Rev. D (7/18) Page 1 of 2
CircuitWorksâ Boron Nitride
Heat Sink Grease
Product# CW7250
Product Description
CircuitWorks Boron Nitride Heat Sink Grease facilitates heat
transfer away from electrical/electronic components and into
heat sinks. The material exhibits exceptionally high thermal
conductivity with outstanding dielectric properties
(nonconductive). CircuitWorks Boron Nitride Heat Sink Grease
shows no creep or migration over a wide temperature range.
The grease contains an efficient heat conducting filler that
enhances the effectiveness of heat sinks on
electrical/electronic equipment.
Exceeds MIL-C-47113 for thermal conductivity
Noncorrosive
High dielectric strength
Stable from -73°C to 200°C
Nonflammable
Typical Applications
CircuitWorks Boron Nitride Heat Sink Grease may be used for
electronics applications including:
Effective Thermal Coupler for any Heat Sink Device
Nonflammable Protective Coating
High Voltage Corona Protection
Excellent for Improving Readings on Contact Type
Thermocouples
Ideal for Silicone Sensitive
Environments
Typical Product Data and Physical Properties
Color:
Specific Gravity:
@ 25°C (77°F)
Usable Temperature Range:
Dielectric Strength:
v/mil
Dielectric Constant:
@ 100 Hz
Dissipative Factor:
@ 100 Hz
Volume Resistivity:
ohm-cm
Arc Resistance:
seconds
Thermal Conductivity:
Cal-cm/sec-cm2 -°C
BTU-in/hr-ft2 -°F
W/m°K
Shelflife
RoHS Compliant
White
1.5
-99.4°F(-73°C) to 392°F (200°C)
400
2.2
0.002
1 x 1012
120
4.4 x 10-3
12.35
1.85
5 years
Yes
1-770-424-4888 www.chemtronics.com
Rev. D (7/18) Page 2 of 2
Heat Sink Grease
Product# CW7250
Availability
CW7250
Compatibility
CircuitWorks Boron Nitride Heat Sink Grease is generally
compatible with most materials used in printed circuit board
fabrication.
Material
Compatibility
Ceramic
Clean Metals
Glass
Silicone Resins
Painted Surfaces
Plastic Surfaces
Vulcanized Silicone Rubber
Good
Good
Good
Good
Good
Good
Good
Usage Instructions
Environmental Impact Data
ODP
HCFC
VOC
HFC
None
None
None
None
Ozone depletion potential (ODP) is determined in accordance with the
Montreal Protocol and U.S. Clean Air Act of 1990. Hydrochlorofluorocarbons
(HCFCs) are regulated under the Montreal Protocol as Class II ozone depleting
substances. Volatile Organic Compound (VOC) information is calculated on a
weight basis using the VOC definition of California Air Resources Board
(CARB) Consumer Product Regulations, South Coast Air Quality Management
District (SCAQMD) Rule 102 and the Federal definition published in 40 CFR
51.100(s). Hydrofluorocarbons (HFCs) are not currently regulated.
Technical and Application Assistance
For industrial use only. Read SDS carefully prior to use.
Apply CircuitWorks Boron Nitride Heat Sink Grease directly to
surface or use the application tip. Remove cap from syringe and
gently depress the plunger. Spread the material in a thin layer on
all mounting and threaded surfaces of the device and the
chassis.
Clean-Up: Wipe away excess material using a Chemtronics
ControlWipes and thoroughly clean the surface using
Chemtronics Electro-Wash PX.
3.4g / 0.13 oz. Syringe
Chemtronics provides a technical hotline to answer your
technical and application related questions.
The toll free number is: 1-800-TECH-401.
Note:
This information is believed to be accurate. It is intended for
professional end users having the skills to evaluate and use the
data properly. CHEMTRONICS does not guarantee the
accuracy of the data and assumes no liability in connection
with damages incurred while using it.
Chemtronicsâ, Electro-Washâ and CircuitWorksâ are registered trademarks
of Chemtronics. All rights reserved. ControlWipesÔ is a trademark of
8125 Cobb Center Drive, Kennesaw, GA 30152 1-770-424-4888 www.chemtronics.com
很抱歉,暂时无法提供与“CW7250”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+221.484181+28.58924
