ST60-18P(30)
ST60-18P(30)
    HRS(广濑)
    CONNRCPT18POSSMD
ST60-18P(30) 数据手册
Interface Connectors for Portable Terminal Devices ST Series Strong locking mechanism Right Mating axial direction Left May.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Top 49N max. Overview The ST Series interface connectors are specifically designed for use as Input/Output (I/O) connectors on portable information devices. They feature a unique structure with high strength which resists deformation and helps to prevent improper mating. 3.0 mm height and 0.5 mm contact pitch connector prevents EMI as well. The ST Series can be used in wide range of applications such as DSC, PDA, laptop PCs, cellular phones, etc. Bottom Fig.1 Prevention against reversed or angle insertion Polarization keys Contacts are not damaged! Features 1. Strong locking mechanism To assure continuous reliability of the connection in an unpredictable consumer environment, mated connectors will withstand pull force of 49N max. applied in any direction. (Fig.1) 2. Prevention against reversed or angle insertion Multiple polarization keys will not allow incorrect insertion of the mating plug. In addition, contacts will not be damaged when the user attempts to insert only the corner of the mating plug. (Fig.2) 3. Optimal I/F for Small Devices Plugs are 8 mm in height and 20 mm long (including covers), which is appropriate for small devices. Receptacles feature the low height of 3 mm and the contact pitch of 0.5 mm. Their small size saves valuable space and contributes to a smaller device set. Fig.2 Plug variations Identification surface Reverse plug Identification surface 4. Multiple Variations A wide variations is available for supporting different types of peripheral devices. Examples include shielded plugs for data communication, non-shielded plugs for power charge, reversed plug types as shown in Fig.3 and cradle type connectors. Standard plug Fig.3 5. Cable Options This connector uses a solder type termination, which allows you to apply flexible cable types. Applications Digital Still Cameras, Personal Digital Assistance, Notebook computers, Cellular phones, Smart phones and other portable devices requiring high reliability small size input/output connection. In cases where the application will demand a high level of reliability, such as automotive, please contact a company representative for further information. 2016.9④ 1 ST Series●Interface Connectors for Portable Terminal Devices Product Specifications Rating Current rating 0.5A (1 A max. can be carried via 4 random contacts) Operating temperature range : -30ç to +80ç Voltage rating Storage temperature range : -40ç to +85ç (Note) 100V AC Characteristic Specification May.