FCRIMP2BL076
FCRIMP2BL076
    ALPHAWIRE(阿尔法电线)
    CONNSPLICE14-16AWG100/PKG
FCRIMP2BL076 数据手册
FIT® Heat-Shrink Tubing Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. 447 FIT® Heat-Shrink Tubing W hether your concerns are mechanical strain relief, environmental sealing, or organizing wires, Alpha Wire’s FIT heat-shrink tubing is ideal for solving many challenges in electrical and electronic wiring: • P  rotect substrates from moisture, UV light, corrosion, oxidation, dust, chemicals, abrasion, environmental conditions, solder joints, and encapsulates • Insulate wire terminations and connections, entire printed circuit boards, from electrical and environmental conditions • R  epair cable splices, insulation damage and cuts, cable jackets, and connections, with permanent or temporary quick fixes • R  elieve strain on cables and connectors to prevent harmful flexing or bending • B  undle and organize wire harness, cable, tubing, and hose dressing on OEM equipment, breakouts, bundle in small spaces, conform to odd shapes • S  eal connections, backshells, and other gaps from moisture and other contaminants • Identify circuits through color coding, grouping, and labeling 448 FIT heat-shrink products Our FIT heat-shrink tubing offers a reliable way to protect and seal terminations or add additional mechanical ruggedness. FIT preferred heat-shrink products are made from premium compounds under the tightest manufacturing controls. This means FIT tubing consistently provides excellent physical characteristics such as low longitudinal shrinkage and wide temperature ranges while providing an elegant appearance when used alone or on OEM equipment. The FIT line consists of various tubing types, each designed with unique attributes that offer tubing solutions for the broadest possible range of applications and environments. FIT products are always in stock and come in an unprecedented variety of package sizes. Beyond the widely used polyolefin tubing that is suited to the broadest range of general-purpose needs, we offer a number of other materials for higher or lower shrink temperatures, wider operating temperatures, and such special needs as outstanding chemical resistance or increased flexibility. Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Material Cross-linked polyolefin Flame-retardant cross-linked polyolefin Cross-linked polyolefin Semirigid cross-linked polyolefin Surface cross-linked, dual extruded Bonding, thermoplastic adhesive lined Bonding, adhesive lined Irradiated PVC Cross-linked PVDF FEP PTFE Chlorinated polyolefin Flexible fluoroelastomer Polyethylene/ polyester Cross-linked silicone rubber Cross-linked PVDF Features Shrink Temperature Single-Wall Cross-linked Polyolefin for General-Purpose Use 90°C 90°C 90°C Low shrink temp Passes UL VW-1 flame test 90°C Approved for 600-V ground lead identification Green with yellow stripe 90°C Passes UL VW-1 flame test 30% stronger and 25% stiffer than 110°C standard polyolefin Dual-Wall Polyolefin for Additional Sealing 140°C Meltable inner wall to encapsulate 110°C without adhesive 121°C Bonds to most materials 120°C High voltage: to 2 kV at 90°C continuous use General-purpose heat-shrink tubing Range of shrink ratios Permanent water and corrosion protection 110°C Special-Application Tubing Low shrink temperature Passes UL VW-1 flame test 100°C 30% stronger than standard polyolefin High shrink temperature Fast recovery time Excellent chemical, heat, and flame resistance 170°C Passes UL VW-1 flame test 3x the tensile strength of standard polyolefin High shrink temperature Excellent chemical resistance 200°C Excellent dielectric properties Thinnest wall thickness available High shrink temperature Excellent chemical resistance 250°C Excellent dielectric properties Very thin wall thickness Highly flexible Oil and abrasion resistant 130°C Passes UL VW-1 flame test High shrink temperature Excellent chemical resistance 120°C Flexible Superior abrasion resistance Excellent flexibility 80°C Resists harsh environments High flexibility available Pliable 200°C Scrape abrasion resistant Passes UL VW-1 flame test Transparent after shrink Fast recovery time Excellent chemical, heat, and flame resistance 150°C Passes UL VW-1 flame test 2x the tensile strength of standard polyolefin Heat Guns Alpha heat guns are the perfect complement to our tubing, making it easy to apply FIT heat-shrink tubing quickly and efficiently. Shrink Ratio (approx.) FIT Family 2:1 4:1 2:1 3:1 FIT-221 FIT-421 FIT-221V FIT-321V 2:1 FIT-260 2:1 FIT-295 2.5:1 3:1 5.6:1 FIT-300 FIT-321 FIT-621 3:1 FIT-700 2:1 FIT-750 2:1 FIT-105 2:1 FIT-350 1.2:1 FIT-400 1.5:1 FIT-500 2:1 FIT-600 2:1 FIT-650 2:1 FIT-FABRIC 1.7:1 FIT-FLEX 2:1 FIT-CLEAR The lightweight, durable guns are designed to make application of heat-shrink tubing fast and reliable. They are well suited to both industrial production and field use. Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. 449 FIT > FIT Heat-Shrink Tubing Heat-Shrink Tubing FIT®-105 Heat-Shrink Tubing 2:1 Shrink Ratio, Irradiated PVC Operating Temperature Chemical Properties • -20°C to +105°C • • • • Shrink Temperature • 100°C min. • 105°C full recovery FIT-105-3/64 FIT-105-1/16 FIT-105-3/32 FIT-105-1/8 FIT-105-3/16 FIT-105-1/4 FIT-105-3/8 FIT-105-1/2 FIT-105-3/4 FIT-105-1IN FIT-105-1-1/2 Color • Black • T  ensile strength: 3000 psi (20.68 N/mm2) • Elongation: 300% min • Longitudinal change: +1%/-25% • Specific gravity: 1.32 • Flame retardant • Shelf life: 1 year at 18°C to 35°C Spools may contain multiple lengths Inch 0.046 0.062 0.093 0.125 0.187 0.250 0.375 0.500 0.750 1.000 1.500 Inch 0.023 0.031 0.046 0.062 0.093 0.125 0.187 0.250 0.375 0.500 0.750 Assorted sizes of 6” (15 cm) lengths 450 See table Recovered ID, Max. Packaged Assortments Availability Physical Properties Supplied ID, Min. mm 1.17 1.57 2.36 3.18 4.75 6.35 9.53 12.70 19.05 25.40 38.10 • 600 V (UL, CSA) • Dielectric strength: 1083 V/mil (426.3 kV/cm) • Volume resistivity: 1012 ohm-cm • Irradiated PVC • Low shrink temperature • Fast recovery time • 30% stronger than standard polyolefin • Low water absorption • UV resistant Part No. Electrical Properties Material AMS DTL-23053/2 Class 1 (except longitudinal shrinkage) UL 224 VW-1 CSA 198 Corrosive effect: none Fungus resistance: no growth Water absorption: 1.0% max. Lead free mm 0.58 0.79 1.17 1.57 2.36 3.18 4.75 6.35 9.53 12.70 19.05 Recovered Wall Thickness, Nom. Inch mm 0.020 0.51 0.020 0.51 0.020 0.51 0.025 0.64 0.025 0.64 0.025 0.64 0.030 0.76 0.030 0.76 0.035 0.89 0.040 1.02 0.045 1.14 FIT-105-MS-1 Contents FIT-105-3/64 FIT-105-1/16 FIT-105-3/32 FIT-105-1/8 FIT-105-3/16 FIT-105-1/4 Availability Ft 25, 100, 500, 1000 25, 100, 500, 1000 25, 100, 1000 25, 100, 1000 25, 100, 1000 25, 100, 1000 25, 100, 500 25, 100, 250 25, 100, 250 25, 100, 250 25, 100 m 7.6, 30.5, 152, 305 7.6, 30.5, 152, 305 7.6, 30.5, 305 7.6, 30.5, 305 7.6, 30.5, 305 7.6, 30.5, 305 7.6, 30.5, 152 7.6, 30.5, 76.2 7.6, 30.5, 76.2 7.6, 30.5, 76.2 7.6, 30.5 FIT-105-MS-2 Tubing Size Inch mm 0.046 1.17 0.062 1.57 0.093 2.36 0.125 3.18 0.187 4.75 0.250 6.35 Quantity Contents 10 10 10 10 10 10 FIT-105-3/8 FIT-105-1/2 FIT-105-3/4 FIT-105-1 IN Tubing Size Inch mm 0.375 