SFO-41T-P187N-8
SFO-41T-P187N-8
    JST
    Through Hole
    0.187"(4.75mm) 快速连接 母头 16-20 AWG 压接 连接器 非绝缘
SFO-41T-P187N-8 数据手册
TAB-ON TERMINAL 250 Tab-on type 6.35 Mating tab T 3.4 8 0.8 L E W Chamfering Listed E70188 Certified LR20812 Dimensions(mm) Applicable wire Model No. mm2 AWG # Insulation O.D. (mm) 0.3 to 0.75 22 to 18 2.3 to 3.0 Standard STO-21-250N STO-21T-250N STO-61-250N 0.75 to 2.0 STO-61T-250N 18 to 14 Material 2.0 to 3.5 STO-81T-250N 14 to 12 L E 7.7 19.0 7.8 - 2.4 - 2.8 to 3.8 3.8 to 5.0 Q´ty/ reel 0.4 5,000 Tin-plated 0.8 - 19.6 Tin-plated UL1015 #20 + UL1015 #20 UL1015 #18 + UL1015 #20 UL1015 #18 + UL1015 #18 *STO-62T-250N T Material Mating tab approx. thickness thickness W Tin-plated Brass STO-81-250N Finish 1.6 4,000 0.45 8.0 7.6 Tin-plated 5,000 19.0 RoHS2 compliance Note: Terminal denoted by * is used only for two wires. If using wires in other combinations than the ones shown above, contact JST. 250 Tab-on piggyback type T Listed E70188 Certified LR20812 Dimensions(mm) Applicable wire Model No. L E W mm2 AWG # Insulation O.D. (mm) 0.75 to 2.0 18 to 14 2.8 to 3.9 Standard SFT-61T-250N Material Finish Brass Tin-plated W L E 7.6 19.6 8.3 Mating T Material tab approx. thickness thickness 2.9 0.39 0.8 Q´ty/ reel 3,000 RoHS2 compliance 250 Tab-on flag type 6.35 Mating tab T 3.4 8 L Chamfering Listed E70188 Certified LR20812 Dimensions(mm) Applicable wire Model No. SFO-61-250A SFO-61T-250A 0.8 E W Standard mm2 0.75 to 2.0 AWG # 18 to 14 Insulation O.D. (mm) Material 2.8 to 3.8 Brass Finish Tin-plated W L E 8.0 16.1 7.8 T Material Mating tab approx. thickness thickness 3.0 0.45 0.8 Q´ty/ reel 3,000 RoHS2 compliance 1 TAB-ON TERMINAL TAB-ON TERMINAL 205 Tab-on type 5.2 Mating tab T 3.2 6.35 Mating tab thickness L E W Chamfering Listed E70188 Certified LR20812 Dimensions(mm) Applicable wire Model No. Standard mm2 AWG # Insulation O.D. (mm) Material Finish STO-21-205N W L E 6.4 15.9 6.4 Mating T Material tab approx. thickness thickness – STO-21T-205N 0.3 to 0.75 STO-21-205N-5 22 to 18 2.3 to 3.0 Brass STO-21T-205N-5 Tin-plated – Q´ty/ reel 0.8 0.7 0.4 7,500 0.5 Tin-plated RoHS2 compliance 187 Tab-on flag type 4.75 Mating tab T 3.2 6.35 E W Mating tab thickness L Chamfering Listed E70188 Certified LR20812 Dimensions(mm) Applicable wire Model No. Standard mm2 AWG # Insulation O.D. (mm) Material SFO-41-187N SFO-41T-187N SFO-41-187N-8 SFO-41T-187N-8 RoHS2 compliance 2 Finish W L E 5.6 12.3 6.4 T Material approx. thickness 0.5 to 1.25 20 to 16 2.6 to 3.5 Brass Tin-plated Tin-plated Mating tab thickness Q´ty/ reel 0.5 1.0 5,000 0.32 0.8 TAB-ON TERMINAL 187 Tab-on type Mating tab 4.75 T Chamfering Certified LR20812 Listed E70188 (Except when AWG#24 is applied.) Dimensions(mm) Applicable wire Model No. Standard mm2 AWG # Mating tab thickness L E W 3.2 6.35 Insulation O.D. (mm) Material STO-01-187N Finish W L E 5.6 15.0 6.3 Mating tab thickness T Material approx. thickness - STO-01T-187N 0.2 to 0.5 STO-01-187N-8 24 to 20 1.5 to 2.6 Brass Tin-plated - 0.5 1.5 0.32 10,000 0.8 Tin-plated STO-01T-187N-8 STO-41-187N - STO-41T-187N 0.5 to 1.25 STO-41-187N-8 20 to 16 2.6 to 3.5 Brass Tin-plated - 0.5 5.6 15.0 6.3 1.5 0.32 10,000 0.8 Tin-plated STO-41T-187N-8 *STO-62T-187N *STO-82T-187N UL1015 #20 + UL1015 #20 UL1015 #18 + UL1015 #20 UL1015 #18 + UL1015 #18 Brass UL1015 #18 + UL1015 #18 UL1015 #18 + UL1015 #16 UL1015 #16 + UL1015 #16 Brass Tin-plated Q'ty/ reel 5.6 19.6 6.4 1.5 0.32 4,000 0.5 Tin-plated 5.6 19.6 6.4 1.5 0.32 4,000 RoHS2 compliance Note: Terminal denoted