ZEROSMOGTL
ZEROSMOGTL
    ATG
    FUMEEXTRACTIONUNITWITHH13FI
ZEROSMOGTL 数据手册
PROFESSIONAL Product Information Zero Smog TL Code No.: FT91013699N Benefits Automated filter change notification system Easily operated and easy filter replacement Longer service life due to exceptionally large filter surface For connection to a WX / WT station a WT Hub is needed Taking you to the next level in removing dangerous gases and particles In addition we recommend: Fume extraction devices Soldering Irons Cleaning Consumables Preheating plates PROFESSIONAL Product Information Technical Data Dimensions W x D x H (mm) 335 x 330 x 445 Dimensions W x D x H (Inch) --- Weight (ca) in kg 9 Voltage 220-240 V (50/60 Hz) Heating output 120 W Noise level (distance 1 m) dB(A)
ZEROSMOGTL 价格&库存
很抱歉,暂时无法提供与“ZEROSMOGTL”相匹配的价格&库存,您可以联系我们找货