9.53 0.500 12.70 0.750 19.05 1.000 25.40 Quantity 10 10 10 10 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. FIT > FIT Heat-Shrink Tubing Heat-Shrink Tubing FIT®-221 Heat-Shrink Tubing 2:1 Shrink Ratio, XLPO Operating Temperature • -55°C to +135°C • -55°C to +125°C (UL, CSA) Shrink Temperature • 90°C min. • 121°C full recovery AMS-DTL-23053/5 Class 1 (except clear) AMS-DTL-23053/5 Class 2 (clear) UL 224 (except clear) CSA 198 (except clear) • Excellent general-purpose tubing • Low water absorption • UV resistant (black only) Material • Cross-linked polyolefin Color • B  lack, white, red, yellow, blue, green, clear* *Clear tubing may exhibit some color tint that is the result of the product’s chemistry; the tint is variable and can be any color Physical Properties • T  ensile strength: 1500 psi (10.34 N/mm2) • Elongation: 200% min • Longitudinal change: ±5% Part No. FIT-221-3/64 FIT-221-1/16 FIT-221-3/32 FIT-221-1/8 FIT-221-3/16 FIT-221-1/4 FIT-221-3/8 FIT-221-1/2 FIT-221-3/4 FIT-221-1IN FIT-221-1-1/2 FIT-221-2IN FIT-221-3IN FIT-221-4IN Supplied ID, Min. Inch mm 0.046 1.17 0.063 1.60 0.093 2.36 0.125 3.18 0.187 4.75 0.250 6.35 0.375 9.53 0.500 12.70 0.750 19.05 1.000 25.40 1.500 38.10 2.000 50.80 3.000 76.20 4.000 101.60 Recovered ID, Max. Inch mm 0.023 0.58 0.031 0.79 0.046 1.17 0.062 1.57 0.093 2.36 0.125 3.18 0.187 4.75 0.250 6.35 0.375 9.53 0.500 12.70 0.750 19.05 1.000 25.40 1.500 38.10 2.000 50.80 • S  pecific gravity: 1.35 (colors)/ 1.00 (clear) • Flame retardant • Shelf life: 5 years at 18°C to 35°C Chemical Properties • • • • Corrosive effect: none Fungus resistance: no growth Water absorption: 0.5% max. Fluid resistance: 1000 psi (6.89 N/mm2) • Lead free Electrical Properties • 600 V (UL, CSA) • Dielectric strength: 500 V/mil (197 kV/cm) • Volume resistivity: 1014 ohm-cm Availability See table, next page Spools may contain multiple lengths Recovered Wall Thickness, Nom. Inch mm 0.016 0.41 0.017 0.43 0.020 0.51 0.020 0.51 0.020 0.51 0.025 0.64 0.025 0.64 0.025 0.64 0.030 0.76 0.035 0.89 0.040 1.02 0.045 1.14 0.050 1.27 0.055 1.40 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. 451 FIT > FIT Heat-Shrink Tubing Heat-Shrink Tubing FIT®-221 Heat-Shrink Tubing 2:1 Shrink Ratio, XLPO AMS-DTL-23053/5 Class 1 (except clear) AMS-DTL-23053/5 Class 2 (clear) UL 224 (except clear) CSA 198 (except clear) Availability Part No. FIT-221-3/64 FIT-221-1/16 FIT-221-3/32 FIT-221-1/8 FIT-221-3/16 FIT-221-1/4 FIT-221-3/8 FIT-221-1/2 FIT-221-3/4 FIT-221-1IN FIT-221-1-1/2 FIT-221-2IN FIT-221-3IN FIT-221-4IN Spools Ft m 1000* 305* 70, 100*, 1000 21.3, 30.5*, 305 65, 100*, 500 19.8, 30.5*, 152 60, 100*, 500 18.2, 30.5*, 152 50, 100*, 500 15.2, 30.5*, 152 40, 100*, 250 12.2, 30.5, 76.2* 35, 50*, 200 10.6, 15.2*, 60.9 32, 50*, 150 9.7, 15.2*, 45.7 24, 50*, 250 7.3, 15.2*, 76.2 16, 50*, 250 4.8, 15.2, 76.2 125* 38.1* 125* 38.1* 100* 30.5* 50* 15.2* 4 ft (1.2 m) 25 25 25 25 25 25 25 5 5 5 5 5 2 2 Qty, Cut Pieces at Length 6” (152 mm) 1” (25.4 mm) 40 1000 36 1000 32 1000 28 1000 24 1000 20 1000 16 1000 14 — 12 — 8 — 5 — 3 — 2 — — — 0.5” (12.7 mm) 1000 1000 1000 1000 1000 1000 1000 — — — — — — — *Black and clear tubing only. Spools may contain multiple lengths. Packaged Assortments FIT-221-MS-1 Assorted colors: Black, blue, red, green, yellow Tubing Size Contents Quantity Inch mm FIT-221-3/64 0.046 1.17 6 FIT-221-1/16 0.063 1.60 6 FIT-221-3/32 0.093 2.36 6 FIT-221-1/8 0.125 3.18 6 FIT-221-3/16 0.187 4.75 6 Assorted sizes of 6” (152 mm) lengths Each length is size identified. FIT-221-MS-2 Assorted colors: Black, blue, red, yellow Tubing Size Contents Quantity Inch mm FIT-221-1/4 0.250 6.35 4 FIT-221-3/8 0.375 9.53 4 FIT-221-1/2 0.500 12.70 4 FIT-221-3/4 0.750 19.05 4 FIT-221 Kits FIT-KIT-221BK Colors: Black Contents FIT-221-3/16 FIT-221-1/4 FIT-221-3/8 FIT-221-1/2 FIT-221-3/4 FIT-221-1IN 452 Tubing Size Inch mm 0.187 4.75 0.250 6.35 0.375 9.53 0.500 12.70 0.750 19.05 1.000 25.40 Quantity 25 20 15 10 6 4 FIT-KIT-221C Assorted colors: Black, blue, red, white, green, yellow, clear Tubing Size Quantity Contents Inch mm Each Color FIT-221-3/32 0.093 2.36 4 FIT-221-1/8 0.125 3.18 3 FIT-221-3/16 0.187 4.75 3 FIT-221-1/4 0.250 6.35 3 FIT-221-3/8 0.375 9.53 2 FIT-221-1/2 0.500 12.70 2 Total 28 21 21 21 14 14 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. FIT > FIT Heat-Shrink Tubing Heat-Shrink Tubing FIT®-221B Heat-Shrink Tubing 2:1 Shrink Ratio, XLPO, Bulk Packaging Operating Temperature • -55°C to +135°C • -55°C to +125°C (UL, CSA) Shrink Temperature • 90°C min. • 121°C full recovery AMS-DTL-23053/5 Class 1 (except clear) AMS-DTL-23053/5 Class 2 (clear) UL 224 (except clear) CSA 198 (except clear) • • • • • Excellent general-purpose tubing Low shrink temperature Fastest recovery time Low water absorption UV resistant (black only) Part No. FIT-221B-3/64 FIT-221B-1/16 FIT-221B-3/32 FIT-221B-1/8 FIT-221B-3/16 FIT-221B-1/4 FIT-221B-3/8 FIT-221B-1/2 FIT-221B-3/4 FIT-221B-1IN Material • Cross-linked polyolefin Colors • Black, blue, clear* Chemical Properties • Corrosive effect: none • Fungus resistance: no growth • Water absorption: 0.5% max. • Fluid resistance: 1000 psi (6.89 N/mm2) • Lead free Electrical Properties *Clear tubing may exhibit some color tint that is the result of the product’s chemistry; the tint is variable and can be any color Physical Properties • Tensile strength: 1500 psi (10.34 N/mm2) • Elongation: 200% min • Longitudinal change: ±5% Supplied ID, Min. Inch mm 0.046 1.17 0.063 1.60 0.093 2.36 0.125 3.18 0.187 4.75 0.250 6.35 0.375 9.53 0.500 12.70 0.750 19.05 1.000 25.40 • S  pecific gravity: 1.35 (colors)/ 1.00 (clear) • Flame retardant • Shelf life: 5 years at 18°C to 35°C Recovered ID, Max. Inch mm 0.023 0.58 0.031 0.79 0.046 1.17 0.062 1.57 0.093 2.36 0.125 3.18 0.187 4.75 0.250 6.35 0.375 9.53 0.500 12.70 • 600 V (UL, CSA) • Dielectric strength: 500 V/mil (197 kV/cm) • Volume resistivity: 1014 ohm-cm Availability See table Spools may contain multiple lengths Recovered Wall Thickness, Nom. Inch mm 0.016 0.41 0.017 0.43 0.020 0.51 0.020 0.51 0.020 0.51 0.025 0.64 0.025 0.64 0.025 0.64 0.030 0.76 0.035 0.89 Availability Part No. FIT-221B-3/64 FIT-221B-1/16 FIT-221B-3/32 FIT-221B-1/8 FIT-221B-3/16 FIT-221B-1/4 FIT-221B-3/8 FIT-221B-1/2 FIT-221B-3/4 FIT-221B-1IN Spools (Length x No. of Spools) Ft m 1000 x 3 305 x 3 1000 x 3 305 x 3 500 x 3 152 x 3 500 x 3 152 x 3 500 x 2 152 x 2 250 x 2 76.2 x 2 200 x 2 60.9 x 2 150 x 2 45. 