852815
852815
    LOCTITE(乐泰)
    Thermal Phase Change Thermal Compound 19 gram Applicator Bar
852815 数据手册
Technical Data Sheet Thermstrate ® TC November 2002 PRODUCT DESCRIPTION Thermstrate® TC is a phase change thermal interface material suitable for use between a heat sink and a variety of heat dissipating components. This product is supplied as a dry compound in bar form, packaged in a unique easy to use applicator, which flows in the installation at the phase change temperature and conforms to the surface features of the heat sink and component. Upon flow, air is expelled from the interface, reducing thermal impedance and the material performs as a highly efficient thermal transfer medium. PRODUCT PERFORMANCE Thermal Impedance vs Mounting Pressure The performance of any phase change thermal interface material will be improved by increasing the mounting pressure at the interface. The graph below shows the thermal impedance values generated on an ASTM D5470 platform. The test block dimensions are 2” x 2”, the finish is 64 microinches and the flatness is .002 inches/inch. The power level is 80 watts. Thermstrate TC is a convenient alternative to die cut preforms. Custom parts of the equivalent preformed material, Thermstrate 2000, are available upon request for a wide range of applications. TYPICAL APPLICATIONS Micro processors, hybrid power modules, solid state relays, power transistors, power modules, IGBT’s, RF components etc. Typically used between any heat dissipating electrically isolated component and a heat sink or thermal solution. MATERIAL PROPERTIES One application of Thermstrate TC results in a compound coating thickness of approximately 0.25 mils (0.00635mm). Data for this coating thickness is provided below. Units Substrate Compound Thickness (Nominal) Thermal Impedance @ 20psi ASTM D5470 @137.8 KPa, ASTM D5470 Thermal Impedance @100psiASTM D5470 @689.5 KPa, ASTM D5470 inches mm Thermstrate TC L PRODUCT CHARACTERISTICS .00025 .00635 °C-in2/W °Ccm2/W .015 .097 °C-in2/W °C2 cm /W .010 .065 PHYSICAL PROPERTIES Part Number (Standard) Phase change temperature TC-175-125 60°C Volumetric expansion upon phase 15% change Viscosity above phase change Thixotropic temperature Color Opaque White No silicones in the compound formulation. The graph above shows the typical performance for Thermstrate TC when placed between a device and a heat sink, under a clamp load of 10psi. The temperature at the case of the device and the heat sink are recorded. During the first reflow cycle, i.e. prior to phase change, Thermstrate TC exhibits relatively high thermal impedance. Once the material has changed phase one time, all subsequent operations will see the thermal impedance values indicated on the curve traces which approximately parallel the horizontal axis. NOT FOR PRODUCT SPECIFICATIONS THE TECHNICAL INFORMATION CONTAINED HEREIN IS INTENDED AS REFERENCE ONLY. PLEASE CONTACT LOCTITE CORPORATION QUALITY DEPARTMENT FOR ASSISTANCE AND RECOMMENDATIONS ON SPECIFICATIONS FOR THIS PRODUCT. TDS Thermstrate TC November 2002 Operating Temperature Range Tests have confirmed that Thermstrate TC can be used reliably up to 150°C. Surface Conditions Typical interface surface conditions are quoted below: Surface finish Surface flatness 64 microinches or better 1.6 microns or better .002 inches/inch or better .001 cm/cm or better General Information For safe handling information on this product, consult the Material Safety Data Sheet, (MSDS). Thermstrate TC is completely reworkable. No foreign residue remains after disassembly. If, due to the need for repair or rework of the installation, a second application of the Thermstrate TC can be made without the need for cleaning of interface surfaces. If a clean surface is required, any residual phase change compound present can be easily removed with mineral spirits. While Thermstrate TC is supplied as a convenient to use