DF20F-10DP-1H(50)
DF20F-10DP-1H(50)
    HRS(广濑)
    10 位 接头,有罩 连接器 0.039"(1.00mm) 表面贴装,直角 金
DF20F-10DP-1H(50) 数据手册
1mm Pitch Double Rows Low Profile Wire-to-Board Connectors DF20 Series Cable 5.4 Socket DF20A**DS-1C DF20EF(G)*DP-1V(52) Cable PCB 6.2 DF20F **DP-1H(52) Pin Header 5.5 DF20A**DS-1C Socket PCB ■Features 1. Contact Pitch Narrower external width and length 1mm contact pitch allows reliable solder and cable termination. 2. Reliable electrical connection wipe Effective electrical connection is assured with a 1mm wipe of mating contacts. 3. Narrower external width and length Redesigned metal fittings decreased the overall length of the board- mount receptacle and permit end-to-end mounting of several connectors. 4. Automatic equipment board placement Straight type pin headers are supplied with a 5.4mm × 4.6mm flat platform to allow vacuum pick-up and placement on the board. 5. Product variations Metal fitting (1) Available with 10, 20, 30, 40, and 50 contacts. (2) Pin headers are available in two types : with or without board positioning bosses. (3) Depending on specific application pin headers can be ordered in straight or right angle types. ■Applications Notebook PC, small office automation equipment, small consumer devices, portable devices. Any application requiring low profile reliable board-to-cable connection with a 28 AWG, 30 AWG, 32 AWG conductors. DF20F-****SCFA Contact DF20A-**DS-1C Socket DF20EF(G)*DP-1V(52) Pin Header 1mm Pitch, Double Rows 1 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 5.8 Pin Header In cases where the application will demand a high level of reliability, such as automotive, please contact a company representative for further information. 2021.2⑤ 1 DF20 Series●1mm Pitch Double Rows Low Profile Wire-to-Board Connectors ■Product Specifications Rating Operating temperature -35°C to +85°C 28 AWG : 1A/pin (Note 1) Rated current 30 AWG : 0.9A/pin range 32 AWG : 0.7A/pin Operating humidity -40% to 80% range (Note 2) Rated voltage 100V AC/DC Item 1. Insulation resistance 2. Withstanding voltage 3. Contact resistance Specifications 500Mø min. No flashover or insulation breakdown 30Mø max. 4. Vibration No electrical discontinuity of 1µs min. Contact resistance of 30mø max., insulation resistance of 100Mø min. Contact resistance of 30mø max, insulation resistance of 500Mø min. Contact resistance of 30mø max. No deformation of the insulator parts that will affect performance 5. Humidity Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 6. Temperature cycle 7. Mechanical operation 8. Resistance to Soldering heat Storage temperature range -10°C to +60°C Storage humidity range 40% to 70% Conditions Measured at 100V DC Conduction of 300V AC applied for 1 minute Measure at 1mA. Frequency of 10 to 55 Hz, single amplitude of 0.75mm, in 3 directions for 10 cycles Temperature of 40±2ç, humidity of 90% to 95%, left standing for 96 hours (-55ç : 30min / 5ç to 35ç : 2 to 3min / 85ç : 30min / 5ç to 35ç : 2 to 3min ) for 5 cycles 50 cycles Reflow : At the recommended temperature profile, manual solder : Soldering iron temperature of 300ç for 3 seconds Note1 : Includes temperature rise caused by current flow. Note2 : No condensing. Note3 : Information contained in this catalog represents general requirements for this Series. Contact us for the drawings and specifications for a specific part number shown. ■Materials / Finish Item Socket Crimping contact Part Insulator Contact Insulator Contact Metal Fitting Pin header Material Polyamide Phosphor bronze Polyamide Phosphor bronze Brass Finish Color : Beige Gold plating Color : Beige Gold plating Tin Plating Remarks UL94V-0 ---------UL94V-0 ------------------- Product Number Structure Refer to the chart below when determining the product specifications from the product number. Please select from the product numbers listed in this catalog when placing orders.  ●Pin header DF20 # - * DP - 1 V ❶ ❷ ❸ ❶Series name ❷Boss Type ❹ ❺ ❻ :DF20, DF20E ❹Connector type ■F : Without boss ■G : With boss ❸Number of contacts ❺Contact pitch ❻Type of housing, header :10, 20, 30, 40, 50 DP:Double-row pin header :1mm V:Straight SMT header H:Right angle SMT header ●Crimping contact DF20 F - 2830 SCF A - (**) ❶ ❷ ❸ ❶Applicable wire size 2830:28 to 30 AWG 3032:30 to 32 AWG ❷Contact & packaging type SCF:Socket contact reel ❹ ❸Plating type  ❹Packaging Specifications A:Gold plating 04:1 reel = 10,000 pieces 44:1 reel = 20,000 pieces ●Crimp socket DF20 A - * DS - 1 C ❶ ❶Series name ❷Number of contacts ❸Connector type 2 ❷ ❸ ❹ ❺ :DF20A ❹Contact pitch :10, 20, 30, 40, 50 ❺Type of housing, header DS:Double-row socket :1mm C:Crimp housing RoHS2 YES DF20 Series●1mm Pitch Double Rows Low Profile Wire-to-Board Connectors Double Row Socket A B P=1 Contact No.2 Contact No.1 Contact No.* Contact No.* 5 4.28 4.1 5th contact marking Contact No.1 mark Unit : mm Part No. HRS No. No. of Contacts A B DF20A-10DS-1C 686-0020-3 10 17.2 14.0 DF20A-20DS-1C 686-0021-6 20 12.2 19.0 DF20A-30DS-1C 686-0022-9 30 17.2 14.0 DF20A-40DS-1C 686-0023-1 40 22.2 19.0 DF20A-50DS-1C 686-0024-4 50 27.2 24.0 【Specifications number】-*, (**) Blank : Bag packaging (100 pcs / pack) Note : Sales quantities are by the package unit (containing 100 pieces). Please order by package unit. Crimp Contacts Part No. HRS No. Finish Applicable Wire (Tin plated annealing copper wire) (Note 1) UL Style AWG Wire Construction Sectional Area Jacket Diameter (Note 2) 1571 28 AWG 7cores/0.127mm 0.089mm2 0.54∼0.6mm(0.58mm) DF20F-2830SCFA(**) 686-0042-6 ** Gold plated (Thin type) 30 AWG 7cores/0.1mm 0.055mm2 0.54∼0.6mm(0.56mm) 1571 30 AWG 7cores/0.1mm 0.055mm2 0.54∼0.6mm DF20F-3032SCFA(**) 686-0043-9 ** Gold plated (Thin type) 32 AWG 7cores/0.08mm 0.035mm2 0.54∼0.6mm 【Specifications number( 】**) (04) :10,000 pieces/reel (44) :20,000 pieces/reel 0.7 0.9 3.3 Note 1 : Please consult with our Hirose sales representative when using wires other than these applicable wire. Note 2 : The wire of jacket diameter in parenthis is only suitable when crimping with hand tool. 1.45 0.5 2 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Shown with terminated and installed contacts ●Applicable Crimping Tool Type Part No. HRS No. Applicator AP105-DF20-2830S 901-4572-6 Manual Crimping Tool HT302/DF20B-2830S 902-4540-6 Applicable contact DF20F-2830SCFA(04), DF20F-2830SCFA(44) DF20F-3032SCFA(04), DF20F-3032SCFA(44) DF20F-2830SCFA(04), DF20F-2830SCFA(44) Press CM-105C 901-0001-0 ---------- Note 1 : Hirose Electric will not be responsible for any problems caused by use of tools other than specified. Note 2 : Please conduct crimping work according to the "Crimp Quality Standard (ETAD-H0929-00)" and "Crimp condition table". 3 DF20 Series●1mm Pitch Double Rows Low Profile Wire-to-Board Connectors ■Double Row Straight Pin header B A Contact No.3 P=1 Contact No.1 Contact No. **-1 ** Indication of number of contacts Contact No. ** 6.4 Contact No.2 0.2 0.7 4.6 5.4 Ø0.5 1.9 A Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. D C 0.2 BPCB Footprints A ±0.05 P=1±0.03 0.9±0.05 0.85±0.1 Contact No.1 marking 7.2 ±0.1 .1 +0 0 .7 Ø0 1.9±0.05 4±0.1 1.8 ±0.1 0.5±0.05 0.6±0.05 D±0.05 Note 1 : Shaded area must be free of any electrically conductive traces to avoid contact with soldered pin header terminations. Note 2 : Required only for pin headers supplied with the positioning boss. Unit : mm Part No. HRS No. No. of contacts A B C D DF20EF-10DP-1V (52) 686-0055-0 52 10 14.0 17.3 16.6 ---- DF20EF-20DP-1V (52) 686-0056-0 52 20 19.0 12.3 11.6 ---- DF20EF-30DP-1V (52) 686-0057-0 52 30 14.0 17.3 