EHF-105-01-L-D-SM
EHF-105-01-L-D-SM
    SAMTEC(申泰)
    SMD
EHF-105-01-L-D-SM 数据手册
REVISION AG DO NOT SCALE FROM THIS PRINT FIG 1 (No OF POS x .050 [1.27]) + .570 [14.48] REF EHF-1XX-01-XX-D-XX-XX-XX EHF-110-01-XX-D-SM-LC OPTION -LC: LOCKING CLIP (FOR -D-SM ONLY) (SEE NOTE 7) -P: PICK & PLACE PAD (FOR -D-SM ONLY) (FOR -03 & -04, USE PPP-25, SEE FIG 7, SHT 3) (FOR -05 THRU -25, USE PPP-48, SEE FIG 2) -K: POLYIMIDE FILM (USE K-500-300, SEE FIG 3) -TR: TAPE & REEL PACKAGING (FOR -D-SM, -D-SM-P, & -D-SM-K ONLY) (NOT AVAILABLE ON -D-SM-LC) No OF POSITIONS -03, -04,-05, -08, -10, 2 MAX SWAY -13, -17, -20, -25 LEAD STYLE .100 2.54 .310 7.87 REF -01 (TYP) REF (No OF POS - 1) PLATING SPECIFICATION .135 3.43 x .050 [1.27] -L: 10µ" SELECTIVE GOLD IN CONTACT AREA, REF REF MATTE TIN ON TAIL (USE T-1SXX-XX-L) 02 -F: 3µ" SELECTIVE GOLD IN CONTACT AREA, "A" MATTE TIN ON TAIL (USE T-1SXX-XX-F) .263 6.67 -S: 30µ" SELECTIVE GOLD IN CONTACT AREA, REF MATTE TIN ON TAIL (USE T-1SXX-XX-S) XX -H: 30µ" GOLD IN CONTACT AREA, 3µ" GOLD "A" ON TAIL (USE T-1SXX-XX-H) 01 -LM: 10µ" SELECTIVE GOLD IN CONTACT AREA, .020 0.51 MATTE TIN ON TAIL (USE T-1SXX-XX-L) (No OF POS x.050 [1.27]) -SM: 30µ" SELECTIVE GOLD IN CONTACT AREA, REF + .200 [5.08] REF MATTE TIN ON TAIL (USE T-1SXX-XX-S) .05 1.270 -FM: 3µ" SELECTIVE GOLD IN CONTACT AREA, MATTE TIN ON TAIL (USE T-1SXX-XX-F) .016 0.41 REF EHF-XX-D POLARIZED OPTION -XX = PIN OMITTED (N/A ON -RA OPTION) TAIL OPTION (LEAVE BLANK FOR THROUGH HOLE, SEE FIG 4, SHEET 2, USE T-1S63-01-XX) -SM: SURFACE MOUNT (USE T-1S15-02-XX) -RA: RIGHT ANGLE (USE T-1S63-02-XX AND T-1S63-03-XX) (SEE FIG 5, SHEET 2) ROW SPECIFICATION -D: DOUBLE +2° 90° - 3° .325 8.26 REF .120 3.05 REF .335 8.51 C .004[0.10] T-1S15-02-XX POS 1 INDICATOR SECTION "A"-"A" LC-09-TM .060 1.52 (No OF POS x .050 [1.27]) + .290 [7.37] REF NOTES: .083 2.111 .170 4.318 (TYP) -SM IN-PROCESS 1 (SCALE: 1.5:1) -SM IN-PROCESS 2 .084 2.13 90°±3° .296±.010 7.52±0.25 (SCALE: 1.5:1) 1. C REPRESENTS A CRITICAL DIMENSION. 2. COPLANARITY TO BE WITHIN .004[0.10]. 3. MAXIMUM BURR ALLOWANCE: .0015 [0.038]. 4. MINIMUM PUSHOUT FORCE: 1 LB. 5. MAXIMUM ALLOWABLE BOW: .002[0.05] INCH/INCH AFTER ASSEMBLY. 