GRPB032VWQS-RC
GRPB032VWQS-RC
    SULLINS
    CONN HEADER .050" 6POS DL SMD AU
GRPB032VWQS-RC 数据手册
8 7 4 5 6 1 2 3 REVISIONS F REV. ECO. NO DESCRIPTION DATE BY A 1452 INITIAL RELEASE 07/31/07 RAH B 1660 ADD TOLERANCE TO TABLE 04/15/08 ASK C 1871 UPDATE POSITION, TEXT & TOLERANCE 2/2/2009 JH F B A E E PIN 1 .134 3.40 .050 1.27 .050 1.27 D D .118 3.00 .039 1.00 .016 0.40 .201 5.10 01-20, 0.20mm MAX. 21-50, 0.30mm MAX. C B C A PIN 1 A .079 2.00 B .240 6.10 NOTES: 1. INSULATOR MATERIAL: NYLON 9T. *PROCESSING TEMPERATURE = 260° C FOR 10 SEC. 2. CONTACT MATERIAL: BRASS. 3. PLATING: GOLD FLASH OVERALL. 4. OPERATING TEMPERATURE: -40°C TO +105° C. 5. INSULATION RESISTANCE: 5000 MEGA OHM MIN. 6. CONTACT RESISTANCE: 20 MILLI OHM MAX. 7. DIELECTRIC WITHSTANDING: AC 500V. 8. UL FLAMMABILITY RATING: 94V-0. 9. CURRENT RATING: 1 AMP. .073 1.85 .029 0.74 .050 1.27 RECOMMENDED PCB SMD LAYOUT Pb *INDICATED TEMPERATURE AND TIME IS FOR COMPONENT INSULATOR. HIGHER PROCESSING TEMPERATURES MAY BE USED, PROVIDED HEAT IS APPLIED FROM BACK SIDE OF PCB, AND INSULATOR DOES NOT EXCEED INDICATED TEMPERATURE AND TIME. 8 7 6 UNLESS OTHERWISE SPECIFIED: DIMENSIONS ARE IN INCHES[MM] TOLERANCES: ANGULAR: .XX= .012 [.30] .XXX= .008 [.20] .XXXX= .004 [.10] SURFACE FINISH: 63 Ra REMOVE ALL BURRS AND SHARP EDGES .010 MAX RoHS COMPLIANT 5 4 DRAWN NAME 12/08/08 JH THE INFORMATION HEREIN CONTAINS PROPIETARY INFORMATION OF SULLINS ELECTRONICS AND IS NOT DESCRIPTION TO BE REPRODUCED, USED OR DISCLOSED TO OTHERS FOR ANY PURPOSE EXCEPT AS SPECIFICALLY PART NUMBER AUTHORIZED IN WRITING BY AN OFFICER OF SULLINS ELECTRONICS. .050" DUAL ROW MALE HEADER, SMT GRPB_ _2VWQS-RC SIZE DWG. NO. C INTERPRET DIMENSIONS AND GEOMETRIC TOLERANCING PER: ANSI Y14.5M-1994 3 DATE REV 10958 SCALE: 8:1 2 C SHEET 1 OF 1 1 FILE NAME: Z:\COMPONENTS\Taiwan\10958, GRPB_ _2VWQS-RC PRINT: 2/2/2009 A
GRPB032VWQS-RC 价格&库存
很抱歉,暂时无法提供与“GRPB032VWQS-RC”相匹配的价格&库存,您可以联系我们找货