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 11. Contact resistance 12. Insulation resistance 13. Dielectric withstanding voltage 14. Mating/un-mating forces 15. Durability (mating/un-mating) 16. Shock Conditions 60mø max. 1,000Mø min. No flashover or insulation breakdown. Mating : 29.4N max. 100mA DC 250V DC 350V AC/ 1 minute With corresponding connector. Contact resistance : 100mø max. 10,000 cycles Acceleration of 490 m/s2, 11 ms duration, sine half-wave waveform, 3 cycles in each of the 3 axis. Temperature : -55ç ➝ +5ç to +35ç ➝ +85ç ➝ +5ç to +35ç Time (Minutes) : -30 ➝ +5 ➝ +30 ➝ +5 5 cycles 5±1% salt water solution at 35±3ç for 48 hours, after washing without salt, leave for 24 hours at room temperature No electrical discontinuity of 10µ sec. max. 17. Temperature cycle Contact resistance : 100mø max. Insulation resistance : 1,000Mø min. 18. Salt spray No corrosions 19. Lock strength Fully inserted and locked corresponding connector. Pull force : 49N max. applied in each of the 4 axis. No physical damage or electrical failure. Frequency : 10 to 55 Hz, single amplitude of 0.75mm, 2 No electrical discontinuity of 10µ sec. max. hours, 3 axis. 10. Vibration Note: Includes temperature rise caused by current flow. Materials / Finish ● Receptacles and cradles Component Material Finish Remarks Insulator Thermoplastic compound, glass reinforced Color: Black UL94V-0 Contacts Copper alloy Contact area: Gold plated ------------------- Shield Stainless steel Tin alloy plating ------------------- ● Plugs Component Material Finish Remarks  Insulator Thermoplastic compound, glass reinforced Color: Black UL94V-0 Contacts Copper alloy Contact area: Gold plated ------------------- Shield Stainless steel ------------------- ------------------- Cover Thermoplastic compound, glass reinforced ------------------- UL94V-0 Product Number Structure Refer to the chart below when determining the product specifications from the product number. Please select from the product numbers listed in this catalog when placing orders. ● Receptacles q Series name w Termination type ST 60 - 18 P (30) q w r t u ● Plugs e ST 40 X - 18 S - CVR (30) q w e r t y u r t ● Plug - Cradle type ST 80 X - 18 S (30) q w e r t y u u 2 60 40 80 Shield X Blank Number of contacts Contact type P S Plug type CV CVR CV1 RoHS compliant : ST : Right angle SMT : Solder type : Cradle, vertical, SMT : With shield : Without shield : Male contact (Receptacle) : Female contact (Plug) : Standard type, for top PCB mount : Reverse type, for bottom PCB mount : For larger diameter cables : (30) ST Series●Interface Connectors for Portable Terminal Devices Recommended PCB mounting pattern Receptacle 10 pos. 10.5 4.5 0.5 )#* E2%#* %#( &#. '#- (#&b^c '#, &#+ 6.4 7 No.10 ST60 ™ 0.3 0.75 RoHS ) &%#& (4) 3 Packaging 1,500pcs/reel G% #%#+ * &#. & 1.5 (4.4) 10.1 18 pos. Recommended PCB mounting pattern RoHS 14.1 ™ 2 2.8 3.6 PCB edge 0.6(Through hole) 1.9(Land) 14.1 0.3 0.75 Packaging 1,500pcs/reel 0.9 .3 2.7 R0. 85 No.18 ST60 Part No. HRS No. ST60-18P(30) 241-0011-9 30 1 6.6(Land) R0 13.2 No.1 0.3(Land) 3.1 6.9 7.5 (0.58) 15.5 8.5 0.5 1.6 1.9 14.5 8.5 0.5 0.18 (4) 3 1.5 4.4 24 pos. Recommended PCB mounting pattern 0.18 (18.5) 16.2 No.1 RoHS 17.1 ™ 2 2.8 3.6 9.6(Land) 17.1 PCB edge 0.6(Through hole) 1.9(Land) 0.3 1.5 4.4 0.75 Packaging 1,500pcs/reel 1 No.24 ST60 Part No. HRS No. ST60-24P(30) 241-0003-0 30 11.5 0.5 0.3(Land) 3.1 R R0 0.3 2.71.6 .85 1.9 (0.58) 6.9 7.5 0.5 0.9 17.5 11.5 (4) 3 36 pos. Packaging 1,500pcs/reel RoHS ™ 1.8 2.35 R0 .3 R1 5 2.45(Land) 9.25 24.6 1.45 3.05 PCB edge 0.7(Through hole) 2(Land) No.36 No.1 ST60 0.3 24.6 1.5 5 0.75 HRS No. ST60-36P(30) 241-0033-1 30 19 2 0.35(Land) (0.58) (26) 23.5 Part No. 0.5 3.65 3.25 0.18 7 7.5 0.5 25 19 2 1.7 2.1 Recommended PCB mounting pattern (4.06) 3 May.