7 x 2 250 x 1 76.2 x 1 250 x 2 76.2 x 2 250 x 1 76.2 x 1 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Qty, Cut Pieces at Length 4 ft (1.2 m) 250 250 250 250 250 250 250 200 125 75 453 FIT > FIT Heat-Shrink Tubing Heat-Shrink Tubing FIT®-221V Heat-Shrink Tubing 2:1 Shrink Ratio, XLPO, Low Shrink Temperature Operating Temperature • -55°C to +135°C • -55°C to +125°C (UL, CSA) Shrink Temperature • 90°C min. • 121°C full recovery AMS DTL-23053/5 Class 1 and 3 UL 224 VW-1 CSA 198 • • • • • Excellent general-purpose tubing Low shrink temperature Fastest recovery time Low water absorption UV resistant (black only) Part No. FIT-221V-3/64 FIT-221V-1/16 FIT-221V-3/32 FIT-221V-1/8 FIT-221V-3/16 FIT-221V-1/4 FIT-221V-3/8 FIT-221V-1/2 FIT-221V-3/4 FIT-221V-1IN FIT-221V-1-1/2 FIT-221V-2IN Material • Cross-linked polyolefin Colors • Black, white, red, yellow, green, blue Physical Properties • Tensile strength: 1500 psi (10.34 N/mm2) • Elongation: 200% min • Longitudinal change: ±5% • Specific gravity: 1.35 • Flame retardant • Shelf life: 5 years at 18°C to 35°C Supplied ID, Min. Inch mm 0.046 1.17 0.063 1.60 0.093 2.36 0.125 3.18 0.187 4.75 0.250 6.35 0.375 9.53 0.500 12.70 0.750 19.05 1.000 25.40 1.500 38.10 2.000 50.80 Chemical Properties • Corrosive effect: none • Fungus resistance: no growth • Water absorption: 0.5% max. • Fluid resistance: 1000 psi (6.89 N/mm2) • Lead free Electrical Properties • 600 V (UL, CSA) • Dielectric strength: 500 V/mil (197 kV/cm) • Volume resistivity: 1014 ohm-cm Availability See table Spools may contain multiple lengths Recovered ID, Max. Inch mm 0.023 0.58 0.031 0.79 0.046 1.17 0.062 1.57 0.093 2.36 0.125 3.18 0.187 4.75 0.250 6.35 0.375 9.53 0.500 12.70 0.750 19.05 1.000 25.40 Recovered Wall Thickness, Nom. Inch mm 0.016 0.41 0.017 0.43 0.020 0.51 0.020 0.51 0.020 0.51 0.025 0.64 0.025 0.64 0.025 0.64 0.030 0.76 0.035 0.89 0.040 1.02 0.045 1.14 Availability Part No. FIT-221V-3/64 FIT-221V-1/16 FIT-221V-3/32 FIT-221V-1/8 FIT-221V-3/16 FIT-221V-1/4 FIT-221V-3/8 FIT-221V-1/2 FIT-221V-3/4 FIT-221V-1IN FIT-221V-1-1/2 FIT-221V-2IN 454 Spools (Length x No. of Spools) Ft m 1000 x 3 305 x3 1000 x 1, 1000 x 3 305 x 1, 305 x 3 500 x 1, 500 x 3 152 x 1, 152 x 3 500 x 1, 500 x 3 152 x 1, 152 x 3 500 x 1, 500 x 2 152 x 1, 152 x 2 250 x 1, 250 x 2 76.2 x 1, 76.2 x 2 200 x 1, 200 x 2 60.9 x 1, 60.9 x 2 150 x 1, 150 x 2 45.7 x 1, 45.7 x 2 250 x 1 76.2 x 1 250 x 1 76.2 x 1 125 x 1 38.1 x 1 125 x 1 38.1 x 1 Qty, Cut Pieces at Length 4 ft (1.2 m) 6” (152 mm) 25, 250 40 25, 250 36 25, 250 32 25, 250 28 25, 250 24 25, 250 20 25, 250 16 5, 200 14 5, 125 12 5, 75 8 5 5 5 3 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. FIT > FIT Heat-Shrink Tubing Heat-Shrink Tubing FIT®-260 Heat-Shrink Tubing 2:1 Shrink Ratio, XLPO, Ground Lead Identification Operating Temperature • -55°C to +135°C • -55°C to +125°C (UL, CSA) Chemical Properties • 90°C min. • 120°C full recovery Corrosive effect: none Fungus resistance: no growth Water absorption: 0.5% max. Fluid resistance: 1000 psi (6.89 N/mm2) • Lead free UL 224 VW-1 CSA 198 Material Electrical Properties • Cross-linked polyolefin • Excellent general-purpose tubing • Low water absorption Color • Green/yellow • 600 V (UL, CSA) • Dielectric strength: 500 V/mil (197 kV/cm) • Volume resistivity: 1014 ohm-cm Physical Properties Availability Shrink Temperature • T  ensile strength: 1500 psi (10.34 N/mm2) • Elongation: 200% min • Longitudinal change: ±5% • Specific gravity: 1.35 • Flame retardant • Shelf life: 25 years at 18°C to 35°C Part No. FIT-260-1/8 FIT-260-1/4 FIT-260-3/8 FIT-260-1/2 FIT-260-3/4 FIT-260-1 Supplied ID, Min. Inch 0.125 0.250 0.375 0.500 0.750 1.000 mm 3.18 6.35 9.53 12.70 19.05 25.40 Recovered ID, Max. Inch 0.062 0.125 0.187 0.250 0.375 0.500 mm 1.57 3.18 4.75 6.35 9.53 12.70 • • • • See table Spools may contain multiple lengths Recovered Wall Thickness, Nom. Inch mm 0.020 0.51 0.025 0.64 0.025 0.64 0.025 0.64 0.030 0.76 0.035 0.89 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Availability Ft 500 250 250 250 250 100 m 152 76.2 76.2 76.2 76.2 30.5 455 FIT > FIT Heat-Shrink Tubing Heat-Shrink Tubing FIT®-295 Heat-Shrink Tubing 2:1 Shrink Ratio, Semirigid XLPO Operating Temperature • -55°C to +135°C • -55°C to +125°C (UL, CSA) Shrink Temperature • 110°C min. • 135°C full recovery AMS-DTL-23053/6 Class 1 (Black) AMS-DTL-23053/6 Class 2 (Clear) UL 224 VW-1 (Black) CSA 198 (Black) • 3  0% stronger than standard XLPO • 25% stiffer than standard XLPO • Low water absorption • UV resistant (black only) Part No. FIT-295-3/64 FIT-295-1/16 FIT-295-3/32 FIT-295-1/8 FIT-295-3/16 FIT-295-1/4 FIT-295-3/8 FIT-295-1/2 456 Supplied ID, Min. Inch 0.046 0.063 0.093 0.125 0.187 0.250 0.375 0.500 mm 1.17 1.60 2.36 3.18 4.75 6.35 9.53 12.70 Chemical Properties • Corrosive effect: none • Fungus resistance: no growth • Water absorption: 0.5% max. (black)/0.02% max. (clear) • Lead free Electrical Properties Material • Semirigid cross-linked polyolefin Colors • Black, clear • 600 V (UL, CSA) • Dielectric strength: 500 V/mil (197 kV/cm) • Volume resistivity: 1014 ohm-cm Availability Physical Properties See table • T  ensile strength: 2000 psi (17.79 N/mm2) • Elongation: 200% min • Longitudinal change: ±5% • Specific gravity: 1.35 (black)/1.00 (clear) • Flame retardant • Shelf life: 5 years at 18°C to 35°C Recovered ID, Max. Inch 0.023 0.031 0.046 0.062 0.093 0.125 0.187 0.250 mm 0.58 0.79 1.17 1.57 2.36 3.18 4.75 6.35 Recovered Wall Thickness, Nom. Inch mm 0.020 0.51 0.020 0.51 0.020 0.51 0.020 0.51 0.025 0.64 0.025 0.64 0.030 0.76 0.030 0.76 Availability Qty, Cut Pieces at Length 4 ft (1.2 m) 6” (152 mm) 25 40 25 36 25 32 25 28 25 24 25 20 25 16 5 14 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. FIT > FIT Heat-Shrink Tubing Heat-Shrink Tubing FIT®-300 Heat-Shrink Tubing 2.5:1 Shrink Ratio, Dual-Wall Semirigid XLPO Applications • T  emporary sealing without sticky residue • Substrates requiring filled interstices AMS-DTL-23053/4 Class 1 UL 224 (Except clear) • M  eltable inner wall for encapsulation without adhesives • Thicker wall for added protection • High shrink ratios • Excellent dielectric properties Operating Temperature • -55°C to +135°C • -55°C to +125°C (UL) Shrink Temperature • 140°C min. • Longitudinal change: +1%/-10% • Specific gravity: 0.99 • Shelf life: 3 years at 18°C to 35°C Chemical Properties • • • • Corrosive effect: none Fungus resistance: no growth Water absorption: 0.5% max Fluid resistance: 1000 psi (6.89 N/mm2) • Lead free • Halogen free Electrical Properties Material • 600 V (UL, CSA) • Dielectric strength: 500 V/mil (197 kV/cm) • Volume resistivity: 1016 ohm-cm • D  ual-wall semirigid cross-linked polyolefin Colors • B  lack, white, red, yellow, blue, slate, brown Availability See table Physical Properties • T  ensile strength: 1500 psi (10.34 N/mm2) • Elongation: 200% min Part No. FIT-300-1/8 FIT-300-3/16 FIT-300-1/4 FIT-300-3/10 FIT-300-3/8 FIT-300-1/2 FIT-300-3/4 ST-3001-IN Supplied ID, Min. Inch 0.125 0.187 0.250 0.300 0.375 0.500 0.750 1.000 mm 3.18 4.75 6.35 7.62 9.53 12.70 19.05 25.40 Recovered ID, Max. Inch 0.023 0.060 0.080 0.050 0.135 0.195 0.313 0.400 mm 0.58 1.52 2.03 1.27 3.43 4.95 7.95 10.16 Recovered Wall Thickness, Nom. Inch mm 0.038 0.97 0.043 1.09 0.047 1.19 0.100 2.54 0.050 1.27 0.055 1.40 0.065 1.65 0.075 1.91 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Availability Qty, Cut Pieces at Length 4 ft (1.2 m) 6” (152 mm) 25 14 25 12 25 10 25 4 25 8 5 6 5 4 5 -- 457 FIT > FIT Heat-Shrink Tubing Heat-Shrink Tubing FIT®-321 Heat-Shrink Tubing 3:1 Shrink Ratio, Dual-Wall XLPO, Adhesive Lined Operating Temperature Chemical Properties • -55°C to +125°C • • • • Corrosive effect: none Fungus resistance: no growth Water absorption: 1.0% max Fluid resistance: 900 psi (6.20 N/mm2) • UV resistant • Lead free Shrink Temperature • 110°C min. • 110°C full recovery AMS-DTL-23053/4 Class 3 UL 224 CSA 198 • T  hicker wall for increased durability • Water-resistant inner