CW7100
CW7100
    CHEMTRONICS
    CONDUCTIVE SILVER GREASE SYRINGE
CW7100 数据手册
Rev. L (4/19) Page 1 of 2 CircuitWorks Silver Conductive Grease Product# CW7100, CW7100KG Product Description CircuitWorks Silver Conductive Grease provides maximum electrical and thermal conductivity, proven lubrication properties, and protection from moisture, oxidation, and other environmental hazards. This system utilizes an advanced silicone lubricant that is compatible with metal, rubber, and plastic. • • • • • • High electrical conductivity Excellent thermal conductivity Provides protection against wear Remains stable in a wide temperature range; -70 to 485°F (-57 to 252°C) Protects against moisture and corrosion Very low viscosity vs. temperature change Typical Applications CircuitWorks Silver Conductive Grease may be used for high and low power applications including: • • • • • Lubrication of substation switches or circuit breakers Heat dissipation from transformers Low or medium speed sliding contacts Static grounding on Seals or o-rings Extending the life of rotating switches Typical Product Data and Physical Properties COMPOSITION: Material: Color: Consistency: PROPERTIES: Volume Resistivity: Thermal Conductivity: (BTU-in/hr-ft2 -°F) (CAL-cm/sec-cm2 -°C ( W/m°K) Operating Temperature Range: Unworked Penetration: (ASTM D-1403) 77°F (25ºC) Worked Penetration: (ASTM D-1403, 60 strokes) Dropping Point: (ASTM D-2266) Steel on Steel Wear: (ASTM D-2266) Corrosion on Copper: Moisture Resistance: Chemical Resistance: Electrical Conductivity: Thermal Conductivity: Lubrication Properties: Protection from Oxidation: Power Rating: Shelflife RoHS Compliant 100% Silver filled grease Silver gray Smooth paste
CW7100 价格&库存
很抱歉,暂时无法提供与“CW7100”相匹配的价格&库存,您可以联系我们找货
CW7100
