .52 C/W 910 12 15 18 21 23 28 33 40mm 40mm 40mm 40mm 40mm 40mm 40mm 9.18 C/W 8.71 C/W 8.24 C/W 7.77 C/W 7.63 C/W 7.27 C/W 6.92 C/W 2.84 C/W 2.64 C/W 2.4 C/W 2.21 C/W 2 C/W 1.77 C/W 1.58 C/W 1.86 C/W 1.36 C/W 1.65 C/W 1.18 C/W 1.44 C/W .98 C/W 1.27 C/W .86 C/W 1.15 C/W .73 C/W .99 C/W .62 C/W .85 C/W .51 C/W 906 907 Material: AL 6063 Finish: Black Anodize Series Chip Size 19- 901 KEY: 669-32AG 669-33AB 669-40AB 669-52AB 30 0 .315 (8.0) Pin Height, low density pin pattern 0.315 (8.0) Pin Height, high density pin pattern 0.400 (10.2) Pin Height, high density pin pattern 0.520 (13.2) Pin Height, high density pin pattern Construction 2- Height 12- Chip Height 1- Finish B- Interface 1 19 2= Pin Fin 12 = 11.6 1 = .9-2.1 B = BLK ANO 0 = None 21 15 = 14.6 2 = 2.2-3.4 1 = T725 23 18 = 17.6 27 21 = 20.6 29 23 = 22.6 31 28 = 27.6 33 33 = 32.6 35 37.5 Refer to Page 33 for Installation Instructions 31
662-15AGT5
物料型号:文档中列出了多种型号的散热器(Heat Sink),例如D10650、602、605、609等,这些型号适用于不同的BGA封装尺寸。
器件简介:文档主要介绍了针对BGA(球栅阵列)封装的热管理解决方案,包括不同类型的散热器,如单向和多向散热片散热器。
引脚分配:文档中没有明确提到引脚分配,但提到了不同型号的散热器适用于不同尺寸的BGA封装。
参数特性:文档提供了各种散热器的尺寸、高度、典型应用、散热片表面处理、重量等参数信息。
功能详解:文档详细描述了散热器的功能,包括提高电子设备中微电子器件的散热效率,延长设备寿命和提高可靠性。
应用信息:散热器适用于多种应用,如网络路由器和交换机、高分辨率打印机、数字相机、消费类视频游戏、数字视频光盘(DVD)和全球定位系统(GPS)。
封装信息:文档中提到了多种BGA封装尺寸,如17x17、19x19、21x21等,并为每种尺寸推荐了相应的散热器型号。
662-15AGT5 价格&库存
很抱歉,暂时无法提供与“662-15AGT5”相匹配的价格&库存,您可以联系我们找货
