GRPB042VWVN-RC
GRPB042VWVN-RC
    SULLINS
    CONN HEADER .050" 8POS DL PCB AU
GRPB042VWVN-RC 数据手册
8 7 4 5 6 1 2 3 REVISIONS F REV. ECO. NO DESCRIPTION DATE BY A 1448 INITIAL RELEASE 07/31/07 RAH B 1660 04/15/08 ASK C 1871 ADD TOLERANCE TO TABLE UPDATE POSITION NO., TEXT & TOLERANCE BLOCK, ADD DIM 'A' & R.S. DIM .127 12/08/08 JH F B E E .134 3.40 A D D .118 3.00 .039 1.00 .091 2.30 C C .050 1.27 .016 0.40 .050 1.27 01-20, 0.20mm MAX. 21-50, 0.30mm MAX. A .050 1.27 B A B .050 1.27 NOTES: 1. INSULATOR MATERIAL: NYLON 9T. *PROCESSING TEMPERATURE = 260° C FOR 10 SEC. 2. CONTACT MATERIAL: BRASS. 3. PLATING: GOLD FLASH OVERALL. 4. OPERATING TEMPERATURE: -40°C TO +105° C. 5. INSULATION RESISTANCE: 5000 MEGA OHM MIN. 6. CONTACT RESISTANCE: 20 MILLI OHM MAX. 7. DIELECTRIC WITHSTANDING: AC 500V. 8. UL FLAMMABILITY RATING: 94V-0. 9. CURRENT RATING: 1 AMP. .028±.002 0.70±0.05 RECOMMENDED PCB HOLE LAYOUT UNLESS OTHERWISE SPECIFIED: Pb *INDICATED TEMPERATURE AND TIME IS FOR COMPONENT INSULATOR. HIGHER PROCESSING TEMPERATURES MAY BE USED, PROVIDED HEAT IS APPLIED FROM BACK SIDE OF PCB, AND INSULATOR DOES NOT EXCEED INDICATED TEMPERATURE AND TIME. 8 7 6 DIMENSIONS ARE IN INCHES[MM] TOLERANCES: ANGULAR: .XX= .012 [.30] .XXX= .008 [.20] .XXXX= .004 [.10] SURFACE FINISH: 63 Ra REMOVE ALL BURRS AND SHARP EDGES .010 MAX RoHS COMPLIANT 5 4 DRAWN NAME 12/08/08 JH THE INFORMATION HEREIN CONTAINS PROPIETARY INFORMATION OF SULLINS ELECTRONICS AND IS NOT DESCRIPTION TO BE REPRODUCED, USED OR DISCLOSED TO OTHERS FOR ANY PURPOSE EXCEPT AS SPECIFICALLY PART NUMBER AUTHORIZED IN WRITING BY AN OFFICER OF SULLINS ELECTRONICS. .050" DUAL ROW MALE HEADER, ST GRPB_ _2VWVN-RC SIZE DWG. NO. C INTERPRET DIMENSIONS AND GEOMETRIC TOLERANCING PER: ANSI Y14.5M-1994 3 DATE REV 10954 SCALE: 12:1 2 C SHEET 1 OF 1 1 FILE NAME: Z:\COMPONENTS\Taiwan\10954, GRPB_ _2VWVN-RC PRINT: 2/2/2009 A
GRPB042VWVN-RC 价格&库存
很抱歉,暂时无法提供与“GRPB042VWVN-RC”相匹配的价格&库存,您可以联系我们找货