6. NOTE DELETED. 7. DUE TO THE HIGH AMOUNT OF INSERTION FORCE NEEDED, THE –LC OPTION IS NOT COMPATIBLE WITH AUTO PLACEMENT. SAMTEC RECOMMENDS MANUAL PLACEMENT FOR ALL ASSEMBLIES WITH THE –LC OPTION. ARM ASSEMBLY & ROTATION EHA-02 .180 4.57 .296±.010 7.52±0.25 .200 5.08 REF FIG 2 CL .295 7.50 REF .445 11.31 REF {(No OF POS X .050[1.27] + .370[9.40]) / 2} .020[0.51] PPP-48 CL -P: PICK AND PLACE PAD (SCALE 1.5:1) .293 7.44 REF UNLESS OTHERWISE SPECIFIED, DIMENSIONS ARE IN INCHES. TOLERANCES ARE: DECIMALS MATERIAL: FIG 3 -K: POLYIMIDE FILM (SCALE: 1.5:1) ANGLES .XX: .01[0.3] 2 .XXX: .005[0.13] .XXXX: .0020[0.051] {(NO OF POS X .050[1.27] + .275[6.98]) / 2} .020[0.51] .260 6.60 REF * PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING INSULATOR: VECTRA E130i, COLOR BLACK 50% REGRIND TERMINAL: PHOS BRONZE 510 SPRING SHEET SCALE: 1.75:1 F:\dwg\sw\exisprod\assembly\050\EHF-1XX-01-XX-D-XX-XX-XX-ASM.SLDDRW 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail: info@SAMTEC.com code: 55322 DESCRIPTION: .050 EJECTOR HEADER ASSEMBLY DWG. NO. EHF-1XX-01-XX-D-XX-XX-XX BY: ERIC M. 08/17/01 SHEET 1 OF 3 REVISION AG 02 FIG 4 FIG 5 -RA: RIGHT ANGLE OPTION (SHOWN: EHF-110-01-XX-D-RA) (SAME AS FIG 1, UNLESS OTHERWISE STATED) STANDARD THROUGH HOLE (SHOWN: EHF-110-01-XX-D) (SAME AS FIG 1, UNLESS OTHERWISE STATED) 01 T-1S63-01-XX "B" "C" 2 MAX SWAY (TYP) T-1S63-03-XX T-1S63-02-XX 90°±3° .350 8.89 REF .120 3.05 REF C .107 2.72 "B" SECTION "B"-"B" .050 1.27 .090 2.29 "C" SECTION "C"-"C" C .050 1.27 PACKAGING VIEWS (LOAD PARTS WITH POSITION #1 INDICATOR IN SAME DIRECTION AS ARROW ON TUBE) REF -RA IN-PROCESS 2 -RA IN-PROCESS 1 .210 5.34 90°±3° .120 3.05 .120 3.05 .480 12.19 .580 14.73 NOTE: ARROW POINTS INTO THE SHEET AWAY FROM YOU. PT-1-24-01-51 T-1S63-03-XX .050 1.27 .180 4.57 PT-1-24-16-29 T-1S63-02-XX .09 2.3 REF EJECTOR ARM MUST BE IN UPPRIGHT POSITION WHEN LOADED INTO TUBES F:\dwg\sw\exisprod\assembly\050\EHF-1XX-01-XX-D-XX-XX-XX-ASM.SLDDRW * PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING SHEET SCALE: 2:1 PT-1-24-05-09 PT-1-24-01-52 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail: info@SAMTEC.com code: 55322 DESCRIPTION: .050 EJECTOR HEADER ASSEMBLY