permanent-bonding adhesive Material • D  ual-wall flexible polyolefin with thick-wall adhesive Color • Black Physical Properties • T  ensile strength: 1500 psi (10.34 N/mm2) • Elongation: 250% min • Longitudinal change: +1%/-15% • Flame tested • Shelf life: 3 years at 18°C to 35°C Part No. FIT-321-1/8 FIT-321-1/4 ST-303-3/8 FIT-321-1/2 ST-303-3/4 FIT-321-1 FIT-321-1-1/2 Supplied ID, Min. Inch 0.125 0.252 0.374 0.500 0.748 0.945 1.575 mm 3.18 6.40 9.50 12.70 19.00 24.00 40.01 Availability Part No. FIT-321-1/8 FIT-321-1/4 FIT-321-1/2 FIT-321-1 FIT-321-1-1/2 458 Qty, Cut Pieces at Length 4 ft (1.2 m) 6” (152 mm) 25 28 25 20 5 14 5 8 5 5 Recovered ID, Max. Inch 0.024 0.073 0.118 0.157 0.236 0.315 0.512 mm 0.61 1.85 3.00 3.99 5.99 8.00 13.00 Electrical Properties • 600 V (UL, CSA) • Dielectric strength: 300 V/mil (118 kV/cm) • Volume resistivity: 1012 ohm-cm Availability See table Recovered Wall Thickness, Nom. Inch mm 0.037 0.94 0.047 1.19 0.051 1.30 0.071 1.80 0.071 1.80 0.098 2.49 0.098 2.49 Recovered Melt Wall Thickness, Nom. Inch mm 0.020 0.51 0.020 0.51 0.025 0.64 0.030 0.76 0.035 0.89 0.040 1.02 0.040 1.02 Packaged Assortments Assorted sizes of 6” (15 cm) lengths FIT-321-MS-1 Colors: Black Size Inch mm FIT-321-1/8 0.125 3.18 FIT-321-1/4 0.252 6.40 FIT-321-1/2 0.500 12.70 FIT-321-1 0.945 24.00 Quantity 5 5 5 5 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. FIT > FIT Heat-Shrink Tubing Heat-Shrink Tubing FIT®-321V Heat-Shrink Tubing 3:1 Shrink Ratio, Flexible XLPO, Thin Wall Operating Temperature • -55°C to +135°C • -55°C to +125°C (UL, CSA) • Flame retardant • Shelf life: 25 years at 18°C to 35°C Shrink Temperature • • • • Chemical Properties • 90°C min. • 135°C full recovery AMS-DTL-23053/5 Class 1 and 3 (except dimensions) UL 224 VW-1 CSA 198 Material • F  lexible cross-linked thin-wall polyolefin Colors • L  ow shrink temperature • Fast recovery time • Reduced wall thickness • Black, white Physical Properties • T  ensile strength: 1500 psi (10.34 N/mm2) • Elongation: 200% min • Longitudinal change: +5%/-15% • Specific gravity: 1.35 Part No. FIT-321V-3/32 FIT-321V-1/8 FIT-321V-1/4 FIT-321V-3/8 FIT-321V-1/2 FIT-321V-3/4 FIT-321V-1IN Supplied ID, Min. Inch 0.060 0.120 0.240 0.360 0.472 0.720 0.945 mm 1.52 3.05 6.10 9.14 11.99 18.29 24.00 Recovered ID, Max. Inch 0.020 0.040 0.080 0.120 0.160 0.240 0.315 mm 0.51 1.02 2.03 3.05 4.06 6.10 8.00 Corrosive effect: none Fungus resistance: no growth Water absorption: 0.5% max Fluid resistance: 1000 psi (6.89 N/mm2) Electrical Properties • 600 V (UL, CSA) • Dielectric strength: 500 V/mil (197 kV/cm) • Volume resistivity: 1014 ohm-cm Availability See table Spools may contain multiple lengths Recovered Wall Thickness, Nom. Inch mm 0.020 0.51 0.024 0.61 0.028 0.71 0.031 0.79 0.033 0.84 0.039 0.99 0.048 1.22 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Availability Ft 500 500 250 200 150 250 250 m 152 152 76.2 60.9 45.7 76.2 76.2 459 FIT > FIT Heat-Shrink Tubing Heat-Shrink Tubing FIT®-350 Heat-Shrink Tubing 2:1 Shrink Ratio, PVDF Operating Temperature • -55°C to +135°C • -55°C to +150°C (UL) • Flame retardant • Shelf life: 5 years at 18°C to 35°C Shrink Temperature • • • • Chemical Properties • 170°C min. • 175°C full recovery AMS-DTL-23053/8 UL 224 VW-1 Material • C  ross-linked polyvinylidene fluoride • C  hemical resistant • Heat resistant • 3x the tensile strength of standard XLPO • Clear • T  ensile strength: 5000 psi (34.47 N/mm2) • Elongation: 150% min • Longitudinal change: ±10% • Specific gravity: 1.80 FIT-350-3/64 FIT-350-1/16 FIT-350-3/32 FIT-350-1/8 FIT-350-3/16 FIT-350-1/4 FIT-350-3/8 FIT-350-1/2 FIT-350-3/4 FIT-350-1IN 460 Supplied ID, Min. Inch 0.046 0.063 0.093 0.125 0.187 0.250 0.375 0.500 0.750 1.000 mm 1.17 1.60 2.36 3.18 4.75 6.35 9.53 12.70 19.05 25.40 Recovered ID, Max. Inch 0.023 0.031 0.046 0.062 0.093 0.125 0.187 0.250 0.375 0.500 mm 0.58 0.79 1.17 1.57 2.36 3.18 4.75 6.35 9.53 12.70 Electrical Properties • 600 V (UL) • Dielectric strength: 800 V/mil (315 kV/cm) • Volume resistivity: 1013 ohm-cm Color Physical Properties Part No. Corrosive effect: none Fungus resistance: no growth Water absorption: 0.5% max Fluid resistance: 5000 psi (34.47 N/mm2) • Lead free Availability See table Recovered Wall Thickness, Nom. Inch mm 0.010 0.25 0.010 0.25 0.010 0.25 0.010 0.25 0.010 0.25 0.012 0.30 0.012 0.30 0.012 0.30 0.017 0.43 0.019 0.48 Availability 4 ft (1.2 m) 25 25 25 25 25 25 25 5 5 5 6” (152 mm) 32 28 24 20 16 12 8 4 2 1 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. FIT > FIT Heat-Shrink Tubing Heat-Shrink Tubing FIT®-400 Heat-Shrink Tubing 1.2:1 Shrink Ratio, FEP Operating Temperature • Flame rating: UL 94V-0 • Shelf life: 4 years at 18°C to 35°C • -75°C to +200°C Shrink Temperature Chemical Properties • 175°C full recovery AMS-DTL-23053/11 Class 1 • FEP • • • • • Color • • • • • • Natural Electrical Properties Physical Properties • D  ielectric strength: 2000 V/mil (787 kV/cm) • Volume resistivity: 1017 ohm-cm Material  hemical resistant C Wide temperature range Excellent dielectric properties Thinnest wall thickness available Lower recovery temperature than PTFE Part No. FIT-400-24 FIT-400-22 FIT-400-20 FIT-400-18 FIT-400-16 FIT-400-14 FIT-400-12 FIT-400-10 FIT-400-9 FIT-400-8 FIT-400-7 FIT-400-6 FIT-400-5 FIT-400-4 FIT-400-3 FIT-400-2 FIT-400-1 FIT-400-0 Supplied ID, Min. Inch 0.031 0.036 0.045 0.060 0.075 0.092 0.115 0.141 0.158 0.180 0.197 0.225 0.248 0.290 0.310 0.365 0.400 0.440 Mm 0.79 0.91 1.14 1.52 1.91 2.34 2.92 3.58 4.01 4.57 5.00 5.72 6.30 7.37 7.87 9.27 10.16 11.18 • T  ensile strength: 2000 psi (13.79 N/mm2) • Elongation: 200% min • Longitudinal change: ±15% • Specific gravity: 2.17 Recovered ID, Max. Inch 0.027 0.032 0.039 0.049 0.061 0.072 0.089 0.114 0.124 0.143 0.158 0.180 0.198 0.226 0.249 0.280 0.311 0.349 mm 0.69 0.81 0.99 1.24 1.55 1.83 2.26 2.90 3.15 3.63 4.01 4.57 5.03 5.74 6.32 7.11 7.90 8.86 Corrosive effect: none Fluid resistance: pass Fungus resistance: no growth Water absorption: 0.01% max Lead free Availability See table Recovered Wall Thickness, Nom. Inch mm 0.008 0.20 0.008 0.20 0.008 0.20 0.008 0.20 0.009 0.23 0.009 0.23 0.009 0.23 0.010 0.25 0.010 0.25 0.010 0.25 0.011 0.28 0.011 0.28 0.011 0.28 0.011 0.28 0.011 0.28 0.012 0.30 0.012 0.30 0.012 0.30 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Availability Qty, Cut Pieces at Length 4 ft (1.2 m) 2 ft (0.6 m) 25 — 25 — 25 — 25 — 25 — 25 — 25 — 25 — 25 — 25 — 25 — 25 — — 50 — 50 — 50 — 50 — 50 — 50 461 FIT > FIT Heat-Shrink Tubing Heat-Shrink Tubing FIT®-421 Heat-Shrink Tubing 4:1 Shrink Ratio, XLPO AMS-DTL-23053/5 Class 1 UL 224 VW-1 • • • • •  igh-shrink ratio H Large supplied diameters Conforms to irregular shapes Low water absorption UV resistant Operating Temperature • -55°C to +135°C • -55°C to +125°C (UL) • Flame retardant • Shelf life: 5 years at 18°C to 35°C Shrink Temperature Chemical Properties • 90°C min. • 121°C full recovery • • • • Corrosive effect: none Fungus resistance: no growth Water absorption: 0.5% max Fluid resistance: 1000 psi (6.89 N/mm2) • UV resistant • Lead free Material • Cross-linked polyolefin Color • Black Electrical Properties Physical Properties • T  ensile strength: 1500 psi (10.34 