F-221 SUPPLEMENT
SC–8P1–GT
SC–1P4–GG
SC, T SERIES
MACHINED TERMINALS & SOCKETS
SPECIFICATIONS
SC–1P1–, SC–6P1–
SC
Contact: BeCu
Shell: Brass
-GG Plating:
30 µ" (0.76 µm) Au over
50 µ" (1.27 µm) Ni on contact;
10 µ" (0.25 µm) Au over
50 µ" (1.27 µm) Ni on shell
-GT Plating:
Sn over 50 µ" (1.27 µm) Ni
on shell
-TT Plating:
Ni on contact; Sn over
-ST Plating:
Ni on shell
Lead DIA Accepted:
(0.38 mm) .015" to
(0.56 mm) .022" and
most IC leads
SPECIFICATIONS
(0.76)
.030
(1.83)
.072
DIA
X
Part No.
SC–1P1–
SC–6P1–
Y
(1.52)
.061
DIA
Z
DIA ±.010 ±.015
(0.51) (3.18) (7.62)
.020 .125 .300
(0.51) (4.57) (8.89)
.020 .180 .350
SC–8P1
(1.83)
.072
DIA
(4.19)
.165
(0.71)
.028
(1.32)
.052
DIA
(2.11)
(0.25)
.083
.010
(1.32)
.052
DIA
(0.74)
.029 DIA
Z
Y
X
DIA
Insertion Depth (SC-1P1, SC-6P1) = (2.41 mm) .95" to (3.68 mm) .145"
Plating Available (SC-1P1) = GG, GT, TT, ST
Plating Available (SC-6P1) = GG, GT
Insertion Depth = (2.16 mm) .085" to .140" (3.56 mm)
Lead DIA Accepted: (0.41 mm) .016" to (0.51 mm) .020"
Plating Available = GG, GT, TT
SC-1P4
Contact: BeCu
Shell: Brass
-GG Plating:
20 µ" (0.51 µm) Au over
-GT Plating:
Insertion Force:
6.5 oz (1.81 N) avg,
13 oz (3.62 N) max
(.032" (0.81 mm) DIA probe)
Withdrawal Force:
3 oz (0.83 N) avg,
2 oz (0.56 N) min
SC–1P4–
T–1S6–
(2.28)
.090
DIA
(0.76)
.030
(0.64)
.025
SQ
SPECIFICATIONS
T-1S6
T Series is available with
a choice of Gold or Tin
plating. Add -G or -T as
a suffix to the part
number shown.
-G Plating:
Au over 50 µ"
(1.27 µm) Ni
-T Plating:
Ni or 100 µ" (2.54 µm) Cu
Note:
Some sizes, styles and
options are non-standard,
non-returnable.
RECOMMENDED
PC HOLE SIZE:
LEAD SIZE
HOLE SIZE
(0.46) .018 DIA
(0.51) .020 DIA
(0.64) .025 DIA
(0.76) .030 DIA
(0.89) .035 DIA
(1.14) .045 DIA
(1.32) .052 DIA
(0.61) .024 DIA
(0.66) .026 DIA
(0.79) .031 DIA
(0.91) .036 DIA
(1.04) .041 DIA
(1.30) .051 DIA
(1.47) .058 DIA
(0.46) .018 SQ
(0.64) .025 SQ
(1.14) .045 SQ
(0.76) .030 DIA
(1.02) .040 DIA
(1.75) .069 DIA
(0.20) .008 x (0.71) .028
(0.25) .010 x (0.51) .020
(0.41) .016 x (0.51) .020
(0.41) .016 x (0.61) .024
(0.41) .016 x (0.79) .031
(0.89) .035 DIA
(0.71) .028 DIA
(0.79) .031 DIA
(0.89) .035 DIA
(1.04) .041 DIA
(2.18)
.086
DIA
(9.53)
.375
(1.98)
.078
DIA
(0.71)
.028
B
(3.18)
.125
(0.76)
.030
DIA
PART NO.
B
T–1S6–07–X–2
(10.92) .430
T–1S6–08–X–2
(13.46) .530
T–1S6–09–X–2
(18.54) .730
T–1S6–10–X–2
(21.08) .830
T–1S6–11–X–2
(23.62) .930
T–1S6–12–X–2
(26.16) 1.030
T–1S6–13–X–2
(31.24) 1.230
T–1S6–14–X–2
(36.32) 1.430
T–1S6–15–X–2
(16.00) .630
T–1S6–16–X–2
(11.30) .445
T–1S6–17–X–2
(12.19) .480
T–1S6–18–X–2
(7.62) .300
T–1S6–19–X–2
(33.78) 1.330
T–1S6–20–X–2
(28.70) 1.130
T–1S6–21–X–2
(8.51) .335
Pins are supplied on a bandolier.
Material: Phosphor Bronze
X = Plating option (specify G or T)
Insertion Depth = (4.45 mm ) .175" to (5.46 mm) .215"
Lead DIA Accepted = (0.81 mm) .032" to (0.97 mm) .038"
–G = 10 µ" (0.25 µm) Gold on (4.19 mm) .165"
contact area. Gold flash on balance
–T = 200 µ" (5.08 µm) Tin
WWW.SAMTEC.COM
Unless otherwise approved in writing by Samtec, all parts and components are designed and built according to Samtec’s specifications which are subject to change without notice.
很抱歉,暂时无法提供与“T-1S6-08-T-2”相匹配的价格&库存,您可以联系我们找货
