8
7
4
5
6
1
2
3
REVISIONS
REV.
ECO. NO
J
3900
F
K
3963
DESCRIPTION
DATE
UPDATE RAB TAIL-TO-RAB TAIL DIM TOLERANCE
FOR POSI 35 TO POSI 40 (WAS .008), ADD DIM A
ON MATING SIDE, UPDATE TOL FOR TAIL LENGTH, 8/22/2018
1ST RAB DISTANCE ( .010 WAS .008) & PITCH
DIM TOL
UPDATE GENERAL TOL IN TITLE BOX, NOTE 8 &
WARP TOL, UPGRADE NYLON MTL (FROM 6T TO 9T), 1/3/2019
UPDATE TAIL-TO-TAIL, TAIL PITCH & TAIL ROW
SPACING DIM TO REF
BY
JH/LH
F
JH
E
E
B .014[ 0.35]
A .004[ 0.10]
A .008[ 0.20]
.100 2.54
.100±.002 2.54±0.05
.100 2.54
.100±.002 2.54±0.05
D
D
.040±.002 1.02±0.05
RECOMMENDED PCB LAYOUT
.100 2.54
A
.200 5.08
.102 2.58
.124±.010 3.15±0.25
C
C
.256 6.50
.335 8.50
.063±.010 1.60±0.25
.100 2.54
B
B
.024(W) X .016(T) [0.60(W) X 0.40(T)]
02-15, .008[0.20] MAX.
16-30, .012[0.30] MAX.
31-40, .016[0.40] MAX.
A
NOTES:
1. INSULATOR MATERIAL: SEE PART NUMBER CODING.
2. CONTACT MATERIAL: PHOSPHOR BRONZE.
3. CONTACT PLATING: SEE PART NUMBER CODING.
4. CURRENT RATING: 3 AMPS
5. VOLTAGE RATING: 250 VAC
6. INSULATOR RESISTANCE: 5000 MEGOHMS MIN.
7. CONTACT RESISTANCE: 20 MILLIOHMS MAX.
8. DIELECTRIC WITHSTANDING: 1000 VAC.
9. OPERATING TEMPERATURE: -40° C TO +105° C.
10.MATES WITH SULLINS .100 [2.54] CONTACT CENTER MALE HEADER SERIES.
(.025 [0.64] SQUARE POSTS)
8
7
6
Pb
RoHS COMPLIANT
5
4
UNLESS OTHERWISE SPECIFIED: DRAWN DATE NAME
DIMENSIONS ARE IN INCHES [MM]
2/15/2008 JH
TOLERANCES:
ANGULAR:
5
DECIMALS
.XX= .012 [.3]
.XXX= .008 [.20]
.XXXX= .0039 [.100]
THE INFORMATION HEREIN CONTAINS
PROPRIETARY INFORMATION OF
SULLINS ELECTRONICS AND IS NOT
TO BE REPRODUCED, USED OR
DISCLOSED TO OTHERS FOR ANY
PURPOSE EXCEPT AS SPECIFICALLY
AUTHORIZED IN WRITING BY AN
OFFICER OF SULLINS ELECTRONICS.
TITLE
HEADER FEMALE, .100" [2.54mm]
CC, 2 ROW, RA
PART NUMBER
SIZE
C
SCALE: 6:1
3
2
xPxCxx2LJBN-RC
CAGE CODE
54453
A
DWG. NO.
10494
SHEET 1 OF 1
1
REV
K
FILE NAME: 10494, P(N)PxCxx2LJBN-RC
很抱歉,暂时无法提供与“PPPC142LJBN-RC”相匹配的价格&库存,您可以联系我们找货