N/mm2) • Elongation: 200% min • Longitudinal change: +5%/-15% • Specific gravity: 1.35 Part No. FIT-421-1IN FIT-421-1-1/2 FIT-421-2IN FIT-421-3IN FIT-421-4IN 462 Supplied ID, Min. Inch 1.000 1.500 2.000 3.000 4.000 mm 25.40 38.10 50.80 76.20 101.60 Recovered ID, Max. Inch 0.260 0.375 0.550 0.810 1.050 mm 6.60 9.53 13.97 20.57 26.67 • 600 V (UL) • Dielectric strength: 500 V/mil (197 kV/cm) • Volume resistivity: 1014 ohm-cm Availability See table Recovered Wall Thickness, Nom. Inch mm 0.045 1.14 0.045 1.14 0.045 1.14 0.045 1.14 0.045 1.14 Availability Qty, Cut Pieces at Length 4 ft (1.2 m) 15 ft (4.5 m) 5 — 5 — 5 — 2 — 2 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. FIT > FIT Heat-Shrink Tubing Heat-Shrink Tubing FIT®-500 Heat Shrink Tubing 1.5:1 Shrink Ratio, PTFE Operating Temperature Chemical Properties • -75°C to +260°C • • • • • Shrink Temperature • 327°C full recovery Material AMS-DTL-23053/12 Class 3 • PTFE • • • • • • Color  xcellent chemical resistance E Widest temperature range High tensile strength Excellent dielectric properties Extremely thin wall thickness Low friction coefficient Part No. FIT-500-30 FIT-500-28 FIT-500-26 FIT-500-24 FIT-500-22 FIT-500-20 FIT-500-18 FIT-500-16 FIT-500-14 FIT-500-12 FIT-500-10 FIT-500-8 FIT-500-6 FIT-500-4 FIT-500-2 FIT-500-0 Inch 0.034 0.038 0.046 0.050 0.055 0.060 0.076 0.093 0.120 0.150 0.191 0.240 0.302 0.370 0.430 0.470 Electrical Properties • Natural • D  ielectric strength: 800 V/mil (315 kV/cm) • Volume resistivity: 1018 ohm-cm Physical Properties Availability • T  ensile strength: 2500 psi (17.21 N/mm2) • Elongation: 200% min • Longitudinal change: ±20% • Specific gravity: 2.20 • Flame rating: UL 94V-0 • Shelf life: 4 years at 18°C to 35°C Supplied ID, Min. mm 0.86 0.97 1.17 1.27 1.40 1.52 1.93 2.36 3.05 3.81 4.85 6.10 7.67 9.40 10.92 11.94 Corrosive effect: none Fungus resistance: no growth Water absorption: 0.01% max Fluid resistance: pass Lead free Recovered ID, Max. Inch 0.015 0.018 0.022 0.027 0.032 0.039 0.049 0.061 0.072 0.089 0.112 0.141 0.178 0.224 0.278 0.347 mm 0.38 0.46 0.56 0.69 0.81 0.99 1.24 1.55 1.83 2.26 2.84 3.58 4.52 5.69 7.06 8.81 See table Recovered Wall Thickness, Nom. Inch mm 0.009 0.23 0.009 0.23 0.010 0.25 0.010 0.25 0.012 0.30 0.012 0.30 0.012 0.30 0.012 0.30 0.012 0.30 0.012 0.30 0.012 0.30 0.015 0.38 0.015 0.38 0.015 0.38 0.015 0.38 0.015 0.38 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Availability, Cut Pieces at Length 2 ft (0.6 m) 50 50 50 50 50 50 50 50 50 25 25 25 10 10 10 10 463 FIT > FIT Heat-Shrink Tubing Heat-Shrink Tubing FIT®-600 Heat Shrink Tubing 2:1 Shrink Ratio, Chlorinated PO Operating Temperature Chemical Properties • -75°C to +121°C • • • • Corrosive effect: none Fungus resistance: no growth Water absorption: 1.0% max Fluid resistance: 1000 psi (6.89 N/mm2) • UV resistant • Lead free Shrink Temperature • 130°C min. • 130°C full recovery Material AMS-DTL-23053/1 Class 1 and 2 • Chlorinated polyolefin FIT-600-1/4 FIT-600-3/8 FIT-600-1/2 FIT-600-5/8 FIT-600-3/4 FIT-600-7/8 FIT-600-1IN FIT-600-1-1/4 FIT-600-1-1/2 FIT-600-1-3/4 FIT-600-2IN FIT-600-3IN 464 • Black Physical Properties • T  ensile strength: 1500 psi (10.34 N/mm2) • Elongation: 250% min • Longitudinal change: +1%/-10% • Specific gravity: 1.30 • Flame retardant • Shelf life: 1 year at 18°C to 35°C Supplied ID, Min. Inch 0.250 0.375 0.500 0.625 0.750 0.875 1.000 1.250 1.500 1.750 2.000 3.000 • D  ielectric strength: 300 V/mil (118 kV/cm) • Volume resistivity: 1011 ohm-cm Color • M  ore flexible than standard XLPO • 2x the tensile strength of silicone rubber • Large tubing diameters • Oil resistant • Abrasion resistant Part No. Electrical Properties mm 6.35 9.53 12.70 15.88 19.05 22.23 25.40 31.75 38.10 44.45 50.80 76.20 Recovered ID, Max. Inch 0.143 0.211 0.286 0.357 0.428 0.500 0.570 0.714 0.857 1.000 1.140 1.710 mm 3.63 5.36 7.26 9.07 10.87 12.70 14.48 18.14 21.77 25.40 28.96 43.43 Availability See table Spools may contain multiple lengths Recovered Wall Thickness, Nom. Inch mm 0.035 0.89 0.040 1.02 0.048 1.22 0.052 1.32 0.057 1.45 0.065 1.65 0.070 1.78 0.087 2.21 0.095 2.41 0.107 2.72 0.110 2.79 0.125 3.18 Availability Ft 25, 150 25, 150 25, 150 25, 150 25, 100 25, 100 25, 100 25, 100 25, 100 25, 75 25, 75 25, 50 m 7.6, 46 7.6, 46 7.6, 46 7.6, 46 7.6, 30.5 7.6, 30.5 7.6, 30.5 7.6, 30.5 7.6, 30.5 7.6, 22.8 7.6, 22.8 7.6, 15.2 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. FIT > FIT Heat-Shrink Tubing Heat-Shrink Tubing FIT®-621 Heat Shrink Tubing 5.6:1 Shrink Ratio, Dual-Wall Flexible PO, Adhesive-Lined Inner Thick Wall Operating Temperature Chemical Properties • -55°C to +90°C • • • • • Polyolefin Corrosive effect: none Fungus resistance: no growth Water absorption: 0.5% max Fluid resistance: 750 psi (5.17 N/mm2) • Halogen free • Lead free Color Electrical Properties Shrink Temperature • 121°C full recovery Material • • • • • •  igh shrink ratios H Heavy-duty adhesive lining Low water absorption Oil resistant Chemical resistant Abrasion resistant Black Physical Properties • T  ensile strength: 1200 psi (8.27 N/mm2) • Elongation: 200% min • Longitudinal change: -10% • Specific gravity: 1.40 • Shelf life: 5 years at 18°C to 35°C Part No. FIT-621-5/8 FIT-621-1-1/4 FIT-621-2 FIT-621-2-1/2 FIT-621-3 FIT-621-4 Supplied ID, Min. Inch 0.600 1.250 2.000 2.500 3.000 4.000 mm 15.24 31.75 50.80 63.50 76.20 101.60 Recovered ID, Max. Inch 0.150 0.220 0.374 0.500 0.748 0.898 mm 3.81 5.59 9.50 12.70 19.00 22.81 Recovered Wall Thickness, Nom. Inch mm 0.060 1.52 0.060 1.52 0.106 2.69 0.120 3.05 0.140 3.56 0.155 3.94 • D  ielectric strength: 200 V/mil (79 kV/cm) • Volume resistivity: 1013 ohm-cm Availability See table Recovered Adhesive Wall Thickness, Min. Inch mm 0.050 1.27 0.050 1.27 0.050 1.27 0.050 1.27 0.050 1.27 0.050 1.27 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Availability, Qty, Cut Pieces at Length 6” (152 mm) 3, 10 3, 10 3, 10, 24 3, 10 3, 10 3, 10 465 FIT > FIT Heat-Shrink Tubing Heat-Shrink Tubing FIT®-650 Heat Shrink Tubing 2:1 Shrink Ratio, Flexible Fluoroelastomer Operating Temperature Chemical Properties • -40°C to +200°C • • • • Corrosive effect: none Fungus resistance: no growth Water absorption: 0.50% max Fluid resistance: 1200 psi (8.27 N/mm2) • Lead free Shrink Temperature • 130°C min. • 175°C full recovery AMS-DTL-23053/13 • • • • •  xcellent chemical resistance E Wide temperature range Flexible Oil resistant Fuel resistant Material • Flexible fluoroelastomer • Black • D  ielectric strength: 200 V/mil (79 kV/cm) • Volume resistivity: 109 ohm-cm Physical Properties Availability Colors • T  ensile strength: 1200 psi (8.27 N/mm2) • Elongation: 250% min • Longitudinal change: ±20% • Flammability: self-extinguishing • Shelf life: 2 years at 18°C to 35°C Part No FIT-650-1/8 FIT-650-3/16 FIT-650-1/4 FIT-650-3/8 FIT-650-1/2 FIT-650-3/4 FIT-650-1 ST-650-1-1/2* Electrical Properties Supplied ID, Min. Inch mm 0.125 3.18 0.187 4.75 0.250 6.35 0.375 9.53 0.500 12.70 0.750 19.05 1.000 25.40 1.500 38.10 Recovered ID, Max. Inch mm 0.062 1.57 0.093 2.36 0.125 3.18 0.187 4.75 0.250 6.35 0.375 9.53 0.500 12.70 0.750 19.50 100 ft (30.5 m) Spools may contain multiple lengths Recovered Wall Thickness, Nom. Inch mm 