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Part No. HRS No. ST60-10P(30) 241-0022-5 30 ] dj\ ]g #(I G% 9.2 No.1 Z ]da (0.58) (11.5) &#+ (#& &#. 0.18 3 ST Series●Interface Connectors for Portable Terminal Devices 36 pos. reverse type Recommended PCB mounting pattern ™ No.1 No.36 ST60 May.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Plug – cradle type(Horizontal) 1.5 5 0.3 24.6 0.75 RoHS (4.06) 3 Packaging 1,500pcs/reel 1.45 (0.58) (26) 23.5 Part No. HRS No. ST60-36PR(30) 241-0036-0 30 PCB edge 0.7(Through hole) 2(Land) 1.8 2.35 2.45(Land) 9.25 24.6 3.05 1.7 2.1 0.18 7 7.5 0.5 3.65 R0 .35 3.25 R1 25 19 2 19 2 0.35(Land) 0.5 13.78 18 pos. Recommended PCB mounting pattern 5) 3.575 3.85(max) 0.9 P=0.5 PCB edge Ø1 Connector positioning 14.5 .5 11.6 1.45(Land) .72 (R0 1.475 0.75 2.95 1.7 3.1 2.5 ) ole (h 1.5 7.95(min) 0.85(Through hole) ™ 15.55 14.5 ) 25 4 0. (R 8.5 0.32(Land) 1.75 RoHS 0.05 1.8 1.5(hole) Packaging 900pcs/reel 0.25 3.575 0.9 1.35 Part No. HRS No. ST60X-18S(30) 241-0028-1 30 0.15 0.5 8.5 1.5 3.05 9.05 (13.65) 0.25 Ø1 .3 1.25 2.25 11.6 15.55 1.375 1.475 17 15.8 No.1 No.18 RoHS ™ 0.15 19 24.95 0.5 Recommended PCB mounting pattern 26 24.95 1.5 2.1 le) 0.05 0.5 19 2 0.32(Land) 3.1 2.5 Connector positioning 4 22.05 1.25 3.55(max) Ø1 .7 (ho PCB edge 7.75(min) 0.85(Through hole) 1.45(Land) Packaging 900pcs/reel 0.25 4.475 0.9 4.475 Part No. HRS No. ST60X-36S(30) 241-0035-7 30 Ø1 .3 0.9 1.4 9.05 (13.65) 0.25 22.05 26 1.475 0.75 No.1 1.375 No.36 1.475 24.25 27.5 (2.95) 36 pos. ST Series●Interface Connectors for Portable Terminal Devices Plug – cradle type(Vertical) 11.3 11.3 4 1.5 ™ No.10 0.15 2.6 2.6 4 2.62.6 7.8 5.5 No.2 1 1.75 RoHS 1 1.75 R0.5 R0.3 1.15 9.6 2.1 2.5 10.3 11.2 0.25 6 4 1.5 10.3 Recommended PCB mounting pattern 18 pos. 14.9 1.5 14.9 8 1.6 8.8 2.875 0.9(Land) 0.5(Through hole) Ø1.3 0.15 2.825 0.25 2.875 .1 R2 No.17 2 2.4 45 le) 1.1 9.6 1.5 R0. 1 4.25 8 13.6 14.2 25.7 ho 7.8 6 . Ø1 .5( RoHS 5.5 ( 55 25 No.1 1 4.25 8 ho R0. ™ 2 Packaging 400 pcs/reel 1.1 ) le 3.75 1 Ø4 (18) 27.6 25.7 8 3.75 1 0.2 No.18 No.18 No.2 No.1 Part No. HRS No. ST80X-18S(30) 241-0020-0 30 2.825 0.5(Land) ST80 1.5 13.6 14.2 A 4.15 5.6 1 5.75 11 R1.8 No.23 5 .4 R0.2 R0 5.25 1 4.8 8.8 1.15 2.6 0.15 1.25 4.15 Ø1.3 6 9.6 1 5.75 11 9.6 16.2 17.2 27 2.1 2.5 0.25 No.1 No.24 No.24 6 7.8 ™ e) ol (h 6 . Ø1 0.5(Land) le) (ho Ø4 .5 3 R0 R0. RoHS ST80 Packaging 400 pcs/reel (20.7) 29.9 27 11 5.25 No.2 1 0.2 No.1 1(Land) A Part No. HRS No. ST80X-24S(30) 241-0037-2 30 2.4 2 0.75 2.6 2.6 1.5 0.5(Through hole) 0.9(Land) 17.2 0.6(Through hole) 0.75 17.2 11 5 Recommended PCB mounting pattern 24 pos. 9.6 1.6 May.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved. No.9 No.10 ST80 Packaging 400pcs/reel 0.2 Ø1.3 2.25 1 No.1 No.1 Part No. HRS No. ST80X-10S(30) 241-0030-3 30 8.8 4.8 16 11.2 4 2.4 2 2 2.25 1 R0.45 0.5 R0.25 (Land) Ø1.6(hole) 0.5(Through hole) 0.9(Land) Recommended PCB mounting pattern 0.6(Through hole) 1(Land) 10 pos. A 1.25 1.5 16.2 17.2 5 ST Series●Interface Connectors for Portable Terminal Devices Plug 10 pos. (Non-shielded type) 7 6 19.5 16 16 Part No. HRS No. Packaging RoHS ST40-10S-CV(30) 241-0021-2 30 1 ™ No.1 May.