by * is used only for two wires. lf using wires in other combinations than the ones shown above, contact JST. 110 Tab-on type 2.8 Mating tab 5.7 T 7.3 E W Listed E70188 (Except when AWG #24 is applied.) ® Recognized E70188(AWG #24) Chamfering L Certified LR20812 Dimensions(mm) Applicable wire Model No. Standard mm2 AWG # Insulation O.D. (mm) Material STO-01-110N STO-01T-110N STO-01-110N-8 0.2 to 0.5 24 to 20 STO-41T-110N-8 Tin-plated 2.1 to 2.8 Brass STO-41-110N STO-41-110N-8 Finish W L E 3.7 15.4 6.3 Q´ty / T Material Mating reel tab approx. thickness thickness - STO-01T-110N-8 STO-41T-110N Mating tab thickness 0.5 to 1.25 20 to 16 2.6 to 3.5 0.5 0.6 0.8 Tin-plated Tin-plated Tin-plated 10,000 0.25 0.5 3.7 15.4 6.3 0.6 0.8 RoHS2 compliance 3 TAB-ON TERMINAL Crimping machine, Applicator Contact Crimping machine Crimp applicator MK-L STO-21(T)-250N MK-L STO-61(T)-250N MK-L STO-81(T)-250N MK-L STO-62T-250N SFT-61T-250N SFO-61(T)-250A STO-21(T)-205N(-5) SFO-41(T)-187N(-8) AP-K2N MKS-L MKF-L-250 MK-L MKF-L-187 - Applicator Dies Crimp applicator with dies MK/STO-21-250 APLMK STO21-250N - - MK/STO-61-250N APLMK STO61-250N - - MK/STO-81-250N APLMK STO81-250N - - MK/STO-62-250N APLMK STO61-250N - - MK/SFT-61-250N A P L S F T 6 1 - 2 5 0 N - - MK/SFO-61-250A A P L S F O 6 1 - 2 5 0 A - - MK/STO-21-205N A P L S T O 2 1 - 2 0 5 N - - MK/SFO-41-187N A P L S F O 4 1 - 1 8 7 N - Note: Contact JST for fully automatic crimping applicator. - *In using the products, refer to "Handling Precaution for Terminal and Connector" described on our website (Technical documents of Product information page). *RoHS2 compliance *Dimensional unit: mm *Contact JST for details. 4 Contact Crimping machine Crimp applicator MK-L STO-01(T)-187N(-8) MK-L STO-41(T)-187N(-8) STO-62T-187N STO-82(T)-187N STO-01(T)-110N(-8) STO-41(T)-110N(-8) MK-L-187 AP-K2N MK-L-187 MK-L MK-L - Applicator Dies Crimp applicator with dies MK/STO-01-187N APLMK STO01-187N - - MK/STO-41-187N APLMK STO41-187N - - MK/STO-62-187N APLMK STO62-187N - - MK/STO-82-187N APLMK STO82-187N - - MK/STO-01-110N APLMK STO01-110N - - MK/STO-41-110N APLMK STO41-110N - - TAB-ON-TAB TERMINAL 250 Tab-on tab type L E W Listed E70188 Dimensions(mm) Applicable wire Model No. Standard mm2 SOM-51-250 0.5 to 2.0 SOM-51T-250 AWG # 20 to 14 Insulation O.D. (mm) Material 2.6 to 3.8 Brass Finish Tin-plated W L E Material thickness Tab thickness 6.4 20.8 11.6 0.4 0.8 Q´ty/ reel 5,000 RoHS2 compliance 187 Tab-on tab type L E W Listed E70188 Dimensions(mm) Applicable wire Model No. Standard SOM-21-187 SOM-21T-187 mm2 AWG # Insulation O.D. (mm) 0.3 to 0.75 22 to 18 2.3 to 3.0 Material Brass Finish Tin-plated W L E Material thickness Tab thickness 4.8 17.2 6.4 0.5 0.5 Q´ty/ reel 10,000 RoHS2 compliance Crimping machine, Applicator Contact SOM-51(T)-250 Crimping machine Crimp applicator AP-K2N MK-L - Applicator Dies MK/SOM-51-250 - Crimp applicator with dies APLMK SOM51-250 - Contact SOM-21(T)-187 Crimping machine Crimp applicator AP-K2N MK-L - Applicator Dies MK/SOM-21-187 - Crimp applicator with dies APLMK SOM21-187 - Note: Contact JST for fully automatic crimping applicator. *In using the products, refer to "Handling Precaution for Terminal and Connector" described on our website (Technical documents of Product information page). *RoHS2 compliance *Dimensional unit: mm *Contact JST for details. 