PPPC162LJBN-RC
PPPC162LJBN-RC
    SULLINS
    CONN FMALE 32POS DL .1" R/A GOLD
PPPC162LJBN-RC 数据手册
8 7 4 5 6 1 2 3 REVISIONS REV. ECO. NO J 3900 F K 3963 DESCRIPTION DATE UPDATE RAB TAIL-TO-RAB TAIL DIM TOLERANCE FOR POSI 35 TO POSI 40 (WAS .008), ADD DIM A ON MATING SIDE, UPDATE TOL FOR TAIL LENGTH, 8/22/2018 1ST RAB DISTANCE ( .010 WAS .008) & PITCH DIM TOL UPDATE GENERAL TOL IN TITLE BOX, NOTE 8 & WARP TOL, UPGRADE NYLON MTL (FROM 6T TO 9T), 1/3/2019 UPDATE TAIL-TO-TAIL, TAIL PITCH & TAIL ROW SPACING DIM TO REF BY JH/LH F JH E E B .014[ 0.35] A .004[ 0.10] A .008[ 0.20] .100 2.54 .100±.002 2.54±0.05 .100 2.54 .100±.002 2.54±0.05 D D .040±.002 1.02±0.05 RECOMMENDED PCB LAYOUT .100 2.54 A .200 5.08 .102 2.58 .124±.010 3.15±0.25 C C .256 6.50 .335 8.50 .063±.010 1.60±0.25 .100 2.54 B B .024(W) X .016(T) [0.60(W) X 0.40(T)] 02-15, .008[0.20] MAX. 16-30, .012[0.30] MAX. 31-40, .016[0.40] MAX. A NOTES: 1. INSULATOR MATERIAL: SEE PART NUMBER CODING. 2. CONTACT MATERIAL: PHOSPHOR BRONZE. 3. CONTACT PLATING: SEE PART NUMBER CODING. 4. CURRENT RATING: 3 AMPS 5. VOLTAGE RATING: 250 VAC 6. INSULATOR RESISTANCE: 5000 MEGOHMS MIN. 7. CONTACT RESISTANCE: 20 MILLIOHMS MAX. 8. DIELECTRIC WITHSTANDING: 1000 VAC. 9. OPERATING TEMPERATURE: -40° C TO +105° C. 10.MATES WITH SULLINS .100 [2.54] CONTACT CENTER MALE HEADER SERIES. (.025 [0.64] SQUARE POSTS) 8 7 6 Pb RoHS COMPLIANT 5 4 UNLESS OTHERWISE SPECIFIED: DRAWN DATE NAME DIMENSIONS ARE IN INCHES [MM] 2/15/2008 JH TOLERANCES: ANGULAR: 5 DECIMALS .XX= .012 [.3] .XXX= .008 [.20] .XXXX= .0039 [.100] THE INFORMATION HEREIN CONTAINS PROPRIETARY INFORMATION OF SULLINS ELECTRONICS AND IS NOT TO BE REPRODUCED, USED OR DISCLOSED TO OTHERS FOR ANY PURPOSE EXCEPT AS SPECIFICALLY AUTHORIZED IN WRITING BY AN OFFICER OF SULLINS ELECTRONICS. TITLE HEADER FEMALE, .100" [2.54mm] CC, 2 ROW, RA PART NUMBER SIZE C SCALE: 6:1 3 2 xPxCxx2LJBN-RC CAGE CODE 54453 A DWG. NO. 10494 SHEET 1 OF 1 1 REV K FILE NAME: 10494, P(N)PxCxx2LJBN-RC
PPPC162LJBN-RC 价格&库存
很抱歉,暂时无法提供与“PPPC162LJBN-RC”相匹配的价格&库存,您可以联系我们找货