DWG. NO. EHF-1XX-01-XX-D-XX-XX-XX BY: ERIC M. 08/17/01 SHEET 2 OF 3 REVISION AG (NO. OF POSITIONS x .050 [1.27]) +.715 [18.16] REF FIG 6 .343 8.70 REF -SM: SURFACE MOUNT OPTION (SHOWN: EHF-110-01-XX-D-SM-LC) (SHOWN WITH LATCHES OPEN) .400 10.16 REF (TYP) R.028 0.70 REF (TYP) .526 13.36 REF .097 2.47 REF (TYP) FIG 8 APPLICATION VIEW EHF MATED WITH FFSD AND ECF FIG 7 -03 & -04 PICK AND PLACE PAD (SHOWN: EHF-104-01-XX-D-SM-XX-P) .200 5.08 REF ROUND HOLES PPP-25 POS 01 INDICATOR .283 7.19 REF LATCHES OMITTED FOR CLARITY OBLONG HOLES FIG 9 -TR: TAPE & REEL * PROPRIETARY NOTE * THIS DOCUMENT CONTAINS CONFIDENTIAL AND PROPRIETARY INFORMATION AND ALL DESIGN, MANUFACTURING, REPRODUCTION, USE, PATENT RIGHTS AND SALES RIGHTS ARE EXPRESSLY RESERVED BY SAMTEC, INC. THIS DOCUMENT SHALL NOT BE DISCLOSED, IN WHOLE OR PART, TO ANY UNAUTHORIZED PERSON OR ENTITY NOR REPRODUCED, TRANSFERRED OR INCORPORATED IN ANY OTHER PROJECT IN ANY MANNER WITHOUT THE EXPRESS WRITTEN CONSENT OF SAMTEC, INC. DO NOT SCALE DRAWING SHEET SCALE: 2:1 F:\dwg\sw\exisprod\assembly\050\EHF-1XX-01-XX-D-XX-XX-XX-ASM.SLDDRW 520 PARK EAST BLVD, NEW ALBANY, IN 47150 PHONE: 812-944-6733 FAX: 812-948-5047 e-Mail: info@SAMTEC.com code: 55322 DESCRIPTION: .050 EJECTOR HEADER ASSEMBLY DWG. NO. EHF-1XX-01-XX-D-XX-XX-XX BY: ERIC M. 08/17/01 SHEET 3 OF 3
EHF-105-01-L-D-SM
1. 物料型号:EHF-1XX-01-XX-D-XX-XX-XX,EHF-110-01-XX-D-SM-LC 2. 引脚分配:文档中提到了不同配置的引脚分配,例如-03, -04, -05, -08, -10, -13, -17, -20, -25等,但没有具体列出每个引脚的功能。 3. 参数特性:提到了多种参数,如最大偏斜2 MAX SWAY,引脚镀金规格如10µ"选择性金接触区域,尾部镀锡等。 4. 功能详解:文档中包含了不同配置的功能描述,例如-LC: LOCKING CLIP (FOR -D-SM ONLY),-P: PICK & PLACE PAD (FOR -D-SM ONLY)等。 5. 应用信息:文档中提供了应用视图,例如EHF与FFSD和ECF配合的视图。 6. 封装信息:提到了不同的封装选项,如-SM: SURFACE MOUNT,-RA: RIGHT ANGLE等,以及相关的包装管和插头信息。
EHF-105-01-L-D-SM 价格&库存
很抱歉,暂时无法提供与“EHF-105-01-L-D-SM”相匹配的价格&库存,您可以联系我们找货
EHF-105-01-L-D-SM
  • 27+33.34699
  • 54+31.03761
  • 108+27.85767
  • 513+24.52056
  • 1026+21.43735
  • 2511+16.54050
  • 5022+13.03410
库存:242
EHF-105-01-L-D-SM
  • 1+31.323101+3.98940
  • 27+29.1074027+3.70720
  • 54+28.2561054+3.59880
  • 513+25.52720513+3.25120
  • 1026+22.880101026+2.91410
  • 2511+18.868502511+2.40310
  • 5022+18.775205022+2.39130
库存:290
