09080007222
09080007222
    HARTING(浩亭)
09080007222 数据手册
Han-Fast® Lock Features Technical characteristics • Solder free PCB termination • PCB contact with locking element • Stamped contact element • Automatic crimping process compatible • For use with different Han® connectors • Cost-effective • Easy handling • Fast assembly to PCB • Contacts with pin - Locking directly on the PCB • Contacts without pin - Fast positioning with plastic adapter Contacts Description Current carrying capacity The new connection of wires to the PCB offers optimized PCB design, combined with outstanding contact qualities. The Han-Fast ® Lock is flexible and allows a fast and simple PCB connection. The PCB has one drilled hole and a pad. The inner surface of the plated drilled hole serves as the interface. The Han-Fast ® Lock is simply inserted into the plated through contact hole. The locking pin is pushed in and hence locks the contact into position. The solder free connection technique is easy to handle and to operate. Maintenance has been made simple with the facility to detach the contact. Han-Fast ® Lock also supports SMD assembly of the PCB. The current carrying capacity of the connectors is limited by the thermal load capability of the contact element material including the connections and the insulating parts. The derating curve is therefore valid for currents which flow constantly (non-intermittent) through each contact element of the connector evenly, without exceeding the allowed maximum temperature. Measuring and testing techniques according to DIN EN 60 512-5 Current up to 60 A Standard drilled hole with pad Position independent of connector Solder free PCB termination Easy locking solution Straight and angled version copper alloy 3 µm Ag < 2 mΩ straight or angled Locking Material copper alloy Surface finish passivation Current 10 mm² stranded wire 60 A Voltage clearance and creepage distances have to be considered Board density t = 1.6 - 3.2 mm Operating current (A) • • • • • • Material Surface - Hard-silver plated Contact resistance Direction Ambient temperature (°C) ➀ Wire gauge: 1.5 mm² ➁ Wire gauge: 2.5 mm² ➂ Wire gauge: 4 mm² ➃ Wire gauge: 6 mm² ➄ Wire gauge: 10 mm² HARTING Electric GmbH & Co. KG | Wilhelm-Harting-Straße 1 | D-32339 Espelkamp Tel.: +49 5772 47-97100 | Fax: +49 5772 47-495 www.HARTING.com | electric@HARTING.com Han® 2015-03-05 Data Sheet 0927 Han-Fast® Lock Identification Part number Contacts with pin on a reel 2300 piece 1.5 to 2.5 mm² 09 08 000 6122 Contacts without pin on a reel 2300 piece 1.5 to 2.5 mm² 09 08 000 6922 Further plated surfaces on request Single contacts with pin 1.5 to 2.5 mm² 09 08 000 7122 Single contacts with pin 1.5 to 2.5 mm² 09 08 000 7922 Further plated surfaces on request Single contacts with pin angled 1.5 to 2,5 mm² 09 08 000 7222 4.0 to 6.0 mm² 09 08 000 7223 10.0 mm² 09 08 000 7224 Further plated surfaces on request Drawing Dimensions in mm Han-Fast® Lock Technical characteristics Technical characteristics Components Contacts Material Surface Resistance Stripping length 1.5 - 2.5 mm² Stripping length 4 - 6 mm² Stripping length 10 mm² Copper alloy Hard silver plated, 3 µm Ag < 2 mΩ 7.5 mm 7.5 mm 7.5 mm Locking Material Copper alloy Surface Surface passivation Current 10 mm² wire 60 A Voltage Please consider clearance and creepage distances when ordering the printed cicuit board Recommended termination cycles 10 x Limiting temperatures -40 °C ... +105 °C PCB PCB thickness Construction PCB Recommended configuration of plated through holes acc. to DIN EN 60352-5 for PCBs Diameter plated through hole t = 1.6 – 3.2 mm Depending on the required current carrying capacity ≥ 1.6 mm d = 4.4 mm +0.05 mm / -0.04 mm Chem. Sn PCB Plated through hole Ø 4.4 mm Cu Sn min. 25 µm min. 0.7 µm Au/Ni PCB Plated through hole Ø Cu Ni Au 4.4 mm min. 25 µm min. 3 µm min. 0.05 µm Ag PCB Plated through hole Ø Cu Ag 4.4 mm min. 25 µm min. 0.1 µm Cu e.g. Sn plated through hole Ø Vibration Vibration test DIN EN 60 068-2-6 • 10 ... 500 Hz • 0.35 mm, 50 ms² • 2 h per axis Shock DIN EN 61 373 • Category 1b • 5g • 30 ms, 3 shocks per axis Random vibration DIN EN 61 373 • Category 1b • ASD-level 1.857 (m/s²)²/Hz (aeff : 7.9m/s²) Test criteria No disconnection >1 µs Mouser Electronics Authorized Distributor Click to View Pricing, Inventory, Delivery & Lifecycle Information: HARTING: 09080007222 09080007122 09080007223 09080007224
09080007222 价格&库存
很抱歉,暂时无法提供与“09080007222”相匹配的价格&库存,您可以联系我们找货