0.031 0.79 0.035 0.89 0.035 0.89 0.035 0.89 0.035 0.89 0.042 1.07 0.049 1.24 0.055 1.40 *Available in 50 ft (76 m) spools only. 466 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. FIT > FIT Heat-Shrink Tubing Heat-Shrink Tubing FIT®-700 Heat Shrink Tubing 3:1 Shrink Ratio, Heavy-Wall XLPO, Thermoplastic Adhesive Lined Operating Temperature • -55°C to +110°C Shrink Temperature • 120°C min. • 120°C full recovery Material ANSI C119:1 UL 486 CSA 198 • H  eavy-wall cross-linked polyolefin • Thermoplastic adhesive • T  hermoplastic adhesive bonds to most materials • Rated for 1 kV, 90°C continuous use • Superior strength FIT-700-21 FIT-700-22 FIT-700-23 FIT-700-24 FIT-700-25* FIT-700-26* Supplied ID, Min. Inch 0.750 1.100 1.500 2.000 3.000 4.500 mm 19.05 27.94 38.10 50.80 76.20 114.30 • Black Physical Properties Recovered ID, Max. Inch 0.240 0.350 0.470 0.630 1.250 1.750 Chemical Properties • • • • • • Corrosive effect: none Fungus resistance: no growth Water absorption: 0.10% max Fluid resistance: excellent UV resistant Lead free Electrical Properties Color • T  ensile strength: 2100 psi (14.48 N/mm2) • Elongation: 600% min • Longitudinal change: +1%/-10% Part No. • Specific gravity: 1.10 • Flame retardant • Shelf life: 25 years at 18°C to 35°C mm 6.10 8.89 11.94 16.00 31.75 44.45 Recovered Wall Thickness, Nom. Inch mm 0.120 3.05 0.120 3.05 0.140 3.56 0.140 3.56 0.160 4.06 0.160 4.06 • D  ielectric strength: 500 V/mil (196.9 kV/cm) • Volume resistivity: 1017 ohm-cm Availability Cut pieces (see table) Recovered Adhesive Wall Thickness, Min. Inch mm 0.050 1.27 0.050 1.27 0.050 1.27 0.050 1.27 0.050 1.27 0.050 1.27 Availability, Qty, Cut Pieces at Length 12” (304 mm) 6 6 6 6 6 6 *Not UL or CSA listed Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. 467 FIT > FIT Heat-Shrink Tubing Heat-Shrink Tubing FIT®-750 Heat Shrink Tubing 2:1 Shrink Ratio, XLPO, Adhesive Lined AMS-DTL-23053/4 Class 2 UL 224 VW-1 CSA 198 • G  eneral-purpose adhesivelined tubing • Total encapsulation • Bonding to substrates Operating Temperature • -55°C to +110°C • -55°C to +125°C (UL, CSA) • All tubing flame tested • Self-extinguishing within 1 minute • Shelf life: 3 years at 18°C to 35°C Shrink Temperature Chemical Properties • 110°C min. • 110°C full recovery • • • • Material • A  dhesive-lined cross-linked polyolefin Color Electrical Properties • Black Physical Properties • T  ensile strength: 1500 psi (10.34 N/mm2) • Elongation: 200% min • Longitudinal change: +1%/-5% Part No. ST-302-1/8 ST-302-3/16 FIT-750-1/4 FIT-750-3/8 FIT-750-1/2 FIT-750-3/4 FIT-750-1IN FIT-750-1-1/2 468 Supplied ID, Min. Inch 0.125 0.187 0.250 0.375 0.500 0.750 1.000 1.500 mm 3.18 4.75 6.35 9.53 12.70 19.05 25.40 38.10 Recovered ID, Max. Inch 0.063 0.093 0.125 0.187 0.250 0.375 0.500 0.750 mm 1.60 2.36 3.18 4.75 6.35 9.53 12.70 19.05 Corrosive effect: none Fungus resistance: no growth Water absorption: 0.5% max Fluid resistance: 1000 psi (6.89 N/mm2) • UV resistance • Lead free Recovered Wall Thickness, Nom. Inch mm 0.027 0.69 0.027 0.69 0.030 0.76 0.031 0.79 0.032 0.81 0.037 0.94 0.039 0.99 0.046 1.17 • 600 V (UL, CSA) • Dielectric strength: 500 V/mil (197 kV/cm) • Volume resistivity: 1012 ohm-cm Availability See table Recovered Adhesive Wall Thickness, Min. Inch mm 0.002 0.05 0.002 0.05 0.004 0.10 0.004 0.10 0.005 0.13 0.005 0.13 0.007 0.18 0.007 0.18 Availability, Qty, Cut Pieces at Length 4’ (1219 mm) 25 25 25 25 5 5 5 5 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. FIT > FIT Heat-Shrink Tubing Heat-Shrink Tubing FIT®-FABRIC Woven Fabric Heat-Shrink Tubing 2:1 Shrink Ratio Operating Temperature Chemical Properties • -40°C to +125°C • 80°C min. • 135°C full recovery • • • • • Material Availability • Polyethylene-polyester fabric See table Color Spools may contain multiple lengths Shrink Temperature UL 1441 (125°C) MVSS 302 • E  xcellent abrasion resistance • Outstanding flexibility and durability • Easy installation: cuts with scissors Part No. FIT-FAB-1 FIT-FAB-2 FIT-FAB-3 FIT-FAB-4 FIT-FAB-5 FIT-FAB-6 FIT-FAB-7 • Black Physical Properties • Flame retardant • Shelf life: 25 years at 18°C to 35°C Supplied ID, Min. Inch 0.472 0.787 1.181 1.575 1.969 2.362 2.756 Corrosive effect: none Fungus resistance: no growth Lead free Halogen free UV resistant mm 11.99 19.99 30.00 40.01 50.01 59.99 70.00 Recovered ID, Max. Inch 0.236 0.394 0.591 0.787 0.984 1.181 1.378 mm 5.99 10.01 15.01 19.99 24.99 30.00 35.00 Recovered Wall Thickness, Nom. Inch mm 0.040 1.02 0.040 1.02 0.040 1.02 0.040 1.02 0.040 1.02 0.040 1.02 0.040 1.02 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Availability Ft 50, 200 50, 200 50, 200 50, 200 25, 100 25, 100 25, 100 m 15.2, 60.9 15.2, 60.9 15.2, 60.9 15.2, 60.9 7.6, 30.5 7.6, 30.5 7.6, 30.5 469 FIT > FIT Heat-Shrink Tubing Heat-Shrink Tubing FIT®-FLEX Highly Flexible Heat-Shrink Tubing 1.7:1 Shrink Ratio, Cross-linked Silicone Rubber Operating Temperature Chemical Properties • -50°C to +200°C • • • • Shrink Temperature • 80°C min. • 135°C full recovery Electrical Properties Material UL 224 VW-1 • Cross-linked silicone rubber • H  ighly flexible over wide temperature range • Scrape abrasion resistant • Pliable Color • Slate • T  ensile strength: 870 psi (5.99 N/mm2) • Elongation: 350% min • Longitudinal change: -15% • Specific gravity: 1.20 • Flammability: self-extinguishing • Shelf life: 25 years at 18°C to 35°C FIT-FLEX-2 FIT-FLEX-3 FIT-FLEX-5 FIT-FLEX-6 FIT-FLEX-9 FIT-FLEX-12 FIT-FLEX-20 470 Supplied ID, Min. Inch 0.165 0.263 0.394 0.512 0.757 0.984 1.378 mm 4.19 6.68 10.01 13.00 19.23 24.99 35.00 • 600 V • Dielectric strength: 200 V/mil (79 kV/cm) • Volume resistivity: 1012 ohm-cm Availability Physical Properties Part No. Corrosive effect: none Fungus resistance: no growth Water absorption 1.0% max Lead free Recovered ID, Max. Inch 0.071 0.114 0.173 0.244 0.354 0.492 0.748 mm 1.80 2.90 4.39 6.20 8.99 12.50 19.00 25 ft (7.6 m) 100 ft (30.5 m) Spools may contain multiple lengths Recovered Wall Thickness, Nom. Inch mm 0.055 1.40 0.055 1.40 0.055 1.40 0.055 1.40 0.059 1.50 0.079 2.01 0.079 2.01 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. FIT > FIT Heat-Shrink Tubing Heat-Shrink Tubing FIT®-CLEAR Heat-Shrink Tubing 2:1 Shrink Ratio, Cross-Linked PVDF Chemical Properties Operating Temperature • -55°C to +175°C • -55°C to +150°C (UL) • • • • Corrosive effect: none Fungus resistance: no growth Water absorption 0.5% max Fluid resistance: 2000 psi (13.79 N/mm2) • Lead free Shrink Temperature • 150°C full recovery AMS-DTL-23053/18 Class 1 UL 224 VW-1 • E  xcellent heat and chemical resistance • Mechanical abrasion and cut-through resistance Material • C  ross-linked polyvinylidene fluoride • Clear • 600 V (UL) • Dielectric strength: 400 V/mil (158 kV/cm) • Volume resistivity: 1011 ohm-cm Physical Properties Availability Color • T  ensile strength: 3500 psi (24.13 N/mm2) • Elongation: 200% min • Longitudinal change: ±10% • Specific gravity: 2.0 • Flame retardant • Shelf life: 5 years at 18°C to 35°C Part No. FIT-CLEAR-3/64 FIT-CLEAR-1/16 FIT-CLEAR-3/32 FIT-CLEAR-1/8 FIT-CLEAR-3/16 FIT-CLEAR-1/4 FIT-CLEAR-3/8 FIT-CLEAR-1/2 FIT-CLEAR-3/4 FIT-CLEAR-1IN FIT-CLEAR-1-1/2 FIT-CLEAR-2IN Electrical Properties Supplied