TSM-105-01-L-DV-P
TSM-105-01-L-DV-P
    SAMTEC(申泰)
    SMD,P=2.54mm
    排针 2x5P SMT
TSM-105-01-L-DV-P 数据手册
REVISION DR NOTES: 1. C REPRESENTS A CRITICAL DIMENSION. 2. MAXIMUM POST HEIGHT VARIATION: .005[0.13]. 3. LOAD PARTS POS 1 IN SAME DIRECTION AS ARROW. 4. TUBE POSITIONS 03 THRU 50. 5. TAPE & REEL AVAILABLE ON POSITION 02 THRU 28 ONLY. LEADS MAY NOT BE VISIBLE FOR CUSTOMER'S VISUAL INSPECTION ON SMALLER POSITIONED PARTS WHEN USED WITH THE -P OR -M OPTIONS. 6. MEASURE AT BEND RADIUS. 7. MINIMUM PUSHOUT FORCE: 3 LBS. 8. FOR -TV USE T-31724-01. 9. DUE TO THE HIGH AMOUNT OF INSERTION FORCE NEEDED, THE -LC OPTION IS NOT COMPATIBLE WITH AUTO PLACEMENT. SAMTEC RECOMMENDS MANUAL PLACEMENT FOR ALL ASSEMBLIES WITH THE -LC OPTION. 10. ONLY AVAILABLE ON -01-DV OPTION, MATES ONLY WITH SSM, SSW, SSQ, BCS, ESW AND ESQ. 11. MAXIMUM ALLOWABLE CUT FLASH .010[0.25], .015[0.38] ALLOWED TOWARDS TAILS. 12. THIS DIMENSION TO BE MEASURED RELATIVE TO DATUM -Z-. 13. -FR OPTIONS WILL BE SHIPPED AT THE MAX QUANTITY PER REEL, BASED ON OPTIONS SELECTED. DO NOT SCALE FROM THIS PRINT C +.000[0.00] (NO OF POS x .100[2.54]) -.015[0.38] C 02 (NO OF POS -1) x .100[2.54] C TSM-1XX-XX-XXX-XX-X-XXX-X OPTION #3 (NOT AVAILABLE WITH -TV & -TM MOUNT STYLES) -P: PICK AND PLACE PAD (POS -04 THRU -36, 50 USE PPP-06, SEE FIG4, SHT 2) (POS -02, USE PPP-81, SEE FIG 9, SHT 2) (POS -03, USE PPP-86, SEE FIG 10, SHT 2) (AVAILABLE ON POS -02 & -03 WITH -TR & -FR OPTION ONLY) -M: METAL PICK AND PLACE PAD * * FOR EXISTING CUSTOMERS ONLY (USE LMP-01, SEE FIG 5, SHT 2) (NOT RECOMMENDED WITH -T OR -TM PLATING) (LEAD STYLES -01 & -04 ONLY) (AVAILABLE ON POS 04 THRU 36) (AVAILABLE ON POS 02 AND 03 WITH -TR & -FR OPTION ONLY, SEE NOTE 5) -TR: TAPE AND REEL (SEE FIG 8, SHT 3) (02 THRU 28 POS) -FR: FULL REEL QTY. TAPE & REEL (SEE FIG 8, SHT 3) (02 THRU 28 POS)(SEE NOTE 13) OPTION #2 POLARIZED POSITION SPECIFY OMITTED PIN OPTION #1 (AVAILABLE FOR -DV MOUNT STYLE ONLY) -LC: LOCKING CLIP (SEE FIG 2, SHT 2) (USE LC-05-TM) (-03 THRU -36 POS, USE 2 PER STRIP) (-02 POS, USE 1 PER STRIP) (USE RTSM-XX-DVU) (SEE NOTE 9) -A: ALIGNMENT PIN (SEE FIG 3, SHT 2) (FOR MOLDED TO POSITION, USE RTSM-XX-DVU-XX BODY) (FOR STAKED, USE RTSM-50-DVU BODY, 5 POS MIN) (LEAVE BLANK FOR NO HOLD DOWN OPTION) USE RTSM-50-DVU SEE FIG 1, CAN BE CUT TO POSITION) MOUNT STYLE -DV: DOUBLE VERTICAL * -TV: TRIPLE VERTICAL (-02 THRU -30 ONLY) (USE HTSW-50-T-LCP, SEE NOTE 8) -TM: TRIPLE MIXED TECHNOLOGY (-02 THRU -30 ONLY) (USE HTSW-50-T-LCP, AVAILABLE ON -01 LEAD STYLE ONLY) No OF POSITIONS -02 THRU -50 LEAD STYLE (SEE