FVDAH-2
FVDAH-2
    JST
    LIPPED BLADE 16-14AWG
FVDAH-2 数据手册
Solderless terminals LIPPED BLADE Non-insulated øD B ød1 Brazed seam G1 G E W T X L E42024 Tool No. Dimensions mm (in.) Applicable Wire AWG#(mm2) Standard Part No. 16 to 14 (1.04 to 2.63) 12 to 10 (2.63 to 6.64) AH-2 AH-5.5 B L G E G1 øD ø d1 T W X 4.6 (.181) 4.6 (.181) 21.6 (.850) 23.6 (.929) 16.8 (.661) 16.8 (.661) 4.8 (.189) 6.8 (.268) 13.0 (.512) 13.0 (.512) 4.1 (.161) 5.6 (.220) 2.3 (.091) 3.4 (.134) 0.8 (.031) 0.8 (.031) 2.0 (.079) 2.0 (.079) 1.7 (.067) 1.9 (.075) YHT-2210 YA-1 YA-2 YA-4 BCT-0514L Certificate No.: Qty/box o o o o o 1,000 o o o o o 500 Note:1) The part numbers indicated in the above table are for products with a brazed seam. When ordering products with a butted seam, add the prefix "WS" to the part number (ex. AH-2 –>WSAH-2). 2) Delivery lead times may vary depending on the product. Contact JST for details. Solderless terminals øD B B øD LIPPED BLADE Vinyl-insulated G1 G1 G G T X L T X L STRAIGHT Applicable Wire AWG#(mm2) 22 to 16 * (0.25 to 1.65) 16 to 14 (1.04 to 2.63) 12 to 10 (2.63 to 6.64) FLARED E42024 Tool No. Dimensions mm (in.) Part No. Standard Straight Flared B L G - FVAH-1.25 - FVAH-2 - FVAH-5.5 4.6 (.181) 4.6 (.181) 4.6 (.181) 25.8 (1.016) 25.8 (1.016) 30.3 (1.193) 16.8 (.661) 16.8 (.661) 16.8 (.661) G1 9.0 (.354) 9.0 (.354) 13.5 (.531) 13.0 (.512) 13.0 (.512) 13.0 (.512) Color øD Str. 3.2 (.126) 3.9 (.154) 5.4 (.213) Fld. 4.0 (.157) 4.5 (.177) 6.8 (.268) T X 0.8 (.031) 0.8 (.031) 0.8 (.031) 1.7 (.067) 1.7 (.067) 1.9 (.075) Red Blue Yellow YNT-2216 YNT-1614 YNT-1210S YA-1 YA-2 YA-4 BCT-0514L Certificate No.: o o o Qty/box o o o o 500 o o o o 500 o o 250 Note:1) The part numbers indicated in the above table are for products with a brazed seam. When ordering products with a butted seam, add the prefix "WS" to the part number (ex. FVAH-1.25 –>FVWSAH-1.25). 2) *The crimping will be more secure if the total cross-sectional area of the wire is at least 0.5 mm2. Examples: If the cross-sectional area of the wire is 0.3 mm2, fold the wire in two when crimping the terminal. If the cross-sectional area of the wire is 0.5 mm2, crimp the terminal onto the wire as it is. 3) Delivery lead times may vary depending on the product. Contact JST for details. 43 Solderless terminals øD B B øD LIPPED BLADE Vinyl-insulated with copper sleeve G1 G1 G G Applicable Wire AWG#(mm2) 22 to 16 (0.25 to 1.65) 16 to 14 (1.04 to 2.63) 12 to 10 (2.63 to 6.64) Standard Flared VDAH-1.25 FVDAH-1.25 VDAH-2 FVDAH-2 VDAH-5.5 FVDAH-5.5 FLARED Tool No. Dimensions mm (in.) Part No. Straight B L G 4.6 (.181) 4.6 (.181) 4.6 (.181) 26.4 (1.039) 26.4 (1.039) 30.8 (1.213) 16.8 (.661) 16.8 (.661) 16.8 (.661) G1 9.6 (.378) 9.6 (.378) 14.0 (.551) 13.0 (.512) 13.0 (.512) 13.0 (.512) Color øD Str. 3.5 (.138) 4.1 (.161) 5.7 (.224) Fld. 4.0 (.157) 4.7 (.185) 6.5 (.256) T X 0.8 (.031) 0.8 (.031) 1.0 (.039) 1.7 (.067) 1.7 (.067) 1.9 (.075) Note : 1) The part numbers indicated in the above table are for products with a brazed seam. When ordering products with a butted seam, add the prefix "WS" to the part number (ex. FVAH-1.25 –>FVWSAH-1.25). 2) Delivery lead times may vary depending on the product. Contact JST for details. 44 T X STRAIGHT E42024 Red Blue Yellow YNT-2216 YNT-1614 YNT-1210S YA-1 YA-2 YA-4 BCT-0514L Certificate No.: L T X L o o o Qty/box o o o o 500 o o o o 500 o o 250
FVDAH-2 价格&库存
很抱歉,暂时无法提供与“FVDAH-2”相匹配的价格&库存,您可以联系我们找货