applicator bar, pretooled pads are available for over one thousand commonly used electronic devices. Thermstrate 2000 may be available as single die cut pads, on multi-pad sheets, or on continuous rolls for high volume production Storage Prior to assembly products shall ideally be stored in a cool, dry location in original packaging at temperatures below 40°C (104°F). Under these conditions the shelf life is indefinite. Thermstrate can be applied to heat sinks which are then shipped to a final assembly location as long as the temperature does not exceed that stated above. Note The data contained hereon are furnished for information only and are believed to be reliable. We cannot assume responsibility for the results obtained by others over whose methods we have no control. It is the user’s responsibility to determine suitability for the user’s purpose of any production methods mentioned herein and to adopt such precautions as may be advisable for the protection of property and of persons against any hazards that may be involved in the handling and use thereof. In the light of the foregoing, Loctite Corporation specifically disclaims all warranties expressed or implied, including warranties of merchantability or fitness for a particular purpose, arising from the sale or use of Loctite Corporation’s products. Loctite Corporation specifically disclaims any liability for consequential or incidental damages of any kind including lost profits. The discussion herein of various processes or compositions is not to be interpreted as representation that they are free from license under any Loctite Corporation patents that may cover such processes or compositions. We recommend that each prospective user test his proposed application before repetitive use, using this data as a guide. This product may be covered by one or more United States or foreign patents or patent applications. Application Recommendations Reasonable flatness and surface conditions should apply to both mating surfaces. Flatness specification for one mating surface of 0.002 in/in is typical of a reasonable flatness and finish specifications work well with this product. These applicator bars are designed in a width that has been highly successful as a low-cost application for microprocessor heat sinks. They are typically used with one “swipe” to make a very acceptable compound application of appropriate thickness and consistency for typical microprocessor heat sinks. Application of this material should be simple with little requirement for repeated application on the same surface. No dispensing or squeegeeing equipment is required. The TC Applicator Bar can be used on an unlimited variety of heat sinks, cold plates, or other component designs, maximizing flexibility. They are intended to be used to deliver a minimum coating thickness on any heat transfer device. Complete directions for use are available via contact with Loctite Laguna Hills, CA at (949) 582-6712. Loctite Electronics Henkel Loctite Corporation, 26941 Cabot Road, Bldg 124, Laguna Hills, CA 92653, U.S.A. U.S.A.: 949.582.6712 Canada: 905.814.6511 Brazil: 011.55.11.4143.7000 Loctite is a Trademark of Henkel Loctite Corp. U.S.A. www.loctite.com
852815
- 物料型号:Thermstrate® TC - 器件简介:Thermstrate® TC是一种相变热界面材料,适用于散热器和各种散热组件之间。它以干性化合物的形式供应,包装在独特的易用涂布器中,在相变温度下流动,适应散热器和组件的表面特征。流动后,界面中的空气被排出,减少热阻抗,材料作为高效的热传递介质。 - 引脚分配:文档中未提及引脚分配信息。 - 参数特性: - 相变温度:60°C - 体积膨胀:相变时15% - 粘度:相变温度以上为触变性 - 颜色:不透明的白色,化合物配方中不含硅油 - 热阻抗:在20psi(137.8 KPa)下为0.015 °C-in2/W 或 0.097 °Ccm2/W,在100psi(689.5 KPa)下为0.010 °C-in2/W 或 0.065 °Ccm2/W - 功能详解:Thermstrate TC在安装时流动并填充接触面,减少热阻抗,提高热传递效率。它是一个方便的替代品,用于切割预制件。Thermstrate 2000的定制部件也可应要求提供。 - 应用信息:适用于微处理器、混合动力模块、固态继电器、功率晶体管、功率模块、IGBT、射频组件等。通常用于任何散热的电绝缘组件和散热器或热解决方案之间。 - 封装信息:Thermstrate TC以方便使用的涂布器条形式供应,也提供预涂垫片,适用于超过一千种常用的电子设备。Thermstrate 2000可提供单片切割垫、多垫片板或连续卷材,适用于大批量生产。
852815 价格&库存
很抱歉,暂时无法提供与“852815”相匹配的价格&库存,您可以联系我们找货