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved. No.10 10 pos. (Reverse, non-shielded type) 7 6 19.5 16 16 Part No. HRS No. Packaging RoHS ST40-10S-CVR(30) 241-0040-7 30 1 ™ No.1 No.10 10 pos. (Shielded type) 7 6 19.5 16 16 Part No. HRS No. Packaging RoHS ST40X-10S-CV(30) 241-0041-0 30 1 ™ No.1 No.10 10 pos. (Reverse, shielded type) 7 6 19.5 16 16 Part No. HRS No. Packaging RoHS ST40X-10S-CVR(30) 241-0029-4 30 1 ™ No.10 6 No.1 ST Series●Interface Connectors for Portable Terminal Devices 18 pos. (Shielded type) 7 5.5 20 18 18 Part No. HRS No. Packaging RoHS ST40X-18S-CV(30) 241-0012-1 30 1 ™ No.1 18 pos. (Reverse, shielded type) 7 5.5 20 18 18 Part No. HRS No. Packaging RoHS ST40X-18S-CVR(30) 241-0016-2 30 1 ™ No.1 No.18 24 pos. (Shielded type) 7 5.5 20 21 21 Part No. HRS No. Packaging RoHS ST40X-24S-CV(30) 241-0004-3 30 1 ™ No.1 No.24 24 pos. (Shielded type) (10) 9 20.1 (10) 21 5.5 May.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved. No.18 21 Part No. HRS No. Packaging RoHS ST40X-24S-CV1(30) 241-0023-8 30 1 ™ No.24 No.1 7 ST Series●Interface Connectors for Portable Terminal Devices 36 pos. (Shielded type) 11.4 6.7 29 30.6 32.5 Part No. HRS No. Packaging RoHS ST40X-36S-CV(30) 241-0034-4 30 1 ™ 7.6 No.1 No.36 Note: Plug assemblies will require additional components. Contact Hirose Electric representative for detailed descriptions and installation instructions. May.1.2020 Copyright 2020 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Packaging Specification Embossed Carrier Tape Dimensions Reel Dimensions Part No. ST60-10P(30) ST60-18P(30) ST60-24P(30) ST60-36P(30) ST60-36PR(30) ST80X-10S(30) ST80X-18S(30) ST80X-24S(30) ST60X-18S(30) ST60X-36S(30) A 24 24 32 44 44 24 44 44 32 44 B --------28.4 40.4 40.4 ----40.4 40.4 28.4 40.4 C 11.5 11.5 14.2 20.2 20.2 11.5 20.2 20.2 14.2 20.2 D 12 12 12 12 12 16 16 16 20 20 E 00.5 00.5 00.5 00.5 00.5 12.2 12.7 12.7 4.95 4.85 pcs. / reel 1,500 1,500 1,500 1,500 1,500 0400 0400 0400 0900 0900 E B A C .5 Ø1 1.75 Unreeling direction D 4 2 Recommended Temperature Profile (Lead-free soldering compound) Reel Dimensions This measurement is performed on Unreeling direction (ç) the contact lead section. 240ç 230ç min 250 (13) Pocket (Ø 38 2) The temperature profile may vary 200 180ç due to external conditions such as 150 150ç the type of cream solder, manufacturer, and board size. 100 60S 50 30S Please contact the solder manufacturer for their specifications. ® 8 2-6-3,Nakagawa Chuoh,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN TEL: +81-45-620-3526 Fax: +81-45-591-3726 http://www.hirose.com http://www.hirose-connectors.com The characteristics and the specifications contained herein are for reference purpose. Please refer to the latest customer drawings prior to use. The contents of this catalog are current as of date of 09/2016. Contents are subject to change without notice for the purpose of improvements.
ST60-18P(30) 价格&库存
很抱歉,暂时无法提供与“ST60-18P(30)”相匹配的价格&库存,您可以联系我们找货
ST60-18P(30)
    • 1+18.43010
    • 10+15.63450
    • 100+14.37010
    • 500+13.30560
    • 1000+12.32000
    库存:1425