ID, Min. Inch mm 0.046 1.17 0.063 1.60 0.093 2.36 0.125 3.18 0.187 4.75 0.250 6.35 0.375 9.53 0.500 12.70 0.750 19.05 1.000 25.40 1.500 38.10 2.000 50.80 Recovered ID, Max. Inch mm 0.023 0.58 0.031 0.79 0.046 1.17 0.062 1.57 0.093 2.36 0.125 3.18 0.187 4.75 0.250 6.35 0.375 9.53 0.500 12.70 0.750 19.05 1.000 25.40 See table Spools may contain multiple lengths Recovered Wall Thickness, Nom. Inch mm 0.010 0.25 0.010 0.25 0.010 0.25 0.010 0.25 0.010 0.25 0.012 0.30 0.012 0.30 0.012 0.30 0.017 0.43 0.019 0.48 0.020 0.51 0.020 0.51 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Availability Ft m 100 30.5 100 30.5 100 30.5 100 30.5 100 30.5 100 30.5 100 30.5 50 15.2 50 15.2 50 15.2 50 15.2 50 15.2 471 FIT > FIT Heat-Shrink End Caps Heat-Shrink Tubing CAP Molded Heat-Shrink End Caps 2:1 Shrink Ratio, Semirigid Polyolefin Material Chemical Properties • Semirigid polyolefin • • • • • Color • Black Physical Properties • T  ensile strength: 2500 psi (1.76 N/mm2) • Elongation: 300% min • Recovered parts may have angularity of 30° to 45° • Specific gravity: 1.25 • Flammability: self-extinguishing • Shelf life: 25 years at 18°C to 35°C • A  brasion resistant • Moisture resistant Operating Temperature • -55°C to +135°C Shrink Temperature • 135°C full recovery Part No. CAP-21 CAP-22 CAP-23 CAP-24 CAP-25 CAP-26 CAP-27 472 Supplied ID, Min. Inch 0.200 0.290 0.400 0.600 0.810 1.000 1.550 mm 5.08 7.37 10.16 15.24 20.57 25.40 39.37 Recovered ID, Max. Inch 0.080 0.130 0.180 0.250 0.370 0.450 0.710 mm 2.03 3.30 4.57 6.35 9.40 11.43 18.03 Corrosive effect: none Fungus resistance: no growth Water absorption 0.1% max UV resistant Lead free Electrical Properties • D  ielectric strength: 700 V/mil (276 kV/cm) • Volume resistivity: 1016 ohm-cm Availability 25-piece packages Recovered Wall Thickness, Nom. Inch mm 0.040 1.02 0.050 1.27 0.060 1.52 0.070 1.78 0.080 2.03 0.090 2.29 0.100 2.54 Recovered Length, Nom. Inch 0.900 1.000 1.200 1.600 2.400 2.700 3.600 mm 22.86 25.40 30.48 40.64 60.96 68.58 91.44 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. FIT > FIT Heat-Shrink Tubing Heat-Shrink Tubing SPC Heat Shrink Tubing 3:1 Shrink Ratio, XLPO, Heavy-Wall Thermoplastic Bonding Layer Operating Temperature Chemical Properties • -55°C to +110°C • • • • • • Shrink Temperature • 120°C min. Material AMS DTL-23053/15 Class 1 • Cross-linked polyolefin • A  dhesive lined for sealing • Thick wall for extra abrasion resistance • Rated to 1 kV Color Electrical Properties • D  ielectric strength: 500 V/mil (197 kV/cm) • Volume resistivity: 1015 ohm-cm • Black Physical Properties • T  ensile strength: 2400 psi (138 N/mm2) • Elongation: 475% min • Longitudinal change: +1%/-10% • Specific gravity: 1.28 • Flame retardant, self-extinguishing • Shelf life: 25 years at 18°C to 35°C Part No. SPC-400* SPC-800* SPC-110* SPC-150 SPC-200 SPC-300 Supplied ID, Min. Inch 0.400 0.800 1.100 1.500 2.000 3.000 mm 10.16 20.32 27.94 38.10 50.80 76.20 Recovered ID, Max. Inch 0.150 0.200 0.375 0.500 0.750 1.000 Corrosive effect: none Fungus resistance: no growth Water absorption: 0.02% Fluid resistance: pass UV resistant Lead free mm 3.81 5.08 9.53 12.70 19.05 25.40 Availability Sold in individual pieces 6 in. (0.1 m) 12 in. (0.3 m) 48 in. (1.2 m) bulk Recovered Wall Thickness, Nom. Inch mm 0.060 1.52 0.060 1.52 0.105 2.67 0.120 3.05 0.120 3.05 0.120 3.05 Recovered Adhesive Wall Thickness, Min. Inch mm 0.050 1.27 0.050 1.27 0.050 1.27 0.050 1.27 0.050 1.27 0.050 1.27 *Availability includes 6 in. (0.1 m) lengths. Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. 473 FIT > FIT Heat-Shrink Tubing Heat-Shrink Tubing SPCM Heat Shrink Tubing 3:1 Shrink Ratio, XLPO, Medium Wall, Thermoplastic Bonding Layer Operating Temperature Chemical Properties • -55°C to +200°C • • • • • • Shrink Temperature • 120°C min. Material AMS DTL-23053/15 Class 2 • Cross-linked polyolefin • A  dhesive lined for sealing • Medium wall for abrasion resistance • Rated to 1 kV Color Electrical Properties • D  ielectric strength: 500 V/mil (197 kV/cm) • Volume resistivity: 1015 ohm-cm • Black Physical Properties • T  ensile strength: 2400 psi (1.38 N/mm2) • Elongation: 475% min • Longitudinal change: +1%/-10% • Specific gravity: 1.25 • Self-extinguishing • Shelf life: 25 years at 18°C to 35°C Part No. SPCM400* SPCM800* SPCM110* SPCM130 SPCM150 SPCM170 SPCM200 SPCM300 Supplied ID, Min. Inch 0.400 0.800 1.100 1.300 1.500 1.700 2.000 3.000 mm 10.16 20.32 27.94 33.02 38.10 43.18 50.80 76.20 Recovered ID, Max. Inch 0.150 0.220 0.375 0.375 0.500 0.500 0.750 1.000 Corrosive effect: none Fungus resistance: no growth Water absorption: 0.02% Fluid resistance: pass UV resistant Lead free mm 3.81 5.59 9.53 9.53 12.70 12.70 19.05 25.40 Availability Sold in individual pieces 6 in. (0.1 m) 12 in. (0.3 m) 48 in. (1.2 m) Recovered Wall Thickness, Nom. Inch mm 0.050 1.27 0.060 1.52 0.065 1.65 0.065 1.65 0.080 2.03 0.100 2.54 0.100 2.54 0.100 2.54 Recovered Adhesive Wall Thickness, Min. Inch mm 0.040 1.02 0.040 1.02 0.040 1.02 0.040 1.02 0.040 1.02 0.040 1.02 0.040 1.02 0.040 1.02 *Availability includes 6 in. (0.1 m) lengths. 474 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. FIT > FIT-PRINT Heat-Shrinkable Identification System Heat-Shrink Tubing FIT®-PRINT Heat-Shrinkable Identification System 3:1 Shrink Ratio, XLPO Operating Temperature • Longitudinal change: 20% • Flame retardant • Shelf life: 3 years at 18°C to 35°C • -30°C to +105°C Shrink Temperature Chemical Properties • 90°C min. • 125°C full recovery Material UL 224 CSA 198 MIL-STD-202F Method 215J • Cross-linked polyolefin FIT-PRINT-1/8 FIT-PRINT-1/4 FIT-PRINT-1/2 FIT-PRINT-1 • D  ielectric strength: 20 V/mil (7.9 kV/cm) • Volume resistivity: 1014 ohm-cm • White, yellow Physical Properties • T  ensile strength: 1160 psi (8.0 N/mm2) • Elongation: 150% min Range AWG 22 – 16 16 – 8 8–2 2 – 4/0 Electrical Properties Colors • P  ermanent, smear-resistant marking • Identification for cable or harness assemblies Part No • Corrosive effect: none • Fungus resistance: no growth • Water absorption: 0.5% Inch 0.344 – 1.374 1.374 – 3.264 3.264 – 6.543 6.543 – 10.2 mm 8.74 – 34.90 34.90 – 82.92 82.92 – 166.19 166.19 – 259.08 Supplied ID, Min. Inch 0.125 0.250 0.500 1.000 mm 3.18 6.35 12.70 25.40 Availability 250 tubing pieces per package Recovered ID, Max. Inch 0.042 0.083 0.166 0.333 mm 1.07 2.11 4.22 8.46 Recovered Wall Thickness, Nom. Inch mm 0.023 0.58 0.023 0.58 0.023 0.58 0.023 0.58 To economically meet the wire identification needs of the electronic interconnect, industrial, computer office automation, marine, and electrical markets, FIT-PRINT sleeves allow smearresistant, permanent identification. The sleeves, available in white or high-visibility bright yellow, feed directly into dot matrix printers (high carbon content ribbon recommended). A standard ballpoint pen may also be used. Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. 