16.6 ---- DF20EF-40DP-1V (52) 686-0058-0 52 40 19.0 22.3 21.6 ---- DF20EF-50DP-1V (52) 686-0053-0 52 50 24.0 27.3 26.6 ---- DF20EG-10DP-1V (52) 686-0059-0 52 10 14.0 17.3 16.6 15.7 DF20EG-20DP-1V (52) 686-0060-0 52 20 19.0 12.3 11.6 10.7 DF20EG-30DP-1V (52) 686-0061-0 52 30 14.0 17.3 16.6 15.7 DF20EG-40DP-1V (52) 686-0062-0 52 40 19.0 22.3 21.6 20.7 DF20EG-50DP-1V (52) 686-0054-0 52 50 24.0 27.3 26.6 25.7 Remarks Without boss With boss Note 1 : Order embossed tape packaging items by the reel. (1 reel contains 1,000 pieces) 【Specifications number】-*, (**) Note 2 : Vacuum pick-up cap are included with embossed tape packaged connectors. (52) : Gold plating, embossed tape packaging 4 DF20 Series●1mm Pitch Double Rows Low Profile Wire-to-Board Connectors ■Double Row Right angle Pin header Contact No.3 Contact No.1 Contact No.**-1 Contact No.1 marking Contact No.** Contact No.2 B P=1 6.2 0.2 A 0.2 C 1.4 +0.1 0 2.45 +0.1 0 3.8±0.05 1.4 +0.1 0 BPCB Footprints 2.75 ±0.05 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ** A 5 5.5 Indication of number of contacts 0.6±0.05 P=1±0.03 A±0.05 0.75±0.1 D±0.05 Note : Shaded area must be free of any electrically conductive traces to avoid contact with soldered pin header terminations. Unit : mm Part No. HRS No. No. of contacts A B C D DF20F-10DP-1H(52) 686-0027-2 52 10 24.0 27.5 26.2 25.8 DF20F-20DP-1H(52) 686-0028-5 52 20 29.0 12.5 11.2 10.8 DF20F-30DP-1H(52) 686-0029-8 52 30 14.0 17.5 16.2 15.8 DF20F-40DP-1H(52) 686-0030-7 52 40 19.0 22.5 21.2 20.8 Note : Order embossed tape packaging items by the reel. (1 reel contains 1,000 pieces) Remarks Without boss 【Specifications number】-*, (**) (52) : Gold plating, embossed tape packaging 5 DF20 Series●1mm Pitch Double Rows Low Profile Wire-to-Board Connectors BEmbossed Carrier Tape Dimensions ●Straight pin header Ø1 12 ±0.1 +0 0 .1 B ±0.1 0.2±0.05 R0. 75 1.7 +0.15 0 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. A ±0.3 C ±0.1 .5 1.75 ±0.1 2 ±0.1 4 ±0.1 1.5 (0.4) +0.1 0 Unreeling direction (7.9) 2±0.1 12±0.1 4±0.1 B ±0.1 0.2±0.05 R0 .75 1.7 +0.15 0 A ±0.3 C ±0.1 .1 +0 0 .5 Ø1 1.75 ±0.1 ●Right angle pin header (0.4) 1.5 +0.1 0 (7.4) Unreeling direction ●Reel dimensions 16 ------- 17.5 16.4 DF20EF(G)-20DP-1V(52) 20 24 ------- 11.5 24.4 DF20EF(G)-30DP-1V(52) 30 32 28.4 14.2 32.4 DF20EF(G)-40DP-1V(52) 40 44 40.4 20.2 44.4 DF20EF(G)-50DP-1V(52) 50 44 40.4 20.2 44.4 DF20F-10DP-1H(52) 10 16 ------- 17.5 16.4 DF20F-20DP-1H(52) 20 24 ------- 11.5 24.4 DF20F-30DP-1H(52) 30 32 28.4 14.2 32.4 DF20F-40DP-1H(52) 40 44 40.4 20.2 44.4 2 ±0.5 D Product name label 6 Ø1.5mm diameter feed hole depth 0.8 Ø21± (Ø80) C ±0 .2 B Ø1 3 A Ø380 ±2 No. of Contacts DF20EF(G)-10DP-1V(52) 10 Part No. 2±0.5 D +2 0 DF20 Series●1mm Pitch Double Rows Low Profile Wire-to-Board Connectors BCrimping Precautions ■Items required prior to start crimping The work-related documents shown below are required before starting the harness connections. (The ● mark shows the document required.) When the documents shown below are not available, ask our sales personnel to provide them. Document Title (1) Main unit of crimping machine instruction manual (2) Operating lnstructions for Hand Tool (3) Applicator Spare Parts Identification (4) Crimp Conditions Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. (5) Crimp Quality Standards (6) Operating lnstructions for Hand Tool (7) Cable Assembly Procedure Description Automatic Crimping Hand Crimping Machine Tool Explanation of main press machine unit ● − Crimp operation ● − Explanation for Applicator installation Standard values of : Crimp height ; Tensile strength Various standards for crimping conditions Inspection items of : Crimp height ; Crimp operation Tensile strength ● − Cable Assembly Procedure Remarks When purchasing main press