5 TAB-IN/TAB-IN-TAB TERMINAL 250 Tab-in type T Dimensions(mm) Applicable wire Model No. mm2 AWG # Insulation O.D. (mm) 0.5 to 2.0 20 to 14 2.6 to 3.8 Standard STI-51-250N STI-51T-250N L E W Material Brass Finish Tin-plated W L E 7.5 19.2 7.7 Q´ty/ reel T Material Mating approx. thickness tab 0.9 0.32 SIM-51 (T)-250N 5,000 RoHS2 compliance Note: 1. Combine a plated tab-in terminal with a plated tab and a non-plated tab-in terminal with a non-plated tab. 2. This terminal must be built into the model 250 tab-in housing which has numerous circuits, and it cannot be used independently. Model 250 tab-on terminals, however, can be used independently. 3. The above case does not apply when we confirm the condition of application and judge that there is no problem. 110 Tab-in type T Dimensions(mm) Applicable wire Model No. AWG # Insulation O.D. (mm) 0.3 to 0.5 22 to 20 2.1 to 2.8 0.5 to 1.25 20 to 16 2.6 to 3.5 Standard STI-01-110N STI-01T-110N mm2 Material Finish W L E Tin-plated - 3.7 15.3 6.3 Q´ty/ reel T Material Mating approx. thickness tab Brass STI-41-110N L E W 0.7 0.25 SIM-01 (T)-110A SIM-41 (T)-110B 10,000 Tin-plated STI-41T-110N RoHS2 compliance Note: 1. Combine a plated tab-in terminal with a plated tab and a non-plated tab-in terminal with a non-plated tab. 2. This terminal must be built into the model 110 tab-in housing which has numerous circuits, and it cannot be used independently. Model 110 tab-on terminals, however, can be used independently. Crimping machine, Applicator Contact STI-51(T)-250N AP-K2N STI-01(T)-110N Applicator Dies Crimp applicator with dies MK-L MK/STI-51-250N APLMK STI51-250N - - - Crimping machine Crimp applicator MK-L - MK/SIM-01-110N APLMK SIM01-110N - Note: Contact JST for fully automatic crimping applicator. 6 - Contact STI-41(T)-110N Applicator Dies Crimp applicator with dies MK-L MK/STI-41-110N APLMK STI41-110N - - - Crimping machine Crimp applicator AP-K2N TAB-IN/TAB-IN-TAB TERMINAL 250 Tab-in tab type W Dimensions(mm) Applicable wire Model No. mm2 AWG # Insulation O.D. (mm) 0.3 to 0.75 22 to 18 2.2 to 3.2 0.5 to 2.0 20 to 14 2.6 to 3.8 Standard SIM-21-250 SIM-21T-250 SIM-51-250N SIM-51T-250N SIM-81PT-250N 1.25 to 3.5 16 to 12 L E Material Finish Tin-plated Brass L E 6.0 28.0 15.8 0.4 6.0 24.5 13.0 0.4 5,000 0.84 Tin-plated 3.0 to 4.0 Q´ty/ reel Tab Material thickness thickness W 4,000 3,000 RoHS2 compliance Note: SIM-21 differs from SIM-51 in terminal size. 110 Tab-in tab type E L W Listed E70188 Dimensions(mm) Applicable wire Model No. Standard SIM-01-110A SIM-01T-110A mm2 AWG # Insulation O.D. (mm) 0.3 to 0.5 22 to 20 2.1 to 2.8 0.5 to 1.25 20 to 16 2.6 to 3.5 Material SIM-41T-110B Tab Material thickness thickness W L E 2.8 20.6 12.0 Q´ty/ reel Brass SIM-41-110B Finish Tin-plated - 0.5 0.5 7,500 Tin-plated RoHS2 compliance Crimping machine, Applicator Contact Crimping machine Crimp applicator MK-L SIM-21(T)-250 SIM-51(T)-250N SIM-81PT-250N AP-K2N MK-L MK-L - Applicator Dies Crimp applicator with dies MK/SIM-21-250 APLMK SIM21-250 - - MK/SIM-51-250N APLMK SIM51-250N - - Contact Crimping machine Crimp applicator MK-L SIM-01(T)-110A AP-K2N SIM-41(T)-110B MK-L - Applicator Dies Crimp applicator with dies MK/SIM-01-110A APLMK SIM01-110A - - MK/SIM-41-110B APLMK SIM41-110B - - MK/SIM-81-250N APLMK SIM81-250N - - *In using the products, refer to "Handling Precaution for Terminal and Connector" described on our website (Technical documents of Product information page). *RoHS2 compliance *Dimensional unit: mm *Contact JST for details. 7
SFO-41T-P187N-8 价格&库存
很抱歉,暂时无法提供与“SFO-41T-P187N-8”相匹配的价格&库存,您可以联系我们找货
SFO-41T-P187N-8
    • 5000+0.33880
    库存:5000
    SFO-41T-P187N-8
      • 5000+0.28600
      库存:3950
