10JQ-BT
10JQ-BT
    JST
    P=2.5mm
    排母 间距:2.5mm 1x10P 直插
10JQ-BT 数据手册
JQ CONNECTOR 2.5 mm pitch/Board-to-board connectors JQ CONNECTOR 5 JS Specifications PC board layout and Assembly layout Top entry type Recognized E60389 Certified LR20812 R50088587 ® ® ® ® 2.5 min. Receptacle: 2.6 min. Shrouded header: 3.4 min. +0.1 Side entry type 2.5 min. Receptacle: 2.6 max. Shrouded header: 7.6 max. +0.1 φ0.9 0 Shrouded header φ0.9 0 2.5 ±0.05 Receptacle Combinations Top entry type Side entry type 6 11.8 2.5 ±0.05 Standards 3.4 5.75 16.3 6.15 ® 16.3 High contact pressure Box-shaped shroud Secure locking on printed circuit boards Vertical, horizontal and parallel mounting Interchangeability 12.4 ● ● ● ● ● * In using the products,refer to "Handling Precaution for Terminal and Connector" described on our website (Technical documents of Product information page). * RoHS2 compliance * Dimensional unit: mm * Contact JST for details. Side entry type S( )B-XH-A-1 Top entry type B( )B-XH-A T This 2.5 mm pitch connector is used to interconnect printed circuit boards. It easily resists distortion during mating, thus ensuring reliable contact, even under adverse conditions. • Current rating: 3 A AC/DC • Voltage rating: 250 V AC/DC • Temperature range: -25℃ to +85℃ (including temperature rise in applying electrical current) • Contact resistance: Initial value/ 10 mΩ max. After environmental tests/ 20 mΩ max. • Insulation resistance: 1,000 MΩ min. • Withstanding voltage: 1,000 VAC/minute • Applicable PC board thickness: 1.6 mm 2.6 max. 2.9 6.15 10.2 2.2 Note: 1 . The above figure is the figure viewed from soldering side. 2. Tolerances are non-cumulative: ± 0.05 mm for all centers. 3. H  ole dimensions differ according to the kind of PC board and piercing method. The dimensions above should serve as a guideline. Contact JST for details. 1 JQ CONNECTOR JQコネクタ表1 Receptacle Model No. No. of circuits Top entry type Side entry type Top entry type 3 4 B A 2.5 5 6 2.5 7 6 2.7 1.5 4.1 8 C 10 11 4.8 1 1.6 9 12 9.5 13 15 03JQ-ST 04JQ-ST 05JQ-ST 06JQ-ST 07JQ-ST 08JQ-ST 09JQ-ST 10JQ-ST 11JQ-ST 12JQ-ST 13JQ-ST 15JQ-ST B C Q'ty/box Top entry Side entry type type 5.0 10.0 8.2 500 500 7.5 12.5 10.7 500 500 10.0 15.0 13.2 500 500 12.5 17.5 15.7 500 500 15.0 20.0 18.2 250 250 17.5 22.5 20.7 200 250 20.0 25.0 23.2 200 250 22.5 27.5 25.7 250 250 25.0 30.0 28.2 250 250 27.5 32.5 30.7 200 200 30.0 35.0 33.2 200 200 35.0 40.0 38.2 100 100 Material and Finish Side entry type Contact: Phosphor bronze, tin-plated (reflow treatment) Housing: PA 66, UL94V-0, natural B RoHS2 compliance A 2.5 03JQ-BT 04JQ-BT 05JQ-BT 06JQ-BT 07JQ-BT 08JQ-BT 09JQ-BT 10JQ-BT 11JQ-BT 12JQ-BT 13JQ-BT 15JQ-BT Dimensions (mm) A 6 4.1 1 1.5 2.5 1.6 2.6 2.2 C 9.5 Shrouded header Top entry type Dimensions (mm) Q'ty/box Model No. No. of circuits Top entry type Side entry type A B Top entry type Side entry type 3 5.0 9.9 1,000 1,000 S3B-XH-A-1 B3B-XH-A 4 7.5 12.4 500 500 S4B-XH-A-1 B4B-XH-A 5 10.0 14.9 500 500 S5B-XH-A-1 B5B-XH-A 6 12.5 17.4 500 500 S6B-XH-A-1 B6B-XH-A 7 15.0 19.9 250 500 S7B-XH-A-1 B7B-XH-A 8 17.5 22.4 250 500 S8B-XH-A-1 B8B-XH-A 9 20.0 24.9 250 500 S9B-XH-A-1 B9B-XH-A 27.4 10 22.5 250 250 S10B-XH-A-1 B10B-XH-A 11 25.0 29.9 250 250 S11B-XH-A-1 B11B-XH-A 200 32.4 12 27.5 250 S12B-XH-A-1 B12B-XH-A 200 13 30.0 34.9 250 S13B-XH-A-1 B13B-XH-A 200 37.4 14 32.5 250 S14B-XH-A-1 B14B-XH-A 200 15 35.0 39.9 250 S15B-XH-A-1 B15B-XH-A 0.64 7 8 3.4 JST (2.35) 2.5 5.75 A 2.45 B Side entry type 0.64 Material and Finish 7.6 JST 11.5 7 8 RoHS2 compliance This product displays (LF)(SN) on a label. 2.5 2.45 A B 2 Post: Brass, copper-undercoated, tin-plated (reflow treatment) Wafer: PA 66, UL94V-0, natural (white) (6.1) 3.4
10JQ-BT 价格&库存
很抱歉,暂时无法提供与“10JQ-BT”相匹配的价格&库存,您可以联系我们找货
10JQ-BT
    库存:50
    10JQ-BT
      10JQ-BT
        • 250+1.32650
        库存:3250