machine unit, it is bundled. When purchasing Applicator, it is bundled. ● − ● − − ● When purchasing Hand Tool, it is bundled. ● ● Ask our sales personal to provide them. ■Tools When crimping work is applied to our contacts, the tool designated by Hirose should be used. Crimping work by using tools other than as designated must not be done because it may result in contact failure, disconnection of cable, etc. *The operating instructions manual is available for the crimping machine and the applicator. Be sure to carefully read the operating instructions manual befor implementing the work. ■Applicable electric wires Check that the electric wire to be used is in the range of application. If you intend to use an electric wire other than the recommended one, ask our sales personnel. [Precautions] ・Electric wires that are applicable for crimping connectors shall, principally, be the tin-plated stranded softcopper wire. ・Crimping of electric wires wherein single wires, polyester yarns, etc., exist and crimping of tin-coated wires should be avoided. ・Avoid crimping two electric wires together. ・The setting values of crimp height (Note 1) may vary between tin-plated and gold-plated terminals even if the same electric wires are used. ・The setting values of crimp height (Note 1) may vary depending on the difference in the core wire configuration even if the computed cross-sectional area is the same. Note 1 : The crimp height is an important item that determines crimping quality. We execute crimping tests for each electric wire to ensure the optimal value for the crimp height with high precision, thereby ensuring optimal setup values. 7 DF20 Series●1mm Pitch Double Rows Low Profile Wire-to-Board Connectors Handling Points 1. Recommended Soldering Temperature Profile for IR Reflow. 10(s) max Temperature (℃) 250 240 220 200 150 60 to 120(s) 60(s) max Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 100 60 120 180 240 300 Time(S) Note 1 : Up to 2 cycles of reflow soldering are possible under the same conditions, provided that there is a return to normal temperature between the first and second cycle. Note 2 : The temperature indicates the board surface temperature at the points of contacts with the connector terminals. 2. Recommended Manual Soldering Conditions Soldering temperature : 290° C ±10° C, Soldering time : within 3 sec. 3. Recommended Solder Screen Thickness 0.15mm 4. Board Warping Maximum of 0.03mm at the connector center section, with both ends of the connector as reference points. 5. Cleaning Conditions Refer to "Wire-to-Board Connector Use Handbook" 6. Wiring Termination Conditions Refer to "Wire-to-Board Connector Use Handbook" Crimp contacts should be handled with care as not to cause any deformation or damage affecting the performance or termination. 7. Mating / un-mating precautions Excessive twisting and pulling on wires during mating/un-mating should be avoided as it may cause damage to connectors. 8. Precautions Please refer to the following documents. ■ Crimp Quality Standard (ETAD-H0929-00) ■ Cable Assembly Procedure (ETAD-H0930-00) ■ Mating/Unmating Operation Instruction Manual (ETAD-H0997-00) ■ User Guide for Wire-to-Board Connector ® 8 2-6-3,Nakagawa Chuoh,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN TEL: +81-45-620-3526 Fax: +81-45-591-3726 http://www.hirose.com http://www.hirose-connectors.com The characteristics and the specifications contained herein are for reference purpose. Please refer to the latest customer drawings prior to use. The contents of this catalog are current as of date of 02/2021. Contents are subject to change without notice for the purpose of improvements.
DF20F-10DP-1H(50) 价格&库存
很抱歉,暂时无法提供与“DF20F-10DP-1H(50)”相匹配的价格&库存,您可以联系我们找货
DF20F-10DP-1H(50)
    • 5+8.34418
    库存:2