475 FIT > FIT-KIT Heat-Shrink Tubing FIT®-KIT Assorted Heat-Shrink Tubing • F  or use in R&D labs, engineering development, and maintenance departments FIT-KIT-1 for General-Purpose Indoor Applications Tubing supplied in 6” (15.2 cm) lengths unless otherwise noted. Family Material Sizes Range Total Quantity FIT-105 FIT-221 FIT-295 FIT-300 FIT-350 FIT-CRIMP Caps PVC XLPO SR-XLPO XLPO PVDF Nylon XLPO 9 9 8 5 7 22 – 10 AWG 22, 23, 24 AWG 3/64” – 3/4” 3/64” – 3/4” 3/64” – 1/2” 1/8” – 1/2” 3/64” – 3/8” — — 18 19 12 10 14 3 pc* 6 pc *1 each of FIT-CRIMP 1, 2, and 3. FIT-KIT-2 for General-Purpose Indoor and Outdoor Applications Tubing supplied in 6” (15.2 cm) lengths unless otherwise noted. Family Material No. of Sizes Range Total Quantity FIT-105 FIT-221 FIT-295 FIT-300 FIT-321 FIT-350 FIT-400 FIT-500 FIT-600 FIT-700 FIT-750 FIT-CRIMP Caps PVC XLPO SR-XLPO XLPO Adhesive-Lined XLPO PVDF FEP PTFE Chlorinated PO Thermoplastic Adhesive-Lined XLPO Adhesive-Lined XLPO Nylon XLPO 9 9 8 5 2 7 6 5 5 2 1 22 – 10 AWG 22, 23, and 24 3/64” – 3/4” 3/64” – 3/4” 3/64” – 1/2” 1/8” – 1/2” 1/4” – 1/2” 3/64” – 3/8” 24 – 12 AWG 26 – 18 AWG 1/4” – 1” 21 – 22 3/8” — — 18 19 12 10 16, 24* 14 22 17 8 2 10* 3 pc** 6 pc *1”/25.4 mm length. **1 each of FIT-CRIMP 1, 2, and 3. FIT-KIT-7 for General-Purpose Indoor and Outdoor Applications Tubing supplied in 6” (15.2 cm) lengths unless otherwise noted. Family Material No. of Sizes Range Total Quantity FIT-105 FIT-221 FIT-260 FIT-300 FIT-321 FIT-350 FIT-400 FIT-750 FIT-CRIMP PVC XLPO XLPO (Ground Lead) XLPO Adhesive-Lined XLPO PVDF FEP Adhesive-Lined XLPO Nylon 7 7 3 4 3 7 7 5 22 – 10 AWG 1/16” – 1/2” 1/16” – 1/2” 1/8” – 1/2”” 3/8” – 1/2” 1/8” – 1/2” 1/6” – 1/2” 24 – 12 AWG 1/4” – 1” — 14 28 6 8 6 14 14 10 12 pc* *4 each of FIT-CRIMP 1, 2, and 3. 476 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. FIT > FIT-MGKIT-1 Heat-Shrink Tubing FIT®-MGKIT-1 Convenient Kit with FIT Minigun and FIT-221 Variety Pack FIT-MGKIT-1 Contents Part No. FIT MINIGUN FIT-221-R FIT Minigun Characteristics FIT-221-R Variety Kit • UL 499 • To 300°C nozzle temperature • 6 ft (1.83 m) power cord • 10.3 oz (0.39 kg) net weight • Workbench storage loop included • 120 V • 350 W • 3A • Color: blue • • • • UL 224 CSA 198 AMS-DTL-23053/5 Class 1 60 6” (15.2 cm) pieces in five sizes and various colors • Cross-linked polyolefin • 2:1 shrink ratio Description Lightweight, portable heat gun FIT-221R Variety Pack Quantity 1 1 kit/60 pieces FIT-221-R Kit Contents FIT-221-1/8 FIT-221-3/16 FIT-221-1/4 FIT-221-3/8 FIT-221-1/2 Tubing Size Inch Mm 0.125 3.18 0.187 4.75 0.250 6.35 0.375 9.53 0.500 12.70 Black 4 4 4 3 3 White 3 3 3 2 2 Number of 6” (15.2 cm) Pieces Red Blue 2 2 2 2 2 2 1 1 1 1 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. Yellow 2 2 2 1 1 Green 1 1 1 1 1 477 FIT > FIT-CRIMP Heat-Shrinkable Crimp Splices Heat-Shrink Tubing FIT®-CRIMP Heat-Shrinkable Crimp Splices 2:1 Shrink Ratio, Nylon Operating Temperature Chemical Properties • -55°C to +125°C • S  olvent resistance: isopropyl alcohol, trichloroethylene, gasoline, battery acid, diesel fuel, motor oil, anti-freeze, brake fluid, 5% salt water Materials • Heat-shrinkable nylon • Polyamide-based adhesive • Tin-plated copper base metal UL ZMVV Availability Physical Properties 100-piece packages 500-piece packages • S  helf life: 25 years at 18°C to 35°C • Not flame retardant Part No. FIT-CRIMP 1 FIT-CRIMP 2 FIT-CRIMP 3 Wire Range AWG 22 – 18 16 – 14 12 – 10 mm2 0.26 – 0.96 1.04 – 2.62 2.62 – 6.64 Alpha’s heat-shrinkable preinsulated crimp splices completely seal electrical connections from corrosion caused by water, salts, and other contaminants. Unlike conventional splices, these adhesive-lined butt connectors provide a strong reinforced connection. They are lightweight and easy to install, too. Simply insert the wires. The sleeve’s transparent nylon insulation lets you inspect wire location and position your crimping tool fast. 478 Length L1 Color Red Blue Yellow Inch 1.50 1.50 1.70 mm 38.10 38.10 43.18 Supplied ID, Min. A Inch 0.170 0.197 0.255 B mm 4.32 5.00 6.48 Inch 0.058 0.092 0.138 mm 1.47 2.34 3.51 Recovered ID, Max. A Inch mm 0.055 1.40 0.080 2.03 0.110 2.79 Crimp the splice and then shrink and seal it with a common heat gun or other heat source. Reliable sealing plus quick and easy installation add up to protection you can count on whenever wire splices are required, including automobile and truck wiring, outdoor electrical equipment, marine equipment, telecommunications equipment, recreational equipment, and household appliances. Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. FIT > FIT-SLV Soldering Sleeves Heat-Shrink Tubing FIT®-SLV Soldering Sleeves Operating Temperature Solder Preform: • -55°C to +105°C (SLV 12 – 16) • -55°C to +125°C (SLV 22 – 26) • Transparent blue • 1 05°C Series: 51.2% tin, 30.6% lead, 18.2% cadmium (143°C melting temperature) • 125°C Series: 63% tin, 37% lead (183°C melting temperature) Materials Physical Properties: • PVDF heat-shrinkable sleeve • S  helf life: 25 years at 18°C to 35°C Sleeve Color ANSI J-STD-004 ANSI J-STD-006 NAS 1745 Availability 25-piece packages 100-piece packages Part No. 105°C FIT-SLV-12 FIT-SLV-14 FIT-SLV-16 Dimensions D min. D1 min. 125°C FIT-SLV-22 FIT-SLV-24 FIT-SLV-26 Alpha’s FIT-SLV soldering sleeve is a one piece, shield ground termination system featuring a strong, low-cost soldered connection that is completely insulated and encapsulated. It consists of a heat-shrinkable thermoplastic sleeve containing a precisely engineered preform of fluxed solder and thermoplastic Inch 0.125 0.200 0.300 mm 3.18 5.08 7.62 Inch 0.110 0.180 0.280 inserts at each end. When placed over a cable shield and heated, the solder melts and flows, connecting the ground lead and shield. The outer sleeve shrinks and the thermoplastic inserts melt, encapsulating the termination. The result is a perfectly soldered, strain-relieved and environmentally protected termination. L nom. mm 2.79 4.57 7.11 Inch 0.625 0.625 0.750 mm 15.88 15.88 19.05 A solder preform ensures exact quantity of solder and flux, producing optimum solder connections for maximum strength and lowest voltage drop. Transparent heat-shrinkable insulating sleeve allows inspection of termination, and provides long-life strain relief. Meltable inserts insure complete environmental protection. Selection Guide 1 M  easure maximum diameter (E) and minimum diameter (F) of combined cable and ground lead. 2. Find appropriate Alpha part number and sleeve size in the cable and sleeve dimensions chart. Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com. 479 FIT > FIT Heat Guns Heat-Shrink Tubing FIT® Heat Guns Temperature, Low Temperature, High Temperature Selection Power Voltage Current Power Cord Length Net Weight Color Nozzle Attachments Approvals Part No. 480 FIT-GUN-1 FIT-GUN-3 FIT-Minigun 60°C (140°F) 566°C (1050°F) Slider switch: Off, Low, Medium, High 1400 W 120 VAC/60 Hz 11.6 A 6.5 ft (2 m) 2.2 lb (1 kg) Black/gray Reflector nozzle 316°C (600°F) 510°C (950°F) Slider switch: Off, Low, High 1300 W 120 VAC/60 Hz 10.0 A 6.5 ft (2 m) 1.6 lb (0.68 kg) Black/gray — — 300°C (572°F) Rocker switch: Off, On 350 W 120 VAC/60 Hz 3A 6 ft (1.8 m) 10.3 oz (0.39 kg) Blue Workbench loop UL 499 UL 499 FIT-GUN1 UL 499 FIT-GUN3 FIT-MG1 Alpha Wire | www.alphawire.com | 1-800-52 ALPHA Specifications subject to change. For complete specifications and availability, visit www.alphawire.com.
FCRIMP2BL076 价格&库存
很抱歉,暂时无法提供与“FCRIMP2BL076”相匹配的价格&库存,您可以联系我们找货
