WT1N
WT1N
    ATG
    WT1SOLDERINGSTATION90W120VN
WT1N 数据手册
PROFESSIONAL Product Information WT1 1-Channel Power Unit, 95 W Product no.: WT1N Benefits High productivity (Power unit with 1 channel, 95W) Intuitive use thanks to clear menu structure Reduced footprint thanks to stackability Grafical backlit LC-Display High performance and functionality many connectable tools Automatic standby of tool thanks to integrated acceleration sensor in the tool (WTP90 only) Housing cover useable as storage OFF time, Prozess window, Lock function, Offset PROFESSIONAL Product Information Technical Data Dimensions L x W x H (mm) Dimensions L x W x H (inches) Weight (approx.) in kg 149 x 138 x 101 5,87 x 5,44 x 3,98 1.9 Voltage 120 V Power 95 W Channels 1 Temperature range (depends on tool) °C Temperature range (depends on tool) °F Temperature accuracy °C 50 - 450 150 - 850 ±9 Temperature accuracy °F ±17 Temperature stability °C ±2 Temperature stability °F ±4 Equipotential bonding socket Display Via 3,5 mm pawl socket on front of device Backlit LCD Air consumption l/min --- Operating pressure in bar/psi --- Capacity l/min --- Vacuum --- Weller Tools GmbH Carl-Benz-Straße 2 74354 Besigheim Germany Phone: +49 (0) 7143 / 580-0 Fax.: +49 (0) 7143 / 580-108 Email: info@weller-tools.com Web: www.weller-tools.com
很抱歉,暂时无法提供与“WT1N”相匹配的价格&库存,您可以联系我们找货
