Consumer Aftermarket
Product Catalog
Fuse Panels and Blocks, and Terminal Strips
Consumer Aftermarket Catalog
Fuse Panels, Blocks, Junction Blocks & Terminal Strips
Designed for versatility, durability and ease-of-installation, Cooper
Bussmann fuse panels and blocks deliver the ideal solution for many
applications. Cooper Bussmann fuse panels and blocks are molded of
high-performance thermoplastic, and feature high quality hardware in a
choice of connector styles.
Fuse Panels For Blade Fuses
Power Distribution Relay Module & Fuse Block
RTMF Fuse Panel - ATM Footprint
The 24 volt CBPRM
contains a 35A relay and
two FMX fuse positions
(one protects the relay and
the other a single-circuit in-line fuse)
The Rear Terminal 20
Position ATM Fuse
Panel provides
efficient power
distribution in a
rugged compact
package.
The sealed Power Relay Module (CBPRM) and Power Fuse Module (CBPFM)
are compact power distribution modules for
high current applications having
extreme moisture and high
vibration.
The CBPFM has two FMX fuse
positions for separate circuits.
The RTMF offers a weather tight enclosure (IP66/67)
for ATM blade fuses and circuit breakers when cover, cable
seals, and cavity plugs are installed.*
Shown with deep cover.
Fuses and circuit breakers sold separately.
Part No.
Description
RTMF
RTMF-SC
RTMF-DC
20 position fuse block
20 position fuse block with shallow cover
20 position fuse block with deep cover
*Electrical terminals, cable seals and cavity plugs are either Delphi Packard Metri-Pack® 280 Series terminals
(sealed/tangless) or AMP® terminals. They accept #12-22 AWG wire sizes. Delphi Packard 280 Series cavity plugs
are installed where wires are not used. Seals and cavity plugs not sold by Cooper Bussmann.
FMX fuses sold separately.
Both the CBPRM and CBPFM feature
rugged M8 power input studs, and an IP66 removable, weather-tight cover
to protect the fuse positions.
Electrical terminations not supplied by Cooper Bussmann.
Part No.
Description
CBPFM
CBPRM
Power Fuse Module
Power Relay Module
S-8202 Series 300 Volt, 20 Amp Glass Tube Fuse Blocks
Part No.
(Poles)
S-8202-1
S-8202-2
S-8202-3
S-8202-4
S-8202-5
S-8202-7
S-8202-8
S-8202-9
S-8202-10
S-8202-12
15600 Fuse Panels - ATC Footprint
A single, common power input makes it
simple to wire for multiple circuits each rated to 30 amps, up to 32
volts. Molded of high grade
thermoplastic, for superior
performance. Quick-connect
terminals for easy
installation. Recessed fuse
contacts provide fingersafe protection.
Short Base
Part No.
4
6
8
10
12
14
16
18
15600-06-20
15600-08-20
15600-10-20
15600-12-20
15600-14-20
15600-16-20
15600-18-20
15600-20-20
X
X
X
X
S-8202 – Fuse blocks with
1
/4” quick-connect
terminals 300 volt rating.
Available in 1 through
12 position units.
Break-away design
lets you snap off or
combine positions
as needed to get
the exact number required
for your application. UL recognized, 20 amp
maximum.
S-8301 Series 300 Volt, 30 Amp Glass Tube Fuse Blocks
Part No.
(Poles)
Fuse
Positions
Blister Tri-Lingual
Pack Blister
Blister
Pack
Tri-Lingual
Blister
X*
X*
Long Base
Part No.
15600-04-21
15600-06-21
15600-08-21
15600-10-21
15600-12-21
15600-14-21
15600-16-21
15600-18-21
15600-20-21
S-8301-1
S-8301-2
S-8301-3
S-8301-4
S-8301-5
S-8301-6
S-8301-7
S-8301-8
S-8301-9
S-8301-10
S-8301-11
S-8301-12
Blister
Pack
X
S-8301 – Fuse blocks with screw connect
terminals 300 volt rating. Available in 1 through 12
position units. Break-away design lets you snap off
or combine positions as needed to
get the exact number required for
30 amp max.
*Not available for long base panels.
For product information and data sheets, visit www.cooperbussmann.com
19
HMEG Fuse Holder
Terminal Strips and Blocks
Use with AMG fuses from 100 to 300 amps.
Recommended wire size #2-8. HMEG fuse
holders have full-access design for ease of
wiring. HMEG is impact resistant and has
durable plastic base and cover.
BP/C5237 Designed for trucks, RVs and wiring accessories - Cooper
Bussmann stud-type junction blocks, BP/C5237-3BC, BP/C5237-6BC and
BP/C5237-8BC available in 3, 6 and 8 terminal configurations. Rated for
applications to 30A, 300V (UL)/ 600V (CSA).
TB200 and TB300 terminal blocks are nickel-plated brass with black
thermoplastic construction.
HMID Fuse Block
Use with AMI fuses from 40 to 80 amps.
Multiple blocks can be linked together to
form an assembly.
SFR Fuse Block
Lift truck fuse holder. Use with ANN and
ANL fuses.
Part No.
Description
HMEG
HMID
Stud Fuse Holder with Cover for use with AMG high amp fuses.
Stud Fuse Holder with Cover for use with AMI high amp fuses, linkable
to form an assembly.
Open Stud Fuse Block for ANN and ANL current limiters
SFR
Poles Part No.
Type
Stud/
Screw
Volts/
Amps
3
6
8
4
6
8
10
15
4
6
8
10
12
Stud Junction Block
Stud Junction Block
Stud Junction Block
Double Row Barrier Block
10-32
10-32
10-32
6-32
6-32
6-32
6-32
6-32
8-32
8-32
8-32
8-32
8-32
8-32
300V/30A
300V/30A
300V/30A
300V/20A
300V/20A
300V/20A
300V/20A
300V/20A
600V/30A
600V/30A
600V/30A
600V/30A
600V/30A
600V/30A
BP/C5237-3BC
BP/C5237-6BC
BP/C5237-8BC
TB200-04B
TB200-06B
TB200-08B
TB200-10B
TB200-15B
TB300-04B
TB300-06B
TB300-08B
TB300-10B
TB300-12B
TB300-20B
TB200_B
Junction Blocks
C1938 Feed-through stud-type
junction block 3/8-16 thread/stud
size, 250* amps max.
JB3816-2 Non-feed through
stud-type junction block 3/8-16
thread/stud size, 250* amps max.
*Voltage rating dependent upon installation
TB300_B
BP/C1938
BP/JB3816-2
Poles
Part No.
Type
1
1
BP/C1938
BP/JB3816-2
Stud Junction Feed Through
Stud Junction Block
Stud Thread
/8-16
/8-16
3
3
Battery Power Tap
BP/BAT-TAP - Attaches directly to battery terminal
to create three additional circuits.
Part No.
BP/C5237
BP/BAT-TAP
Description
BP/BAT-TAP Attaches to side battery terminal to create three, non-fused 1/4”
quick-connect circuits.
Mouser Electronics
Authorized Distributor
Click to View Pricing, Inventory, Delivery & Lifecycle Information:
Eaton:
HMEG BP/JB3816-2
很抱歉,暂时无法提供与“BP/JB3816-2”相匹配的价格&库存,您可以联系我们找货