TABLE 1) PLATING SPECIFICATION -T: MATTE TIN ON ENTIRE PIN. -S: 30µ" SELECTIVE GOLD IN CONTACT AREA, MATTE TIN ON TAIL. -G: 10µ" SELECTIVE GOLD IN CONTACT AREA, 3µ" SELECTIVE GOLD ON TAIL. -L: 10µ" SELECTIVE GOLD IN CONTACT AREA, MATTE TIN ON TAIL. -TL: TIN/LEAD (90/10) ON ENTIRE PIN. -STL: 30µ" SELECTIVE GOLD IN CONTACT AREA, TIN/LEAD (90/10) ON TAIL. -F: 3µ" SELECTIVE GOLD IN CONTACT AREA, MATTE TIN ON TAIL. -H: 30µ" SELECTIVE GOLD IN CONTACT AREA, 3µ" SELECTIVE GOLD ON TAIL. -TM: MATTE TIN ON ENTIRE PIN. -SM: 30µ" SELECTIVE GOLD IN CONTACT AREA, MATTE TIN ON TAIL. -LM: 10µ" SELECTIVE GOLD IN CONTACT AREA, MATTE TIN ON TAIL. -FM: 3µ" SELECTIVE GOLD IN CONTACT AREA, MATTE TIN ON TAIL. -SS: 30µ" STRIPE SELECTIVE GOLD IN CONTACT AREA, MATTE TIN ON TAIL. (SEE NOTE 10) RTSM-50-DVU .200 5.08 REF "C" MAX (SEE TABLE 1) 01 03 .025 0.64 SQ REF (TYP) 2 MAX SWAY (EITHER DIRECTION) 5 MAX SWAY (EITHER DIRECTION) 2 MAX SWAY (EITHER DIRECTION) C C C 3° (SEE NOTE 12) .100 2.54 REF * = FOR EXISTING CUSTOMERS ONLY .100 2.54 C "B" (SEE TABLE 1 & NOTE 2) "B" (SEE TABLE 1 & NOTE 2) -Z- SEE TABLE 5 FIG 1 TSM-1XX-XX-XXX-DV SHOWN .050±.010 1.27±0.25 (TYP)(SEE NOTE 6) C 5° (SEE NOTE 12) UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN INCHES. TOLERANCES ARE: DECIMALS ANGLES .XX: .01 [.3] 2 .XXX: .005 [.13] .XXXX: .0020 [.051] MATERIAL: IN-PROCESS -DV MOUNT STYLE * PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING INSULATOR: LCP, UL94VO, COLOR: BLACK TERMINAL: PHOS BRONZE SHEET SCALE: 2:1 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: DOUBLE ROW GULLWING ASM DWG. NO. TSM-1XX-XX-XXX-XX-X-XXX-X F:\DWG\MISC\MKTG\TSM-1XX-XX-XXX-XX-X-XXX-X-MKT.SLDDRW BY: BRYANT 04/24/1991 SHEET 1 OF 3 REVISION DR .045 1.14 REF (SEE TABLE 3) .110 2.79 "A" (NO OF POS -2) x .100[2.54] LC-05-TM .063 1.59 REF 2 MAX SWAY (EITHER DIRECTION) (NO OF POS -2) x .100[2.54] FIG 2 .047 1.19 REF FIG 3 -LC: LOCKING CLIP (DIFFERENT AS SHOWN, OTHERWISE SAME AS FIG 1) -A: ALIGNMENT PIN (DIFFERENT AS SHOWN, OTHERWISE SAME AS FIG 1) "H"±.020[0.51] "G"±.020[0.51] 2 MAX SWAY (EITHER DIRECTION) "J"±.020[0.51] "E" .020[0.51] .390 9.91 REF PPP-06 .157 3.99 REF .164 4.17 .257 6.53 REF PPP-81 PPP-86 .225 5.72 REF "D"±.010[0.13] .270 6.86 REF .270 6.86 REF "D"±.010 .270 6.86 REF .0790 2.007 "D"±.010 "F" FIG 4 -P: PICK AND PLACE PAD (DIFFERENT AS SHOWN, OTHERWISE SAME AS FIG 1) "G" = ((NO OF POS x .100[2.54]) - .390[9.91])/2 FIG 9 -P: PICK AND PLACE PAD (-02 POS ONLY) (DIFFERENT AS SHOWN, OTHERWISE SAME AS FIG 1) "H" = ((NO OF POS x .100[2.54]) - .157[3.99])/2 FIG 5 -M: METAL