PC SCREW TERMINALS
LOW PROFILE VERTICAL TYPE
SPECIFICATIONS
6-32 X .250 [6.3] L.
SCREW
Rated: 15 Amps
Terminal: .032 (.81) Brass, Matte Tin
Plate
Binding Head Screw: Brass, Nickel Plate
.343 [8.7]
.250 [6.3]
.310 [7.9]
6-32 x .250 [6.3] L.
SCREW
.310
[7.9]
7775-2
.250 [6.4]
7778-7
.134 [3.4]
• Color coded screws
available (add color
screw suffix to Cat. No.)
.187 [4.7]
.197 [5.0]
.276
[7.0]
.055 [1.4]
(2) PLS
.312
[7.9]
.059 [1.5]
(4) PLS
.197 [5.0]
Mounting Detail
CAT. NO. 7784 (No Screw Supplied)
screw suffix to
Cat. No.)
Mounting Detail
.187 [4.7]
CAT. NO. 7785 (No Screw Supplied)
.312 [7.9]
CAT. NO. 8198 (Screw Supplied Unassembled)
CAT. NO. 8195 (Screw Supplied Unassembled)
.067 [1.7] DIA.
(2) PLS
CAT. NO. 7778 (Screw Installed & Captivated)
.144 [3.7]
DIA.
.276
[7.0]
CAT. NO. 7775 (Screw Installed & Captivated)
.062 [1.57] DIA. (4) PLS
VERTICAL TYPE
EXTENDED
HEAVY DUTY
SPECIFICATIONS
Rated: 15 Amps
Terminal: .032 (.81) Brass, Mattte Tin Plate
.310 [7.9]
SCREW
.310 [7.9]
.375 [9.5]
10-32 X .375 [9.5] L.
SCREW
.382 [9.7]
8174
.947
[24.1]
.383 [9.7]
PC MOUNT
.276
[7.0]
Mounting Detail
.197 [5.0]
.197
[5.0]
.060
[1.5]
.341 [8.7]
.197
[5.0]
.060 [1.52]
(4) PLS
.197 [5.0]
CAT. NO. 7789 (No Screw Supplied)
CAT. NO. 7697 (Screw Supplied Unassembled)
Mounting Detail
.209 [5.3]
.197 [5.0]
.341 [8.7]
.276 [7.0]
CAT. NO. 7791 (No Screw Supplied)
.073 [1.85] DIA.
(4) PLS
CAT. NO. 7699 (Screw Installed & Captivated)
.073 [1.85] DIA.
(4) PLS
CAT. NO. 8174 (Screw Supplied Unassembled)
30 AMP - VERTICAL
HEAVY DUTY
PRINCIPAL FEATURES
• Compact, heavy duty design
• Six snap-in legs for total stability
• Serrated top surface secures connection
.060 [1.5] (6) PLS
SCREW
.310 [7.9]
.470 [11.9]
10-32 x .375 [9.5] L.
SCREW
.507 [12.9]
8199-6
.060 [1.5] (6) PLS
.250 [6.3]
• Combination drive, binding
head screw
.210 [5.3]
.276
7.0
8196
.470 [11.9]
.453 [11.5]
.197
[5.0]
Mounting Detail
.394
[10.0]
SPECIFICATIONS
SPECIFICATIONS
Mounting Detail
Rated: 30 Amps
Terminal: .032 (.81) Brass, Matte Tin Plate
.394
[10.0]
.276
[7.0]
CAT. NO. 7786 (No Screw Supplied)
.425
Rated: 30 Amps
[10.8]
Terminal:
.045 (1.14) Brass, Matte Tin Plate
Screw: Stainless Steel
.410
[10.4]
.205
[5.2]
.410 [10.4]
.425
10.8
.205
[5.2]
CAT. NO. 7787 (No Screw Supplied)
CAT. NO. 8197 (Screw Supplied Unassembled)
CAT. NO. 8199 (Screw Installed & Captivated)
.197
[5.0]
.226 [5.7]
SCREW TERMINALS
.718
[18.3]
7699-6
.076 [1.93] DIA. (6) PLS
.101 [2.6] DIA. (6) PLS
CAT. NO. 8196 (Screw Supplied Unassembled)
COLOR CODED SCREW TERMINAL SELECTION GUIDE
Color Coded Screw Terminals
provide:
• Quick identification
• Visibility for field service
troubleshooting
SPECIFICATIONS
Combination Binding Head:
Standard screw is Brass,
Nickel Plate. For painted,
color head, add suffix as
shown.
COLOR SELECTION:
Select desired screw terminal
and add color suffix to the
screw terminal Cat. No.
HEAD COLOR
RED
BLACK
WHITE
BLUE
GREEN
YELLOW
NICKEL
6-32 x
.250 [6.3] L.
THREAD
• Available for screw terminals where noted.
Tel (718) 956-8900 • Fax (718) 956-9040
(800) 221-5510 • kec@keyelco.com
SUFFIX
-2
-3
-4
-5
-6
-7
none
CAT. NO. COLOR SUFFIX
Ex: XXXX
-X
7699-6
8199-2
7775-4
7701
7693-5
7692-7
7700-3
Refer to page 133 for color screws only
RoHS COMPLIANT ~ ISO 9001 CERTIFIED
www.keyelco.com
31-07 20th Road – Astoria, NY 11105-2017
67
很抱歉,暂时无法提供与“8199-6”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+7.58160
- 200+3.02400
- 500+2.92680
- 1000+2.87280