PICK AND PLACE PAD (DIFFERENT AS SHOWN, OTHERWISE SAME AS FIG 1) "E"=((NO OF POS x .100[2.54]) - .225[5.72]) / 2 FIG 10 -P: PICK AND PLACE PAD (-03 POS ONLY) (DIFFERENT AS SHOWN, OTHERWISE SAME AS FIG 1) NOTE: HAND FILL USE LMP-01 MACHINE FILL USE LMP-01 "J" = ((NO OF POS x .100[2.54]) - .257[6.53])/2 * PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING SHEET SCALE: 2:1 F:\DWG\MISC\MKTG\TSM-1XX-XX-XXX-XX-X-XXX-X-MKT.SLDDRW 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: DOUBLE ROW GULLWING ASM DWG. NO. TSM-1XX-XX-XXX-XX-X-XXX-X BY: BRYANT 04/24/1991 SHEET 2 OF 3 REVISION DR .100 2.54 C .230 5.84 (SEE TABLE 2) (SEE NOTE 2) HTSW-50-T-LCP .100 2.54 REF 3° (SEE NOTE 12) 3° (SEE NOTE 12) .450±.015 11.43±0.38 -TM: TRIPLE MIXED TECHNOLOGY (DIFFERENT AS SHOWN, OTHERWISE SAME AS FIG 1) .020 0.51 REF (TYP) 03 .050 1.27 REF (TYP) 0.00 .150 3.81 REF .050±.010 1.27±0.25 (TYP) (SEE NOTE 6) FIG 6 .1000 2.540 REF (TYP) .0490 1.245 REF (TYP) (SEE TABLE 5, SHT 1) C .150±.010 3.81±0.25 +.000 .230 - .005 5.84 - 0.13 IN-PROCESS T-1S6-17-XXX-2 -TM MOUNT STYLE ROUND HOLES .0500 1.270 REF (TYP) PIN 1 OBLONG HOLES 01 .2980 7.569 REF (TYP) USER DIRECTION OF UNREELING POCKET NOT DETAILED FIG 8 PACKAGING VIEWS (SEE TABLE 5, SHT 1) .050±.010 1.27±0.25 FIG 7 -TV: TRIPLE VERTICAL (DIFFERENT AS SHOWN, OTHERWISE SAME AS FIG 6) FOR EXISTING CUSTOMERS ONLY +.000 0.00 .230 - .005 5.84 - 0.13 +.000 0.00 .230 - .005 5.84 - 0.13 +.000 0.00 .230 - .005 5.84 - 0.13 * .150 3.81 REF .150 3.81 REF .050±.010 1.27±0.25 IN-PROCESS 1 -TV MOUNT STYLE IN-PROCESS 2 -TV MOUNT STYLE IN-PROCESS 3 -TV MOUNT STYLE F:\DWG\MISC\MKTG\TSM-1XX-XX-XXX-XX-X-XXX-X-MKT.SLDDRW PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING SHEET SCALE: 2:1 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail info@SAMTEC.com code 55322 DESCRIPTION: DOUBLE ROW GULLWING ASM DWG. NO. TSM-1XX-XX-XXX-XX-X-XXX-X BY: BRYANT 04/24/1991 SHEET 3 OF 3
TSM-105-01-L-DV-P
1. 物料型号:文档中提到了多种型号,例如TSM-1XX-XX-XXX-XX-X-XXX-X,具体型号取决于引脚数量和配置。
2. 器件简介:文档描述了一种双排鸥翼式表面贴装(ASM)连接器,具有不同的引脚分配和配置选项。
3. 引脚分配:文档提供了不同位置的引脚分配信息,例如从-02到-50的引脚位置。
4. 参数特性:包括了引脚长度、终端类型、整体引脚长度等参数,例如对于-01型号,引脚长度为0.230英寸,终端类型为T-1S6-16-X-2,整体引脚长度参考值为0.445英寸。
5. 功能详解:文档详细描述了不同配置的功能,如-DV型号为双垂直配置,-TV型号为三垂直配置,-TM型号为三混合技术配置。
6. 应用信息:文档提供了关于如何使用这些连接器的指导,包括引脚的锁定夹(-LC)、对齐销(-A)等选项。
7. 封装信息:文档中包含了封装的尺寸和公差信息,如引脚间距、最大摇摆角度等。
8. 其他信息:文档还包含了制造和设计注意事项,以及关于如何正确处理和包装这些连接器的说明。
TSM-105-01-L-DV-P 价格&库存
很抱歉,暂时无法提供与“TSM-105-01-L-DV-P”相匹配的价格&库存,您可以联系我们找货
TSM-105-01-L-DV-P
    • 200+11.51700
    • 500+9.79000
    • 1000+7.97500
    • 2000+7.53500
    库存:3000
